- will RS4 oil cooler fit A4's? i suppose it would need a different sandwichh plate?
- what do you think of this badge?
- Anyone manage to get to the bolts on the oil return line at the turbo?
- best intake for 2000 1.8t a4?
- what do you guys think of this?
- airbag light after weeks in the cold
- last night was a bit chilly
- I have searched but I didn't find what I was looking for...
- "T" fitting for tapping the fuel pressure regulator for boost gauge...
- pretty bored so i took a pic to tease u guys
- Dash Oil Light Comes on (and then off after a while. Intermittently)
- Low Boost AGAIN!!
- Boost leak - hooked up air compressor, can hear air coming out of something right next to the water
- how do I remove the old oil feed line?
- It's 30F outside, car is dirty, how do you wash the car when it is this cold??
- Pro Imports fixed my clutch problem today. The clutch was down to the floor
- Clunking sound at low speeds when wheel is turned all the way???
- Power Stearing Groan
- ALRIGHT!!!!......I want lots of modified A4 pics....lets have em
- LLtek messh... is it plastic or metal?
- Anyone experience this; My car sounds like a squeeky tank
- anyone have an intact xenon bulb that doesn't work anymore?
- Tie Rods stuck HELP!!!!
- suspension installed, pics
- VAG
- Castrol 10W/30 Motor Oil: O. K. for my 1999 Audi A4 1.8TQ?
- When I test my ICV valve, is my car supposed to be running, or just have the ignition on?
- x-post: 1.8T question
- what is the best alarm system for your audi's
- bout to change my buddy's tbelt on his 2.7 a6
- Car wont start!!! Any ideas?
- Reposting for you guys...My ABS brake warning light beeped but I didn't brake hard at all...
- DTC Codes - Anyone Know?
- So I finally got my wheels mounted
- My car feels down on power...help inside...
- $306 to put new brake pads on?!? tell me i heard them wrong..
- Anyone know where to buy Motul 600 on a sat. in the OC? Please?
- what's with these weather forecasts...
- F'ing great.....fixed one thing, broke another
- Reminder: Central NJ meet tonight 1/10 at Arthur's tavern 6pm.
- headlight bulb spring clip part available separately?
- Bumper shocks??
- need some advice, engine possibly seized
- Wow this place is slow at this time...
- HELP! Car sputtering
- will turbos from an a6 2.7t fit my a4 2.8?
- Do you guys warm up your cars in the morning?
- pic request- Audis in motion- bodyrooll, just cruisin etc, please post
- Not my auction but this seems like a great deal for 18" Oettinger Rims and tires
- 2turbos1mission, email me about tires
- P6's coming off. Want them?
- FORCED PERFORMANCE BIG28
- Brr.. Its a cold night in PA!
- Have vagcom, need codes to reset airbag light.
- '02 a4 w/ sports....18's or 19's?? help!
- I find it amusing
- did my pic show up? if not how do you put a picture in your sig?
- Wiring a 97 Bose system to an aftermarket head unit
- thoughts on the V&S shifter
- Rear power outlet mod... help please!
- just when i thought i had audi everything
- Ricecop Audi Accord
- Anyone have the lower grill inserts ( L&R) for an 01 stock bumper?
- Repost. A8 rotor upgrade. i checked out the model for the part number in the tech article
- in really cold temps (sub 15 f) will the a4 "burn" or use, extra antifreeze? or am i leaking??
- WTB 98-00 tail lights... anybody?
- ECS Adjustable coil over suspension kit for B5
- quick question: what size is the stock tire for 99.5 audi a4 qt. w/o sport package.
- models
- Projektzwo P1 17s. Anyone know of a set? Thanx in advance.
- does anybody know what power a 1.8t fwd makes at the wheels when standard?
- Normal engine oil temperature in 2.8 30v
- been over a year since i left forum...got my bro to get an 04 1.8t cvt...questions
- how much could i expect...
- Fuse Box Diagram
- Buying new wheels old ones 4 sale
- yeeehaw...oil change and chip change in 30mins, in 6deg F weather.
- Dead battery... again...
- OT - has forum stats been released for last year? =)
- 60mm A-pillar pod?? Do they make it for Audi?
- What R these side skirts?
- GIAC: very happy to report, 2nd day, the idle problem gone. Now the idle....
- i think my APR chip died?
- HELP: Left my car to warm up this morning and when i went back down to leave it had killed itself...
- For those who have purchased the ECS timing belt kit....
- Just picked up a 5-gallon container of toluene....
- HOOOOOOAHHHHHH Can't wait to install these! along with my grooved bilsteins....
- Anyone know of a site that has the bulb holders for 99.5+ taillights? checked 5 sites...
- Where can i buy S4/RS4 lower grille inserts???...
- On the subject of suspension design...why aren't shocks designed the other way around?
- Antenna Cable for Shark Fin (Cellular)
- Speedy Delivery: What did ECS forget???
- For the past couple of days my brake light has beeped and flashed ....
- A-pillar gauge pod complete (long)
- Another oettinger spoiler question....
- S4 Avant whith Superleggeras photoshop gurus
- ok, so i pulled the trigger and ordered this just now.
- Drove an Evo today on my lunchbreak..
- '00 A4 lighting options?
- Group buy on A4 Carbon Fiber Engine Cover
- Warning light for brake pads wear came on..
- dealer just called. pinion shaft blew through the axle housing, hit the muffler and broke rear diff.
- C pillar weirdness!!
- Anyone have their front windshield tinted? If so what percentage? Buddy is getting his 50% just
- Where can I buy a new ICV valve. I've checked Clair, but they don't have it.
- AudiGirl315 here.. looking for Silver Streakin
- As long as I'm replacing front rotors on '98 A4
- No more beep when I lock my doors. What part is broken? 9 degrees F outside.
- quattro IV
- Help! Exhaust question & Insurance on accident?
- anyone from Wichita Falls, TX. or surrounding areas??
- does anyone have a creaky steering wheel? how the hell do i get rid of it?
- Anybody encountered bubbling problems on the steering wheel?
- Well it's final...I'll be starting at DCH Audi/VW/Mazda in Maplewood, NJ on Monday...
- Boost Gauge in dash
- Why my car rattles when turning??? help.
- So did anyone notice your drive behavior chance after chip? I used to ....
- Will the 18" A8 Swing wheels fit 98 A4?
- Anybody here a member of the Audi Club North America?
- A little to cold for my taste!
- Oil plug!!
- 2001.5 (50k mi) 1.8TQM w/ sport, cold, bose, sunroof & auto dimming for $17,000+ for trade in
- Anyone want to sell thier Rieger v2 rear valence??
- Poll: Has your gas mileage changed signifigantly as the temperature has dropped?
- Talking about big turbo's.....long.
- OMG if any of you are interested buying an insanely fast BMW for CHEAP!
- [CV shaft bolts]- Anyone ever tighten these on the drivetrain?
- Milltek installed.....first impressions
- FFFFFFFFFFF!@#$%
- 2.7 Bi-Turbo w/ trans Drop into 1996 A4???
- Sold
- Carputer Install: Day 6 - BWW (mini-day)
- WTB: anyone have an extra passenger side a4 fog light ?
- Are Banker's Drafts safe to accept??
- car doesnt start after a few weeks in the cold, please read more
- Which control modules are under rear seat? What does "Air Bag" light mean?
- Repost for day crowd====Renn-Art group buy======
- Have you ever backed into a parking space, then fiddled around in the shutting off the
- Broken armrest.
- My window rolled down on it's own while I was at work, seat full of snow. This happens often?
- Looking for advice on Turbo Upgrade
- ho would you get out a snapped lug?
- Somebody should snag this...
- So I finally hi 60k....
- alcantara boot installed....
- Need some advice on Fog Lights that would fit on a reiger RS4 Front bumper?
- anyone want this wing?
- Very new to the forum, Want to replace A4 tie rod with S4 but...
- aeb guys w/ ko4....... what injectors are you using?
- S4 rear swaybar interests? ...
- Question about eliminating gap lines when reinstalling S4 bumper...
- V&S Shifter arrived yesterday. It's a shame to hide this thing under a shift boot.
- Let it snow, let it snow, let it snow...
- what is the description for this part 8D0-615-301-J its the A8 rotor but i need to know what Audi
- Anyone know a good Audi mechanic in Toronto??
- ITS -40 in Toronto today...A4 broke down...wont hold idle....(please read)
- autobody in Brooklyn, NY
- Putting my car on the ground.
- Spring install: Do it your damn self our pay a pro????
- Problems with rattling interior?
- Good mechanic in Queens or Long Island, NY?
- Good deal for RS4 bumper (so far)...
- Would the B5 exhaust manifold fit on a B6?
- who has the best mp3 player install?
- anyone know anything about " yamaha weddington classic" guitar plz let me know. thanks.
- now how the heck do i get something shipped to canada?
- Clutch replacement
- body kit issues...please read (kinda long)
- Might be purchasing an A4, please help.
- i just noticed a crack in my windshild (about 2.5 inches at this point).. questions inside
- A random $600 dollars falls into your hands.
- i remember reading that if we debadged and took the quattro off
- Good mechanic recommendation wanted in Northern or Central NJ.....
- 2000 Pedals?
- 95 miles down, 405 to go...
- I need tel # for audi assured roadside assitance in Canada? Please help! COLD OUT THERE!! Thanx
- Carbon fiber hood?
- I smelled coolant from the engine bay today.
- Was someone asking about this?
- Bonrath lower grill for B5 A4
- this happens to be in the back yard of a house I'm gonna look into buying!!!!!!
- What the heck is a sundade?
- wat's the size of connector.....
- Great, just great!!!
- which A8 do the rotors for the conversion come off? just i can't find 312x25 rotors anywhere
- Advice to fellow Noobs
- LLteks Hybrid BO/DV Valve
- dromo 1 socal carting event info
- My stainless steel hood strut arrived from Germany this morning.
- irvine, socal people - i need a shop recommendation for regular maintenance please
- Which turbo timer is everyone running and where can I find one?
- Suspension Install
- Major catastrophy -NEED HELP-
- WTB: Bose speaker grill for driver's side rear door, grey interior.
- RCA jacks for iPod
- anybody know of a brilliant black RS4 or S4 bumper for sale?
- STFA and I don't have Bentley.....
- Is there any special procedure for installing a new battery?
- >>>Renn-Art group buy starting<<<
- Need help getting ash tray Drawer out- Quick, My dash is apart
- does anyone wanna sell me an rs4 front bumper in silver ...mine got slammed
- Is it the ABS Controller or the Airbag Controller or both or neither that's under the rear seat?
- FVCKING DEALER!!
- What do you think I could sell my car for? 99 1.8TQ Avant, with extras?
- YAY! Baleeted!!!! pwnt ;)
- where is skene anyways? he bet his car that he wouldnt post til 05?
- Britax baby car seats -- too big for the a4?
- any 311 music fans? (this isn't off topic)
- ok..i can either get a free UUC shifter(hafta order sum small parts).....
- Already stfa and read bently.. Im having trouble finding out how to use special
- good books for learning about our cars?
- took this picture of some rice the other night...."Quality"
- In the light of recent n00b developments
- New 1.8t for my girl this past wknd. Looking for suggestions on 1st go mods
- Sweeeeeeeeeeeeeeeeet. V & S short shifter is here....
- My car is at 59500 miles and it displays that my car needs service soon.
- hit or skip? Aftermarket warranty for 5 years / to 100k on odo. for $1615 with $25 ded. per visit?
- so someone must like me... got a letter from aoa today, regarding replacement of coil packs...
- oy skene .. wanna sell your pes wheels? <nudge nudge>
- car is idling kind of rough and the check engine light is on... any thoughts?
- To Reggie: you were right, "Check Engine" light was caused by a loose gas cap. It was only about
- How do I make power?
- checking VAG codes w/ GIAC ecu..
- car audio for sale...2 infinity perfect 12's dvc in sealed box,audiobahn 1200W/audiobahn digital cap
- 1.8t.org audi/vw dealer ratings site gets 1000th dealer review
- Went in my car after a full day outside...all ice on the INSIDE of the windshield. What happened?
- Replace 2.8L Engine?
- Engine light...GIAC?
- Frustrating Trim (no, not that kind)
- Does anyone know A4Snow?
- shouldn't they tie it up or cut it off?
- 1.8t challenge vids and pics
- Repost.... Looking for some stock bumper grilles w/o fogs
- my car sounds very burbly in the low rpms.
- Anyone have the black plastic snorkel/intake tube that leads to the airbox they wanna sell?
- Anyone have a drivers front door bottom molding they want to part with?
- Problem with Tip/ shifter. Any others with same problem??
- I'm 15.875 and was wondering if.....
- Does anybody know where i can get the timing tools 3242 and 3243 (more)
- Cross Post: Who wants to race a B5 A4 in the US????
- STFA to no avail. Factory recommended service?
- Car won't start.
- anyone's air compressor (snowflake) not always come on?
- Valentine 1 radar detector...your experience & thoughts?
- New '00 1.8TQ A4 owner, chip programming advice needed
- Anyone have a pin code for a bosch ECU 261206318
- is it possible ?? (rear foglight question)
- anybody need a STOCK chip for an 01 1.8t?
- Avants - any pics of roller cargo-partition net in action? I did STFA but pics no longer come up -
- Now what oil should I use? I'm out of my stock of M1 0w-40 (old formula). thinking of going with
