- Hong Kong Beach Pictures (to AWOT!)
- a4 vs gti
- new toy I'm buying
- need help fast
- Welcome me to the Failed ABS Controller Club
- Center support bearing...
- Finally got a temporary host for the rest of my Watkins Glen in-car videos....
- Can 16" rims off of 2001A4 model fit 1998-99 A4?
- brake pads
- which big brake kit if any can i fit under 17" asa ar1's
- Anyone have link on how to replace BPV? Couldn't find in search...
- Anybody know the dimensions of the little area behind the ciggarette lighter? ...
- Has anybody seen that "How AWD works" page on subaru's website?
- Wheel Weight Importance
- To buy or not to buy... A new car
- xenon light out
- Day 5....
- So happy: completed the TB job today.....
- Any reason to buy the APR snub over the PureMS at double the cost?
- i just put my rims on
- Is this "QFrog's" ride .... ??
- anyone have a central propshaft bearing for sale...
- Question about Neuspeed chip
- My passenger side HID bulb sometimes doesn't start up
- who here runs slotted rotors/mintex red box...ne problems with pads gripping rotors...more
- UPDATE on can't shift into gears..PICTURE REQUEST b5 brothas!!
- Looking to sell my car....
- Quiet exhaust systems
- Sunroof assembly change?
- nothing to do... What do you guys have in minds for your next car?
- serpintine belt shaking when I turn on ac. should it be replaced?how do u adjust it.
- Phatnoise cable for 13 pin Audi CD changer.
- What are the use of all this "ENGINE TIMING FUSES" Located in the Fuse Panel?
- Specials on Achtuning parts for Waterfest show customers ONLY!!
- Can anyone point me on where to go to get my ECU reflash?
- conek&n vs normal k&n?
- someone please help me identify this part
- x-post:Water collecting in wheel well. I STFA and someone said it was the registration plate screws
- Repost, "Radio Code"
- Why haven't you left yet?
- Anyone make a custom intake for a 1.8t? I'd like just a bit of advice...
- Hartmann Wheels back in stock. ""Special""
- HELP! tank was a little less then half empty,i go fill it up,they do,it was $16 gauge says 3/4 full
- What tranny fluid do I need for a '01 1.8tq tip? TIA
- Has anybody switched their clusters/gauges...
- My HID's won't work
- Am I asking too much for my Stage III A4?
- Anyone with a c/f hood use it all winter (and really has a winter?)
- air conditioning charge value
- Weird whining/whistling high pitched sound comming from underneath the rear of the car
- Is Anyone Using this for their Big Turbo Setup???
- look at the first post ever since jetsa4pages turned into AW on the B5 board
- Also have a k03 (not sport) with 58k for sale
- 18010 - Power Supply Terminal 30: Voltage too Low -- got code need help
- Orange dipstick tube
- New Eibach springs for sale
- Friday! what is everyone doing this weekend? ill be heading to waterfest tomorrow in an ur-s6
- i passed an s4 today in 4th gear at 75mph...
- TECHIES: LEDs in turns, which wires to tap resistor into?
- Anyone have an extra reinforcement bar they want to get rid of?
- Sigh....I told myself I'd never get a personalized plate, but I did
- Another P/N request.....Phil, I'm looking for a B6 water pump.
- whomever was asking about the cd changer hardware....but
- whose got koni sport kit?? pics? like it? $550 isn's bad but i dont know much about suspension
- Anyone have an instrument cluster for an A4? 8D0919930LX
- You guys gotta see this ...
- need stock manual shift knob
- Anyone have an extra insert for a RobKnob?
- when i opened my hood today i noticed the intake vent? above the left side of the radiator was.....
- Public reminder: replace those 2 OEM clamps at the oil cooler.....
- Ah, so happy to be able to wiggle the turbo shaft and it only had very small shaft play.....
- Carbotech Brake Pads
- Oil Change >> Easiest, Fastest, Best in Connecticut?
- Where to buy a Passport 8500 Smart Cord???
- horrible new addiction... and its expensive too!
- HELP!STFA, I can't shift into gear. 2k a4 1.8tqm. Cluth slave cylinder bad????
- 17-18" Wheel-Tire Package, Sale
- oil chart....its in pdf format....post it in the faq in pdf format or change it?
- Dahlback Turbo Options (STFA)
- What is the highest mileage B5 S4 you would consider purchasing? and what price?
- Rieger RS4 Bumper needed ASAP $$
- took the silver 4 to the stealer for a presale inspection as requested by the potential buyer, $147
- exhaust smell and slight sounding leak from exhaust manifold? or Test pipe?
- I hate eBay
- AC Pulley Question
- When I engage the air con there is a clicking type noise from the engine bay. Is it a loose belt??
- Bored...here is my B5 to do list when I come back to the US
- My power door locks stopped working today ... and it is not the remote battery ....!?
- So everyone post your best interior pic.
- Anyone know of a place that sells a clear bra kit for a Rieger RS4 front?
- tinted and cleaned (finally)
- Cold engine damage
- clicking noise coming from engine bay
- KONI's!
- My AC went out and in AZ you can't live without, please HELP!!! Codes are:
- a4 bumper question
- Do we have a drain between the 2 firewalls?
- water leak drivers side footwell.
- Turbo Glowing Hot
- need a 6 cd changer, 8 pin
- check engine light is on!!!
- 2000 A4 Catalytic converter failed at 81,500 miles
- Bulbs behind the dash
- at low speeds im getting a pulsing squeeking sound coming from what seems like the front drivers ...
- STFA... best low-cost add-on to a chip?
- Kudos to ATP Turbo...x post
- Can someone please post a good pic of a sport steering wheel ('99 2.8).........(more)
- where's the link to the various model year specs?
- favorite short shifter?
- 6 Months into owning my A4
- 4s..........
- oil change time. recommendations on grade...
- OK, so you all knew it was coming...... the what's my car worth post.... *cringe*
- Anyone have any OEM foglights and grills they dont need??
- Brake Squeal!!!
- BJ Help...
- Carputer opinions
- Oil Viscosity
- So I swapped my '98 1.8TQ Tip tranny for a '00 and now it's going limp on 3rd gear...(m)
- Need help ASAP with code
- Qfrog - Need your advise
- Update and details for the SoCal TT Club Tecate Mexico Run! (non-TTers too!)...
- Will 99 S4 stock bumpers fit on my 99 A4?
- 2 quick questions: How to replace the breather hose/tube on 1.8T and cheapest place to buy a new one
- Drove through a 2.5' puddle - car running funny
- hey everyone, I found the six-fingered man (may be NSFW)
- Wife just called, car has prob, trying to do some pre-diagnostics.
- sure would like to find some Elf...
- Who's in for another Boston Area GTG???
- Had an interesting idea for a test pipe/cat today...
- ATP/Walbro 255 "drop in" fuel pump -->
- When warm, the car barely chokes to life during restart; rough idle - long
- Throw away X-Girlfriends Pics Or Keep For Memories? ... (just got married)
- saw a A4 today with unpainted glass body kit and fart can
- Is the Forge SMIC enough...
- 2 very important questions...
- How does bigger wheels and tires effect gas mileage?
- 1997 to 2000 drivetrain question
- anyone in MA or close to it with the right tools for the job...
- OEMEURO, anyone ever buy from them?
- Best TB kits and prices?...
- Breather valve pump / suction pump replacement question...
- new oil pump and cam shaft
- REALLY CRAPPY MPG
- AWE Tuning at Waterfest!
- Worn Brake Pad Light Still On (Repost)
- Timing belt in Connecticut
- Anyone have any thoughts on this noise?
- Timing belt > Shops
- Snap-On...
- my tie rod end finally came in, i know what my project for the weekend is.
- Sunroof opens
- Finally finished my suspension....H&R race/Bilstein sport
- Replacing my bad ko3 turbo on my 99 for a 2003 ko3 sport turbo- any concerns?
- dropping the car off at a shop tomorrow to get it proffesionally detailed
- 2000 A4 1.8T QMS oils?
- oh no steering...
- Intercool Hose
- Neuspeed 19mm rear sway....new for less than $249.98 shipped?
- I hate being high at work...
- whos a4 is this for sale in maine?
- Intermitten valve tap....mostly upon warm restarts, anyone experience this? solutions?
- Driving to florida
- What is this wheel drive? The one in the red circle. TIA
- Anyone running k04 without FMI? Programing problems!
- Second Flasher Failure. Where is the 01C designation? TIA
- Going to get my new tires mounted today!
- .Rear wheel bearing...
- i hate the mornings when you're late to work and don't have the time to sit in your car idleing
- Picked up a used A/C compressor yesterday and was wondering...
- how old r u guys?
- Got My First Speeding Ticket - Wooooo!
- Bilstein Sprintline Kit - A question... Please help a newb!
- An owner's worst nightmare...Timing belts :X
- what site do you guys use to host small car videos?
- Who was the guy that was looking for the pinout on the Symphony head unit?
- Worn Brake Pad light
- Ok, i did the TB adaptation (unhooked battery for 10mins, hooked up, key at "On" for 1 minute
- Just following up on a post I put up last night about 2.0 conversions.....
- ACNA NEQ Watkins Glen Video, 1 of 4
- Crossed drilled rotors, which is right & left?
- Can a ko3 sport from a 2003 fit a 99 1.8t?
- Anybody have the link to the quattro night video with the rs4 up the hill?
- Best decision of my life . . . .
- Tuner in Ingolstadt - Sigel / Sigl. Anyone heard of them.
- Just got my PhatBox from Clair, but cant download the disk on my desk top, any else have this prob.
- 1999 or 1999.5
- Brake Squeal - Mintex Pads - ATE Rotors
- A picture of the EVO and my newly aquired 67' GTO.
- We should add a comprehensive library for Audio systems with pics and set-ups to the FAQ...
- repost? s4 turbo replacement.... lots of work
- Being the decisive person I am..... I reaffirmed my love of the Avant today. ;)
- how much faster is a manual than an auto?
- k04 for 01 dbw?
- Bodywork question/revenge question (slight teen chat warning)
- paging yoeddy!
- What is the Engine leak detector spray G 001 800 A1 ?
- Control Arm Kits: Febi Bilsteins $480.00 or Meyle $600.00? please post your experiences with either
- Does the RS4 motor mounts include a snub mount???
- is my steering rack dying?
- turbo oil line heatshield sucks!
- Need help with Airbag warning light
- anyone in so cal selling a aftermarket exhaust?
- my shocks on my car are going?
- DIY painting lowers
- How do you tell if your car has can bus? Is it by the Analog or Digital clock? I have a 99.5 A4
- Help, A/C / aux fan won't turn on.
- Intercooler dimensions.
- ANYBODY HELP
- Could someone recommend me a place to get my windows tinted. I live in NYC. Thanks!!!
- Sorry, Another Off Topic (my other car)
- Anybody have a spare ECU (8D0 907 557 P) for sale???
- 2000 A4 1.8T---HELP HELP
- PES G2
- A4 1.8T Frontrak + APR chip = ??? 1/4 time
- Has anyone Installed an audi nav dvd RNS-E in a B5 Without the can bus?
- Pics from "Gatebil" in Norway. Many pics and some ww. 56K-grab a Snickers!
- FYI Made a run down to Delaware today on I-95
- one of the road deputies came into the jail today and talked to me about my car
- Is this steering wheel compatible?
- what do you think i could get for my car.....?
- K04 w/k03 programing?????
- How to Set Your Side-view Mirrors
- "yoeddy" please delete your post.
- So how many of you guys are planning to get ATP new kit?
- who is heading to waterfest this weekend?
- WTB: Anyone have a black carpet driver's front floor mat they want to sell me?
- Driver window not working
- If anyone is looking for a competition sound system for a B5 let me. know
- I'm in a serious debate with myself: Avant or Sedan (Quattro of course)???
- Is anyone here still selling the lower mesh grill inserts for the B5?
- Why are custom exhausts so cheap? Because ...
- If your going a constant speed, does the turbo work? Or is it just the engine?
- Does Miltek make an exhaust for Fronttrak Tiptronic for the 01 1.8t?
- engine stalling on a tip.
- Is there a turbo break in period?
- Borla Exhaust on 1.8t
- what is this?
- Purchasing a used car. This week. HELP!!!!
- Clutch showing signs of wear - Am I damaging anything??
- Just put the order in for the PureMS snub. Hope it arrive in time when I wrap up my TB job.
- co i think my oil temp. sensor is shot. im assuming its not a priority one problem.
- feel free to make fun of me. need help with water pump, can it be changed without taking off TB?
- Bingo!, I got the 6mm allen off, thank to spdrcrpete and Joey T, took a 12mm.....
- xpost from classifieds, OZ Superleggera 17x8 anthracite
- Question about tire size 225/50 R16
- Paging S7 :: Re: Your e-mail
- I'm replacing control arms *sigh*.. any brand suggestions?
- out of town w/o a jack...will a bottle jack do??
