- Do B5 RS4 replicas clear Stoptechs?
- Let the teardown begin
- question about front brake pads...
- i have question about boost pressure and cars going slow..
- just a few newbie q's
- replace both cv joints or one that is bad? I've found on website for
- ModifiedA4, please call WJM on his cell
- low balled on my car?
- Signals Lights
- Tick after timing belt change.
- Registration opened today for the ACNA/NEQ track event at Mont Tremblant
- I have an audi, I have an audi, I have an audi, hey, hey, hey, hey!
- So my engine is gone...
- [SAT Aug 12th] Special event for SoCal, Tour of the NEW Audi Design Center in Santa Monica
- How do you remove your front valence? How do you mount a front lip?
- Need a New Set of springs
- Has anyone painted polished SS before? I'm thinking about painting the muffer
- Crankcase Breather Hose (PCV Hose?) Whooshing sounds also
- Just had my car towed for a coolant leak..
- Competent B5 shop in the Boston area?
- X-Post from OT Forum
- Any idea how much the stealer charges for Alcantara door cards/inserts? Direct fit for our cars?
- new wheels
- other than $100, any difference between ATP test pipe and Ecode test pipe?
- Anyone from upstate ny, ticonderoga, lake champlain area?
- What are everyones thoughts on Aftermarket Coilpacks?
- Need help to bypass IMMOBILIZER...
- Silly questions on control arms...
- A/C is not blowing enough volume. I suspect the recirc function isn't working.
- which n75 valve came on 99.5?
- Water injection.
- with this heat, i might be tempted to do a very high heat CAPS run!
- Is it normal to have some play in the steering rack....
- EPL Tuned ATP GTRS Kit all done, and the car is running awsome.
- Help with leaking hose. Is this hose a hose for power steering or coolant?
- Is buying used Sway bars a good idea?
- antenna amp
- Is there a thread or tech article on how to"reset upper bushings/inner pivots"?Wth are they anyways?
- 1996 A4 2.8L 12V - Need a Catalytic Converter recommendation
- Just sent out my ECU to get chipped... : )
- Anyone have the new RS4 wheels on their car? Pics?
- Can A/C and Serp belt be replaced w/o draining coolant?
- Bad control arm bushings.
- aftermarket clutch and flywheel question
- Cruise control problems....
- Front Non-bose speakers
- Milltek or LaBree HFC dyno results?
- Best Gas Mileage Ever!?!?!
- antenna question
- side marker lights
- Some pictures from Sunday's control arm and Shock install at Kris's house..(the curse)
- Neuspeed.com: Ordered a set of Berus from them last Thurs, now website is DOA! { B-( .........
- Grooved Bilstein guys.. how many grooves down - front and rear are you?
- took out BPV to test, and noticed drivers side motor mount leaking it's purple vitals :-(
- new N75 H Valve WOW !!!!!!!!!!!
- I've changed the shocks it rides a lil better but still rough
- ok... so not much of an update havn't had much time to be building things
- Who's had to cut their bumper to fit an FMIC?
- Anyone here want to sell/trade their aluminum interior trim for the wood from a S4?
- Clutch install....
- Getting that stretched look with a stock rim?
- What did I get my self into...
- Did some "work" on my interior tonight......
- Pics of my A8 rear brake upgrade...
- Today's driveline upgrades!
- Condensor won't turn on, neither will the recirc. Condensor symbol turns on though?
- Anyone ever do the Audi Factory tour in Germany?
- New Oettinger REs in Charcoal Silver (x-post from Wheel forum)
- 2001 A4 1.8T Alternator Issues
- Thank You FedEx and my new friends at PureMotorsports
- audi a4 1.8t quatro year 2000
- Back from the UK to find my k04 waiting for me and my ATP mani at Jet-Hot ready to be coated...
- anyone have an extra central locking pump for 99.5 for a straving college kid?
- My car is having problems starting.
- On FWD cars, what kind of tire rotation schudule should one follow?
- Cross post from B5 S4 forum.
- Diverter VALVES e-bay
- Driving Experience Poll: Driving Schools or Events
- What else could cause the door to be off its mark when shut?
- will 245/35/19 tires fit on a lowered a4? offset is i believe 35
- Am I next in line for something to happen? Kris's little girl just broke an arm off a trampoline...
- Can someone suggest a place where I can get replacement lower door moldings?
- Anybody use the "NASA" wheel repair method on gunmetal?
- Interesting development this past week with wifey's A4........................
- STFA and couldn't find an exact answer to my HID problem.
- Stereo ground wire location on 99.5 A4? I stfa, no luck.
- Next Upgrade??
- Thoughts on these for the B5? the simple style I always found attractive..
- Pricing on a 2001 Avant
- A4 radiator automatic transmission cooler hose connections different
- Am I on some kind of blacklist somewhere? I responded to a couple classified ads (not AW)
- I won some track wheels/tires from ebay
- Squeaking windows
- Cleaning out my garage
- Can someone please tell me why.....
- CV boot replacement or complete axle?
- I need to put a new CV Boot on. Is there a specific 2 arm puller that I should get, or will any work
- Which B5 to buy?
- Got stuck yesterday, couldn't finish CA TRE and springs...
- Got rearended today.
- which ox sensor?
- Xenon auto level acting up (car getting lazy eye), any one else encounter this problem?
- Crack in windshield
- Repair manuals: For the record, Bentley is the only real choice....
- [sorry about the language] has anyone sucessfully attached a dimmer to their boost gauge?
- Ecru armrest... what parts, and what sources?
- Looking to help out my A/C system a little a take a home install approach to the refrigerant lines
- Part number/name request - interior door jam
- Wow, I tried to be friendly and ask how your b5 related fixing went, and you lock it?
- So Kris and Joey... How'd it go? Sorry I couldn't make it.
- Hesitation at low rpms and surging at 3300 rpms...
- Replacing clutch, today....
- nunnya.....were you at WW?
- Loose A/C hose conection
- If u replace ignition switch, do need new keys?
- A-pillar covers are not all the same.
- Where is the vag com listing? I am sick and tired of getting emails from random people who just want
- Where to find Audi Technical Service Training Self-Study Program for B5 A4?
- Tire/wheel shipping suggestions?
- Sounds like something is up with fuel pump after driving, if i open gas cap, lots of pressure is...
- New Brakes
- COOLANT QUESTION Audi A4 1.8T
- replacing all 4 tires
- License Plate
- Kris-
- Has anyone ever tried making a center vent mount for a V1 remote display?
- Sluggish Throttle on 2000 2.8
- I STFA - Flashing Brake Light/Beep
- wow, Motul 300V Motorsport 5w40 seems so thin compared to any other oil I've ever put into an engine
- What 17" wheels are people running that will clear a Brembo 332 brake kit?
- paging audi junkie: is valvoline maxlife 10-40 good?
- I found the suspension creak...
- Track pic - photo by sideline sports photography
- 1999.5 a4 avant going to canada
- What's it worth... '97 A4 1.8tq
- installing S4 rear brakes today. do I need any washers to space the S4 carrier? or is this a bolt-on
- Anyone ever made a Drive Train Stabilizer?
- Do they really shift THIS bad?
- so I get the Southbend OFE stg3 clutch....
- VTB SMK777 - Those in favor say ban!
- 160000 miles and running great. Is there anything I should have checked
- Paging SMK777: You might want to rephrase your addition to the FAQ so it makes a little bit more
- Does anyone know where to get koni's rebuilt in socal around LA?
- Does anyone have an Ace Lola lying around size 17x7.5?
- ALARM HELP !!
- Think twice about disconnecting your battery with a 1.8t
- interior help please
- $18 000 canadian will get you a 10 sec. A4
- Goodnight, setting alarm for 3:15am to drive to VT to play Audi's with Kris, Unpimp & RallyVT
- Anyone know where to get a driver side fog lamp? I have broken screw mounts
- I can't figure out these sway bar end links
- VAG-COM Results for a 1.8t with neuspeed chip and changed turbo
- AC Compressor...help please
- is there a catback exhaust made for a fwd b5 2.8 30v and also ecu or chip
- Also got my lights installed. Pic of the fire smoke for QuattroJay
- The official: What should i use to clean out my stock smic?
- Anybody have a sport shift knob they don't want?
- compatibility question...
- I took the belly pan off to find an oil leak...
- 15-17 lbs sustained boost under WOT a little low w/ a k04?
- got rear ended today. not major, but it shifted my bumper in about 3-5mms on the drivers side
- What's an ECU from a B5 worth these days?
- TIP Collapsing or Engine Load threshold?
- Stock turbo is goin....
- Question: Do 97' A4s come with a factory film tint? (one that needs to be removed before tinting?)
- Would a TBA issue throw a Check Engine light? Yes I STFA's no luck
- Can I buy new ones of these or audi sell something similar in a repair kit? Part Number Request
- i've heard about someone having the sides of their carbon hood painted...
- ignition switch
- 99.5 2.8QT 79,000 mi Engine Temp guage was a little high last night -- just a hair past half way.
- What settings should I set my Koni shocks to? I'm using Vogtland Club Spec springs
- A fellow AW Member mentioned that it can be done wanted more info
- Brakes... Odd
- 2.8 30v Thermostat: Did Audi change from 87C to 92C T-stats between AHA and ATQ?
- Boo-ya. My Firebird was on Autotrader for 4 days and I just took a deposit for it
- ONE free bent valve
- When doing a boost guage you tap into the FPR hose that is like 6" long right?
- Can anyone use a new green temperature switch or stock non sport sway bars?
- Finally got my S4 H&R c/os aligned and dialed in. I'm very pleased with the results
- Paging: Unpimp, Kris or Rallyvermont....... question for you.......
- Washer reservoir leak.. want to fix it today. i will check back for posts. the leak is definitely
- NEED HELP: I'm desperate...(stalling issue)..
- Edgeracing - Not only was the order shipped late, I recieved the wrong rim entirely!
- Emmissions testing, facility cannot connect their computer to OBD on my A4
- Anyone buy these?
- PES: manifold to turbo bolts - specs? Looking for stronger bolts for new cast mani..
- Does the AWE center vent only take 1.5hr to install? More? Less?
- Ever heard of using motor oil instead of gear oil......
- Electric Fan finally working
- finally got a chance to taker a picture with the coilovers installed...
- What FMIC is on this A4?
- Update to my situation from yesterday - WJM gets a cookie BTW....or beer
- How to clean ABS sensors (front)
- Will upper spring perch from Passat fit an A4?
- need to VENT abt creaks
- Car stalled out on me and would not restart after cranking it several minutes..
- I have a HID that keeps going out when I hit bumps....
- Recent engine bay pic...
- Hmm, my car still blows white smoke after sitting for a few minutes while running
- White A4 RS4 rims.
- Crankshaft Vent Location on 2.8?
- Question for the few guys who have gotten a CEL from a Labree HFC
- Hot Damn!!
- Bad News of going to Rerverse while MOVING, tiptronic....arghh
- I just pwned the kid at the parts counter
- could any body tell me what this part number is from ?
- Question: LED in my boost gauge is brighter than balls.
- God I used to be a dumbass . . .
- What type of oil pressures do our cars run?
- I have only 10.6 volts on my dimmer wire. Anyone know why that may happen?
- Anyone run S4 side skirts w/o changing the lower door moldings? I might throw my S4 sides on....
- Part Number Req: ATW N249, CEL & P1287 17695 Turbocharger bypass valve open
- Update:
- Module Masters Here I Come....
- Stebro....Yay or Nay for exhuast?
- Brake change.... must bleed?
- The two plastic pieces under the front of the car...
- Is my CD Changer cable bad?
- I just got an APR chipped ECU for my buddy with a 99.5 (nDBW) and I have a question.
- Thottle Valve Controller Code, I never ends with this car please HELP
- Who here has H&R Sports with Koni shocks?
- possible wheel bearing?
- Wich washer fluid pump should i buy from ECS?
- Put the rims on. I'll get some day pictures tomorrow.
- chirping noise from brakes
- I need myself some....
- Think I could sell her quick for 15k?
- in light of failing turbos and such.....I bring.........
- ModifiedA4: A follow on question about SJP & PCV valve
- parts and labor breakdown for struts and shocks for 01 A4 sport
- Boosting Problems
- LLTek having some kind of Blue Sky Blowout??...
- So what kind of Crappy Dino Oil should I use during my AutoRx treatment? Autozone Special? Castrol?
- Can I beat on the pinch bolt with a sledge hammer?
- does anyone have a picture of the awe turbo vent gauge at night?
- HELP!!! Where is the water drain for under the battery. Im full of water right now.
- Name that coolant leak...
- How to paint a stock bumper part 1:
- Rear sway bar link replacement...
- About to make a purchase from Audone... Vouches? :)
- Poor A4 stripped of it's headlights yesterday....
- Brake Bleeding/Flush
- Seems as though edgeracing doesnt want to answer their phones during 'Normal business hours"
- Looking to swap a stock CH Ecu for an APR chipped one
- Toyo T1s/T1r
- 2 tires need replacing...
- audi car phone
- Questions on 96' Mods
- 96 audi cd and or ipod
- WTB Front License Bracket
