- REMINDER: NorCal Audi Club Lunch TOMORROW at St. Johns in Sunnyvale @ 11:30am
- Part number for left and right tail lights on an 01 sedan anybody? Also for the passenger mirror.
- Time is valuable; I only need 1 minute, please read.
- Warning Light Question - Please Help!
- 17" or 18"???
- X-Post... Weird "Kingdom of Yahshua" Audi spotted in Burlington, VT
- New car pics & PShop request, TIA
- Need Help with boost gauge....
- 1996 audi a-4 door protective rubber strips
- mirror mounting
- voltage problem?
- Audi or Lexus?
- Rattle in 98 A4, sounds like the sunroof...
- turbo xs h-34 bypass valve. please read
- Well, add another notch of praise for the strat short shifter. it's great.
- True or False...3 Hours to fix a seperated cat??
- Optimal wheel size .>>
- When you see these pics, can you tell me what do you think happened? ANSWERS...
- A4 steering rack leaks...
- 98 A4 does not fall under ingition recall?
- Question about who covers repairs after a recall repair has been done...
- Those of you with S4 coilovers?
- Jim Sklenar? gas pedal mod?
- Alright.. what the hell is draining my battery? (edit)
- I'm having an issue with the shifter on a 99.5 A4 1.8TQM...
- Underbody repair, need to texture surface prior to painting!!
- New subs finished with polk/momo
- Information Display Screen Lights Out
- timing belt & water pump for 2001 A4 1.8TQ
- Took my center console/dash out and now i don't have blinkers..
- Sunroof stopped working altogether. No response when the switch is moved
- repost for morning crew: 50k suggestions and extended warranty options
- Carfax Help Needed...
- what is the proper tire size for atp flash 17x 8 thanx.
- Lower Door Trim
- Kenwood CD Player Install
- Reminder - Local GTG in Burlington, MA tonight!!!
- indoor mods. Storm so i aint going outside
- Attenion NOR CAL audi drivers
- Finally got the car back after 2 months in the shop, here's some pics of the new rieger bumper...
- 3in exhasuts with a magnaflow and no res.=
- Heel/toe shifting...what is it?Why? and how?
- few shots of me and my buddy's gti from the other night. both cars were pretty dirty but...
- runnin hot
- tie rod end replacement problem
- New sig options...
- it feels good to wear this again
- 2.0 TFSI, would it fit, if we're unlucky enough to need engine replacement?
- Car should be ready tomorrow! 2:1 that it isn't until Tuesday though:(
- 2006 A4 Spied. Gack....the trapezoid is here!
- CV Boot Job: need help, I could not knock the bearing off like tech article described
- Today's adventures... (see that off-topic symbol?...ignore this if you ain't interested)...
- Nice or Rice?
- need help in the middle of an oil change...
- Maybe a dumb question but..........
- How much should I sell my car for? <Info inside>
- Do you have to replace the sensors when replacing brake pads at 58k?Getting stealership to do it but
- what lip is this a knock-off of?
- Any Pics of black b5 w/ 18" Flik Justice - Anth?
- anybody know where i can get some cool audi photos
- got my 50k service coming up..what should i ask to get fix/replaced
- My first shot at a signature ...
- any solution to acid rain yet?
- LOL is it possible to register with a tuner for my wedding??
- If a '98 A4 did not come with the switchblade key, can the key still be programmed with the stock...
- Anyone with basic mods(chip,exhaust) have oppinions on awe stg 1or2 clutch w/ lightweight flywheel?
- retrofit 2000 center armrest into 97 a4
- My frusturation is over. This rocks. And this post has no purpose.
- I really need a pipe bender in my life.
- acidtone
- Any mods for 1997 A4 2.8 Quattro?
- control arm lube?
- Opinions please: repair or not?
- any ideas for inexpensive mods i could do?
- How reliable are the automatic transmissions without tip on the B5's?
- Fuel Delivery Problems (need advice)...
- Painted Lowers vs. spending the $$ for S4 sides???
- How to put in PUSH START -Searched - found no good answer
- Anybody know a good place to get Projektzwo body kits online?
- got an airbag light today, probaly the connectors under the seat right?
- any other 1.8t owners get a letter from AOA today about warranty extention for "turbo sludge"?...
- Adjusting an adjustable BPV/DV
- Looking for info before I purchase a 97 1.8T Quattro w/Automatic Trans
- I have to say one of the most worthwhile mods I've ever done is the AWE-DTS
- HELP loud huming sound coming from the rear when making U-Turns???
- Repair Manuel
- any body know
- in-pro tail lights melting!!!
- a lot of smoke at startup...
- Quick question about the Motive Powerbleeder.
- um....WTF
- does the 2000 a4 1.8t need round or square sensors?
- http://www.importpartsauthority.com/ anyone use them before?
- anone have any good tricks for keepoing IC hoses on....
- found tech article for o2 sensor mod, does this work for 99 1.8, i assume the article is for S4
- 2 piece Projector Headlight assistance needed
- my car got towed
- what would the difference be with a stock dv and an upgraded dv on giac chip?
- Steering wheel swap (4 spoke and 3 spoke)?
- Service Manual
- Anyone know the part number for Engine Coolant Temperature Sensor for a 1998.5 2.8QM?
- Noob question ...
- OEM Cd changer move
- Anyone with leather damage from moisture?
- Urgent chip help needed.
- AC is blowing fuses....
- resetting self-check display?
- I think my cat finally seperated
- started the TT dead pedal project tonight
- Floor jacks and side skirts - are they compatible?
- x-post anyone near Philly pa has a die 12mm 1.25
- a lap and change from the 1.8t challenge...
- please help me ....
- I found some copper based anti-seize today, should I use this on my control arms,...
- Today while driving like an arse I noticed something strange
- Selling My Car, Check the Classifieds
- Front Bumper question...No0b I am
- Here is a nice little vid of my boost gauge, boost is closer to 24psi.
- Anybody from PES around? Cant seem to get your site to work lately...
- Loud rubbing noise when turning, speed sensitive, not bearings and not tires, what could it be????
- Side Markers
- X-post: Looking for 1 19x8.5 Dronell M10
- You might not get all of this but check out this flash movie
- Shifter internals all messed up?
- Rear View Mirrors
- Attn chipped cars: What spark plugs do you use?
- who here has a modded pelican blue in MA
- I just redid all my vac-lines and I once again have an idle...
- clean car pics, nice weather enjoy =P
- any one using Nankang tires ? any review on these tires ?
- Brake Upgrades
- Odd ECU problem going from 1 bar back to stock
- wheel aligment
- service light
- Does anyone run Mobil 1 75w-90 in their tranny?
- Will an S4 bumper fit through my trunk?..(pickin it up from dealer)
- just bought a used kamei grill. need help finding some weather stripping...
- Moving: xpost
- LLTEK v. Achtuning prices
- Some action shots of the car on the track(1.8t Challenge) thanks to Tom.
- Tune-up time....
- 1997 Audi A4 taillight
- Todays my 20th birthday . happy birthday to me :-)
- G1 Intercooler V2 (and final) (BWW)
- update/problem...RKA? anyone?
- NEW information HID level changed to 5300K for
- gettin ready to hit 90 k, what maintance needs to be done and $$ wise?
- pics of my new oz superturismo gt's
- are these 2 error codes related? 18014 17544
- will the seats from a 96-01....
- What come with a Tune up...
- Kamei MESH grill for sale $70 shipped
- Doing my control arms next week. What kind of anti-seize should I get, and where should I pick it..
- Wife says no K04 for my 'cross country trip. ;-( --------Actually....
- xpost: Info for autowarranty broker users.
- quick favor please...what is the length of exhaust from cat to tips?
- What pressure to run 225/40/18 with?
- OFF TOPIC: late '60s muscle cars for sale q inside
- Curious as to Which is the best Brake Kit for the Money
- 1998 AEB ECU with TAP Stage II Software?
- Can somone make me a new sig for my birthday? :) ALL my mods and pic inside.
- Happy Birthday to Me! Engine is finaly back in the car!
- Garrett GT42R Turbo anyone here have?
- Got new shocks....help inside
- control arm kit, urgent!!!!!
- Pricing Audi
- Any boston area people want to do a cruise tomorrow night??
- where to buy k04?
- Anyone not using their Forge DV green spring?
- Car mod update. Wanted - side skirts.
- teaser: Officially home from 1.8t Challenge. No pics till later :) LONG
- Steve Schmidt
- ABT A25
- people wanting Sportec wheels I found a cheaper place to get them.
- Painted lowers on brilliant yellow....pics? Can't find any with search, any good pics at least. TY
- Well another 1.8t challenge turns into a huge joke.
- You guys might enjoy this......
- Anti-rattle Spring\clip for brakes - Part number request plz...
- K04 owners....
- Buying 98 Avant
- is Mccolloch HID kits really cheap and suck?
- Cannot find blitzsafe at autotoys. Anyone have a link?
- Updated sig,,, what do you think??????
- Rear windows child lock button repair
- Just Ordered and Plan for tomorrow if anyones interested.
- Oil service reset interval...
- wanted... Yakima cross bars and maybe a bike rack... already have the feet....
- question on how to downshift
- GT28RS pics
- smoke shows
- can anyone post pics of cars dropped 1.75 inches
- Which A4 should I get? Help me!
- Anyone know where to find driver side rear door shell?
- reasons for AC to stop working?
- Anyone have a stock shift pattern laying around??
- will a Labree DP work in conjunction with APR S3?
- anyone have pics of the 17 RS4 with spacers?
- FYI: 1.8T Oil Sludge Warranty Extension
- New sig again
- damn it....I lost my idle this morning...
- Hey Silver Streakin' happy b'day...
- Funny thing, I just notice Audi back down the required time for timing belt job. Now 75k miles.
- misfired, regapped to .032 drove fine, raced my g/f...
- wow a n00b trifecta...
- worst noob trifecta... evar.
- lol.... no one has the 3 lower mesh grills in their cars
- come on guys no one knows?
- grille
- Anyone here from Maui with custom color ?
- Today's "thing that has me pissed off".....idiots who can't take 4 seconds to read an AW classified
- Anymore info on Highline Wheels and there replica rims?
- Lighting
- Looking for 1 OEM 17" RS4 celebration wheel?
- timing belt stuff for 97 A4 1.8T
- uhoh....the ups man came!!!!!!!
- Tried to ask this before. Where can I get an aftermarket clutch for a 2.8
- has anyone experienced a decrease in mileage with Shell's new 93 oct V-power?
- Switchblade conversion
- Has anyone tried Mobil One 15W-50? Any difference from previous weight?
- Those with linear springs, what rate do you run?
- ticking sound...
- came out of work yesterday to find this.....
- questions on getting a new Audi A4
- learned somehting today at New Country about the oil drain plug...
- Turbo Question for the 1.8T
- What are the measurments for my 2000 a4 1.8t sedan speakers?
- Figured I'd RANT in here ..... I've victim of ANOTHER timing belt issue
- Can I run an apr stage 1 without a hyperboot DV...?
- Highline replica wheels...are they any good?
- Would 17" celebration wheels be a good track wheel?
- Charcoal Pollen filters
- where is the clutch master cylinder? under the battery??
- Anyone got an email for maggiobomb? or could he chime im?
- bulbs
- Average price for coilpacks? Places to buy?
- Night pic
- Rims
- Would anyone recommend the Chilton manual?
- ==>Good Audi Mechanic around San Jose, CA?<===
- Headlight switch problem/question
- Messin around with Sigs: Which is better? + New Pic of FMIC
- just got back from a week and a half in Australia... what did I miss?
- A4 Wiring Diagrams, Pwr. Dist, Performance, Cluster (Large JPEGs)
- justin517.....tell me more about the metaly, rattly noise when u let off the gas
- o2 sensor
- im looking for the clutch switch, another thread in my "car wont start" sage
- Stalling A4
- Well, happy freakin birthday to me. So, is the turbo covered under the 7/70 emissions warranty?
- HID group buy price lowered will ship next week
- where to get RS4 replica wheels....
