- Audi is replacing my wiring harness
- HELP!!! 97 tiptronic conversion question again
- Location of Ouside Air Temp Sensor?
- with the introduction of the b7 models. how much is the value of the b5 going to drop?
- anyone have a do it yourself write-up on installing shocks/springs on a B5 A4...thanks
- right when i start to make forward movement in first and second gear i get alot of stuttering...
- Slightly Bored.. so let's see em.. nicest pics of green cars for saint patty's day
- which fuses/relays belong to the power windows in the kicker panel under the steering wheel?
- anyone know what size hub rings I need for 18" Flik Artic's?
- what does it feel like when your clutch is slipping?
- Simple Green Question
- 2001 325i vs 1999 audi a4 (comparisons
- oemeuro.com
- 1 reason for poll,,,(inside)
- Poll: How long have you owned your A4?
- s4 front bumper?
- Few Projects Finally Done!!! Garmin GPS and Shifter Plate...
- Washington DC area timing belt change deal
- My new sig
- Need part # for passenger side lower grill
- Poll: 1st, 2nd, 3rd, 4th, etc... Owner of the vehicle.
- Anyone had bends removed from rims? I hear it softens the rim, and therefore will bend again
- Special Purchase 22lb 18" Wheels
- 97 A4 2.8 QM, how much do you think he can get for this car (NOT a for sale post)
- sporting green for st pattys day
- 2001 1.8t ECU -stock - CH
- anyone need 17" rs4 type celebration package wheels
- 98 a4 a/c problems.
- anyonw selling springs for a 97 2.8 Quattro?
- Ok, Im a little concerned that Audiworld has let "Import Tuner" place an AD here.
- does someone have a picture of where the N75/WGFV is located?
- is the problem my heater motor or something else?
- how long have the k04's been backordered?
- Would you get the Pure-MS snub mount or APR snub mount
- So I've been trying to diagnose a pinging problem in my 2001.5 apr chipped car. Original, I know.
- anyone have a cross section pic of the brake servo?
- check engine light came on for a second.....
- steering wheel mod
- Exxon/Esso "Oil System Cleaner"...
- AARRGGHH!! My car is such a POS....
- Valeo 1 piece question
- FORGE 007 : If Chipped what color spring is being used???? Green - Yellow or Blue..??
- Hartford County Audi Owner be warned
- Coolant Leak, Any Help?
- one touch windows no longer working.
- Airbag light - connectors?
- Does anyone have a set of chrome exhaust tips for the 2.8 that they're willing to sell cheap?
- Oxygen (lambda) sensor again
- Recode Mileage VAG COM Problem , a little help?
- Replacement Battery
- So my exhaust is installed and "sounds good" from what I hear.
- fooking hog ring pliars are the suck.....
- Should I risk ECS Timing Belt Kit if I have Extended Warranty (AA)?
- Audi can't diagnose my engine problem
- need options for 100 cel cat
- Looining for drivers side seat cover(butt part), onyx black, anyone w/info appreciative
- Is this catalytic converter failure??
- Are CPP control arms the only way to get some decent negative camber?
- replaced my clutch + pressure plate and tinted the windows
- What should I gap my plugs to on a 98.5 1.8T??
- Reasons why I hate audi seats....
- Any good looking side skirts for 200-300 dollars?
- how hard to change my own lower control arms
- Any1 selling or planning to sell an A4 in Ontario Canada.
- Are people planning to go to the Yarrowsport event in April? --->
- Front Swaybar bushing information...
- Climate Control Sensor's
- on the 99.5's: where does the cd changer mount? if seen side pictures and top mounts
- Questions about going big turbo
- Difference between '01 S4 and A4 Exhaust
- Not to jinx us or anything, but it's eerily quiet in here today.
- got the car back from the shop. alignment and tie rod end change 145$
- will RAD69 please pick up the nearest courtesy phone...
- God, I hate tip-toeing and asking for f**king permission at every turn at work.
- purchasing a m3 lip spoiler replcia
- Is it possible to do the independant fogs on a 99?
- pics of Volcano black A4 with RS4 body kit
- fan or pump running after shutting the engine off (searched but couldn't find anything)
- Yet another brake post
- is there any supercharger or turbo kits for 96' 2.8 quattro?
- LLTek is pushing a new BOV? I thought that they were bad for our cars...?
- Audi content must see to believe... Here is link Sorry can't post pic on AW... discretion advised WW
- neuspeed bilstein with adjustable perches....????s inside
- Can't see your cup holders at night? Here you go
- Remote Central Locking Upgrade
- Yarrowsport Dyno day update/reminder
- '98 A4 2.8 30V fuel problem
- People in the Madison, WI area, anyone going to the State HS bball tourney?
- What are my winter rims and tires worth?
- Paging Audi Juice...Clear corners?
- Can I adjust my parking / hand brake?
- Just got a reply from my note to the guy using RiegerAudiA4's pics on Ebay.."which pics?" Thats it..
- What to do next with 800-1000 dollars???
- shop just called and said that the tie rod is extremely tight on there...
- best wheel choice ideas, low cost if possible.
- Rant of the day
- Horrible creaking from seatbelt harness area. How to remove side airbag cover?
- Is there such thing as a K04-428?
- Question using Seafoam...
- Paging Matt@induktion and all other custom turbo owners.
- OK. Decided to repaint my entire rear bumper since we had it apart....
- when to change timing belt?
- shieht. car will go in the shop tie rod end wont come out..
- Tire size on B5
- Transmission Problem?
- I just switched sides.
- The lights on the tip buttons on my steering wheel keep cutting out
- K04 kit question
- pass side front door opens, but doesn't pop open.
- VW gauge lighting conversion???
- oil filter
- S4 tie rod on a B5 A4 ?
- anybody interested on a Falken 512's 225/40/18 only 500 miles on them and trade me
- What is the cheapest way to ship a bumper?
- Can't find fuse box..help!
- this is g&y but guys with lowering springs and sport shocks,,,what springs? ,pics and experience
- Rear bumper is pulled. Lower valance on the rear will be painted today.
- x-post from the NE forum....
- TURBO TIMERS???? are they worth it?
- Rear Left Brake Dragging
- Has anyone out there tried the helix auto 2-piece e-codes? How about purchasing through eurosport?
- Brake problems ... a little help, please
- Timing Belt
- woohoo! i get back from my ski vacation...
- People are TEIN Springs any good for my 2001 FWD? What shocks should I get with them?
- is exhaust system covered by the 4yr/80km warranty?
- Looks like somebody hit my car in a parking lot...
- Shark fin fenders- actually on a car
- Turbo is dyin
- why cant anyone get my wheel finish right?!
- Josh, do you sell K&N filters on your site? I can't find them.
- My car search continues. What would you choose? (inside)
- a4 1.8 pulley reducer kit, anyone have one
- Dahlback/O.CT tuning chip w/k04 software for 2001 1.8T
- Opinions please
- Hard choice on tires need opinions
- Well crap. I do believe my tranny's dead.
- Timing Belt Change -Prices in Northern Jersey
- Ah, Hidden EQ...found the answer
- my tie rod is driving me crazy, that thing wont come loose. i need some help please
- Help, just got nailed (but I think I may have a chance)...
- !!!scam in classified ads!!!
- control arm aluminum or steel?
- Vag-Com Question (Trying to clear a code!)
- anybody know an online retailer of Moda R6 wheels other than the Tire Rack?
- I've been contemplating useing Seafoam, did search & found some people who used WATER before
- Here's what I think is wrong w/ the B7 grille...
- Can someone please photoshop these B6 wheels on my car...
- 'Where's the *boost*?' lady pic. Anyone remember that?
- rolling shot of my A4 (BWW)
- Younger brother is looking for a B5, 1.8T or 2.8?
- Stock fog light has water in it. How to remove?
- Funny and true post
- Paging GilliamOS
- pulled on my door handle(inside) and it came loose. still opens door, but is wiggly
- So I've got these exterior chrome door handle parts... but,
- Is the police force in your area physically attracted to your pig of a car?
- $565 to replace an O2 sensor?? Please help
- I just got the "be careful, its the other guy you gotta look out for" lecture again
- boost pressure test
- RiegeraudiA4 is this your car?
- Can't wait to put on my new wheels
- suggested oil...
- re-post......gtg in SLC UT Sunday March 20th at Thanks Giving Point......more......
- Oil Leak, see pics, what are these parts that are leaking??
- Termperature sky rockets, don't know whats going on, afraid it will overheat
- Anyone selling 2001.5 1.8T, tip? NY area
- Wouldnt mind owning this twin turbo bad boy!
- Final ICM Statement
- Used b5 frontrak sport suspensions becoming scarce?
- Rear right suspension is squeeking
- 205/55R16 and 225/50R16 would they fit on 10 spoke stock rims?
- Yarrowsport Y2 event Apri 23rd-24th
- (KC) Reminder March 16th GTG at O'Dowd's on the Plaza at 6:30p
- Not mission critical however - question on interior
- my dad has been looking at switching this time from a a6 to the a4..
- EXHAUST
- just reset service light...and lock vacuum pump ??s
- STFA - 2.8Q Throttle Body Cleaning Write Up
- Update on fellow audiworlder Mike (shep1.8t)
- will h&r coilovers from a b5 s4 work on my 972.8 quattro?
- Time for clutch job?
- Is this a price quote high?
- Cost of new keys from Dealer (Q-Frog?)
- can somebody please verify how shady this is for me??
- paging kris hansen
- Tail light above reverse light replacement???? I'm at work and need to know what to buy, don't have
- Vote to Ban: 2Fat2Serious
- 55W or 80W
- those that are using it, where are you getting your silicone vac line?
- Paging Mike@PureMS: the RS4 motor mounts still available at all?
- Anyone tried Meyle brake pads from Blau Parts?
- Flik Justice, wheel opinions?
- Poll: Manual Transmissions
- Called NAPA about plugs. They have NGK 6437/BKUR6ET
- I would like to hear some current comments on P&P exhaust manifold
- Noob + FWD Tip x Power Braking x Neutral Drops = This
- cheapest place to buy ngk laser platinum PFR6Q?
- 01 A4, neuspeed chip, what n75??
- how hard is it to get a spare ecu for 2001.5 1.8T QMT5?
- Received my reimbursement for control arm repair from AOA today
- searched (forums and tech section) need a how to for going back to 2 piece halogen from ecode wiring
- anybody here from the nashville area?
- City Light Install
- Phil,,question about your mirrors...
- got an A3 brochure today.... looks cool so far
- Replacement center visor..
- Quick Q's: 2.8 30v researching exhausts...
- Huco ICM
- what to do to a 1.8t Avant mt5
- Cost of fuel filter for '98 A4 2.8? Where to buy online?
- Thoughts on putting used s4 street coilovers on an a4?
- MAF SHOT!!
- Air Filter-Holy Cow!
- Steering alignment in Maryland
- At what point are people replacing clutches?
- Ok so give me your opinion which wheels do you prefer ???
- X-Post from Mid-Atlantic regarding tinting my tails...
- idle problems
- stupid question.....turbo breakin?
- Help Me
- old timer roll call: where are you guys
- Considering a '97 1.8T as a backup car - searched the archives is there more to watch for ?
- Quick ques about engine..
- Pulled over twice in the past two days.
- M3 Lip with Rieger Roof Spoiler Pic..
- I've always wondered, whats more reliable, German or American?
- Timing Belt Etc.
- Replacing stock headunit question??
- omg look at what this idiot is selling..
- If a panel is not primed and it has to be repainted, would the clearcoat come out messed up?
- ABS still beeping ....
- Question about A8 brake upgrade from ECS
- Rear humming noise...
- Hi, anyone change to open intake kit, then went back to stock air box??
- Final ICM Question
- Going to use Seafoam tomorrow...
- i went to a body shop today to ask a question about lower black bumper.....
- Ok guys..need some help. Need a nDBW ECU for a 98 A4 -ends in 557P
- 1998 A4
- check engine light reset
- i saw a guy with a 05 mustang gt. i was pretty impressed. what do you guys think of them?
- vag 01192
- help please... real quick
- Thinking about buying a chipped ECU (more)
- NJ State Inspection this past Saturday...+ Rant!!
- If I buy BOSCH Platinum F5DPOR from the partsbin...do I need to gap it?
- Can the guy with the red slammed avant with 19's (supermesh I think) please post pics?
- who has HID Xenon E codes in stock? ecs doesnt, i know that
- Vag-Com Codes Help
