- Is the ski jump part real. they have a new version of that on tv these days.
- N75 question
- recommendations, please.
- The "You may as well shoot yourself" idiot light
- repost: but still a nice video..
- How much boost for .8bar
- Need help with VAG Code: 17965 - Charge Pressure Control: Positive Deviation
- What should I set my tire pressue at now that I have 225/40/18's and coilovers?
- Problems on idle (99A4Q 2.8 30V V6)
- How much ATF Fluid?
- GIAC K04-PC16 or APR Stage III
- Is there something wrong with the classifieds?
- THANKS CHAD@APR!!!! I got it today...
- Ok still have an amp problem...If i disconnect the front fuse the amp will come back on for a few ..
- my car redone
- lol... my new credit card look
- WTB: black ALL WEATHER RUBBER FLOOR MATS
- Thick white smoke out of exhaust on cold startup...
- Mobil 1 Extended Performance Motor Oil - 10W-40
- I wish I could get this hp gain from a K&N filter, and a Shnitzer exhaust
- Anyone know where I can a replacement t-fitting for boost gauge
- Broken Coolant Flange - Can a I use AEB one? i'm AWM
- B5 Avant moviespotting (might be a repost)
- upper arms done !
- oh baby...........
- I am the window tint master!
- I haven't realized how cheap B5 S4's are going for nowadays...
- 2.8 12v performance parts
- Stock size of REAR sway bar on FWD 1.8t
- Stock Wheels: Same for all years?
- Damn, slow night on the ol' forum. . .
- Just finished installing new rear brakes and pads (1 problem)...
- Already searched: need help removing front ABS sensor
- MD gtg this sunday
- Guys with HID headlights -- what size fuse are you running? (LONG)
- centervent boost guage vacum line
- Ok, I'm an idiot...
- Where to buy the pod for the vent boost gauge, so you don't have the look of the vent ...
- What other causes of steering wheel vibration are there?
- Which hose/tubing kit do i buy with the vdo? And what length on egauges
- Has a 2.2T transplant ever been done?
- I just recieved my car from the body shop.....
- haven't modded my car in almost a year now, pretty sure i don't want to put any more $$ into it
- Just bought a 96 A4, but is it alright?
- My ride has been PIMPED!!
- Will the new bigger Mann oil filters from germanautoparts.com fit old filter wrench?
- Starting Problems
- best place to get some rs4 or 2.8 engine Mounts?
- $55 later I have a brandi-new DBW accel. pedal... but STILL get a 18047 DTC! Urrgh!
- Finally made the change...
- Incident on the freeway resulting in cracked oil pan...
- Continuing driveline slop - suggestions?
- Sort of off topic, but this has VAG-COM potential. . .
- loss of boost, only 10-13psi now, and something rattles at WOT... ive checked vac lines and they
- vag cel 17544
- changing all vac lines and vac clamps, are there only the 2 vac lines on manifold? ...
- Rear window 1 touch up mod.....Help please
- Paging Phil(Qfrog): Tie rod ends 8e0-419-811 question
- SPP Now has Neuspeed Optican Flashing in House!
- How often do you feel the need for a suspension alignment? And how long after installing new susp?
- looking for ECU part number (important)
- Cleaning out SMIC and hoses connecting to BPV (any advice)?
- 059-919-501A correct PN for '01 1.8T Coolant Temp Sensor?
- Crazy Tire Kingdom deal.. 4 new tires free Black Berry. Well I needed snows anyway ;0)
- 2004 A4 1.8T- is this a good deal?
- Windshield is looking fairly pitted. Replacement costs?
- Need some help for a friends A4 quattro 1.8T
- Quick plug question, the copper plug most people use is the NGK BKR6E correct???
- Anyone know of a LWFW that would mate to a dual friction centerforce? no luck at all..
- Is me or does Audi look like they ripped off Edge Racing's FLIK Lex Wheels for the new RS4
- AWE Tuning increases warehouse space
- New TUrbo =)....read on
- Replacing Brake Pads, a DIY project??
- 3 servie questions... oil, brakes, fuel filter
- SO this weekend might the warmest one for a couple of weeks
- POLL: Who here still has a FULLY functioning trip computer display?
- Carbon Fenders, Rice or nice?
- its not right...
- can we use the red coilpacks from the B6/B7 S4?
- Getting a strange vibrating sound for a few seconds when I start my car.
- Nokia old car kits (CARK)... Possible to run 2 privacy handsets?
- what kinda solvent can i use to clean out the greeeezy CV joint?
- Ventilating the seats?
- Woot!!! Greddy FMIC ordered! Going to be a FUN winter!!!
- Is this all i need??
- when is enough, enough on our A4's???....more......
- I have a defective front left wheel bearing
- SPP EFK
- STFA about boost gauges, and i've decided the vdo will do.
- Coilovers being put on, Yeah!
- Help! Starter Problems.
- Upper control arms
- what happen if ur dv vac line doesnt work anymore, would it make the car buck and jump around?
- Recall?
- any tips for cleaning an old intake manifold?
- Woohoo! Its cold out!
- My turn for the limp tip selector, oh yay me....
- PERFORMANCE SILICONE HOSE KIT
- The snowflake made its first appearance this morning since last winter...
- sad day
- does anyone know
- Front blinkers just one second of your time
- passenger's side near front wheel: oil leak
- the intercooler man stopped by my house today
- Injector
- Headlight Quick Question
- I know that most of you are in love with iPod variants. Not just to be different but
- mileage too high for chip?
- 4Rings v2.0, what size/type are your wheels? Lips?
- Winter Tire Help
- Nasty knock..sounds like internals...
- Looking for the guy who intalled a Engine Start button into his pop up lighter a while back.........
- do more people have a mix and match K04 setup or one from a company, like AWE?
- ..........and we have rusting??????
- just finished ripping EVERY pink floyd cd to my phatnoise...
- i recently installed an aftermarket intake and now my car sounds like it has a bov..is this normal??
- I'm trying to figure out if my 19" I-forged Senekas would fit on a B5 S4?
- ok, sry if its been answered ... where to buy stock vacuum hoses other than dealership?
- Installation of the KT-SR2000 Sirius Receiver
- So once again my amp decieds to cut out for the day...It is really starting to annoy me
- TB finished
- for stock bov if i push up on the spring and hold my finger on the vac hole at teh top will
- if i am going to tilt the engine up a few inchs can i undo the engine mounts from the bottom side
- usually I boost @23psi but for those days that I loose pressure this is the answer.
- could be a dumbass question but....Will a FMIC screw up my smog emmisions
- smoked tails, how do i?
- Just a gentle reminder
- Need Help... Did anyone replace rear control arms because they were faulty? Or did anyone ever have
- Fresh Wash and Wax Pics.
- i may haved been scammed with a coilover purchase that was posted on AW classifieds..BEWARE
- Need any experience on AT 1.8t. My wifes just went out.
- Am I going feel silly if I put my stock rims on after I lower the suspension? For winter of course..
- ok ok i know lltek is a joke, but has anyone ordered their interior trim kit?
- Need a part # ASAP
- paging azndrunk.....
- GIAC chip compatability between years 97 and 99.5
- Madan....heres teh catch can!!!
- I was just wondering what the best vacuum lines are(strongest)
- A4 2.8 Engine Modification Ideas
- Help Engine not running right.
- Speedo and Rev counter off
- 1/4 mile database has been updated to reflect Tapp auto's 11.91 et.
- How much do you guys think a set of used TT carriers and A8 Rotors would be worth???
- My mud fetish unleashed. . . (BWW)
- immobilser fault on a4 1996
- Will autozone have vacuum hoses for our cars?
- I'm told my bumper has been painted
- When i rev the car and the rpm drops down a bit and i rev it again, it seems realy bogy
- Latest Bentley Pubs CD
- s4 wheel liner
- 1996 A4 problem..Engine stumbles, ck engine light comes on.....
- Does anybody have...
- A/C blower fan works sporadically
- For Qfrog Can a stock carbon driveshaft be replaced by a steel one?
- mike look
- can low coolant cause cel light? ...
- Opinions needed: Turbo upgrade
- Winshield wiper problem....
- Markbradford - YGM
- best place to buy stock ECU?
- If Random CEL comes on while driving ...
- Chip problem?
- well, I raised the car a little last night
- Begining of day 3 waiting for a response from Edge.
- Will Borla Cover this
- Will this vag-com cable work with a 96 a4 obd-2?
- so does the number of prongs on a spark plug effect combustion completion?
- Experimental Platform?
- Pinging noise coming from turbo
- Anyone running GS2X???
- Does anyone know if the front wheel hub behind the rotor is same in the A4 as the S4?
- Need some advice please...
- Custom Ipod Install
- How do we go about finding part numbers for our B5's? Is there a CD/manual we can source? dcc236
- My CEL codes... what do they mean?
- Carpeted Floor Mat (Front) What is the Item Number for Black Floor Mat ?
- External oil cooler users, WTF did you guys do with the coolant lines
- Just a few pic of new intake...
- Is it worth it?
- Update on seized/welded clutch
- hi, math 101?
- Finaly found "boost leak" its huge...
- thanks a lot, lazy construction guys
- Engine mounts shot...
- 2.8 12v for 97 A4, what motor oil does it drink?
- definition of ricers...
- who here...?
- Random cel light ...
- F7LDCR Spark Plugs
- PC-16 needs intercooler?
- So I got pissed off and ended up burning out of place leaving some nice 4wd...
- Installing 1-piece headlights on the A4 this friday
- everything is fine, nothing is ruined.
- Chippin a 2.8?
- Ign switch today by dealer,One arm and now tip shifts differently,reason?
- does anyone know the part number for the metal clip that holds the connector on the fuel injector?
- Cleaning textured interior plastic
- i think i figured out the whole incredible shrinking armrest cover thing.....
- First oil change!!! Piece of cake!
- Need to have an ecu recoded. where to get codes from?
- my new taillights (thank you ShadY12v)
- look what ups dropped off today
- Oh god. . .
- What do you think..pick up an 87 4000cs $600 for winter beater and fix the B5?
- need help removing front liscence plate mount!
- is it a problem to put 235-35-40s on rs4 reps??......
- quick question, where is the T supposed to be?
- xenon bulbs are D1S and light output is greenish/blue/purple
- Excessive AC condensation?
- Evo X. Not so good.
- what do i need for a good KO4 "kit?"
- this is so sad...
- Could it be possible that a front..
- some ppl are idiots
- great experiences with horsepowerfreaks.com
- anyone with an rs4 grill thats going to paint the trim??
- who here is from PA and has a friend that wants the v8 4.2 in his b5?
- A not so unresonable request (I hope). . .
- Big day tomorrow...
- So my amp problem fixed itself after i played with the wires...How do I reset the service interval?
- Polyurathane bushings added on my 98 1.8TQ.
- Will I rub?
- So, some bimmer guy on AWOT just likened the B5 to a civic
- Do I *really* need to clamp those vac lines? :)
- 1.8T - 4.2 Engine Swap
- If anyone wants top spin harnesses, order them through spp, there $20 buck cheaper currently.
- Surging under heavy load
- does anyone have pics of...
- How do you get the ciggarette spin mechanism out, ...
- Install S4 rear brakes on an A4
- Dyno results. Not earth turning, but I didn't blow it up...lol
- So its ranning pretty hard here and the ground is really soft. . .
- keith@APR
- Why doesnt Audi have a fail safe to prevent valve damge when tb breaks occur?
- Koni & OEM Sport Evaluation - 1 week
- How to Clamp my Map Sensor?
- Timing Chain A4 Turbo with chip
- almost that time again
- It seems that every 2-3 months my amp cuts out for no reason..Anything to check?
- Suspension Clunk / Bilstein questions...long
- Will B5 A4 Stoptechs fit on a B5 S4?
- Can a steel driveshaft be swapped for a carbon fiberone?
- Injector Question
- Torx screw on belly pan?
- SNOW wheel-tire Packages.
- what would cause a single cylinder to misfire?
- How much abuse does it take to weld a clutch together??
- Thermostat on a 99.5 1.8
- Alright gents (and ladies), need some help w/ some questions for those that know the '01 A4 2.8…
- PDA OBDII
