View Full Version : A4 (B5 Platform) Discussion
- Central Locking Pump - maybe?
- Preformance in cold weather
- Lights Signal won't change
- HID PLEASE HELPPPPP!!
- car cranks and dont start
- HOLY SH!T PUT DIESEL IN!!!!
- mechanic says oil plug is on too tight, can't change oil - ideas?
- What are the best aftermarket wheel bolts?
- Modulare Forged good or BAD?
- Speedometer woes
- 4 wheel disk mania
- Beating the dead intercooler horse questions
- Rear spindle going bad on FWD ??
- Help evaluate my climate control repair retro-fit plan?
- Oil Pressure Tap Location for Mechanical Pressure Gage on A4 2.8L V6?
- Delta Radio Question
- Spongy Brakes - What did I break?
- VAG COM in Chicago
- gurgling coolant noise & slow loss of coolant
- any experience with BlauSport shocks?
- License Suspended..
- is this an air bag?
- 2001 Audi A4 1.8t ...... my engine is oil is gettn mixed with transmission oil.
- Need to replace dash g56 temp sender. Where can I get one?
- Power steering fluid level
- Front End Chirping Noise
- car moves sideways when I hit a bump
- 97 Sport Package
- Factory stereo to In dash Nav
- No interior trunk lights working..
- MFS went bad after only 5 months. Transmission won't go into reverse AGAIN.
- Winter floor mats
- Ok....so now u got the code, how do punch it in???
- AIRCON NOT COOLING
- Still no solution for Oil Light Flashing - Other causes?
- coil pack question
- Engine vibration when turn on electrical accessories
- Rear Tie Rods?
- shakey idling engine
- Heater core - heat
- What logs do I use with vag com when fine tuning your big turbo??
- AU: Well she is finally built and alive...
- Need Help With Audi Part Number (Manual Transmission Fluid)
- :: ECS Tuning :: 94% OFF A4 FWD exhausts and more!!!
- Pricing help for 2001.5 A4
- A4 B5 AWM Tiptronic - Gear Shifter gets stuck in park...
- 2001 Leatherette seats
- water pump problem
- audi a4 stereo
- New Audi A4 owner needs help ...
- Problems with stereo
- A4 B5 AWM - RPMs at 70MPH
- Help with a stereo problem.
- Oil Light Flashing - Sludge and Sending Unit Question
- noise from climate control system
- Interior temp sensor--big spark bad smell. Where is the freaking thing?
- 1999 audi a4 1.8t
- part name/number question
- Hi New 97 A4 2.8 here...I have some CELs
- airbag light reset -> vag-com general help --in PA
- Whiny Wipers
- Brake pad warning light Bypassed
- Putting S4 Aero kit on the A4 Avant?
- Installing a silencer..
- Transmission issue
- Power Steering Fluid
- Climate Control Lights flickering, then off
- windshield washer
- ignition coil
- looking for a lower engine splash shield
- need the obd2 port pinout please
- A4 Quattro Trans Oil Pump Removal
- Anyone know Joseph Denning?
- Timing belt tensioner How To ??
- A 4 Interior Swap
- Driver seat and armrest needed
- *New site - Render 3D images of your A4 on TireBuyer
- Audi 2.8 Misfire Problem
- Noise coming from transmission on 99 A4 Q
- No heat!!!!
- EGR Valve and Vcuum Hoses connection
- M3 STYLE TRUNK SPOILER ??
- Driver control arm kit
- a4 b5
- setting time and date on 2009 a4
- 01 A4 1.8 Rough idle at start up
- Central Lock vacuum pump
- New Audi owner needs a few tips...
- turbo rebuild cost
- turbo install problems
- OEM fluids vs RedLine
- Audi a4 parts?
- Help with the turning lights
- DetailersDomain's Holiday Special 15% off and Free Shipping over $75.
- Conversion of rear lap belt to shoulder belt
- HID, wipers and other issues?
- :: ECS Tuning :: Holiday Giveaway 2009 - $8000 of Free Stuff!!!
- Extended Warranty
- audi a4 b6 2.5 esp quistion
- fuel capacity
- APTuning/APR Holiday Sale Has Begun, Nov. 23rd-Dec. 31st!!!
- Blue Can type thing? Help!
- 22,000 miles only - change timing belt??
- Help! Need advice on white smoke
- Interesting Article on Oil Viscosity
- anyone know a web page that shows oem wheel color codes
- 97 a4 left me stranded today... lots of vag codes....
- VMR Wheels | V701 Straight Spoke PRE-ORDER
- Converting rear center lap belt to shoulder belt
- Need New brakes, suggestions?
- Horrible gas milage and missing at Idle
- would blown head gasket or turbo seal cause error code on vag
- Funny Craigslist ad for VW
- VMR Wheels | Cyber Monday Limited SALE
- Source for 96-99 B5 Valeo style H4 E-Code headlights?
- Rear center lap belt -> shoulder belt
- I may be buying a '98 A4 Avant 2.8
- 1800 with rumble noise at 4500 rpm
- Transmission Control Module
- need new ignition coil or spark plugs wires?
- How long should wheel bearings last
- b5 2.8 30V coolant pipes
- Code po688 question Plaese help!!!
- parts # help
- Thoughts - Adjust throttle for car starting troubles
- AEB engine auto trany help
- hard start & rough idle
- a4 b5 1800
- Transmission build code
- question
- A4 Spring/shock Question
- Wrecked the front end need advice?
- 12V Accessory belt update questions
- leak.. dont know where its coming from
- ipod adapter problems
- What Tha Hell??!!
- Stuck ashtray redux
- Transmission trouble
- Heater Core leak-Please help
- humming noise or road noise bearing problem?
- Rough idle after front axle replacement
- :: ECS Tuning :: Holiday Sale and massive Holiday Giveaway 2009
- :: ECS Tuning :: Holiday Sale – Nearly Website Wide Savings - Up to 25% Off
- **Cash In On Revo Technik This Holiday Season!**
- Catback
- *********NJ Audi Meet dec 6 , 2009***************
- *********Audi Meet dec 7, 2009***************
- Good deal or lurking nightmare?
- bad "clock spring"??
- am wanting to chip
- DVD Navigation for a 96 A4
- modual master problem
- To you A4 owners -
- 1.8T engine vibration function of outside temp??
- New to Audi & Thanks for the info
- Fuel Injector Sizing
- :: ECS Tuning :: Clearance and sales on various A4 parts!
- VMR Wheels | V709 Wheels *New*
- Squeaky noise?
- '97 A4 2.8Q, EGR location
- Fuel return line test?
- Not blowing hot air inside the cabin
- Replaced MFS still No Reverse
- Need Help, car totalled in freak accident!
- Anyone please help!!
- Probable Transmission Failure?
- help, please! 2000 Symphony non-bose facotry crossover?
- What happened...
- Head linghts are not bright anymore
- VMR Wheels | V710 18" and 19"
- some help on pulling a 2000 a4 2.8L engine?
- Audi A4 B5 - Vacuum Reservoir location on V6
- Happy Anniversary! (Long)
- Audi A4 Vacuum Hose Question
- climate control is dark and acting funny
- 99 A4 Shaking
- Spent some quality time with the A4 this week....
- Radio Concert to RNS-D in A4 avant 2001?
- Engine won't stop when key turned off
- Check engine, hard start, random
- Front passenger window regulator changed $37
- new here
- Turbo swaps done ... took about 25 hours total
- What do you think my car is worth?
- 2001 a4 turbo replacement gasket part numbers
- Sun roof drainage
- 97 A4 2.8 v6 12valve unable to connect ODB II
- antifreeze/ coolant change
- Replacing front inside door pulls
- Help with coilover install
- Air intakes
- Anyone had EBC Greenstuff pads fail?
- there was a time...
- audi a4 rear door panel removal
- Bumper question/disc changer issue
- Why would a new axle be clicking?
- Trouble placing last electrical block connector, passenger footwell
- Accessing On-board computer A4 2001
- 2000 Audi s4 questions??
- Need online Parts Store for Upper control Arms
- 97 Audi A4 Alternator
- Need a Celebration rim cap
- :: ECS Tuning :: Insane wheel deals continue – Set of 4 OEM alloys – $399.95
- New Stern Transmission Mounts
- How to connect lower Radiator hose?
- 1999 A4 quattro 2.8 general maintenance question
- '97 2.8QM noises.
- Any difference in Sedan vs. Avant springs?
- Fog light grill needed !!!
- Fuel Filter
- Cam chain tensioner problems
- Low oil pressure idiot light
- audi a4 ticking from the head
- Master Cylinder rebuild - brake
- ABS ECU removal
- Connector identification
- ABS
- Ipod Adapter, only one side working?
- Cruise control stalk switch - 1998 A4 tq
- Erratic gas gauge B5 help!
- Front Wheel Bearing Size?
- Need B5 hood in Socal
- REAR ABS Sensor? 807C the same as 807F?
- Looking for a good Avant as a "work" vehicle
- HELP! No Forward or Reverse! Trans prob
- Ild Rev of engine when not throttling..
- Still no heat...hate to bother..
- Euro Sport Garage - Motorized Folding Mirrors
- grinding noises in power steering pump (again)
- No flow to heater core
- need pics of white/silver face gauges
- Broken LF door lock
- steering rack " clunk "
- first audi dilemna (2.6 ltr V6 A4 quattro, Australian spec)
- audi a4 heated mirror glass
- Buying my first Audi. Maybe
- 99 2.8 a4 / battery dying & more!
- Serious Maintence needed....
- How to tell if replacement springs are sport or std???
- Why are A4 Reverse Lights RED??
- Drivetrain Component Weights?
- Redline Tranny Oil Grinds my Gears!
- Brake Vacuum Booster?
- audi a4 moon roof slide
- Where to spend hard earned money?
- Auto Body Repair Shops MA Area
- Need Help with Misfires
- ABS Module rebuild
- VMR Wheels | V713 Wheels: B5/B6/B7
- Brake Pad warning light (yes another one)
