View Full Version : A4 (B5 Platform) Discussion
- 1997 Audi A4 2.8 has problems starting and stalling & heating
- My observation: stock air box vs aftermarket
- Any idea where I might find maintenance schedules online?
- Break/Pad Replacement
- homelink visor into b5.5 without homelink
- REPLACING CAMSHAFT ADJUSTER GASKET
- Rough Starting when Damp
- Good Mechanic or Mechanic Help East Bay
- Heater Problem
- B5 RS4 Brutally Accelerates Off of the Line!! Ferrari Cant Keep Up.
- 97 A4 catalytic convertor
- 01 a4 central locking module issue HELP!
- heater not blowing hot
- 2006 Audi A4 2.0T seatbelt buzzer and headlight warning buzzer stopped yesterday!
- stalling problem 98.5 1.8TMQ
- cat came apart
- Ran into Fuel Pump Problem
- 1996 A4 12v manual 5 speed slow RPM droppage
- Rubber Grommet in 1/4 panel
- Is there a throttle solution for a 1999 a4 2.8 auto?
- Camshaft position sensor code, weak battery?
- 99 A4 1.8T Need Help Identifying this part
- quick TB question
- Weird tranny
- Help with a cooling problem...
- Transmission Fluid fill - overfill risk
- One piece prop shaft
- Bentley Service Manual CHEAP!
- RADIATOR is leaking somewere from pass side - any plastic hose there?
- Upper control arm bolts (tightening in loaded position)
- Oil cooler seal is bad, I think, not sure what my next step should be.
- Problem with Battery or Alternator? Please Need to identify problem asap
- 98 Audi a4 1.8tQ P1613!
- R.A.I. Motorsport Presents: B5/B6 A4 1.8T TURBO KIT!!
- My 1st audi....
- 99' A4 Fuel Problem
- A4 - DTC p0171 Advice
- Need advice on removing bolt
- Help with Codes!!!
- Heater - Whats next to try?
- mystery bubbles in power steering system
- Front end shaking
- 1998 engine replacement - HELP
- 98 Audi A4 1.8T, 125k mi, Mystery Smell from climate control duts at idle
- won't shift
- B5 1.8T Radiator hose question
- A4 (B5) Speedometer is possessed!!!
- so i think i may of bent some valves
- 2.8l ignition btdc at idle?
- O2 Sensor issues..advice on plan of action.
- New here w/ ??S about the 2001 A4 Quattro.
- Avant rear window buttons lites....
- Headliner Falling
- 2001 a4 1.8t exhaust help
- What does this Code mean.. I see it in many uploads people load up with their Faults
- cold start problem
- Need help fixing coolant leak - pictures of problem
- MAF fuse
- Need help! Flowmaster Muffler
- HVAC Control Screen Looks Like Etch-A-Sketch
- Rattle and now Hard Shifting Into All Gears
- 99 Audi A4 with air bag, abs, and brake lights on: Couple questions
- need help diagnosing
- How to replace MIL bulb
- trunk struts
- Bad Luck A4: Large Repair Bill...Sell it or Keep it?
- HELP! Fuel pump??
- need used a4 3.0 flywheel anyone???
- changed cam chain tensioner now still wont start
- wont start..... got no click nothing ?? help??
- can an s4 motor bolt up to an a4 shell?
- Hole in floor
- Rear Caliper Bolts, Cannot find anywhere
- ALLDATAdiy.com Introduces Sponsorship of AudiWorld with a Discount!
- A few confusing problems...
- will other flywheels fit my car??
- help with clutch please read
- Best place to buy a replacement alternator?
- Do I have a Tiptronic tranny problem?
- APTuning December Special- Winterize Your Ride For $59.95!!!
- APTuning December Special- 10% Off Suspension Installs + Free Alignment!!
- Need fuse diagram for 98 2.8L A4
- Heater Control Issue
- Yet Another CV joint Question
- Koni coilover installation Qs
- LED headlight information
- B5 30v Vacuum Line Replacement DIY with Pics
- How to change front differential fluid?
- Looking for Floor Mats and Lower Grill Piece...
- Got a flat and cracked original wheel!
- Continental DWS Alignment issues?
- Won't start...but I do get a click...?
- s6 seats in my a4?
- No electrical power, can't start car after few days
- Difference in A4 and A4 Quattro ?????
- Oil Pan
- squeaking noise when idling
- 2000 A4 oil pan removal help needed
- '98 2.8 a4 quattro will crank, but wont catch after rear brake job
- A4 1.8T water pump impeller
- bad n75?
- Coolant Temp Sen/Thermo question
- DrivTech | VMR Wheels BLACK FRIDAY/CYBER MONDAY Deal of the Day – V708 V710 18"
- serious problems need help
- Help, what should I do with broken corner light?
- Battery Replacement Question -- Please Help!
- Coolant leak passenger side, dripping off oil pan
- '01 avant cargo mat
- H7 HID bulb replacement questions, please help
- APTuning Black Friday Discount - 5% off Anything on the Site!
- Do I have front or rear mount calipers? need help ASAP
- Cat Back System for my 98 a4 2.8 30v?
- To cat or not to cat.
- Oil Pressure Safety Switch
- HELP WITH MY CONTROL ARMS!!
- Vacuum and DV question
- finally defeated the airbag light.
- No Heat
- No fuel, No spark
- Need Clutch
- Need Clutch
- Check Engine Light/ Engine Shaking
- :: ECS Tuning :: The Holly, Jolly, 2010 ECS Tuning Holiday Sale ~ SAVE UP TO 25%!!
- APTuning/APR December to Remember Holiday sale!!!
- The 6th Annual ECS Tuning Holiday Giveaway
- 1.8t Worries
- Could someone help me diagnose this power window problem? I searched...
- Cold weather airbag light
- ways to test ECU?
- Quick help needed - Removing sunroof headliner insert
- 6 disk cd changer cd err3 fix
- Replaced Rear Wheel bearing multiple times
- 01 A4 1.8T Koni Coil Over Adj Question
- What is this leak (tranny, diff, ?) ? Any suggestions? (pics)
- 99 A4 1.8T Quattro - Tire Pressure?
- Parting Out 1999 Audi A4 1.8t
- BC Racing coil overs.... any feedback?
- Enging Stalls Randomly!! Help?
- what is this nut? and what does it mean if it comes loose
- Sensors/Connectors ID
- Hitachi ECU 8D0 906 266B
- Pretty amazing in the snow... 99 A4 2.8 Q
- please help. getting high oil temperature.
- Potential impact damage checks
- $100 off Differential Installs at APTuning!!
- APTuning November Timing Belt Install Special for Virtually all Audi Models!!!!
- What can cause NO "MIL" (or CEL) light with key on?
- X-Post - CANGate module possible solution
- Roof Rack Fit Kit Question
- Wire diagram - pin out - ECU connectors
- Downpipe question
- Rear Right Wheel Hop Around Corners
- Upgrading Suspension, need suggestions
- power locks don't work
- rear passenger side brake pads wearing unevenly
- Key Fob not working
- '99 A4 1.8T: Oil leak & C.E.L Code P1136
- Hit & run: Hood release pops, but hood won't open.
- 99 A4 b5 2.8 30v upgrades
- How Many o2 sensors?
- Drivers door lock clyinder
- Suggestions for Bluetooth integration
- Air bag Light
- 1996 seat interchangeability
- Texaco's Texamatic 7045E atf
- Best mods for a 98 A4 2.8 30v
- p0011 and P0333 codes; 2001 Audi A4
- Blauparts Suspension
- cat replacecement on 99 2.8
- dash lights come on and go off
- new throttle body still won't calibrate?
- Ignition control unit/module
- Rock Auto CA kit
- Clutch Life??
- Hesitation/stuttering at low RPMs with engine under load
- increase/raise ride height?
- fix flashing abs light myself??
- Cranks, won't start
- Yep I'm an idiot...
- EXHAUST RATTLING
- Center Carrier Bearing
- Confused: Engine, Trans Codes
- 96 A4 2.8 SOHC AFC: Cam Position Sensor
- fuse 29..
- 1996 A4 2.8: AFC engine: Engine Speed Sensor
- 1996 A4 2.8: AFC engine: Motronic wire diagram
- Subframe question. 96 2.8 5 spd
- What causes a broken lifter and damaged cam?
- Oil Temp Gauge?
- High beams dead
- New A4 Owner with Tons of Questions..
- 1.8T Timing Issue
- anti-lock break sensor
- Friend says I don't need a club?
- Cigarette lighter fuse keeps blowing!
- Washer Pump Relay - Windshield Washer not working
- Engine Won't Run... Need Advice
- Help Please.. Do I have Transmission problems.
- Any way to reset the computer without disconnecting the battery?
- 98 Audi A4 1.8t - Is it possible to disable high beams?
- 2000 A4 1.8 - Intermittent Charging Problem
- Battery BT...Want to change my battery to GellCell..
- Catless Downpipe
- Got my audi flashed by GIAC today.
- VAG needed or will any OBD II Scanner work?
- Melted Serp Belt. Crooked AC pulley?
- Need help with strange brake problems.
- erradic idle and more??
- Tranny problem, possibly from atf cooler
- Rear knock sensor locatoin
- need help asap
- Intermittent misfire
- 96 A4 2.8 auto: won't start (no spark) after trans change
- Intake and Exhaust options for a 2.8
- Newbie needs help and advice
- DBC Tuning
- LCD on my 99 Cluster went south so I got a cluster....
- Looking at a 1999 Quattro, help plz
- Secondary air system
- Cold air intake
- 1996 a4 2.8 clutch replace question.
- Can someone help me?
- Transmission Leak
- Suggestions for maintenance with 01V tranny out?
- Oil Pressure problem
- Oxalic acid (wood bleach) to clean the heater core??????
- has anyone succesfully repaired a faulty throttle body?
- a4 2.8 30v shutter/vibration at 14-1500 rpm
- I've already STFA so don't flame. VR replacement with alternator in place???
- Part Numbers.
- Fuel Pump Questions
- my 1996 a4 quattro sat for three years; tried starting it last night-no spark>>
- OEM oil filter 3-pack
- hard braking, good for tranny?
- FMIC with stock bumper
- I need a new clutch for stage 3+ car... Opinions??
- Audi a4 2.8 30v engine code?
- Punching Cats.
- Where to buy OZ Superleggera wheel??
- Where to by OZ Superleggera wheels??? I need one...
- ac compressor help
- Question about bypassing the air bag system
- Engine pull begins.. wish me luck.
- K04 swap
- Bent Rims
- onto a new project 97 A4
- CHECK ENGINE LIGHT FOR P1128 (BANK 1 SYSTEM TO LEAN)
- exhaust rattling
