- X-post from audio forum: dealing with a loud aftermarket exhaust on an Avant
- Timing Belt on 2000 1.8tqm advice
- Anyone have a link or know off hand what other cars are compatible wiht our wheel offset (5x112)?
- Let there be sound........
- Group Buy Canceled, they won't do it...
- Turbo Question for the 1.8T
- XPost: What is he talking about that can get rid of the smoke smell in a car that someone smokes in?
- hmmmm phil is thinking of even larger rear brakes
- Question for someone with the OEM 2piece s4 xenon headlights Lltek sold back in 99
- Possible good news re: mom's car
- Battery died, did I fried my comp?? STFAed
- Anyone changed brake pads recently???
- LLtek Strikes Again.... the snowplow effect times 1000 ..... minus 200HP
- Car history checks
- Minor clunk question...
- What is the consequence for using something other than G-12 coolant from Audi?....
- quick front suspension question..
- Look what I found Heavy duty skid plate 96+ B5/6
- x-post for Saint louis people. Be careful out there.
- Anyone know if this will fit?
- Dealership told me that a front wheel bearing is $111.50 not installed just the bearing.............
- Tyrol Sport reactions....Stage 3 T-28 and SB clutch...
- Guys is this a decent price?
- T- 4 hours till I leave for school... lets hope I get my V&S before then...
- need a new transmission pan
- What is the orange coolant in 98.5 A4 Quattro?
- anyone need a stock tiptronic chip, yellow corners, 710n bpv, free.
- Chipstar.... What is the meaning of this?????
- Who else needs a chip, let's get a group buy going for APR 93 octane...
- dropped my car off yesterday for TB change, i miss it : (
- Gecko you said you were running Falkens Tyres?
- Climate control works but wont blow any air.....
- Archive post: GIAC J31 2000 K04 software MUST be used with a manual boost controler
- Just moved to the New England Area.
- New owner, 2001 Audi A4 1.8T Quattro 5-spd.
- got back from KK GTG in van nuys...
- pics
- Chip Compatibility....
- anyone replace sun roof gasket?
- went to 1/8th mile track tonight again!!!
- Best Big Turbo(GT28RS) Software?
- slightly OT...any reason audi doesnt sell supercharged variants of its cars through dealers.....
- Update on Battery vs Altenator ..... repair is $$$.
- don't you hate it when people waste your time? (by hitting your car)
- Clutch / Trans. Blowout? Any ideas?
- Teaser pic....
- Audi Carputer
- the k04-15 isnt actually stock on any vw/audi auto, correct?
- My AC Blows . . . .
- how much for new oil pan
- Will this work?
- anybody in hudson valley/catskills ny want to help me out?
- How thick is the vacuum/boost hose in a 98 A4...Want to know what size tubing to buy for gauge...
- still making not 100%
- painted roll bar
- Quattro Tiele.......you around?
- Adds 500 HP!!!
- PSA: AW now has new forums, check your pull down menu.
- La Jolla Lunch Sept 2nd Thursday
- Anyone have before and after pics of E-Codes on a 98.5 or 96 - 99... Appreciate it... I searched too
- Will my 235/40/18 ABT A24s fit on my 2000 A4 1.8?
- Just put in Mobil 1 0W40
- Got pix of your aftermarket stereo unit for the A4?
- Now here's something weird...my ABS ECU, along with my ESP just started working again mysteriously
- OT, and maybe stupid, but do any of you guys with yellow cars notice that bugs love them??
- Audi said they replaced the Radiator, but the temp gauge is still on the rise...
- Should I go with these?
- CHIP SWAP!!
- Thoughts on 98 S/C'd 2.8 or B5 S4?
- Does anyone know what wire to tap when intalling a boost gauge so that the dimmer controls it? pls!!
- I'd like to take a poll to see if there's a trend. Those with the trip comp/driver info display:
- Well, APR software is nice and smooth....
- IMPORTANT - Please i need help ASAP
- KKK K04-0015 Turbos in back in stock...........limited supply.......$795 each
- anyone going to the LA (van nuys) KK meet tonight?
- someone went rally with an A4!
- You A4 guys made Maxim!!
- anyone here had experience with replacing their map sensor?
- ANY NJ heads down for an edgewater meet tonight (Thursday)??
- I was thinking about getting an Ipod for the car
- Question about clutch drop similarity in auto a4
- Just got the HP EVO 18's, check em
- New red Alcantara and some night shots (bad location though)
- Is this a good deal?
- Bumper Question/Rattle
- Coolant leak temporary fix....Aimed at Chipster..
- X post from A6 forum: Lowered car leads to broken rear axle...
- Xpost from VAG forum. If anyone can help, it would be much apprecated.
- Aftermarket bumper install question
- Which wire is connected to the dimmer on the cluster...
- Ok, very sad night last night @ Drags, Think I'll rename the car to pokey the blubber butt
- Any suggestions on the source of a ticking sound coming from under the stock airbox cover?
- how do rain-sensing wipers work?
- 18x8 ET30 on B5 should i drop it ? i have an eibach pro kit thats ready to be installed
- when is timing belt recomended i have 63k on the odo
- Stock HID's on '00 seems dim...
- 2000 A4 Brake Sensor Help
- How hard would it be to replace my front right wheel bearing myself?.........
- Navigation Wiring
- anyone ever maych paint at store in spray can and paint lowers?.....more
- Question about insurance...(more)
- Buying advice
- Anybody here know a certified Audi tech/mech that'd be willing to sign a statment...
- Is it possible to install a k-wire if you dont have one?
- Where can I find a 3BAR FPR??
- Boost Guage qustion X-post...
- raped....man this maintenance is starting to add up...
- 2000-1.8TQMSport, thanks for taking the picture the other day. :-p
- Ashtray jammed - Any suggestions?
- An A4 with a twist
- Help please: Engine Light on, Vag code: 17544...
- Should I, or should I not? ...
- Do not Buy Sumitomo HTZ II Tyres
- Non-Sport Susp to H&R/Non-Adjustable Bilstein setup
- have you heard of issues with the on board diagnostics being affected by removing the stock radio?
- Ignition Amplifier
- Is my battery dead?
- 400+HP and all wheel drive what a crazy night we had fun.
- Anyone have an AMS Chip?
- I finally got some door sills for my A! skirts...
- 12:30am / 4 West - 17 North nice run 330ci........too bad though....
- neighbor IM'd me about his friends A4 breaking timing belt $3,800 estimate
- PHIL'S plugs say.....
- Bucking/stuttering after repair...any help? (long)
- Stomped on a WRX with exhuast + FMIC on the way home..while I was having issues
- What should I look for when buying an A4 1.8t Quattro?
- Repost? Sport Compact Car names the B5 A4 one of the 100 greatest sport compact cars of all time
- Anyone know anything about Motodyne
- Paging Mr. Moto.....
- Scam email I got for my Evo intake?? This one is pathetic...
- XPost: Posting and you
- Replaced ignition control unit and now i hear pinging.
- Vote for the Audi, just cause.
- Recall work cleared my 16795 "secondary air injection" code . It's called the LK Recall
- I'm PISSED... the wheel shop I went to a couple months ago WAAAY over-tightened the bolts. (more)
- ok i think it is time i look into putting in a Boost gauge...
- Chrome window trim on 97 A4 2.8 Replacable???
- Angry, here is the updated sig.
- Does 1.8t B5's idle at anything other than 900 rpm....
- I found this ad funny
- Just got my new MAF sensor,$64! ;-P- if K&N's fry the MAF with the oil in them... what to do??
- 28 motorcycles rode by individually on the main road while I was outside washing my car....dang you
- FRONT ARMREST LID STUCK
- where can i get a set of mud guard for a B5 A4?
- Is $365 too much to pay to have my wheel bearing replaced??? Thanks
- Anybody have a stock cat they dont need anymore?
- Brullen quality? I thought they were supposed to be better than this
- I need money to buy my motorcycle...so someone buy this suspension already!
- whose widebody s4?
- Place to purchase Sparkplug (ignition) wires
- So... I brought the car to Audi and they found the "coolant" problem...
- stage 3 clutch options + recomendations? Yes i have searched
- wheels?
- DROPPED SWITCHBLADE KEY AND DORM KEYS DOWN DORM TRASHSHOOT!!!
- Wheels... anything new and nice looking?
- Pic request: BBS RC's on BLACK A4/S4
- XM Radio Hard Wire?
- What do you use for Tranny fluid and Differential Fluid?
- What's your opinion of installing a "used" engine?
- coolant smell when vent on in 2001 A4 Avant 2.8Q
- Poll: Should I get a HF Cat or a Straight Pipe?
- Here it is! My write up on my Aquamist 2d install / experience / results... (long & BWW)
- Bozo vs A4 (Better photo)
- Had my local audiTek take a test drive in my car yesterday to give me a heads up...
- I thought this was funny.
- Sparkplug wires & Cap & rotor
- HELP! tiptronic Question!~
- Xenon Question... need help pleas...
- How long does an oil pump change usually take?
- How can I tell if my car is a sport model?
- Drivers side lower bumper grill
- need help diagnosing boost regulation problems
- Finally finished the head unit install. Looks really good just waiting on the invertor and then car
- after changing my pads, my calipers make a "click" noise once when I apply the brakes
- what is the DX button that your supposed to hold down with the FM 1/2 when resetting.
- Help needed ASAP! Question about pureMS snub mount.
- still learning my audi....key fob question
- anybody have the upsolute chip from bahn brenner?
- BPV 710
- i was told the code for the radio might be in the wheel well of the spare.
- does this make sense?
- Bozo vs A4
- PES G2 Supercharger System for 30V
- automatic Climate Control (A/C)
- Does a 96 A6 dash button panel fit a 98.5 A4?
- Speedometer Issues - 1998.5 A4 1.8TQ Tiptronic
- Anybody have a URL for a recall pdf list website besites NTHSB?
- Has anyone found aftermarket carpet that comes close to matching OEM Onyx interior?
- OK B5ers, I need some info on tinting the rear tail lights
- Gas Mileage
- Where is Cabin airfilter
- Gauge cluster and trip computer dead/battery drained also...
- Pic request: OZ Classe on B5 S4/A4
- Under Hood Padding on CF hood?
- Full walk through to install a headunit. Will pay you. Can anyone help me?
- wooohooo...MAF is back in with the recir...and the car is running very nicely.(new intake pics)
- dropped my car off at hoffman audi today
- MAF problems 2001 K04 GIAC
- Tail Light problems
- Front/Rear caliper bolts for pad changout: torque settings...18lbs/26lbs. F/R, correct??
- if the cam tensioner seal is leaking, where would you see the oil?
- Does anyone know where I could buy a window regulator besides dealers and Claire's?
- I hate to ask... Anyone here have a Volvo V70R?
- whoa wow holy sweet.
- low fluctuating idle after timing belt install.....what do you think
- do you need to replace rotors when you change your brakes?
- I need real help here. I have no idea how to get this headunit to work. Write-up/ideas
- So if a part fails because of a directly connected recalled part, should the failed part be covered?
- quick questions
- My car is overheating... Could it be my Coolant Temp Sensor?
- Anyone know of insurance problems with a T-28....?
- <RANT> why is AWE such a pain with their center vent boost guages?...
- 1996 A4 Transmission Question
- A4 service manual
- Anyone has a pair of 1 piece headlights to sell ?
- Answers for AddictedA4 from yesterday's Q's.
- Pentosin CHF-11S? Anyone know where to get this...
- neuspeed springs
- Audi Driver Rant <long>
- How hard is it to solder an apr chip to ecu ?
- rear main seal?
- leaks?
- 97 rear ashtray
- Radio on Safe Mode after changing the battery.
- Where can I get my transmission/clutch looked at in orange county, california?
- finally a fix for fading trip display?
- Places to buy rims besides Tirerack.com... I am looking to get Moda R6's...
- SGI RS4 front bumper...
- (Midwest Forum Sucks) Moving to Cinci. Anyone know a good Audi Mech there?
- what is this rear valence?
- Woohoo! First gear going down hill fast.
- PSA: SCAM in the classifieds. Matt Lebouf is now faking suspension ads
- made up my mind, i'm getting a LaBree DP, my question is do you leave the exhaust in when you lay a
- Timing belt Question: Stretch and moving teeth..
- aftermarket pedal options?
- Need help, power loss when car warms up? (long)
- No luck in the B6 forum...PHOTOSHOP guru, please help...(simple).
- Oh yeah, Chip was right, OZ Chronos lips bend too easy. No pictures right now.
- My custom in-dash touchscreen.
- Please Help
- antenna mast
- Here are some HU shots after the install last night.
- How much should I pay for a 1999-2001 A4?
- Ok guys which should i do first?
- paging liam... do you have anything to part out
- Ordered my 2nd A4...if any of you old time suckas are still around and care...
- PA/NJ/DE/MD folks --> Reading PA Fun Fest/GTG this Sat! 48 hours left to RSVP!
- Anybody know...
- JUST GOT MY A4 QUATTRO!!!!
- i think my car is allergic to oil....need some help
