- MAF and Fuel trim issues
- so do our cars have two or one coolant temp sensors?
- B Stock garage sale, I need to make room for all the B7 RS4 wheels and Dunlop M3 arriving
- How to replace the starter?
- sun roof fuse
- Problems With New Head Unit
- ReigerAudi...
- Heater Core, final installment
- Antenna amp question
- what does the tip chip do???
- sound system TROUBBLES..HELP PLEASE
- Noob with Vag-Com.. some help needed.
- nav disk
- a problem with my neuspeed p-chip
- So I've tried this new "not asking my parents for money thing"
- finally got my vag.com up and only got two codes
- haha, the a-hole that chased me and that i went to court for had an accident after court on monday
- Why so cheap? Doesn't say the brand i don't think ...
- how much should a good 4 wheel alignment from the dealer or equivalent cost me?
- Temp regulator flap...COLD AIR
- Ok lets try this again :) A8 upgrade on and pics of damage from boston.
- Is simple green ok to use as a cleaner for the pcv valve?
- I've recently installed Hankook ventus 225-55-16, and I'm having a problem.
- The little red mark on my "T"
- Audi Audio Question: How to get it to sound good/options?
- Update for those of you who are interested.....
- Need help everyone! (overheating problem)
- My buddies 1942 ford gpw jeep
- Need quick answer please...
- Anyone here install an EGT gauge on their 1.8T??
- quick q about ecu's
- Foaming power steering fluid...
- OUCH!!
- Looking to upgrade my PES T28 on my 2k A4-
- winter driving
- Just a recent shot of my car at Importfest in Vancouver tonight...
- need help ..
- Q frog: Can you verify the validity of this at all?
- did quattroman's website full of audi pdf files get taken away?
- worth reading
- awe-giac ecu on ebay
- Broke More than Works...Ha Ha
- Anyone have an A4 cargo net they are willing to part with? I need one...
- RS4 B5 drifting on rainy track
- While I was at it.... Fixed the floppy Tip shifter..
- Got carnage? Or, Yes friends, changing a heater core is a HUGE PITA!
- Crap! Don't overtighten the shock tower bolts
- How much am I looking at to have both outer front cv boots replaced?
- Anyone hear from Chip recently?
- 1/4 mile question
- Rotors for a 98 2.8 quattro recommendations??
- High Mileage Issues (Around 100k)
- exhaust for a 12v quattro
- Are A4 and A6 half axles the same?
- Some pics of my A4 in full-on winter mode!
- Help w/ ECS bilstein adjustables
- phatbox for 6 disc
- did I ruin my car?
- oil choice
- Add another A4 to the crunched list . . .
- Sweet garage pics!!!!
- check that FMIC out
- repair manuals?
- Cold Start Problem
- Trouble with suspension install
- found this red a4 wagon on the dc craigslist
- Audiworld Firefox Search Plugin
- Some knocking at start up
- Some pics of the interior ...
- Anyone know about Eneos oils from Japan? I picked up the 0w50 synthetic today
- APR Chip Boost Issue, allready STFA
- Qfrog: If someone came in with a broke cat at the flange and they had an aftermarket cat back...
- Help needed ASAP! I am stuck removing the PCV breather hose
- For those who get their tires @ tire rack...
- When taking out the pcv valve is there only 1 hose clamp towards the top ...
- Looking at AWE center vent boost gauge. PureMS has it for $225. Hit?
- What do you guys think i could get for my car....
- Im new.. welcome me.
- 98 Tip in labour
- Waiting for DCH Audi to call me back and tell me "if" the cat failure at the flange is covered.
- 2000 A4 passenger headlight bulb replacement...
- front crank seal
- Refinishing Wheels
- Another One Bites the Dust.... Car was Jacked in Irvington NJ last night while
- Aligning cams on 1.8t
- well i just finnised my second cup of java and about to start to tear into my 12v
- VW TDI throwing a code...
- so last night and today my cluster doesnt have any dead lines anymore
- Is anyone using a sig like this one?
- What exactly is the arrow-marked part in this picture? Might this be the real culprit?
- whats the best chip
- Late night boredem post...
- TB done, now overheat?
- New Jersey Dealer Service BT: Bell Audi or Jack Daniels?
- Post whore time: After spending the day with Shep1.8T....
- Looking to do 2.0T FMIC Mod...
- how do i make my headlight washers work if they dont come connected from the factory?
- Car dies when cold after 1-2 miles
- Ive realized that the upper control arm is hitting the car inside the firewall, its dented up in two
- Anyone have any experience with a Spec (PES) Stage 2 clutch with OEM flywheel?
- Where can I get the clips that attach my floormats to the ground? (God damn vacuum)
- How do I make my headlight washers work? Thanks!
- Repl Thermostat and heat sensor 2.8
- 2 years and 40k later...
- Anyone using studded tires, and is there that much of a difference?
- Do the stock front or rear bumper spoilers come off?
- Paging MikekiM@PureMS
- blown shock???
- Got a decent amount of rust between my firewalls, and cleaned my garage
- OT: Its come down to...S2000 vs. IS300. Which one would you take?
- Vacuum Hose question
- anyone know what type of bulbs go in the overhead. i need the bulbs for the 2 reading lights
- Ended up paying 114 for the sport rubber floor mats ...
- quick lighting question...
- Backfire
- do we have a page that shows pictures of all the diff headlights ppl have ?
- anybody know Overspun's email address over on AudiZine? looking to get one of his vent gauge pods
- Please tell me I am fvcked.
- ATP Exhaust Manifold worth getting?
- Hartmann Black Friday Deals Now Online Includes New B7 RS4
- Is this bad?
- Fuel pressure/Evaporation System leak - HELP before I get robbed
- How often would you guys suggest to have a four wheel alignment done?...
- boost gauge noise
- why does my car always get shot with orange paintballs?
- Need to know what part this is P# 06B 133 062 M
- Aftermarket replacement for 058 905 291 check valve?
- does the VAC diagram from Bentley show both 3mm and 9mm hoses?
- anyone in north san diego county know of a good place for repair?
- led light above rear window in avant
- stone guard
- Anywhere else i can buy sport floor mats for a 2001 a4 other than ecstuning
- Unknown liquid fluid... Whats that?
- Extended Weekend Mod and Maintenance Report roll call: What are you doing
- '01.5 A4 1.8T Humming or howling noise at 115 kmh ( approx 70 mph )
- ETKA online parts search
- My dad just took his car to a place he knows some people ...
- Xenon issue ('99 two piece HELLA model) & heated seat problem...
- Need help to find the updated Shifter linkage Part Number
- oil temp post from yesterday: 2 mile drive| 31F outside| oiltemp 150F | coolant @ 12o'clock
- Fuse Numbers/Diagram
- Liam in Montreal contact info???
- Mintex Reds came with no shims, now I've got clunking noises. Anyone else have same prob?
- Rattle & Hum
- Any ideas?
- Noob - My new A4
- WEIRD PROBLEM- Coin pushed into horn/steering wheel crevice, horn keeps going off! HELP! HAHAHAHAHAH
- narrowed it down to two possible tires...
- on the old styled tail lights, would it be possible to make the bulb for the brake light only come
- OK, need to order an intercooler.
- Keyless Remote "Ready?"
- What is involved with switching the KO3 to a external wastegate???
- changing internal water pump
- It was bound to happen one day, my stupidity caught up with me.
- Just a bit down bitjockey said within 5 min his oil hits 175 degrees
- Are our TB and intake manifold gaskets one time use only? Or can I reuse them?
- POLL: how much finger gap does everybody with modded suspension run in winter/spring?
- how important is it to get a wheel alignment after altering suspension settings?
- New Tein Basic S4 coilovers installed
- When you guys say short trips are bad ... what is considered a short trip?
- Anyone know the part# for the battery hold down clamp?
- Saw buddy racing post on AZ that he sold his car
- STaSIS / Koni Street Sport Coilover Kit
- Selling B5 A4 Brakes?
- edfc
- Smashed rear tail light, anyone have a spare 96-97 driver side tail, or 98+ pair?
- bumpersticker?
- Pics of the new S4 bumper installed with evo fmic lurking behind
- bunch of kuhl stuff in the classifieds.. and again not my stuff
- Would you say my k03 has gone bust?
- is this the best brake pad comparison out there?
- chipped mbox on ebay guys
- Front bumper/belly pan fasteners for '96 A4
- anyone delt with these guys? safe bid?
- A few random things...
- repair shop in miami area?
- OT: What do you guys think of an 2001 Lexus IS300??
- Did you guys who own a k04-powered plant have your ECU flashed or chipped?
- TomRitt/HBC Productions rebuild video FOUND!!!
- Brief rough idle just before stopping
- I may have posted this already but i stfa and couldn't find it ...
- After this post ...
- Best brand battery to buy? Interstate? In my dads a6 his battery died.
- Quattro doughnuts rock
- Lost my Mcgard wheel lock key...
- pre-99,5 w/APR chip - need help installing cable/switch to change ECU programs
- Can someone provide the OEM part number for the (B5 A4 1.8TQ) direct bolt-on k04-15 turbocharger?
- car is not leaking oil, its draining oil........more...........please help......big problem.......
- Random/Multiple Cylinder Misfire - Humid weather startup trembling
- Help!!! Is it possible that a rear differential seal job could screw up handling..(long)
- Happy Thanksgiving everyone!!!
- Is it bad to have the EFK cooling the rad too much?....
- Please help out a newb - I need ammo to right a wrong..
- local tire store wants to sell me 225/55/r17 at clearance price, will they fit? 17's and stock sport
- can't reach benchpress, what to use to put on terminal on 1/0 gauge wiring?
- Help with something that seems to be effecting many people?
- what do both the engine temp sensors do? (pics inside)
- car runs very cold at high speeds? qfrog and audi experts help please >?<
- A new kind of noise , added wet weather shields like in tech section ,now..
- missing bolt?
- Small mod to keep me happy...
- Any thoughts on the ATP high flow manifold?
- ****, part of my viscous fan broke today...
- any benefits of 5bar FPR w/out a chip?
- Another Death by Sludge...long
- Why, I hate when bad stuff happens!!!
- My car burning out ( and it's an auto!) :) ~10MB
- Getting annoying same CELs when I had a crack in my cat,think its cracked again >=[
- Got a sweet vid of my car accelerating, how can I post it?
- Repost: OEM Audi Navigation: Nav Plus?
- Two thumbs up to PureMS.. . ordered stuff monday, hoped it would get here for thanksgiving weekend,
- so who is gonna work on their car tomorrow?
- Pittsburgh sucks... My apartment sucks ...My tires do suck too... sliding backwards on a hill is ...
- The saga ends! Boost problems are no more!
- Anyone here could help me to find Part Number for the Shifter linkage mod
- Stereo install tomorrow...wish me luck!
- removing CD changer
- 1998 A4 Brake light--how the !@#$ do I change it?
- now thats what i call a question.. well a stupid question
- just got car back from dealer to have them check the swaying
- why buy vogtland coilovers when H&Rs are same price?
- Where is Oxygen sensor Front/Rear (AWM)
- DNP Manifold with J31 or stick with stock?
- Shop is charging me to $750 to replace....
- Airbag Control Module Reprograming
- Ipod cradle....
- Where are the vac lines on the 2.8 to do seafoam. My father asked me to do it for him ...
- Already did a search: What is the part # for the Shift linkage mod 8D0711613H or 8D0711613J
- all good things....
- Power Steering flush question...
- Smelly air conditioner
- AWE Tuning Holiday Schedule.
- Brake fluid recommendations? And one more thing...
- Vogtland coilovers going quickly.
- Calling all Harmon kardon TrafficPro users...anyone have or know where to get updated maps??
- s4 swap has been completed 4.2 in a B5
- *sigh* time for tires...
- what's the site that advertises' on here for the euro plates?
- Update!! V&S (IPP) shortshifter group purchase $125 shipped
- cant wait for some of this this year..
- Think this eBay seller lives in New Jersey? :-p
- just picked up a car cover from a craigslist post here in the wash dc area
- guaranteed to make your car LOOK like it stops well -lol
- Overheating after 60k mile service, UPDATE 2
- What is this?
- I've got a gallon of 50/50 mix coolant/water...is that enough for the 2.8 water pump change?
- any opinions on this headlight??
- rumors has it that the the b8 s4 wil be a 3.2l TT
- VAG-COM Features?
- so I dont need a gearbox...
