- Power Stearing fluid leak
- what happens to an a4 when you put green coolant in it?
- Resonated or Non-resonated
- Trading in car + CEL
- Heater smells like gas-not coolant...
- just wondering
- I'm planning on making my own homemade canards
- Turbo issues need help
- swapped my cracked up melted k03 with 190k for a k03s
- Cat Converter Flange Crapped Out
- Axxis/PBR Deluxe Brake Pad Failures
- P/N requests: upper and lower coolant hoses that go into the radiator?
- well, I guess I can cancel my trip to Hollywood.
- would a 245/45/17 tire on a 17x8 38 mm offset fit with OEM sport suspention
- Oh for fvcks sake.
- What the heck is the wishbone? Part # (L&R): 8E0-407-693-AG and 694-AG
- Input please.....
- RPMs pausing with pedal to the floor? What the hell is going on... (LONG)
- My Saturday mod day.....repainting curbed to hell S4 rims I picked up for $100.
- X-Post from AWOT ,part of my Christmas shopping is done. Sorry, linked now.
- Subaru STi/WRX powered ATV
- Question about fuel cut after K04 install. Car will start and run for less than 5 seconds.
- Help - Wheel Needed
- help!!! where is the engine speed sensor in these pics???
- Anyone have a pic like this of the B5 A4 or S4...
- What are the specs (ID and OD) for the vac lines? A technician recommended using diesel fuel lines.
- anyone using german castrol 0w30? or formula rs 0w40?
- what n75 to get?
- Antenna amplifier black wire - need a bit of help.... [update - w/ pics]
- Cool vid: BBS factory
- Test Pipes
- OK, going to try to replace VC gasket and CAM tensioner gasket today. How difficult...
- Hey all, kinda new to this. Please help having boost problems!!!
- EAT THIS VORTEX (it's a jaw dropper)
- Started picking up ice today. Had to pull out all the stops.
- Milltek vs. Borla $$
- Driveshaft bearing solution.
- some advice on side mirrors.
- Did the DIY boost leak test... no leaks.. now what?
- Borla or Milltek tip diameter?
- Driver's rearview turning yellow?!
- AM radio station screech/squeal
- FYI: "Secrets of Speed" - Audi quattro *On YouTube*
- Does anyone have a hood latch they want to part with?
- In March I am going to Germany for 8 days. I plan on going to the Nurburgring. What else
- WMMT?
- Rant <> My dad the proffesional painter ... RTFM MAN!
- No boost at WOT...just fine at partial throttle
- Seat Question Need Help
- My turbo showed up wahoo! Vut I'm think about selling it after falling on this new plan
- About to leave for Chicago and my Coolant is a bit low. I know 50/50 is ideal, top off with distille
- Anyone want a Haynes Repair Manual?
- Whats the best cold air intake for my b5 a4 1.8t
- been pondering something...
- What kind of turbo set-up might be just enough to take a Carrera 4S?
- soooo on the way up to Toronto....
- A.W.E. Tuning has 97-99 A4 Vent Gauge kits in stock.
- AWM coolant flange comes with all needed O rings?
- Does the B5 have the same CD Changer 'adapter' as the UrS6?
- '96 A4, 2.8 engine
- Must read...Suspension? Hmm after a long night of going over some awesome reads...
- Where can you buy Redline SI-1...
- STP / Mobil 1 Products
- A little update on my Project A4 Avant :-) BWW
- 17" Sport Edition F2 / Dunlop Wintersport 3D...
- Installed my Apikol Rear Diff mount tonight. A+ to Avalon Motorsport....SWEET product!!
- Carson....need some help here:
- Google to Search the Forums
- Ship jumpers, dig deep for this one. Here's your Avant
- Why can't ATP do anything right???
- Need help from the VAG guys...
- WTB: Anyone have a Front License Plate Mount for 97 A4?
- Alright guroos! Gremlin inside.... Listen to this wierdness
- rear urethane sway bar bushings done....
- I will be replacing a front outer cv boot this weekend and i plan to use
- Fuel pump relay
- Hartmann Winter specials up on Achtuning.com!
- Im going back to the stock pcv system...can I get some part number/prices? Also paging Carson
- C-V Replacement Kit From Autohuaus missing new C-clip...
- How do you remove the filter underneath the oil reservoir cap?
- Just want to check to be sure, but 235/45/17's should fit fine on stock sport right?
- Can anyone who has changed a waterpump and tstat please chime in...
- This guy is def. having a BAD DAY.
- hit or skip for evo cold air intake
- 99.5 or 99 a4 2.8l
- I have a dilemma. (possible project)
- Where is a good place to buy xenon bulbs?
- Has anyone used http://www.modulemaster.com/index.html for the ABS fix?
- Maybe I should change my cabin filter more often.
- Calling all track whores! Suspension related.....
- P0170 boost related?
- Rear Passenger Door Skin Damage Estimates- Whoa!
- Paging Carson, parts needed.
- Anyone else read this to imply some kind of warranty?
- need vacuum routing diagram for 2000 a4 1.8t
- x post loss of power..help
- Diverter Valve
- the engine warms up ok, but the interior heating does not work even thought the blower fan works
- Engine shaky upon startup
- What is the word on ASA AR1's for winter wheels? Are they strong/durable?
- Wired Vibration
- Re-Post: Anyone have the Part# for this E-Code Turn Signal Bulb Holder?
- Can I get by with Regular gas on a stock 1.8T?
- What is the difference between ATW and AEB motor
- Honest reviews of rotors please: SP Performance vs. Power Slot
- Has anyone seen BitJockey around? I have money that I want to give him.
- Is Idiling the engine for 15-20 minutes bad for it?
- Hmm...here's a question:
- 2004 and 2005 1.8T
- Used faulty MAF, what to do?
- Whistle sound at 3200 rpm????
- EGR Low Flow Diagnostic Question
- Another Avalon Motorsports victim...
- Best place to find a 6 wire O2 sensor...
- Bah, I need my own track. I love this weather, it's like 38 and dry out.
- Oh, Lord.....I bought some Royal Purple synthetic motor oil....
- sway bar bushing update/interesting article(nytimes) on car repair
- Just finished my K04 install, fluids and everything in. On starting, I had a really weird noise(more
- 02 sensors? Bosch direct fit versus universal, is there any difference?
- Seafoam in engine oil.
- Where can I get a Turn Signal/Parking Light Bulb Holder like this? (For E-Codes)
- Hmm...
- Small Rant >:(
- A8 rotors and TT carriers forsale
- Replaced my front brakes....didnt remove possible excess fluid... it sems ok...
- What model# turn/parking light bulb fits in 1-piece Valeo halogen housings?
- Tein Coilovers??? Opinions wanted
- Changing my non-sport suspension with a used sport suspension this weekend, will i need any parts?
- the mother of all oil coolers...lol!
- Suprising news for the next S4
- vortex potd
- EPL's : One last hurrah before the holidays: Dyno Day-GTG DEC 8th 9am-5pm
- Hate to bring this up again...
- Ambivalent injectors for k04 / gt28rs setups on stock fpr? Looking at min size. AEB seats.
- Hmm, not bad... (Audi content)
- Boy am I happy our cars don't use UFO brakes!
- Rad hose replacement
- Front and rear bumper re-mount. How much time should I alot for this?
- VVME Question
- Trifecta block
- After a novel driver didn't give way today I feel like fitting a truck air horn in my B5...
- Lengthening 5th gear? Anyone done it? ABT used to sell a stage 3 kit with gear mods but not any more
- Vogtland Springs on Sale for 1.8TQuattro
- Ignition Coil Boots Going Bad
- When installing an FMIC, do I need to get the 42 design map sensor flange or can I JB Weld that in?
- Chicagoland! 98' A4 30V For sale
- Anyone have a good source online for O2 sensors?
- WWAWD? Parents asking for my xmas list, and I'm trying to choose between 4 pt harness or helmet
- :: ECS Tuning :: ECS Cana-Ease Saver for Canadian Shipments !!!
- here's a dumb idea :) using seafoam to decarbonize...would injecting before the TB
- Alright, my garage is cleaned out and ready for use
- Looks like PC16 software really is aggressive. Since I ended up with 91 octane in the tank
- Compass Rear View Mirror
- labree HFC = pass smog in CA?
- purems where are you?
- Tire choices - please help!
- keyless entry remote replacement
- plug in maf.. car dies.. unplug maf car fine.. replace maf and plug in maf car dies
- Steering Rack differences - Koyo versus ZF
- YAR!! VICTORIOUS!! IMAWESOME!
- Ok I'm ready to kill this car now! Everday i find more problems. Today I changed the
- 182076 miles n running strong but..
- Tire pressure
- brake bleed W/esp but w/o vag-com.........suggestions?
- any hints/tips to remove that front 02 sensor...
- I broke teh law.
- Are there any good writeup's for a spring/shock install on a b5 A4, other than the obvious?
- Installing B6 S4 sport seats in a B5?
- Replacing Valve Cover Gaskets - 30V - Pic inside
- Airbag light on so scanned. found 16395 even though no CEL. How there w/ no CEL. More about both ins
- Anyone use 65w halogen bulbs in their cars?
- To those running HFCs or Test pipes w/ stocker exhaust...some questions.
- JoeyT, I moved the steering wheel after the battery was disconnected while doing headlight switch
- **Need advice on my aftermarket HID lights I've been using for the past 5yrs.**
- help diagnose problem, please
- Chipped tooth first gear, anyone here dealt with that? How long did you have the noise?
- I have steam and water dripping out of the tailpipe upon startup...what are all the possible causes
- iirc you can use an HID kit for standard non-xenon 1-piece oem headlights?
- Need some help, AEB gurus - Clicking noise under light acceleration anyone else deal with this?...
- when heat is on the a/c motor also turns on
- Saw an unbelievable pic on AZ. **Post best pic of B5 (Preferrably A4) of all time.** IYO.
- 99.5 A4 non-bose speaker replacement (front)
- What does WOT mean, I have been seeing it alot now.
- A4 2.8 removing cats
- Buying 2001 1.8T (Laser Red)
- Any suggestions for where to find a set of 4 17" steel rims for the a4?
- Hey Starting, this came in my email and thought you might be able to use it.
- Feeler Post: What's "market value" for a set of used H&R Sport springs?
- Now I know why Starting has not been posting any updates on his car.....
- HELP! Could someone look at my logs and see if you can tell why this PC16 is so rich?>>
- B6A4potd
- Air filter is only recommended to be changed every 20,000 miles... but
- Brake Dust
- Spark plug gap.......
- need help 96 A4 door locks
- Installing test pipe and quik question. Can the cat come out through the top?
- How much should it cost to get a sport suspension installed on my B5?
- how is everybody have not been around for a while
- Finally ordered my Bentley CD... and this was all I got..
- ashtray removal for 1998 a4
- Leatherette Seat Cover Replacement (Looking for a DIY writeup.. Ideally)
- First flat on the A4
- Which gas is better?
- noob question: what year/engine did the 30v 2.8L go DBW?
- starting ... hows your widebody project doing
- Is 40k on a set of used stasis tracksports too many miles?
- 99.5+ Dash Conversion: Did anyone ever figure out how to re-wire the HVAC?
- Incase anyone was wondering which to choose - black or silver tint.. i just
- Please help. I need part numbers from an etka. last weekend, I changed my TB..
- Tinting windows on Silver 1.8T B5 - Black or Silver Tint? What percentage?
- ok so i replaced my starter and it seems as clutch is slipping?
- Any reccomendations on changing out my blinker fluid or clutch belt>?
- Throttle Body is shot: : Throwing a code , So what do I upgrade to?
- issues with my clutch>>>>i think its the clutch...(update)
- How low is too low? What damage could occur?
- Last Q! :-) Are these the part numbers for the upper control arms on both sides?
- Why is brake fluid change recommended every 2 years regardless of mileage?
- Alignment after replacing upper control arms on both sides?
- Haha, I gots the package Dave. Great stuff! Love the $4 multimeter, lol.
- those of you that have painted your stock wheels...
- REMINDER: San Diego GTG tonight
- 1-Piece Headlight Wiring Question:
- Any VW parts suppliers on the East Coast? I'm not sure, if Carson can do VW parts...
- <RANT> F@#K ECS Tuning!!!
- hood latch wont snap into locked position..
- Question about sill plates.....
- Finally stopped my coolant leak
- I put my K04/PC16 kit in a Passat over the weekend. It rips pretty good in a FWD...
- can't remove front seat
- paging 77'911 ->
- Vacuum line replacement
- sorry I keep doing this, but opinions on this A4? (Audizine warning)
- Jerking firing
- What should I check/do if my engine suddenly starts ticking
- Radio power question... (trading in my A4)
- does anyone have a writeup on adjusting grooved bilsteins?
- They're on. Hit or Miss? Needs to be raised a bit.
- 1997 a4 Fender Fit on a 2000 a4
- Can some1 tell me cost of O2 sensors + how many mechanic hours labor to replace?
- 3K NGK BKRE7 or something - half white half black (super small picture)
- OK - my bank 1 efficiency was a fubar CAT. Will a Lebree hiflow still still need a non fowler?
- Does anyone have a suggestion on a snowboard rack? or have one for sale?
- Now i know why they are all silver and black.....
- Oil Weight for winter?
- question about installing a K04: When did you put the coolant line from block back on?
- weekend mod/maintenance wrap up.. what did you accomplish.. mah day yesterday =
- Help for my little Bro. His car dies when it gets warm.... Info in Post...
- What battery is everyone using now? I want one that is a. . .
- How do you relay a ice link with cd changer?
