- Any UK folks in here going to Fast and Modified in July?
- Looking for advice on a clutch upgrade...
- engine codes... 17956/17536
- How do you remove the Crank sprocket? (w/o Airtools)
- cv joint removal. i put the axle bolt back in the cv to make it pop off, but the axle spins too
- I hate the stealer. I needed the crush washers for the fuel filter & they didn't have them...
- Diverter valve question
- ugggg rough decision to make: WWAWD
- Anyone have a Hawaii nav disc?
- Climate Control Problems...
- any tire suggestions, used Conti extreContact last season but I only got 26K on them . . .
- so took out my vacuum pump and graphite isnt smashed so put it all back together and
- Anyone have a HID that flickers on and off while hitting bumps...
- Anything else you guys would do when doing the PVC system?
- Iwasawesome: Sorry, I lied
- Putting the engine back together and found this : : : Not good.
- question about spacers..help
- World Impex is great!
- A4 reconstruction b5 vs mack truck (day one) *BWW*
- Since no one seems to ever be awake on the wheel/tire forum
- Replaced my battery, still low voltage
- I changed my first rear wheel bearing yesterday & it wasn't too bad...
- Cruise Control combination switch
- 2007 VW GTI what do u guys think?
- Alignment after wheel bearing change
- Getting the driver's side airbag 'resistance too high' code lately....
- wtf? did this guy just glue a bumper on top of his stock a4 ?
- Lemme get this straight...in order to change out the Front Lower CA's, you have to...
- Quick questions about Differential Maintenance
- I GOT IT!!!!!
- Do bigger wheels effect engine performance?
- Cruise Control Switch Replacement Part
- Tiptronic is having an electrical problem I think.
- Airbag light is stuck on after I fooled around with some wires behind the glove box.
- Pics from this weekend's Autocross
- My Ibis white project progress
- Driver Side B pillar wind noise- Does anyone know how to fix it yourself?
- What is max age of post u can reply to & will still show up at top of pg for those tracking it?
- All in good fun: Possible graph for Tightt's A4 ? ---
- Is there a Bentley writeup for replacing seals/dust boot in rear caliper? I thought there would be
- Now working: Alright, I've finally upload sound clips of my Borla exhaust to YouTube
- got a problem with my a4 1.8t fwd tip
- Does the 01 have the locking remote module integrated in the locking pump?
- Headlight BT: High Beams work (Both constantly on and flash-to-pass), Fog Lights work, Low Beams...
- This is bad right? Some clunking after I did TREs. Could this be it? CAs look pretty good.
- is replacing the radiator part of ongoing maintanence?
- My update... no where near as pretty as Adams...
- why does my door lock not lock from inside the car? it makes a pneumatic sound.
- Should my radiator fan stay on when temp levels are fairly high??
- headlamp height adjustersss....
- Just put in a Fuel pressure gauge and was wondering - what should the ...
- Easter Weekend Mods
- What a ride it has been...bye to the A4
- It was indeed the RR wheel bearing... I wonder if they'll do an alignment after it...
- no thermostat issue here.
- easter blog entry #1...my A4 hit 100K :)
- Thermostat Issue
- Engine Thermostat Issue?
- I can put an AEB engine in a 00 ATW car correct?
- Yeah, real fvcking cool. I love it when people egg both my car and my fiance's
- So will the RNS-D ( 8E0 035 192 B) Nav work in an '01 B5 with a Symphony?
- Which Camshaft Holder 3391 or 3243 for 99.5 V6 2.8 AHA ?
- Where is the turn signal relay located in a 96. 2.8???
- 1.8T cylinder numbering question
- Tip-Tranny ECU
- Finally replaced my front O2 sensor after almost 197k miles. I don't think it changed anything
- Tire question... posted there, but not much going on...
- Selling my 17" OZ SLs
- Stebro cat back. Yay or nay?
- Just when i though i was out......they pull me back in....Sopranos are back
- Performance Parts-Anyone Selling
- What is this... The second I'm in the market for an A4, all the AW law breakers stop posting FS ads.
- Few more...since everyone here has been so damn patient (unlike AZ!!)
- economic exhaust
- rear link arm
- Hooray!!! Pinched fuel line!!!!! (re: update on lean condition/fried computer)
- Audi A4 1.8T Engine
- Are there any negatives to tire stretching?
- Would an alternator be covered under CPO warranty?
- Where can I get ABS plastic? (To fill in Valeo euro-spec headlamp box hole)
- Easter teaser pic........................................
- Thermostat problem
- Tried a search but couldn't find, please help if you can..
- sway bar or anti roll bar?
- I am on the fence about a BM, is it worth the buck fiddy with an S3 kit?
- Borla Muffler on a 2.8
- A4 Navigation
- Question for some maintenance work on the A4...
- Found a cool video of the man in action:
- weird problem with xeonons
- Where to buy "green check valve" for 99.5 2.8 v6 AHA ?
- Dumbest thing I've heard in a while....
- Alright, out doors sound clip... nate you better post yours up soon...
- BEEEJ YOU'RE A GENIUS! .... i < U ... and a reminder for all the rest of yff's
- maximum bore for an ATW block? archives say 83.5mm is safe (more)
- Blog #5: Another few steps closer...Manifold back from coating
- Good news and bad news
- ive got a defi bf gauge for the oil pressure... do i just need to splice into the oil pressure...
- Will this rebuild kit work for my rear calipers?
- Control Arms - which will worn out first ?
- Great A4 on ebay for an enthusiast (not my ad).
- Is 100ml of fuel flow after one minute too little!!??? Man, my fuel flow is really low!!!!
- Nice A4 up for grabs... NOT MINE... (I'm looking for a sedan)
- Clutch just started to slip in my 00a4 1.8tq. How long can a slipping clutch normally last?
- Anyone want to trade their A4 for an A8?
- Need an opinion on some rims from ebay,
- steering column switches
- For all you with cluster pox... heres a GREAT deal
- replaced MAF after failed emissions and my car totally bogs when i tap gas, read on>
- Spikey boost with APR 1 bar chip questions
- Dayum, worked on a customers 98 A4 Thurs... broken rear spring (stock) --->
- Would having a failed post cat O2 sensor cause my gas mileage to suc or anything else to my engine ?
- need online owners manual for 1997 AUDI A4 2.8 quattro
- sigh, sold the B5 today..
- After taking our time (since we didnt get her finished for the South FL G2G)....
- Wet sex, a blood transfusion, and 2 questions that could probably be answered by STFA'ing.
- Today's build update
- V A G Help?
- ko3 wastegate troubles
- CD Changer pin locations needed 98.5 Avant
- Help, turn signals stoped working
- Punctured the boot around the piston on the rear caliper tonight :(
- Anyone know where I can buy a set of Moda or Radius R6's?
- Met up with a Victoria enthusiast today to work on his car... AL2K
- Resurfacing dual mass flywheel
- Engine mounts done,
- Introducing the JHM "Solid" Linkage Upgrade for the B5 A4 and Passat
- Front axle shaft replacement
- New Spark Plugs
- Audi/VW G-005-000 Manual Tranny Oil "use until" date
- Good call, Carson, my turbo was toast...though not really what I expected.
- Link to reset "service oil" light?? 99.5- can't find in faq. thanks
- Car stalling, surging when hot, no power intermiten EXPERIENCED GURUS HELP PLEASE( kinda long)
- So I got some Baaaad ideas...anyone know where I can get a junk 1.8t head for real cheap?
- PureMS :-: Preorder Sale on Vogtland Coilovers!
- Valeo Ecodes....
- Real Quick...can i do some prep for TREs' and CA's......
- Does the emrgency relay/flasher have anything to do with the cruise???
- Engine chugging, power gone help!!!!!
- Pictures of the new exhaust installed (dirty car/bandwidth warning)
- A little taste of what is to come
- New Lights/turn signal switch is on....Thanks ddrieger for pointing me in the right direction...
- What size intercooler can I fit under a stock bumper without much modification.
- My friend who gets the Cayman loaner car got a manual trans today. 100x more fun than the Tip
- Phisherman Fakes the Funk with Bogus Email Scams
- Harbor Freight has the quick valve oil drain plug...$2.99!
- HELP!!! Transmission Problem!!
- For those that have followed my issue ... It was in fact the wire running to the CP
- Awesome-o. Exhaust is being installed right now and will be done in the next couple of hours...
- AWE Tuning Package Special for April
- I think I just did something really bad. Please confirm.
- well i got my CA and TRE kit, bearings and brake pads all done last night (all in 6 hrs), but . . .
- Sold my car...
- Can someone pls. explain in simple terms what control arms do & what happens when they go bad?
- Anyone know of anywhere else that builds tip trans besides IPT, Level 10, or 2 Bennet?
- Hey Mike 2.0GT35 wondering if I could pick your brain some more?
- A4 Sport seats VS Comfort seats...
- Wierd. I just saw a post down vvvvvv a couple, and realized that I came up with CAPS..
- Keyless entry
- CPO warranty about to expire. Help me with ideas
- Can someone explain to me how a DIY pressure tester works?
- How to adjust the exhaust bracket supporting the downpipe? Thanks!
- For CAPS times, how can I figure a correction factor for different tire diameters?
- rebuild blog entry #... umm, don't care, I'm too tired
- *Added Link* Update on issue ...
- need towing capacity for (newer) B5, man. or avante ...couldn't find it in 00 manual...
- that one hurt! since we are on the week of smashed, crashed and burned audis
- I still smile when I walk up to this car... after 100k. Jeez.
- # i'd give her a real 8A0-501-387-D... and let her lick my N-906-350-01s...
- Airbag dash light
- Bump Steer?!?!
- What is the deal with my horn?
- Here we go again...
- hmm oil temp guage doing some funny stuff...now to find the sender.
- Hurray, my car threw codes!! P1128 and P1130. But I replaced MAF and no different, ideas...
- should I risk the 4 mile drive to the parts store with a dry power steering rack?
- how long would it take 2 or 3 guys to replace all front control arms and tie rods and both bearings?
- anyone use http://www.germanimportedparts.com/ before?
- next time the tie rod ends come around i am ready!
- quick: negative % fuel trim on vagcom: does it mean i'm running rich or lean?
- paging nunya: what kind of numbers does your homebrew setup make?
- FARK.. big blue puddle under my car, power steering reservoir is dry, power steering making noise
- For the wiring can I buy the wiring from ... an autozone? As long as it is the correct gauge there
- Rolling shot videos: Flik Justice vs Flik Artics (black)
- Anyone have a working driver side foglight assembly they want to sell me?
- Well.. I'm about screwed.. I could take the tint off the front, zip tie the plate on the front..
- Where do I find GIAC J31 programming (nowadays) for a K04 setup? STFA
- Ecode phishing scam. Someone is sending emails asking for CC data on a fake site. Beware. xpost
- ABS Module Rebuild -Suggestions?
- Maintanence + OCD = Spreadsheet
- I'm getting conflicting info as to what size/length flywheel bolts that I need for an AWM with UR
- Anyone have a ball pivot housing for sale?
- Question about spacers and offset
- HA! Now I've got Motive too. . .
- New grill, New rear window spoiler, vvme hids and claybared & buffed
- Ignition coils - again
- How excactly do you remove the pins from the connector for the coilpacks?
- Mad Horsepower!!!
- Stupid quick question: what size is the ko3 inlet?
- WOOT!!! Filled up this morning!!!
- Ok, pictures of the exhaust for real this time AND the old engine and transmission mounts!
- Where is the headlight warning buzzer?
- Opinion on stock sized rotor for a DD?
- Toasted Avant Pics
- Wow, I never knew about this track being built...
- I'm going to run a vac line over the turbo... Should I give the auto parts store type rubber hose a
- Does an ECU need to be reprogrammed if putting a new one in your car?
- a few action shots from this weekends driver's school at Autobahn Country club
- i need the part# for the n75 hose that has two diff diamaters. tried searching
- Update on the front-end noise
- will 225 fit on OEM 15" rims ? or is it too wide ?... thanks
- We got DUMPED ON with snow last night.... Quattro weather.... and I'm driving a TDI Poonetta. ;-(
- what's it worth.. s4 rear? bumper + lower... silver (fastest colour).. i need to get rid of it
- ModifiedA4: Did you get my email in regards to this?
- my current B5 A4 is probably worth 5K max.. 140,000 miles, a laundry list of problems.. Parts car??
- will 01 suspension fit a 99.5 Q
- Noise coming from right rear wheel... It goes away around curves and does not change when I brake...
- Swapped the wheels today, flushed the brake fluid, changed filters and cleaned up.. BWW lots of pics
- It's official...I dont' think I'll ever understand how this ECU works w/DBW...
- Anybody selling a set of B5 S4 (Avus) wheels???
- Anybody looking for an inexpensive second car?
- Update On Justdave mod: One more layer of primer and she's off to paint.
- Car trouble. Any help appreciated.
- ZOMG DUNGBEETLE YGM! FOR CEREAL!
- source for front axle shafts
- Maybe some good taste?
- anyone ever purchase from autopartswarehouse before?
- How important is it to change brake fluid every 2 years as per manual?
- IC Service for Pre-Cats - Dealer won't return my calls :(
- My new show car
- does anybody know where i can get a carbon fiber hood for a 95 S6
- New(er) Audi poll
- anyone have the post with all the cheap audi vendors listed?
- Intake vacuum line (I think) part #?
- Part # request for the Etka pimps: pass. side window regulator for the wifey's '01 TT 225 coupe.
- (Xpost) What blocks should I log for my bouncing boost/soft limp mode issue?
- Tempted to try these out as a replacement part for the $$$ stock part.
- Fuel Filter Replacement
- Which MY sports (cloth) seats come with airbags in them? Already searched ...
- Update 2 on fried computer/poor running: not the fuel pump...
- The loot, THE LOOT! Somebody get the loot!
- One set of Pauter Rods available at special pricing..
- repost: new empi axle from germanautoparts $100 or rebuilt from raxles $175?
- CD mode stopped working suddenly
- Hey Joel, in the interest of keeping you on the right side of the law...
- Replace my exhaust?
- Turn signal crapping out
- any thoughts on easiest way to remove top washer pump from reservoir?!
- Every dealer I called is claiming they have no idea what I'm talking about when I say a repair kit
- Milestone reached today, but I missed the Photo-Op....
