View Full Version : A4 (B5 Platform) Discussion
- my Audi A4 b5
- Certified pre-owned
- LV: A4 B5 1.8 engine rattle
- 2.8 Overheating, P0117 code
- Help buying a b5?
- Transmission Compatability...?
- ZA: 1997 Audi A4 2.6 V6. owner's manual?
- Piston question
- 2011 Audi A4 Excessive Engine Oil
- clutch flywheel, need help!!!
- ECU Programming File required
- which ecu for 1997 aeb dbc?
- 2001 A4 B5 Quattro
- 99 Audi A4 Quattro 2.8
- Need help diagnosing MAF sensor
- No crank No start
- Spark plug melt..
- 1997 Audi A4 Electronic Systems Malfunction
- HR: 1996 1.9TDI fuel starvation problem
- Audi a4 2001 2.8 V6 5smt wont go into reverse
- FI: B5 Sedan automatic trunk opening
- So who are you people anyway?
- 2005 A4 1.8t Cabriolet rear pass. regulator fix
- Immobilizer problems
- My thoughts on P0441
- 2002 A4 1.8t losing coolant and no turbo… where to start?
- Instrument cluster beeping but no display
- Head Gasket Replacement and more
- Airbag light on
- DE: Mystery with ABS ⚠️🛑
- Weird problems with windows and door unlocking
- Connector name ? Buliding 30km/H PKW
- DE: Hard acceleration makes car hiccups
- Another Misfire Thread
- Help with stereo!
- BE: Need Help with Window motor
- Air Flow Flap motor G113
- LT: Passat B5.5 Armrest into A4 B5 Prefl?
- car wont go into neutral? feels like its stuck in a gear?
- GR: AUDI A4 B5 95 1.6 shows E2 at climate control
- Need help? 2008 Audi A4 2.0 Quattro mileage expectancy
- UK: Help?
- Avant 2.8 Catalytic Converter
- A4 2.8 quattro rough idle no power (limp mode)
- Climate control problems
- In need of mechanic in Peoria that could inspect potential A5
- 01 Broke Timing belt… what should I do?
- MFD light that I can't figure out
- navigation software not working
- Should I buy the extended service warranty?
- Partial EDL disable - drift mode?
- engine stall after ~15 mins
- 2001 A4 Avant 2.8 Quattro Suspension info
- MK: Hello
- A4 B5 cranks but no start , no communication with ecm
- Shifter linkage help please.
- 17748
- Intermittent Total Dead System
- Heater hose source
- LT: wheel bearing seal type?
- 1999 Drivers Floor Wet
- Can’t figure out what this oil line is
- car shuts off if/when MAF sensor is plugged in
- 1997 A4 1.8T A/T Transmission issue
- PES G2 ECU for 2.8L 30V AHA (drive by cable)
- Driver Side Door Mechanism Problems
- 2.8 V6 rear engine coolant leak
- LV: Audi A4 avant 1997 1.9 TDI
- Strange sound from my Audi A4
- Just bought 2000 Audi 1.8t with the following mods....need guidance.
- P0153 P0160 1999 Audi A4 B5 2.8L V6
- Cant figure out oil leak. NEED HELP ASAP
- Need help diagnosing what the problem might be
- Cluster: Needle calibartion help
- coolant crossover pipe 2.8
- NO: I need wheels and i need inspiration or tips
- How to clear check engine light codes
- where do y’all find your parts?
- Indicators
- Fuel pump not getting power
- 1.8T AEB 110kW wastegate measurement analysis
- good engine mods for audi a4 2001 Quattro V6 2.8L?
- 2.8l Marks on camshaft don’t line up with marks on camshaft caps
- 2001 A4 Quattro outer CV boots started clicking and are torn
- early 98 2.8 cylinder locations please so i can get home!
- Another "Hooked front bumper on upstand, damaged it on driving away" thread!
- Brake Fluid Reservoir A4 B5 2001
- '99 A4 2.8L 30V CCT clicking and chain skipping
- audi a4 quatro wagon 1998?
- Owners manual for Audi A4 1996
- Replacement exhaust system
- Door Compatibility
- Cut wire?
- Need help with Fuse 5
- UK: P187A00 P187B00 P081100 P17F900
- 2002 Audi A4 quattro 1.8t B6
- 1997 A4 2.8 12V Sputtering/stalling when at operating temperature
- Any alternatives for out of stock coolant hose?
- How important to match tires (2017 A4)
- Darrian’s 99 A4 build thread + Pre-Facelift RNS-E install
- Suddenly parking light on blows the fuse
- Wiring Diagram suddenly gone from the old place on Internet
- Inner cv axle bolts snapped
- Car wont start
- Strange Negative Vacuum Situation
- Does a black preface headligner for avant exist ?
- Wipers won’t shut off
- Car shakes and doesn’t start with key fab in need help!
- Climate control unit doesnt work.
- Rattle sound from the suspension area
- 4th gear issue
- Brake fluid reservoir pipe replacement
- Oil light issue
- Front/Rear Premium Cross Drilled and Slotted Brake Kit BRAND NEW
- Paddle shifters not engaging
- 2001 1.8t burns oil
- Best Audi mechanic in Raleigh,NC area, other than the dealership
- B5 A4 2.8 Complete Exhaust
- Train Horn?
- How to remove back middle seat belt
- Online Parts?
- Audi a4 b5 afc no start
- Mystery High Idle
- 2.0L TFSI knock at startup
- Wanting to build my audi 1.8t quattro to 500 bhp
- 1.8T injection upgrade questions
- ecu no fuel issues
- Help with part(s) identification
- Ticking noise
- IT: A4 Avant diesel
- 2017 A4 Premium Plus
- 2002 A4 B6 Quattro wiring diagram needed
- 1999 Audi A4 1.8T Quattro Wiper Fuse Keeps Blowing
- ecu
- I solved my ABS-absence which was hopeless - Bosch 5.3 ESP
- 2001 a4 1.8T - ecu pin out and engine wiring diagram
- Thermoplastic available?? ....or next best material
- 1996 Audi A4 Quattro 2.8 No spark
- Missfire, rought idle, no power and ecu no communication
- 2003 audi a4 1.8t quattro
- 2.6 to 2.8 30v
- 99 a4 b5 transmission problem
- How fun is the B5 A4 1.8T?
- Third Brake Light Wiring Harness Help needed
- 98' 2.5Tdi v6 weird boost
- Santorin blue avant?
- Timeing
- 1996 convertible wont start
- getAudiparts.com | Last Minute Holiday Savings Promo Code: HOLIDAY2020
- I need B5 experience for my '99 A4.…in or near San Diego County
- I need B5 experience for my 1999 A4.…in or near San Diego County
- Tiptronic Transmission Problem
- Audi Steering problem
- Temperature Problems
- Can a defective ABS block cause a by-passed brake?
- P0012 Code Won't Go Away...
- NO: Breaking system: Soft pedal and an “internal piss-like sound”
- Any idea?
- Boggs and dies
- Coil packs
- Audi A4 B5.5 Facelift - Alarm Guide
- Drivers door adjustment
- getAudiparts.com | Black Friday/Cyber Monday Promo Code: BFCM2020
- deAutoLED Black Friday and Cyber Monday sales are LIVE NOW! Best prices of the year!!
- Weird door sensor issue
- Headlights work when 'flash' lever held only
- Mnaual B5 Rear diff locker or lsd options ?
- bad auto trans problem plz help
- Black Friday Sale Starts Now 10% Discount use code : mbenzgram
- A4 B5 non-DBW Cruise Control Indicator DIY
- Timing belt dilemma
- APR . AWE . Dinan and more products available
- Burning Plastic smell
- Auto Climate Control Module
- Audi A4 96 auto transmission problem
- LV: A$ B5 quattro 1.8t or 1.9tdi ?
- No crank, power windows after heater core replacement
- 5V diagram
- Over-engineering the testing of NDBW cruise control
- 96 2.8 fwd auto
- Electric fan sounds like jet engine - what should series resistor value be?
- A4 everything good except for engine
- I am cursed - Back into "all keys lost IMMO"
- Has anyone managed getting the VAG Commander to work with A4?
- Has anyone got the VAG Tacho 5.0 to work on B5?
- Brake system bleeding - the RS4/C6 ABS
- Vacuum Diagram 1.8T - I know all hoses except one
- LEDs for pre-projector headlights?
- Gear knob removal on manual shifter
- A4rims/tires
- Bosch fuel pressure regulator - Same format 3.0 & 4.0 bar?
- Battery/Alternator problem + parasitic drain
- PCV
- Oil cooler failure?
- Audi says I’m on call with myself..?
- Spare tire anchoring bolt for full-size wheel in trunk
- Q5 (8R) 2014, 2.0 TDI Automatic, AC sudden stopped working
- Low miles PES G2 ndbw supercharger available
- A4 Electric Windows Problems
- My Free 2001 Audi A4 1.8T 5 Speed Manual Project
- Pes g2 giac chip swap
- Mmi 3g basic problem
- Interior plastic sticky (a4 2001 1.8t)
- Exterior detail on my '97 B5
- Resetting mileage: USB-interface with software that WORKS on B5?
- 2001 A4 1.8T, No OBD connection and crank/no start
- Can somebody help me retrieving the PIN?
- Software compatible for VDO D12 cluster?
- Fast idle issue
- I bought another B5!
- Major AntiFreeze Leak
- A4 2.0 2010 Quattro overheat then no start until get cool
- A4 2.8 rough idle & stalling
- Vintage A4
- NO: How incredibly good are the valves in the 1.8T?
- A4 b5 electrical issues
- Code p1136
- Temperature Sensor replacement
- 2.6 to 2.8 engine swap issues
- Does anyone have the elec. wiring diag for the instrument cluster for the 99 A4 B5?
- My B5 baby might be dead. Sell/parts options/advice
- What is this plug?
- B5 1.8t starts and dies after valve replacement
- 2004 audi a4 3.0 oil leak
- A4 B5 avant won’t charge correctly
- Audi a4 b5 1,8ts misfire issue att 5000rpm and 0,5bar
- 96 a4 2.8 ecu halp plz
- LONNNNG SHOT A4 B5 Spoiler
- Cambelt replaced tooth misalignment
- Faulty ignition / intermittent starts
- More engine swap questions
- Tire questions!
- 98 Audi A4 1.8T - Lights Stay on When Cars Off
- Bluetooth
- 99 B5 2.8 Ambient Temp Sensor replacement
- My 23 yo 1997 A4 1.8t project
- Side airbag resistance too high
- Propeller Shaft End CV-Joints - Look here
- Strange engine noises at particular rpm
- U-joint propeller shaft replacement - risky?
- Bose radio to non-Bose system
- LV: Fuel gauge?
- Interior fan blower stopped working
- Steering Knuckle - There are two types on B5
- Window regulator maintenance?
- Which software is the real deal for obtaining the PIN-code to operate?
- Rear wiper goes backwards and front wiper onset opens the trunk
- 2004 audi a6 3.0l Transmission Safe mode
- Please help me with electrical error
