- 1999.5 Audi A4 headlight washer
- Bilstein warranty experiences?
- So the local Stealership told my dad his 96' needs a front subframe.... any good sources ?
- 2 pins Missing out of 5 on door latch/sensor connector? Normal?
- Ok so riddle me this Batman...
- pretty much all Audis have the gimp up til '99?
- I tried... Will a B7 split 5 spoke wheel fit a B5 with the 235/45/17 tires?
- Lost to the pinch bolt...
- Hey so I should have some time during my motor install to take it nice and slow
- Finally!!! I've gotten rid of a vibration in my cars front end after replacing...
- Win some, lose some.
- Any suggestions on how to lock the Flywheel from moving to break the 17mm bolts loose?
- May be one of the last photos I take of her....not the Audi, but will be hard to part w/.
- brake fluid reservoir cracked
- The inside of the original fuel filter after 132K
- Any advice and/or comments on repairing this . .
- WTB: Front license plate holder, Yakima/Thule roof rack
- anyone have pics of how to remove the door panels?
- Airbag light on...... Question......
- Turbo newb constructs first build list..... please critique...
- woot my s4 parts are here...
- Alternator came in..it is a little broken...
- Is the Bilstein PSS 10 coilover system offered for the B5 A4/S4 in Freedomland?
- VAGCOM Noob.. Can I log block 115 on a 99.5 AEB? Looking to graph requested/actual boost. STFA'd.
- Just finished installing new transmission PITA
- Annnnnnd . . . its in!
- What are the average going prices for A4s these days?
- Is something supposed to go here?
- Worth it to replace accesary belt tensioner and roller while doing TB?
- Does this 2001 1.8t look like a hit to you dudes ?
- *stops and thinks*
- purems down?
- Anyone know who's car and girl this is? Found it in an old 2004 archive of mine.
- Alright! Who here did this?!
- Anyone heard of Seibon CF products? quality? fitment? hood would be ~$700 shipped.
- So, what's AW's guess on how much longer my clutch will last?
- Oil Inspection flashing
- Poll: Do you use dexcool coolant in your B5 or stealership, more expensive G12 coolant?
- MAF Problem? MAP Problem? What to do now - need some advice.
- has anyoned tried this i have some alum wheels
- Weekend mods?
- Anyone else have an A4 that has all of the common problems? inside driver's door handle did the snap
- Brake lockup
- What product is good for cleaning the steering wheel?? Mine is so shiny, it blinds the
- What airbag is this?
- Engine ligh is on
- Using plastic to trap nuts FTL. Another should be simple thing turns into a 4 hour PITA
- 1998 Audi A4 100k miles P0302 CEL 2.8L V6
- So what's the best turbo upgrade to buy ?
- Any B5ers in or near West Los Angeles?
- Hello Audiworld..... I turbo-newb and looking to purchase my first A4 1.8t and was wondering if...
- Anyone have a spare driver's door non-Bose door speaker? Mine is blown.
- CL Find: stock clutch
- do i need a special program to run a ko4 turbo???
- Upgrade to the spouse's side of the garage today...(puts on flame suit,just in case)
- Fast power steering leak
- Soooo... what do you think I could get for my A4 with the blown engine?
- I'm bored at work...Thinking about fast cars...I want one. How much to budget for a 034 VR6t swap???
- Some pics of a recent project if you are interested... [LONG and full of pics]
- Anyone have an auto-dim mirror with compass for sale? I can't stand this anymore.
- Stock Front Brake Caliper Carriers Worth Anything?
- Anyone have a parts car
- Is a nearly new OEM leather shift boot worth posting in the classifieds?
- shipping car to cali from NY, advice?
- 2000 A4 1.8 lost last key...what to do?
- My AWE DTS is hitting the frame and causing lots of vibrations. I no longer have my original...
- Installing Apikol snub today. Any advice or tips?
- Damn, my gas light just came on, DIY?
- wiper blades: DIY or should I take it to a shop?
- How long does it usually take to change a headlight bulb...?
- brake light change
- does anyone know how to remove a stripped rear axle bolt? The bolt head is rounded out.
- Paging Audi Junkie.. Is the Redline 5w-30 the right type II oil to use with the Auto-Rx...
- Anybody know if new-style front swaybar links are sold w/ hardware?
- Help please, headlights don't work.
- Paging andysprague ......sorry I was at an interview for way longer than I expected today....
- Found a FMIC FS.... i don't like it, but it would work fine....
- Audi Transmission/clutch question
- Cl find: bbs rk rims anyone?
- Funny CL Find: BOV stands for?
- vag com
- spacer - how much do i need
- That doesn't look right...
- Anyone here into kart racing? I am looking into getting into it... and i guess my question is what
- looking for a stock or replacment exhaust for 96 2.8 FWD
- Last call before I pull the trigga on a Stage 2-3 clutch kit. Bang v Buck, any suggestions?
- Rear brake rotors...... HELP!
- Maxscan
- WWAWD - Winter prep on a budget.. more inside.. c'mon in.. I know you want to..
- Could a clogged PCV system cause an engine ticking noise for 1st 2 mins after startup, hot or cold?
- Reading posts for a year I now have a question.
- what is the going rate for a working ABS module from a 2000 A4?
- Wheel clearance at Achtuning, new selection and lower prices!
- Airbag light
- any euro based gurus? help me understand immo
- My car is now ding free! Amazing how those things spread parking at the airport every week.
- Reminder: Hartford GTG is today!
- Brakes
- Fuel Filter info...
- Drivers seat started to tear out on the left side ....
- changing thermostat - as per Bentley?
- What the fudge? 1" of H2O in the spare tire well. Nothing else wet.
- lookin for a corvette and this came up...never seen one before
- Oil leaking from filler cap. (1.8T AEB) STFA.
- ski ya lat..... check out www.vagcat.com
- What's up with the verticle banner ad for LLtek? I think someone put the pic in the wrong place.
- VAG block 115 N/A?
- coil packs
- Quick thought. Only thing I've changed in engine bay has been putting modded stock airbox back in.
- Anyone selling a new or used FMIC before I buy one elsewhere?
- mystery leak :(
- Anyone have an extra one of the clips that keeps the wastgate rod on they can part with?
- Audi Extended Warranty Group Purchase, see inside for details if interested
- Anti Rodent system?.....
- Are all cars with the Delta radio prewired for CD changers?
- Erm, please don't laugh....
- Quick question about GT28RS setup.
- can anyone explain how these cam covers get rusty? on a new motor?
- Wheel Fitment Question
- Does anyone sell pre-made FMIC piping for our cars.
- Safelit denied fault I'm not paying them to install this ****e glass again. <bangs head>
- Battery problems, wont hold charge.
- Question for the 2.8 guys: Installing a supercharger
- Finally eliminating soft limp (N75). Can someone please confirm that it is the ONLY likely problem.
- Happy day! Tomorrow @ 8:00am the spoon man commeth.
- Help: Handling Problems
- Anyone have the piece of trim that encloses the back of inboard seat track on the PS?
- Anyone selling an A4 avant tip? Might be in the market soon.
- Tie Rod End and Strut
- Anyone know a good Audi mechanic in the Miami, Ft. Lauderdale area?
- Does anyone have a set of side skirts for the b5 platform, need s4 looking ones.....
- Door chime keeps going after driver door is closed, icon shows in display
- Funny how you can tell who has the FAQ tracked....
- Northeast A4 owners......
- Any Suggestions for a nice looking mesh grill?
- had to dismantle mirror to put harness in. Not too bad...
- How the hell do you switch from icelink UI to iPod UI on a dension icelink?
- Audi A4 B5 quattro powersteering rack and flex pipe
- B
- Thanks Chris it arrived today! Yeeeehawww, I will be un-Gimping my car tonight if all goes well
- need to replace fuel filter what will it cost at dealer?
- For those of you who have had to replace the fuel pump in a B5...
- What does a bumper bolt screw into? The 2 long allen ones that go up into the cover near the grilles
- clunking on rear left wheels.
- Snake Oil
- Winshield #3 becomes #4 tomorrow. All I can say is I hate Safelite AutoGlass.
- Almost 100 B5 V-Maxx Coilover kits on the road...
- Piston or Diaphragm DV?
- installed Stern Power Ring...
- tie rod end won't come off inner tie rod...
- Intermittent Won't Start
- Timing Chain Tensioner
- New to AW, so please allow myself to introduce myself *Pics*
- Grills
- For those of you that want to see just how crappy the lower engine to trans bolts are..
- What's a Tip steering wheel with airbag and ring worth? Pulled one today and can't find any Ebay
- See my MAF code post about 8 threads below. Here's the log. Whaddya think?
- Speedometer doesnt work
- could someone run this vin # for me?
- Does anyone have an ICM near Fort Washington PA?
- Joey T, check out my cam timing. Does this look right?
- How can I get the 4 digit pin for my car? Need it to swap ECUs
- just got my stud conversion
- burnt oil on the top of a few intake valves
- Seriously, why can I never take decent looking pictures?
- YFFs- Fram AirHog reusable filter...FREE @Amazon.com!
- 034 Street Density motor mounts are in! I didn't realize how bad my stock ones were
- Late night post... I miss my car
- Come with me on a virtual B5 tour of my town and the outskirts. Cue Life Blog...
- about to try an ACK ecu in my AHA car. Anything I should beware of?
- CEL & Low Boost Problem. Suspect MAF is bad. Opinions?
- CV's Done! Thank you for your help!
- Could one of you guys please share the torque specs for AHA motormounts/brackets.
- Got VAG?
- i got a '96 a4 and im trying to get a keyless entry remote because i went
- CL Find: Taillight anyone?
- A few pics; and the first detail since I got it.
- Any tips for removing the lower three engine to trans bolts?
- Widebody Update: About a year later...
- Anyone want a 3 inch v band testpipe? just shipping
- anyone have a good 98.5 or less hazard switch laying around?
- Paging ModifiedA4
- Can I take a sport steering wheel and airbag from a '99.5 and fit it into my '97?
- Need Brake help fast
- Should I Replace Cam Chain Tensioner Along With Gasket?
- I have a 2001.5 A4 1.8t avant, w sports package, how do I know if I have 75mm or 82mm wheel bearing?
- is there a way to find the fcc id in the vehicle?
- what does a used ko4 usually go for?
- what type of small/lighterweight batterys are you guys running?
- FYI - Our cars should have one huge vband to mate the trans to the engine.
- X-post. Help! h-sport front sway install
- so bad I had to share "The B5 RS4 Sedan"
- Need new stock rim for 2001 Audi A4 2.8
- transmission problem
- * Personal Blog: Stardate 9.12.08 * H-Sports have arrived.... getting food and beer for night time
- Exhaust Rust: Anything to be concerned?
- Ipod question.....
- OEM Sport suspension replacement opinions
- Another stupid wiper question
- Wondering what the best solution to stripped screws would be
- Premium fuel only?
- Can someone tell me if 98 2.8's came with stock 2 piece projectors?..
- anyone know what ohm resistor I'll need to bypass the driver's seat airbag?
- Mike@PUREMs you around?
- B5 A4 reliability - please sign up
- There's a future driver on his way in my family...
- After getting my LED License Plate Lights to work, I still have the bulb out warning at nite time on
- X-Post - B5 RS4 Hood Grille Stock Elimination Sale - Riverside Audi
- anyone have any brake issues when replacing rotors and pads.
- Weekend Mod/Maintenance Thread -- What's everyone doing this weekend?
- K03 Hybrid sound
- So just got back from driving my 1st 1.8T MT Avant (1999). Pretty much felt liket the 1.8T Sedans...
- 1.8T exhaust drone? Please advise
- H20 B5 g2g details........
- This oughta sell quickly.
- I'm running ecs slotted rotors, mintex redbox pads all around...
- brake rattle when coming to a stop
- what plugs are you guys running for a 1.8t K04 set-up or what do you recommend??
- 12V vs 30v V6 - What's the deal?
- AZ POTD:
- :: ECS Tuning :: ECS B5 A4 V6 30v Timing Belt Kits - New Pricing - Free Shipping !!!
- anyone have wood beltline trim for sale? I want it for my 2001. Just want the 4 doors and 2 dash pcs
- Well, pretty sure I got screwed by a long time AW member. Be careful who you trust from this board
- Insurance Question: Collision or No Collision?
- SilverStreakin. check yo intraweb mail foo..........
- Good deal or no???
- Paging Joey T... quick question for you
- Solution for maple tree sap? Tried to get it removed with rubbing alcohol and eventually clay bar
- Woo Hoo cold air!!! Just took my dad for a ride up through the mountains
- front brake are clunking at low speeds..
- a4 tiptronics to manual trans conv
- Paging JoeyT
- Talk about cold air. You guys are missing out. Already in the 30's morning with zero humidity
- Tie rod replacement for dummies..
- Just switched to Amsoil 5W40 European Spec
- anyone know the book time for awm motor removal?
- Paging Mike@PureMS: I need new engine mounts. Can you please e-mail me the details on your new ones?
- Local Hillclimb Event this weekend. (B5 content)
- I'm going to go drive a 1.8T tomorrow at 7PM. Could be dangerous to do for me
- does anyone have the write up for the steering rack replacement? the link is dead in the faq.
- car wont charge battery, B5 1.8T
- Anyone got a K03 sport turbo kickin' around?
- Last CL Find: APR 3+ injectors
- CL Find: Random b5 front parts
- CL Find: Who was looking for a 1.8t engine?
- I STFA but AW search sucks. Anyone use a tape adapter to play an Ipod?
- Got my Osram Nightbreaker +90% bulbs today from across the drink
- Sad thought I love mine so oh very much, but have thought I may want to start looking...
- Some jerk thinks he's REALLY funny.
- Which block on Vag-com for rear 02 sensor? more...
