- Sunroof repair question
- damn good thing i'm replacing my parent's tbelt. the old water pump feels like craaap
- ECS Stage 1 - 13.1" 2-piece rotor + Porsche Calipers Possible?
- Woot......look what USPS delievered! [/useless post]
- Headlamp on '99 A4 - high beams work but not low??
- WTB - Bosch Euro Headlights
- Upgraded my boost gauge install today. Replaced plastic with . . .
- Ok, what am I doing wrong with zee boost gauge?
- cool audi f1 video... OT
- Got brakes?? (and dirrrty wheels) =)
- Clean a$$.......
- Cheapest wheels in the world? RS4 & RS6 replicas + free shipping
- Link in FAQ to FSM not working
- Well this is interesting...Audi is moving away from free scheduled maintenance...
- are the clips holding on the bumper cover of a B6 similar to a B5? i'm never going to get an answer
- X-post: Dealer Parts Locator. (Helps find those parts that the dealer says they don't stock anymore)
- When using A8 rotors in a Boxter brake upgrade...are there any issues utilizing an aftermarket...
- wheel stud conversion
- Difference between 99/99.5 A4?
- SCC Audi's March events -- Angeles Crest Drive / The Stand GTG / Buttonwillow track event
- Brembo Rotors abs sensors problems
- remote starter
- another awesome vortex post...
- Eurotuner editorial linked on APRs website
- free altezza mod with fence removal help
- I have an unistalled Autometer A/F gauge. Is it a waste of time since its not wideband?
- theres an a4 1.8t that ran a 12.001 1/4 mile here....
- ecs or purems?
- I just ordered the 42 Draft Designs oil pressure relocation kit. Anyone running this?
- Front Turn Signal Socket: Is this a dealer only item?
- Have to go back to stock 16" rims for a while. The best tire size for an all-season? 205-55-16?
- Lost a hubcentric spacer ring! : /
- slow throttle response (1.8T)
- Anyone have any pictures of a DTS install, I lost the instuctions since it has been sitting in my
- For those you are interested in a Milltek exhaust: I found a tuner to fix my milltek alignment....
- Update - Oil change procedure for men & women
- Is timing belt easier to do on 1.8 than 2.8? I did my 99.5 2.8 a few months ago and I'm about to do
- It's not much - but I took the forum's advice and swapped my stock air box back in today.
- Update on Boostd... dealer thinks he needs a head cleaned/stuck open valves
- looking for beige interior color code, not the code in part no's but the one in the service manual..
- idle drops off. need some help
- Some new pics from this morning
- Testpipe | Non Fouler poll
- Just installed H-Sways...
- So..My new problem... (long post)
- Brake issues...
- k04 installed :) need some advice on fpr
- What to do for performance mods
- Poll : Worst stunt ever pulled on friends or enemy during HS ....
- Update: GIAC FX-K04 file installed tonight. Checkkkkk it outttttt.
- Worried my rear diff, or perhaps a rear bearing going bad....
- a4 30 valve performance??
- out of all the dumbass things to do
- Looking into a 99 2.8 Quattro
- anybody here live near/in secaucus NJ that cares to lend a midnight troubleshooting hand to an AWer?
- Suspension decisions...
- Can you guys post pictures of Pearl White with 20% and 35% tints?
- S4 suspension on an A4
- Any experience with Grooved Bilstein Sport Shocks???
- swapped foulers before leaving work, kept cel and got a no activity code as well. a faulty 02 sensor
- Which Vacuum do I need...?? Anyone have a PartNumber for me??
- kevcpA4.....your car looks awesome.
- Anyone running AWE's K04 PC-16 Kit?
- whaddya know, a good experience @ the dealer
- xpost, Tell me what my car is worth? I might be trading it this week.
- Price to install xenon kit?
- Pol(e): What spark plugs are you running in your enigne? Soon to be changed NGKs for me.
- New to the Audi world
- Factory Service Manual
- its time for a seafoam writeup someone....
- 1 more sea foam topic w/question.
- FWIW: SSR GT7 (17x8.5, ET35) do, in fact, clear Stoptech 332 mm fronts...
- Disengage push down on manual shifter
- I'd just like to remind you to drive with a constant awareness of your surroundings
- Paging Mike@PureMS. A4 Left rear window regulator. Is the price right?? Its like 2x other side.
- 6hrs 10mins later TB, water pump complete. I would like to says.... (long)
- 2001 A4 1.8T with 45k. Am I pushing it, or should I wait until 60k for a t-belt change.
- What would you guys do....
- Part of my instrument cluster just went out (0-30mph)
- Can/will a mechanic charge me for parts he installed and didn't solve my problems?
- ok, i'm being a little slow here... need help w/ timing belt tools on my 12v
- Cheapest source for the equivalant of the ECS Ultimate Timing Belt Kit...
- Poll: What do you guys like better - black wheels on a dark blue car, or the normal silver color?
- Replacing the Radio
- A4B5 Clutch/Brake Bleed Question: Since the clutch and brake systems share...
- Does the stealership sell the old G12, or do you have to get G12+?
- LI,NYC,CT Audi GTG march 10th 8pm
- new suspension
- Hahaha, seafoam caused a couple codes and kicked on the CEL...
- Just ordered Koni Sport/Vogtland kit for my car from PMS
- Did you have a senior prank in HS? What was it?
- Xpost: One set of Volk Racing LE 37T wheels available
- off roadin
- Steelies > * w00t
- Overheating problem. Help needed!! Added info.
- Does this sound like the ignition switch?
- SRSLY, how did this guy become the moderator? (VW)
- Kris(mod) Question: Why does the Image Gallery only show the B7 models under A4?
- on a manual transmission, the starter spins the flywheel to start the car, right or wrong? thanks.
- OT: Why mechanics like women drivers...
- how to tell if shocks are blown?
- Has anyone tried WURTH wheel/rim cleaner?
- Trying to seafoam the combustion chamber. Sucked in too much, now the car won't start (doh).
- Didn't post it here yet, but another K04 breaks into 13s.
- Considering buying a second car, a 2000 1.8T Avant tip. But I have a few questions...
- Somehow a cone broke my passenger side side-marker...
- Where to buy "triple square" bits?
- Can I just change the rotors without changing the pads?.....
- OT for you guys...but thought some might get a kick. Looks like I made some Belgium friends. =)
- Will stock b5 s4 injectors work in a 1.8T? A friend with a stg. 3 s4 offered his to me...
- Trans fluid change 97 A4 2.8 Auto What kind of fluid/procedure
- uh, hey guys, thanks for the 7 (yes SEVEN) views on my help post today...
- Help!!! My Car Won't Start.....
- Who's A4 made it to a W V car lot?
- I just made an interesting spreadheet on mod costs of a Stage 3 1.8T versus SC 2.8
- The head is off!!!!!1!!1!!111!!!!! *many pics*
- yay.. 2 days till s4 sides come in...then paint.. install... and you guys can all call me a poser =)
- Geuss everyone sold there a4s'
- TestPipe is installed and WOW | AeroKroil works better than PB Blaster | Got a CEL as well
- Upper radiator hose leak where it connects too radiator my question is
- About to try to self-repair my broken Central Locking Pump broken disc. Wish me luck.
- OEM Rear Bumper
- slow coolant leak. could it be a bad reservoir cap?
- Would castrol high mileage 10w40 oil...
- about audi sport suspention
- Tie rod end/assembly
- need help with installing carbon fiber racing seats... yeah I stfad have some info but not all
- CEL Code P0171 and occassionally dies at idle
- mmm forged OZ SL's. so nice!
- looking to do my timing belt...read further
- Spied! new S3
- Just pulled the trigger...
- help... i'm having problems starting my car.
- Two quick qeustions about GIAC socketd chip
- Anyone disagree w/ me buying the blauparts tranny flush kit other than the fact that i will need ...
- Is a small misfire count under WOT tolerable? I got a blinking CEL going up one mountain at WOT...
- How Much Cost to Change Rack and Pinion in NYC or LI NY Area?
- any possible problems or issues with using seafoam ?
- does the ecode test pipe only come with ONE gasket?
- Seafoam is fun!!!
- Speaking of plugs: Anti-seize on threads or di-electric grease on top of plug?
- Car Country Club...
- Anyone here change their plugs w/out a torque wrench/bentley?...
- so i just ordered some axxis ultimate and new brembo stock rotors $158
- Ronal again....
- Bodyshop called re S4 bumper.
- HELP - Dash lights don't work... Only signals, temp and that's it...!! Recent heater core job
- would the axxis ultimate pads be ok for a second DE short 1.8 mile 12 turn track
- any market for a new stock cat? ebay maybe?
- Sooo.....DAP....wanna play with this??? lol
- Ecode question
- lower valance
- Retrofitting for HID
- Has anyone successfully used these speakers in the parcel shelf of an otherwise stock Bose system?
- poll: what kind of emergency supplies/parts kept in car at all times?
- already posted in b6.. but damn that forum is slow.. any ideas what this is
- Steering Rack and Hoses
- Eibach Pro-Kit Springs with stock non sport suspension?
- What effect does the secondary O2 sensor have on fuel trims?
- fedex and the testpipe are MIA
- Horn working intermittently - 1995 A4 1.8 (Right Hand Drive)
- Its a rare occurance when the Audi tech breaks down on the way to work
- Imawesome, what type of rims did your old ride have? I like them.
- Paging... Person dealing with APR 3+ with injector problem / or anyone that knows the answer
- DBW folks. I have a chip that is supposed to be a DBW k04
- Good times...
- Had to replace my original battery today - 7 years and 11 months and 2 weeks of service!
- Let me ask a naive question......
- suspension difference, early A4 and 2000 on?
- Code 0779 Outside Temperature Sensor Intermitent?
- I know it has been asked and answered but...
- Well..while i am still in there... What kind of lube/grease should i use to service my BPV?
- slotted or cross-drilled for a daily driver??
- Quick question...
- The ORLY? Owl Has Died!
- '99 A4 1.8T Timing Belt Woes
- Can center grill on lower bumper be removed?...
- Paging BEEEEEEJ: Can I just show you this pic real quick?
- anybody have the link...
- Parking light on ONE side
- I have a few questions about halogen e-codes vs us xenon housings..
- Who here has never replace the central locking pump? I never have, and the car is at 138k+ miles.
- Anybody ever clean their SMIC before??
- OT:Since we're such a close knit family here in teh B5 forum..I wanted to send out a thank you....
- Finally got my dyno graph done...
- using firefox?
- Why am I the ONLY 2000-2001 with middle console creaking!?!?!!?!?1 arggghhh
- Clamp sizes for vacuum booster?
- Now that the new "Reformulated" Amsoil 5w-40 euro oil isnt as good as it used to be ...
- ATP OEM replacement Manifold
- hot damn! Stealers charge a lot for OEM manual trans fluid
- Paging those with afterarket seats... Need brackets
- current laundry list of stuff to be done...
- What type of lube to use for shifter?
- Timing belt / cam chain tensioner gasket tools for sale.
- Does anyone have pictures of this graphite wheel that has been breaking in the locking pump?
- Opinions needed: FMIC goes on saturday... wondering what to do about the core.
- Anyone seen this car...is it really worth $20 000???? link inside
- ECU Intake Hose
- passport 8500 X50
- Just pulled the trigger on 4 of these with 235/45 Falken ST115's
- Any of YFFs going to the APR BBQ?
- i had to replace my battery and now my APR chip kicked back into stock mode...
- WTK:Anyone has a borbet 17" type e to spare or for sale?
- car is burning quit a bit of oil, seems to be about a quart every 3-4k. Just did my TB and there was
- Sound like a bad turbo?
- Anyone else having a hard time finding 5w40 synthetic? I barely found 0w40 Mobile 1.
- 99 1.8 timing belt replacement, when does this really need to be done?
- 97 A4 2.8 rear Shimmy, Vibration any suggetions? thanx in advance
- The bad weekend was just the beginning...
- Has anybody painted the black trim between the front and rear windows?
- New Suspension Coming
- alright you hardcore 1.8T ers that are against BOV... i need some info. (no rice involved)
- I see AW got a face lift!!!!!
- Has anyone replaced the entirety of their PCV System before? Valves, hoses, everything?
- Just a thought - New Carpet?
- Anybody have a Cam adjuster tool 3366 in north NJ I could borrow?
- anyone parting out a tip a4?
- Stock Clutch Ratings
- If i remove my stock stereo from my 98 audi a4, will i need a code?
- Hey eveyone...posted this in B6 group, but heard I should post it hear too....
- Is this the right part to start with for CEL
- did brushed tip shifter mod and now tip mode will not work???help
- Question...Brakes acting up after brake fluid flush service
- k.. this isn't a for sale post.. but i have a 225 40 18 gsd3 F1 tire
- Where can we buy a Spare tire (donut)?
- ok so I have a check engine light on and a couple fault codes
- Anyone know what the "Special Tool" is to remove the steering wheel?
- search is broken... part numbers for s4 sides? my car needs them :(
- Anyone have a spare turbo to crosspipe connection hose (the one the dv plugs into)?
- Problem about the oil consume display
- Summer tires getting mounted on the wheels today. Question now is: how long will I wait to put...
- Need part numbers for hood sound absorber and the 17 plastic pins that keep it up.
- Ran my A4 on the dyno. Do these numbers sound correct to you?
- Lower molding for passenger side front door
- Universal O2 sensor (after cat) on AWM engine
- Strange issue with starting yesterday
- selling car soon, need help solving problems first
- What is the name of the plastic cover UNDER the front of the car?
- Is it just me or does the "Search" function not work anymore???
- Central Locking Stopped Working... Now What ???
- couple of Qs??
- Alignments
- Remove and clean C-Pillar cover
- help with this code please
- How to clean sunroof drains and remove rear bumper (BWW)
- Central Locking Pump Module Failure and Repair
- How much can I hope for GS2X cat delete racing downpipe and Mika s/w with injectors and plugs???
- Wiper arm needed for 1996 A4
- i'm sure this is a repost... but is this new look of the forums just esthetics?
