View Full Version : A4 (B5 Platform) Discussion
- looking for an economic way to chip an A4(B5) 1.8T
- Car won't start after getting wet
- 2.8 liter oil pan replacement
- A/C problem fixed -- thanks Audiworld!
- 1998 Audi A4 1.8T parting out
- valet key won't turn
- Wanted: rear coil springs for 1997 A4 TQA
- emission problem in A4 TDI 1,8
- What is the refrigerant capacity of my car??
- car cranks but doesnt start ,giving gas doesnt help
- Transmission Drain and Fill Plug
- thermostat housing screws
- Neutral Safety Switch Part confirmation needed
- Coolant Leak - 2001 A4 1.8TQ - 121K Miles
- Spark plug problem?
- Lazer Red Looks Best! Post Your Picture
- Help-Required-Starting pblms
- P0455
- a4 b5 2001 AWM cheap interooler
- turbo's blown, shrapnel in my oil... what engines will fit?
- Will this KO3 bolt on to my 1.8T?
- Swapping B5 A4 ECU With APR Chip
- VMR | Wheels - V701 Straight Spoke Wheels IN STOCK!
- 1996 Audi front seat damage
- Sport versus standard suspension question
- ATF lines to Radiator
- Cone filter mod
- Please Help with engine missfire
- bad power steering pump? need opinions please
- Is the 2.8 just a 'hot-natured' engine?
- Bad coil pack causing an engine fire?
- 3rd serpentine belt in 1 month!!!!
- Head Light and Signal Light not working today
- Engine won't shut off, not ignition switch!
- 99.5 1.8T Owners Manual and Temp Light Question
- Please help identify this piece
- B5 overheating
- B5 Audio Question - from an Audio Illiterate
- Just for fun...
- 1.8t B5 engine replacement
- HELP! A4 front bumper fittment
- cruise control questions
- Help needed: A/c line nut size
- Leaking AC Hose, need opinions/help
- Anyone knows what this part's name is?
- 2001 A4 cupholder
- '99 A4 recently purchased, a few questions
- Need Help on Oil Cooler Job
- clutch and flywheel that fit perfectly help
- Need rear spring p/n for sport and std suspension!
- somthing corrosive coming out of the hose.
- misfiring cylinder?
- Who's painted the lower part of their stock bumper???
- 2002 audi a4 3.0 timing
- 1996 trunk lock
- ***PUBLIC SERVICE ADVISORY, stay away from Do Werk Garage of Rhode Island
- Ignition problems
- B5 die hards..garage cleanout have couple old school A4 B5 posters shock/springs ect
- Side Skirts Falling Off....
- A/C Problem
- Just bought a new (to me) Avant 2.8 and need some help (mostly cosmetic)
- Valve stem seal replacement/pressurization help (2.8 30V)
- a4 fuel filter help
- Need help, going to dealer and hate answer can't hear it
- Need advice about CV axle
- Battery problem or worse?
- APR tune
- s4 headlight housing in a 1.8t
- Free shipping on TireBuyer.com orders
- Need Help ASAP
- 99 A4 2.8L Exhaust Help
- front speakers stopped working
- Brake fluid reservoir screen (1996)
- Wiring Diagram Link
- TRANS FLUID
- Audi shuts off while driving.
- Ball bearing turbo question HELP!
- blow off valve vs. diverter valve?
- Help me keep my A4!
- VERY LOUD road noise when going 25-60 mph!!!
- finishing my cat-back exhaust
- Test Pipe Problem
- Engine workie, car no go...weird transmission problem?
- Rear Subframe has cracked - Need help
- SAI test question
- Need advice - ABS/Parking brake warnings
- Guage Cluster Dim??
- blower motor
- power steering oil cooler
- Replacing Clutch Questions
- Totally a noob question
- 20% off Waterfest Special 7/20/2010 at Detailer's Domain!!!!
- Planning On Engine Swap from 2,6 to 2,8
- Flashers spontaneously flashing while car is off???
- Good Tint shop - in Allentown, PA ?
- Misfires and P0411 code
- Hello - I'm new and have several questions...so, I joined....need your thoughts
- B5 Part Out
- Hello Audi!!!
- Gauge Cluster ?
- Code 18010
- This is no fair. check out the pics
- HELP! All warning lights ON!!
- 2.8 qm - high speed vibration under acceleration
- Sealant
- rear spacers
- 97 A4 Display Problem
- Puzzled: Engine cooling/overheating problem
- rpm dip when shifting into neutral - can't get rid of it this time!?!?
- need to change the tranny fluid and stuff
- Brake Bleeding! How to replace??
- Alarm/battery issue.....
- ECU gone bad w/GIAC chip in...
- CV Boot Kit and Wheel Bearing in classifieds
- Will 225 tires fit on Swing wheels?
- clock spring?
- 1999 a4 2.8 v6 random misfire on bank 2 only at idle
- Transmission leak
- Slight Oil Leak Passenger side rear side Cylinder Head
- Upper Control Arm Bushings
- Radio and CLimate control not working
- Does MIL store errors?
- anyone here have a subwoofer with a stock bose system?
- 1996 Audi A4 1.8 Auto transmission gets stuck in 3rd gear
- Coolant Temp gauge not working, now working???
- Mass Air intake sesnor
- Weird things after GIAC Chip install
- Audio upgrade
- Timing Belt Replacement.
- My First custom gauge panel in Audi A4
- looking to buy Audi Quattro
- Possible transaxle/clutch issue
- Replacement of Flex Pipes on 2.8
- Intermittent AC problems...
- Selling Supercharged A4
- A4 B5 Stalling and Starting
- Bose wirring pin diagram?
- electric fan wont turn on, no a/c and overheating help
- 02 sensor replaced, still sick
- wheels from other audi models
- auptic body kit
- Need help on exact Cam Position -- 1999 Audi A4 2.8l 30V (Engine AHA)
- Audi A4 Delta CC Stereo removal
- Time to do the timing belt
- VMR | Wheels - V708 RS4 Style PRE-ORDER
- coolant leaks...
- Rear fog lighrts
- B5/braking problem
- power cuttting out
- intermittent power
- Started with a bad waterpump now I'm thinking about pulling the motor and rebuilding
- Lots Of Problems Help me Eeek! Hair Pullers
- Oil in Coolant
- Where is the a/c relay?
- Garrett turbo questions.. TURBS GURUS take a looksy
- air cond display - no display
- help with clutch question
- A4 2.4 AUTO SHUDDER
- mechanical fan clutch in 2.8 30V replaced
- SOS!! Brake Light not working
- A/C question. Please Help!
- B5 Part Out
- Transmission cooling pipe rusted, need part#
- Condenser Blew up? Why
- Minneapolis MN Mechanic
- 98 Audi 1.8l idles low sometimes, but . . .
- VMR | Wheels - July 4th Pre-order Specials!
- front control are replacement
- Misfire started after using AC, stop/restarting: cleared itself after 1/2 mile
- Got a few codes that I need help identifying the problem.
- For Sale: PES Supercharged A4
- Name this part PLZ
- Haven't been here in a while, But I desperately need some help, Please!
- Right turn signal wont work when taillights are on...
- Avant @ Auto-X Pictures
- 2011 Audi A7 Sportback Concept Photos
- Sourcing a shift bushing kit
- Odd conversion, neat idea..
- 99 a4 2.8q awd Rough start then goes normal
- Intermittent Temp Gauge
- Dash brake wear light on
- Brakes
- Any insight? Car's stalling all of a sudden
- difference between OEM stock & OEM sport suspension heights
- Hood Latch Broke ..:::NEED HALP ANYONE:::..
- Front passenger speaker keeps blowing
- Anyone buy the ECS floor mats?
- VMR | Wheels - Photoshoot 19x10 All Around
- Power Steering Pump Chatter/Clatter/Noise when cold
- Head Gasket busted... FML
- coolant resevior hose clamps
- Crankshaft Lock Tool & Timing Belt
- fan/cooling problem -- need advice
- ABS controller changed, VAG procedure to reset?
- Oil on the Spark Plugs
- How to Remove the Water pump in a 1999 A4 Quattro 1.8t
- Remove Control Arm Link to Install Springs?
- Votex sill jacking point covers (A4 Avant-B5)2001
- Still overheating after replacing lots of parts. Help?!!?!
- Radiator choice need help.
- using hr coilover springs with regular sport shocks
- Rear Shock Struts A4 1996 2.8
- 2001 Audi A4 Quattro key fob help
- 1996 a4 tdi fan removal / tensioner
- 99 2.8v6 s_belt?
- camshaft and crankshaft seals - should I replace?
- Crazy gauge problem
- 1997 A4 radio suddenly not working. Fuse ok
- 1.8TQ Cam Tensioner Bad???
- tape stuck
- feeler post...
- B6 USP RS4-style wheel fit an 01 Avant?
- AudiclubNA 2011 S4 Raffle
- Boost Gauge/Oil Pressure Gauge Location
- Still Overheating
- Transmission Multifunction Switch
- Well I believe timing belt tensioner broke...
- AC on car vibrates
- Warm starting problem & ECT sensor ( G62 )
- changed the mfs and did not work
- My 99 Audi Over Heats I've Tried Everything Can Someone Help Me Please!!!!
- 2.8L 12v engine swap
- Replacing Rear Brake Pads
- If the T-Stat is OK, why isn't my A4 heating up?
- AFX-24 Challenge 12 June 2010 at Audi Forum NYC
- code for radio
- Brake noise AFTER repairs
- VMR | Wheels - V713 Split Spoke Design IN STOCK!
- Electric Fan relay? Overheating with AC on
- OEM Items up to 88% OFF - Radios, trans, car bras, abs, A/C and more
- Power Window Problems
- If you need a 5 speed transmission, come inside...
- Can anyone tell me what relay switch is which?
- Smoke, odor and high-pitched sound when I start engine
- Repair of Heated Seat
- A8 wheels/tires. 225/55/R17...will they fit?
- ac odd issue
- Kl.15 Supply Fuse keeps blowing
- Front Bumper removal
- Car won't start!
- SAI, PCV, and EGR Removal (2.8)
- :: ECS Tuning :: Floor Mats 87% OFF
- Rear Differential Replacement DIY?
- B5 manual heated seats to power seats
- water pump leak - will fix myself - some questions
- Help identifying oil leak...Pics included
- Argg... K04 install problems..
- Lost- Where is location of ICM on 2005 a4 1.8T
- Litany of problems! Am I doing it right???
- opinions please
