- Did the "No A/C" mod today
- Rh rear wheel bearing noise question..was replaced before..
- 12V rear muffler repacement poll: magnaflow or flowmaster?
- Anyone know of a source for a larger than stock cat>dp gasket?
- bilstein sport struts + stock springs question
- 30V spark plug torque specs
- I have a problem.
- Good idea/bad idea: Remove the grating from the MAF unit to improve flow.
- 189miles on my last fill up...
- A4 1.8T power question..no flame or arguments please..
- Stock Manifold
- Anyone paint interior trim laser red or a body color?? including ash tray and around the shifter?
- Is my coolant supose to look this crusty??
- Squeeling / High Pitched noise when compressor is on...
- Update on my previous post of my car not starting. 2000 A4 1.8t Problem solved.
- Rattle buzz when letting off gas at high rpms in low gears
- Is there a listing anywhere of Dyno results for the AWE KO4 kit? Specifically for...
- Has anyone dropped a VW 1.9l TDI into an A4? I searched and
- my cluch fluid is low what kind does are cars use?
- yeah! more trunk space
- Oil temp won't go above 210F in 2.8Q - Normal?
- Auto-X folks...looking for some advise...(course design)
- Foglight wiring help
- What to look for in a 96/97 A4
- new PBR ceramics/ plain faced brembo rotors making noise. should i reset them?
- 2000 B5 A4 GT2X dyno charts - Advice wanted
- Location of Coolant Sensor on 2.8
- SeaFoam question - 1.8 non turno engine.... Where's the IM?
- New short shifter in. What a ball ache!!
- Alarm problem
- Axle/CV joint issues!!!! LONG
- windshield wipers not working!
- parked next to an other A4 today
- problem after filling up with gas
- Stage 3 owners....
- Pulled into Tim Hortons for a coffee car was fine, came out a started it and....
- Question about quattro and axle/CV joint problems.
- Poll...should TighTT stick with the PES T28 kit (new T28) or upgrade into the unknown (2871R?) ???
- So does anyone have that GIAC GT28RS chip that I have been reading about...
- i changed my opinion on beru ultra x plugs....sh!tty. Porcelain is either stained or cracked after
- Has anyone used a zip tie tool like this on their vac lines? Better or worse than screw hose clamps?
- "There's nothing more chickensh1t than fvcking with another man's vehicle"
- Man...these Volvo guys are lost on the whole DV/BOV thing....
- Anyone have a vdo gauge laying around?
- I'm dynoing the car next month...what is some small stuff I can add?
- Making progress!
- god damn it !! i'm retarded...
- ECS Coil Over kit...
- Boost leak near back-top of engine, line going to part #7 in pic?
- Maybe Air Mass Sensor?need help?
- annoying noise...possibly tranny.
- tangled windshield wipers
- A/C sucks all my power and messes with idle
- speaking of noobs....
- Hi, and welcome to n00b Saturday.
- does anyone know if the power supply to the headlights is ac or dc? Also which is hot, yellow/brown?
- Sport package shocks
- Biggest turbo?
- How important is setting that 11 degree orientation on the front springs?
- Has anyone been able to fit a 99 full plenum cover to a 98.5 yet?
- time to go rip out the dv and see if i can fix that hose.. pics to come.
- Hey guys...any good forums for the volvo S60R??
- 1996 turbo question
- its cold outside...get that CAPS run done :)
- Help! Car won't stay running....
- To mod today or not mod today?
- Any recent pics of the new OZ UL's on B5's ?
- Can you recommend a good place to get a complete timing belt kit for 2.8 30v?
- Audi announces 2.9% financing on ALL 2001-06 CPO cars!
- wish me luck guys: im checking out this puppy this morning
- Pics of the carnage
- Just read a tech article on front control arms, says to order passat ones instead as they are.....
- Quick question for those that are still up...
- Question about removing Shocks
- would a bad coil pack throw a CEL? im suddenly having misfires and ...
- Fvcking fvck fvck fvck...
- I did TB replacement at 65K...should I keep the same interval for the next one?
- Found this control arm kit on ebay, what do you guys think?.....
- any pics of Neuspeed Bilsteins
- Car will not start. Replaced ECU but still no luck. Got a P1517 Code.
- The parts bin rocks
- where's the best place to buy a S4 bumper... i tiried searching and nothing
- PC-16 user be aware to install FMIC because I blown my K04
- Weird. Passenger rear sits much lower now then previously.
- Detailed the car today... first time since buying it...
- white trunklid anyone?
- TRE's and CA's done!!!!
- So I really like the new GTi....
- WOOT! new CAPS personal best!...6.40, thats close to J31 territory...
- 99.5 non bose stereo upgrade
- I am not a wheel whore...
- what would cause the all the warning lights in my cluster to flicker when i push down on the gas?
- anyone have picture of a stock front sway link installed? i need to see the orientation of the link.
- B5'ers in the St. Louis area
- Anything else I should get or do while I am doing these? I want her happy. p/n and prices inside.
- Traditional cold air intake vs. Carbonio intake?
- CPO warranty & question regarding reimbursement.
- just ran across this pic again...its sad it never happened
- Bank 2 Sensor 1? Which O2 Sensor is it?
- Pancake/Puck PCV Valve part number needed for AEB 1.8T....
- My A4 is killing me!!!
- Flame suit On!... After reading that whole thread on the srt forum... im confused...
- Is it possible to weld this back together?
- tire size?
- Anyone run Rotora BBK?
- Amounts required for a Diff oil change for 2000 A4 1.8T Tip
- 96 A4 2.8qm AC issue
- Can any one tell me what this is ? and what it's for ?
- Its Friday 1153hrs: Weekend Mod Maintenance Thread! What is going on this rainy weekend?
- Removing fan clutch on 01 1.8 AWM
- Ok.. poll: Most helpful member of this forum for you.
- anyone mind doing a carfax for me? 3p3aa46kgst542819...
- Bosch EV12 fuel injectors -- interesting response from Bosch Motorsport
- Paging Iwasawesome: Its payday for you!
- So why do Audi Dealerships suck so much? (rant)
- This is what I like to see:
- Who did that full engine bay cleaning with a ton of pics? link?
- TighTT.....
- I'm surprised no one posted this here, B5er posting on another forum
- 96 2.8q key stuck
- Need some part numbers for minor items (fixing my f'ups)
- Part number request: shift boot plate...
- Yeaaahh!! SeaFoam and Short Shifter this weekend!
- Does Anyone Know if There Are Any A4 Meets Here in the Bay Area???
- Poll: Any good uses for my old control arms?
- 2.8L (wih PES G2) or 1.8T (with APR STAGE III)
- few random questions; just got a b5 a4.
- where can i buy a w8 belly pan and screws other then ecs?
- Hey AsTheCroweFlys, WTF are you doing mentioning us on an SRT-4 forum?!
- i found this rubber piece laying on my bell pan and it has a p/n. need to know what it goes to
- we're not alone...
- anyone P/N for two 'lil coolant hoses?
- Poll: Favorite Stock Wheels (Order highest to lowest)
- Anybody want a Lambo door kit for their a4?
- Since I am now a proud owner of a B5 and a B6...
- Coming back to this forum makes me miss my A4...
- Coolant Temp Sensor Part #?
- british rice
- Which brake pads will give me the least brake dust??
- New sig.
- Ok so I STFA on t3/t4s working on our cars, is it a direct bolt-on though, or will I need to change
- cd changer
- Darn it...I heard a crack in my rear door...and now my window won't stay up! Any ideas?
- coolant temp past middle marker
- the only car that could make me stray from audi for my next car...
- Can B6 s4 wheels be run on a b5 a4 without spacers or new lugs?
- Where to buy 2000 or 2001 A4 Tail Lights. Anyone Selling??
- Projector Headlight Help
- About 92k miles on the clock. Good idea to change the transmission/dif oil. OEM GL-4?
- So it's been brought to my attention that this is no good...
- 2001.5 60K Service $215
- Vibration in 1st and 2nd gear 2000 rpm untill 4000 rpm under heavy load
- alarm, winows and locking pump not working all at once
- Drive Las Vegas Speedway, 4/28-29
- Paging----> trancesp0t
- How much could I get for my car? 2000 A4 1.8T Q
- TighTT please e-mail me...or anyone who has his addy let me know...
- DTM body kit a4/S4 in vegas with red roll cage on Rampart and charleston today you here?
- Think this is legal? or atleast close?
- Paging BSK: Let me know if you got that email I sent you.
- Anyone interested in my Forge BOV?
- What temperature should the a/c blow when on low? I tried searching
- Interesting article on the engine break in period, what do yall think?
- I'm Sorry, I just bid someone up on an AWE boost gauge
- 5/13/06 - CT/NY Audi Group & EPL present Dyno Day for Breast Cancer in Stratford, CT
- Troubleshooting help
- So stock wheels aren't so bad after all.......
- Yeeaaa wife just called my KW coilovers arrived from supremepowerparts.com!!
- B5 AEB Oil temperature sensor?
- YEA BABY!!! I can't believe, I'm still in shock! Passed emissions w/TP and bad o2 codes
- I updated my front wheel bearing how to in the faq, I re-posted pictures
- Part number help. "puck/pancake" for AWM engine. Mine says 06a 129 101A but stfa
- secret codes
- Exhaust Wanted! for a4 01 1.8t man.
- Cursh [the intern]....Funny story/rant your comment about parking by feel made me remember:)
- Canadian retail source for Febi front control arm kits? Thx
- Hey guys is this all i need to replace the valve cover gasket?
- which is Cyl 1 on 97 a4 V6? 12v
- So, i want to make my car faster!!! whats the best chip???
- Does anyone have j31 numbers? I need some info almost ready to pull the trigger
- New Sig! Check it out!
- Hey guys quick question about spark plugs ...
- what a nice color
- Not again!
- Body Kits - Fiberglass or Plastic?
- audio in A4 2001
- Oh , May the Audi Gods strike this owner down
- what is it with my spottings today?
- YAY!!!!! misfires are gone and bikes front tire is correctly mounted
- Selling 97 A4 2.8
- Weird Smell
- S4 Strut Bar is installed and done.
- Trunk will not open...
- How long do you usually let wax set/sit on a car before you buff it out?
- about to finish the rear h-sport install (more inside)
- Cool. Stasis used the picture I took on their latest email blast.
- Nuvolari and Turbo Twist wheels on sale at Hartmann/Achtuning
- Nice 2001 S4 Avant for sale
- Was looking at the FAQ and interested in Front Wheel Bearing... The pictures are gone!
- Anyone looking for a trunk mounted factory 6 disc CD changer I just found
- led tail light mod, brake light warning
- How much would it cost to repaint an entire front bumper?
- How do you guys feel about remus exhaust?
- AWNE Xpost: after 5 weeks of repairs, I have my baby back!!
- Real strut bar post.
- very, very wrong...
- yet another strut bar post...question about endlinks/bushings
- Quattro vs. FWD
- So the local dealer is hiring service tech apprentices
- Front hood latch sensor.
- Underside seals soaked in oil. Normal?
- Tell me if i am crazy... please
- turn signals and hazards not working - hazard relay?
- 2001 A4 Top End Seals
- how much stiffer is the HSPort front sway compared to OEM Sport front sway?
- Has anyone done the drivers side Cam tensioner gasket?
- H-sports.... Best place to buy from/least expensive..?!?!
- Please come on out!!
- do we have a visual tech section writeup on how to change spark plugs on the 1.8t?
- Washer Pump
- So my front passenger side window just came completely off the track...
- post some hot shiftknobs for blue/ecru interior plz
- For those who have been around long enough to remember them...
- CAPS question...
- comfort module audi A4
- Suspension thread stripped
- Well gentlemen...the sh*t has hit the fan...as they say.
- Are there any supercharged A4s in and around Phoenix, AZ?
- Goodbye A4
- SPP FMIC group buy info?
- rather odd problem when filling up at the gas station...
- Certified Preowned Requirements for Brake Rotors
- Looking at a '99 B5 this weekend
- 4B0906018BH is not interchangeable with 4B0906018CH right?
- Follow up to the paint warranty discussion last night
- Supercharged Audi for sale in classifieds
- Buying a Used Power Steering Pump... Good or Bad idea?
- Quick Poll: What color is your car? Exterior | Interior
- Vacuum lines questions
- wheel fitment on 96 A4
- ebay projectors no good?
- Who here works for Thule in CT??? I know somone does...
- Paging Nickelmedia....
- BLACK VS CHROME
- Rant of my last 2 days .. misfires flashing cel and bike issues UPDATED
- =) good morning b5 forum ... it's 4:45am.. i think i've gone slightly insane
- Noob question: Flame suit on!! I was looking to get my lowers painted...
- has anyone on here installed all the functions for the apexi TT?
- Autocross this Sunday at Nashville Superspeedway
- Im thinking of taking a road trip...
