- I STFA, but i dont think im calling it the right thing. I need to check my ECU code/number. I want
- audi secrets on ebay, lol
- Central locking system randomly locks and unlocks doors
- Where to get a 3 inch Downpipe???
- Alarm sounds but doesnt beep when locking!! Search didnt help..
- How to tell if motor mount needs replacement ?
- 2-piece wheels with lip and offset question
- Anyone tell me if the balljoint boots are replaceable alone?
- New A4 owner here..... pic of the whip
- questions about ECU/CHIP/immobilzer?!
- Need Help Finding a Half Shaft
- S4 engine into A4, how hard, how long?
- Ice Link or Subs??
- A new ABS computer, new windshield, a coat of Zaino and my car is feeling good again.
- PIMP's PES G2 thoughts... <written in the voice of the late Phil Hartman>
- Not many topics on spark plugs and plug wires...
- Where to get the best price for short shifter?
- AMS Borla Exhaust Sale!
- Gains with the Bosch 5 Bar FPR?
- Replacement Symphony Radio
- To replace radiator and radiator support on a 99 2.8 manual would this part work?
- Cracked Insulation on Xenon Bulbs
- Mike@PureMS, Question inside.
- Hesitation and Surging. Please help (long).
- Help with Lowering Subframe
- What is the best way to pass Speakers Wires to the Trunk ?
- Where can I get a good intake for a 2.8 30v? TIA
- *Update* on Flashing Oil/CEL and experience at stealership
- ABS Light stays on....
- Repost: ETKA help please (120+ views but no reply)
- heated mirror on 2001 not working (driver side)
- How much for 18" OZ Crono Evo's???????????
- clear corners on a 2000 1.8t?? if so how!!
- I'm running my car in the 1/4 mile this weekend & need some advice (more inside)
- Would this fmic core work assuming I could fit it in?
- will this make my car faster?
- Power Steering going in and out...
- anyone have any pics of their apr'd ecu?
- How hard is it to replace speakers in 98 2.8 Quattro?
- Parking brake switch????
- Dual Exhaust?
- 2nd gear tip is so slow!!! Is this normal...
- 1.8t challenge update...
- ok bishes. go do some CAPS! testing. now.
- when am i supposed to change my injectors on my 1.8t?
- CAPS test v.3.Several updates including how to easily find your score and a soon to come...
- so will there EVER be any new news on the stage 3+....
- magio do you have a new bumper on your car?
- how come all the morons come out of the woodworks on the same night?
- can you put 2004 a4 headlights in 2000 a4?
- symptoms of a bad N75 valve?
- Car Alarm Malfunction
- how many pins does the connector for the 99.5 cd changer with concert HU have?
- Inskip Audi in RI..... A rare dealer prop.
- MAF Problem...Engine rough idling, RPMs up and down
- Was there a front control arm recall on 2001 A4's?
- Any cheap Audi parts dealer in Canada? (Toronto, ON)
- will this audi tt hid kit fit easily in my audi a4 headlight?
- Suggestions on chip and cat back Exhaust
- Are all German cars as unreliable as Audi???
- Is bank 1 the forward O2 sesor?
- I recommend to take the 15 minutes to take the console out when installing a B&M short shifter.
- AW member with ACHTuning RS4 replicas, how would i know if have the ACH RS4 reps.
- Time to play "what killed teh willis' car"
- Air Bag Replacement ($800) at 100,000 miles...anyone else?
- anyone ever hear of SPYN wheels or have any info about them?
- burning oil
- ca emissions warranty
- KKK K04 Group Buy
- Do you need a Fender roller......
- anyone know dealer prices for S4 lower door moldings?
- Looking to sell BMW wheels... what site/forum is best?
- finally got a pic of my car....
- Tried a 1.8T.... now I want a 30v..
- Koni shocks...or regular bilsteins shocks to go with my neu. sport springs..and
- Looking at buying a 97 2.8L Quattro (Manual)
- odd - transmission shifts late on hills?
- HELP code 18010 power supply terminal 30 P1602-35-10
- Need advice on SPEC replacement.
- how does starving the engine of gas cause damage??
- Audi A4 wheel hub diameter
- If 2 ECU's are coded as "4B0 906 018 CH" are they the same?the words"Benzin ME 7.5 0002" dont match.
- are there any front mount intercoolers that fit behind the front bumper without modifications
- LL tek intake or Giac chip?
- I-Pod Connection
- Help Wiper Fluid Runs Straight Through
- What spark plugs for K04?
- Hey guys...what do you think about this diagnostic tool??? Anyone using it??? TIA
- upclose of fins
- Check valve btw. manifold and brake booster part #?
- need ECU -- what's the letter for at the end of model #?
- PA/NJ/NY/DE/MD peeps - EPqC Fun Run and 4 Dogs Tavern lunch 7/31
- stfa, anyone know where i can buy a speed sensor?
- Some ECU questions...searched
- lock nut on tie rod end wont come loose. anyone have an idea?
- Sport package suspension question...
- anyone know how to make one of those 3rd brake light decals?
- '99 with S4 fogs....connector question.
- Aluminum instrument cluster rings
- CPP adjustable upper control arms - user experience/ opinions?
- HELP: Anyone know a good muffler shop around santa monica/marina del rey, CA area?
- Rain entering car
- How do I clean the MAF element?? What do I use and will this help?
- Performance benchmark request 1.8T
- A few impressions, beginning with the new A6 (long)
- cleaning seats....did search, but no answers
- How bad is it to redline your car right when the car is turned on and when the oil is cold?
- for those with the audi lifestyle rack .... how easy is it to remove/install the base carrier bars?
- paging kennyc ..... i have one more carfax to run if you dont mind
- sup guys
- boost prob. found....
- Fender rolling...
- Should i remove my console to do my B&M short shifter install on my 98?
- anyone selling stock rims in the boston area?
- does lowering car void factory warantee?
- Seat questions
- need help ASAP, friends 97 A4turbo quattro won't run
- Who will best Audi2ptzero's CAPS time? Only time will tell....
- LLTek 12v intake (used), good mod or no?
- Can any other turbos be mounted to the pes manifold without major problems, like a 28rs
- Reminder: Long Island, NY Audi Meet/Drive/BBQ 8/1/04................
- Does anyone know where I can get a cheap Under belly lower engine cover for cheap??
- HEy guys posted yesterday about a misfire.... another Q
- Paging PCW: Are they sold??? If not, I'll take 'em!
- S'dTFA ...how do you "test" your PCV valve (under the intake)...more
- headlight washer question...
- hey Nojoi, looks like your art is on mtv
- All that fuss about a recall and I still haven't heard anything solid on it
- Where is J_ in NY? Did you get your rebar yet?
- I have the opportunity to pick up a santorin Rieger RS4 bumper but still have OEM A4 sides. (more)
- Help need pictures of an pre 99' A4 american ecu wiring harness
- anyone selling a used neuspeed short shfiter for a 2000 1.8t?
- turbo timer
- no heat update... (help)
- Help with boosting
- snub mount
- HELP! How bad is it to switch from 3rd gear to first? (well, on a tiptronic transmission)?
- Any Selling a G2 Supercharger?
- Do these fit in a 97 A4?
- Are the 8pin CD changers hard to find items?
- Can somebody post a pic of the Greddy Turbo Timer III?
- Getting my windows tinted 2morrow,what do you guys think about a strip at the top of the windshield?
- So I checked my pass speaker connections to diagnose why my speaker cuts out...
- MAF problem...Rough Idling, Stalling after installation of MAF and housing.???
- Just got a TT knob for my A4. Are there any tricks to installing it? Thought it was just a screw on.
- maggiobomb is the first to enter his CAPS test...who next?
- Just got an A4 - the issues begin
- Pictures of current look (bww).
- Power steering fluid...is there a special way to refill it?
- before i buy an unpainted hood from junkyard thought id ask one last time......
- Want to see some Audis move on your screen? Check out this site!
- if i cut the wheel all the way...the car vibrates
- Wining sound from front of car, can be heard when I'm going uphill on the highway and only when I'm
- still looking for some help in regards to an earlier thread:
- My pirelli P Zeros are absolutly awful in the rain.
- OK I had my front main seal replaced
- Will 235's rub on 8.5 wide wheels on my car?, I have the koni/eibach combo, not the same............
- Headlights don't work: Cause, repair, solution.
- Hey guys!
- Relocating forge valve
- when putting a cone filter on which way do i face the MAF and housing???
- Where is the best place to get recaro seats
- Does anyone know what happened to carpart.com?
- What kind of plugs do you guys run on your 1.8t? (more)..
- KK GTG THUR @ 9 .......
- looking at getting an A4
- Steve_Ag Arrow, where did you get your new headlights?
- multiple misfires after timing belt change
- Help Needed! I just installed an aeromotive fuel pressure regulator, checked the gauge, and it's
- warantee
- can i look at bentley service online ?
- can you mount a scoop onto the front bumper?
- Name this highway... and fun in the snow ( Video )
- timing belt ?
- Repost night crawlers : Stealthbulb part # for ECS E-Codes turnsignal, NON Xenon
- Logged my MAF on the way home today...
- Repost for night crowd: Drving out east next month
- Install help next weekend...
- Turbo Timer on Used A4
- Anyone else's AWE Stage 2 clutch/LWFW chatter like a mofo?
- Does the $25 O2 sensor work in nDBW cars?
- Anywhere to get OEM Parts other then ECStuning.com?
- any members of BIRA? how cheap do the kits become?
- ok, 4 year (last) service coming up. What to have checked?
- where can i find strut brace for '96??
- everyone talks about the V1 detector, but dont any of you guys use radar/laser BLOCKERS?
- Best 300-400$ Mod?? List of my mods in the post.
- Pure MS strut bar group buy info?
- A4 Where do I put the MAF sensor in a CAI?? Also how do I remove it from the factory box??
- Spec clutches? so iv been searching and tracking a couple threads...
- So I tested a Mazda3 as a potential replacement to my A4...
- Liam.
- Skyline : Engineering Genius, or Rice Boi Hype?
- radar/laser detector
- What is the best 6 Speakers Setup ??
- abs problems...i need some help...
- buying ECU off ebay. Safe? He doesnt take pay pal and is in Canada. Think its a safe bet?
- Running Lean
- Tire issues.... rubbing on rear suspension, any one else had this?
- Off topic question for my trusty A4B5 fellows.
- Anyone in SoCal willing to trade stock exhaust for Neuspeed G2 + cash?
- Does the A4 Avant Sline exist? Also, will the 2005 get the...
- How can I tell if my 2000 1.8T A4 is an AEB or ATW??
- supersprint exhaust.......hit or miss?
- What's the proper bed-in technique for new pads?
- any of you guys change the "real" pcv valve, and if so, how the hell did you get to it???
- $1100 estimate for painting a hood and bumper? Way too much??
- 2 1/4' or 3' exhaust
- Who's f*cking VW was this at Waterfest???
- X post - Will be selling an S4 with a title with a lien, need advice:
- ABS Module
- I STFA and i am still having trouble with the squeaky right front
- OMG I cant believe this. My warranty company went bankrupt.
- Driving out east next month...................
- Repost for the day crew: Updated pictures of my car and my friends with first mods.
- Dyno results....
- Just did my brakes...ecs cross/slotted rotors hawk pads, stainless steal lines...etc...my question..
- does the front have camber adjustment
- mounting of slotted rotors
- Xpost help needed. Let's play fix that VAG code.
- if you can blow through your pcv valve both ways, it's toast right?
- X-Post: Targa Breitenbach - July 31st
- '97-'98.5 ? Owners: Where to buy this...[PIC]
- Anyone have a power bleeder in Orange County I can borrow this weekend?
- Changing Spark Plugs A4 1.8T/ Pollen Filter
- Paging J in NY
- powerflex bushings for front upper control arms.
- Question: Has anyone used the MAF sensor from ecstunings site to replace their oem sensor?
- Im doing 50 higher and my car starts vibrtating like jello, what can be the problem?
- What is the highest mileage you would buy uses coilovers? thanks
- ANYONES engine ever start to shake as if a cylendar was out?
- XM radio install
- So when i get rid of my B5 think I'm going to go with the A3 or Saab 9-2x
- Anyone rewire the heated mirrors on 98.5 models to come on at the same time as the defroster?
- Paging...NC A4 with a license plate LODORINGS
- anyone know the torque setting for the (Bolts?) holding the hot and cold side together on a K04?
- Start submitting your CAPS data...newly added 12v test! (more)....
- Crap! My ABS computer is dead.
- Homelink question
- Where to fix DTCs 17536, 17538, 17551?
- HELP--people who have up-graded tie rod ends from ECS...
- i think i should add a picture to my ad?
- Pagin relaxin230
- whats the best place to buy parts ?
- next post on cruise control. anybody have a known good computer lying around?
- Looking for anyone who installed an aftermarket oil cooler and removed the stock
- Oxygen Sensor Keeps Blowing
- A4 Cold Air Intake
- hey guys...just came across this on google looking for southbend clutches...
- Lease Prices
