- Oh, DAMN....look what happened to my car.... * unbelievable *
- I STFA but can't find info on removing head light assembly from...
- Who needs corner-bulbs?
- Injector size: how big should I go?
- Question for Milltek cat owners. Have you ever had problems?...
- Bumper torn off?
- ***cues up music*** it's beginning to look a lot like Christmas.....da..da..da....daaaa.....****
- So i have a 1000 credit for parts and labor help me decide how to use it i cant think of anything
- I got my TT225 3" maf in my airbox. Question inside.
- How hard would be to replace the wiper switch? Mine has been acting up for a while now.
- forged crank vs cast crank
- going back to stock brakes for a while. where to buy the brake hose?
- Temperature sensor
- Can anyone give me a reason to not buy General Exclaims?
- Anyone got a spare stock N75?
- any one know how to remove the side skirts on a 96....i need to put different ones on
- Had a spark plug back out of my Avant...
- Screw you guys. I'm officially leaving
- OK Avant guys: good site for rear wing? the Caractere wing from LLtek is like 500!--nuts
- Replacing the airbag module
- A few AWM build questions.
- can i get a PN#? Temp sensor in air intake box? ...
- is there still that dealership/shop review website i cant find it anywhere
- Is my pancake valve bad if I can blow thru boths sides? Is it normally closed?
- cluster pox repair?
- Rear bearing noise (I think) 1997 A4 Quattro
- Trying to find eletrical diagram to troubleshoot my SAIP issues
- Im pressure testing the boost hoses. I need help.
- Soon to be a B5 owner...
- Failed safety due to leaky exhaust flex coupler, what are my options?...
- Crosspost: Anyone looking to sell an A4/S4 Schroth Rallye 4 Quick Fit Harness?
- Speaking of CAPS, I havent seen any fast times posted lately. Wheres the new BT setups?
- Achtuning! When are you going to get the shop back online????
- anyone know: will an s4 steering rack fit on an a4?
- cluster repair x-post
- Silver Streakin, and Bassed...
- anyone have the p/n or willing to sell the cup holder that fits in the big rectangle slot
- Suspension Removal Help!!!!
- Looking for the 1st events at a local track and found this. Does it fit for you?
- Oh no you DIDNT....
- Whining noise...Power Steering Pump??
- Does the CAPS calculator only work on B5 A4s and Passats?
- Whats the best way to match ecru interior color?
- vanity plate remorse and I don't even have the plate yet!
- cross post from brake forum - which size wrench to buy to remove Alcon type-B pistons
- is it possible to modify what the cluster displays on the LCD?
- Anyone got an armrest for sale? Pref the upper part in grey.
- What interior color is this?
- question about 1996 audi a4 2.8 two wheel drive.
- attn: dungbeetle, I got the hook up yo
- 01206 - Signal for Duration of Ignition Off Time... what does this mean...I searched..
- B5 Board Annuals Garage Thread. Post pictures of your garage used from wrenching on the car!
- part numbers please... add prices as well
- my display gauge fades as car warms up
- heater blower barely working
- --looking for a set of 99.5-01.5 projector headlamps....
- Oooooooowwwwwwwwwww la la.
- so umm, how do you get lil pics at the bottom...
- Anyone know where I can get big right angle circlip (snap ring) pliers?
- X-post Help oil filter!
- GPS mount. Cheapest thing I'l ever buy for my car and it looks pretty good...
- I need the pop up cupholders for my center console...anybody??
- Vent mounted boost gauge people....
- Is Febi the company to go with for CA replacement?
- turbo bracket bolt, how important is it???
- Differences between '99 & '99.5?
- help with hooking up the post-facelift turnsignal bulb housings!
- Revo Technik welcomes Reflex Tuning in Merrimack NH to our authorized dealer network
- Revo Technik welcomes Forge Motorsport in Orlando Fl to our authorized dealer network.
- Ecode Xenon housings in stock....
- well.. it seems I'm fairly screwed on my brake issues. Does anyone have stock front calipers
- Paging Carson: I need some parts. ;)
- So what do you guys think about my euro style plate??
- Silver Streakin', did you see this about Robby Gordon's penalties? I almost fell out of my chair
- SAI turning on randomly causing the battery to drain. does it have a switch or does ECU turn on/off
- Sun roof seal; is the dealer my only source? (hopefully not!)
- brake saga continues.. looks like massive pad failure led to my f-ed up rotors
- New problem. Upon normal acceleration up to around 3-4k, then WOT, my rpms shoot up and I dont go an
- Window lockout switch illumination
- RS4 bumper acquired...a question about the mounting procedure (BWW)
- Show off your Euro license plate!!
- P/S hose replacement for 98.5 A4 1.8t
- Anyone parting out their car? Need a hood for a 2000 A4 Avant (SoCal)
- x post from awt - behave yourself
- Did a search with nothing conclusive... what would cause the tach to stop working?
- Ok guys, help me out here....
- lol!
- Quick question about coil packs. If one goes do they all start going??...
- Anyone have a rear caliper and carrier "laying around"? Have a custom thingy-ma-bob I'm messing with
- OEM piston rings...
- Has anyone considered doing a B5 GTG?
- Figured out why I was misfiring so much. Spark plug washer's were sitting in some dirty holes.
- 1998 1.8T quattro sedan stock springs = Free. Pick up only. NYC area. email me
- Looks like I will be spending some quality time with my A4
- In the middle of brakes,.... Piston is stuck/(seized?) ......
- ebay side view mirrors
- CF trunk
- Has anyone installed a USB port for charging an iphone/ipod?
- Paging Dungbeattle!
- I'm looking for a Stage III A4 Avant...do you guys have any leads?
- No Problems
- Update from last nights driving over the 5inch "tree"
- side mirror
- front brake noise when comming to a stop - the brakes pretty just
- Front-end Popping noise
- x-post from Audio forum in case some of you that have answers don't go over there very often.
- Would 1997 A4's climate control unit would be compatible with a 1997 A6's? Can "dual" unit be used?
- What am I missing here?
- What would one need for the very first track event?
- Stupid ETKA part # request
- Broken Headlight Washers
- control arms
- Those running OEM RS4 front bumpers, what type of FMIC are you using?
- P/S hoses
- and the luck with the car and my dad continues.. today he "drove" over a tree in the storm
- She's alive! gt3040r swap is up and running
- Getting a pair of S4 rear calipers & slightly cracked S4 bumper for $200/all...good deal?
- what is the difference between the 1.8t and the 1.8t in the TT? i am talkin about the 170hp TT..
- Feeler: what's my heap worth...
- Question for those of you that made your own vent boost gauge.
- WWAWD
- 1.8T turbo making noise. Help me!!!!
- Score! A friend of mine gave me a Valentine 1 today. He bought it a couple years ago
- Anyone with 1998 cars in southern states ,have you seen the new law in Mexico?
- Clutch Plate Change
- VVME HID Kit
- Hey Kris....
- is there a way to test if the o2 sensors are shot?
- Imsuspended/awesome/whatever update: So I know you guys are all saying sell sell . so i listened
- You guys with k04 and TT225 MAF's. How the hell do you get the MAF in the turbo inlet?
- death battery
- sooooo. whats everyone paying for flex pipe repairs these days
- ecodes or s4 headlights
- How can you keep at B5 A4 tight?
- Hey stage 3 guys, what are your peak boost levels?
- Approaching 100k Miles (Part 2)
- Paging manualAvant: thanks for the headsup
- ah five boxes of parts appear to be arriving tomorrow according to tracking numbers!
- time to replace the struts on my 01 with existing sport suspension. are the bilstein sport the OEM
- Hesitation under hard acceleration...
- does the racetec fmic block the use of the towing anchorages?
- RNS-D Question
- Best Service Manual
- So, I finally replaced my CTS. An easy 5 minutes...
- Beergoggles and Pentosinjunky - Was the coilpack... Thanks!
- Tire Rods - 1996 A4 2.8 (Not a Quattro)
- Check Engine Light - 1996 A4 2.8 (Not a Quattro)
- sick of looking! Does anyone have a set of stock headlights that will fit an '01 A4?
- Where to get a Phatbox connector cable - Totally confused...
- Handbrake imbalance. Left rear wheel does not lock. What could be the cause?
- Climate Control Gone Wild
- Zytek_Fan has found an A4
- Paging Carson...need rear caliper retaining bolt p/n for 1997 A4 2.8 Quattro/Manual
- rs4 body kit?
- I am thinking of Selling the Avant
- i hate my car some days.
- kmd dyno tune price offer
- Special Request from a fellow B5 owner.. post up videos of A4's with GT28 or larger turbos (more)
- Need Help Identifying a Bulb. Socket picture included. Turn signal
- no vacuum leak?
- How difficult are DIY shocks? (Have already done a half shaft, pads, rotors)
- Interesting.
- This is the 1st thing i'm gonna buy with my new Economic stimulus check:
- what would cause large gouges in my brand new rotors???
- Door replacement
- Anyone have a 215/40/17 tire laying around they wanna sell for cheap?
- Microsoft Zune and Navigation Install
- Not another brake bleeding question
- cheap money, but kinda scary looking. not mine yadda yadda yadda
- how longs do 02 last - i have 130K on mines
- Silver Streakin' shoot me an email.
- Leather Source?
- Removing rear oxygen sensor on 1.8T
- Has anyone ranked the different coilovers in terms of stiffness?
- Looking for parts
- Long shot Does anyone have one extra used 205/50/17 Continental ContiTouringContact
- Looking for interior door trim
- I recorded the squeak I have coming from the front end
- Carson@Riverside: Thanks again. My parts have arrived. :)
- Can 6cd-changer trunk cable be cut, and reattached to connector (to Phatbox socket)?
- Limited Edition K2/Pabst skis for sale in marketplace
- Independent Shops
- What was I thinking!
- Misfires, blinking CEL of doom and two finals this week. What fun... Need some advice.
- OK, so is it simply not possible to genuinely upgrade your lighting without spending
- Brake Job
- Fuel Filter Question (MPG Related)
- Overkill???
- Fuel economy tricks.... I just averaged 28mpg for 350 miles in my 2.8q tip Avant.
- could this many people REALLY like DEPO?!?!?!?
- Little update on 2.0T phase 2 1/4:).......
- Alex Ferguson (Owlicks) - Great guy to do business with
- Looking for an A4 for my daughter. Need advise.
- 17x9, 5x112 ET 24.5 is there any remote chance in hell these will fit and clear a BBK?............
- Something dark brewing at the Ritt camp..
- CEL Error code P0411 and P0140 Question
- New rims are on ( PICS)
- My new ride.
- Got my car with GIAC Hammer file working. I like it. It pulls really hard now.
- So what is the difference between 1H0 253 115 and 8D0 253 115 gaskets?
- Question about my FPR.
- PSA: Carson is one responsible mutha.
- Front Axle exploded. raxles.com fastest?
- passenger side mirror assembly from 2001 fit my 1998.5 Avant?
- Struggling with Concert radio removal -- need advice
- 16x7.5 et45 wheels on B5 A4 Avant
- Anyone have a photo of the wiring harness for a Concert-I radio from a '99 A4?...more
- The weld on my cat broke. Is it normal for the turbo to get red after the cat breaks?
- Eibach Pro-Kit Spring question...
- Can you guys imagine a geo metro with a 1.8t engine?
- Has anyone else seen this bull s***?
- Street + track worthy tire part 1of 2:
- So my teenager seems to have a magical attraction to fixed objects...
- School me please [--> exhaust]
- Is there a way to tell if a car was orginally equipped with a Bose radio or not?
- Paging: Nunya
- Pardon my noobish Q,but when accessing the AM/FM amp, you just pull the pillar out with brute force?
- Need help with no start. I changind my ecu and injectors and now car is dead.
- so who's car was this??
- Tranny slipping, recently replaced engine, tranny was fine before change, but car sat for
- Quesitons about the adjustable upper control arms....
- Found a complete B5 S4 motor for super-cheap, thinking of buying, but has issues--details inside...
- Feeler: Won these limited edition K2 Pabst skis at work. I dont ski. Looking to trade or sell...
- Paging velosouljah and anyone else who wanted to see my Alpine IDA-X001 Install...
- Hi guys, just visiting from another model, but had a tranny ? for the experts
- 2008 NORTHEAST AUDI SPRING BASH
- Is a compression test fairly accurate when the engine's cold?
- Show of hands: Who here hates gas pumps with one shared nozzle?
- sitting next to craw mark at joeys wedding on my itouch
- Any benefits or detriment by installing this clutch kit?...
- An idea for an S4 Bumper... anyone seen it done?
- VDO Boost gauge
- Need help identifying corner light. Help extremely needed
- What do you guys think of the location of my intake. Dont you think I should re-route it back up tow
- guess how much I just paid for a shop to do a wheel bearing, all new rear brakes and inspection?
- NAPA rear rotors OK for normal use?
- Bose Stereo Issue
- Install help: I'm trying to replace the lower door moldings. Does it matter... *edit*
- http://www.ibeo-as.com/squba/squba.wmv ... thinking of buying a laser scanner
- Need some install instructions on lowering a 2000 B5 Avant
- Is the light output of those $100-or-so ebay lights decent? The ones with the halo things...
- Post up your best/worst Dino vs. Synthetic valve train pictures...
- Mr. DungBeetle,RovingBeetle,StinkinHippie etc.. YGM
- bad snow (upstate ny) + woman driving Jeep =
- blown speaker?
- Garage cleaning.. Anyone need a set of rare Sport seats?
- Gas Brand
- Paging carson: price check on B5 A4 oem rear rotors
