View Full Version : A4 (B5 Platform) Discussion
- broke brand new slave cylinderr ughhh need helpp plzz
- Can anyone list the P/N's for the Oil Filter/Drain Plug/Crush washer for me please?
- audi rings air freshener
- 1999 Audi A4 2.8Q Broke Front Axel, Damage to Shocks. Body Perfect. Repairable?
- Oil in IC pipe & idling problem...
- OUCH!!! Opinionz Plz! New OEM clutch w/1.8t APR chipped engine slippin after 7 mos??
- HELP! Need replacement Flik 18" Justice (Gunmetal)-Pothole killed mine!!!
- Need some help...Car wont stay on...
- A4 UltraSport 3.0 Q SALE!!!!
- Need help with ECU
- Poll - how many of you are heading to Waterfest this year!
- Brake experts' advise badly needed - please read all
- thinking of putting LED DRL-too much?
- need help please!!
- Replacing starter
- Body shop
- help
- Having problems with my shift lever
- A.W.E. Tuning Waterfest 15 Sale: July 6th – 31st!
- SUMMER BLAST SALE 10% Off STOREWIDE. V-Maxx Coils, Milltek & MORE!
- Help diagnose humming noise
- Oil check valves
- Cylinder misfires....part number needed
- Sudden overheat problem
- Turbo kitz
- Airbag light on
- transmission problems
- tiptronic tranny prob.add fluid?
- Any PES T28 equipped cars out there?
- engine realiability
- Stock suspension
- Keyless entry programming help.
- Is it time to sell and upgrade?
- ac aux fan blowing fuses
- Recaro Vivo booster child seat in a B5?
- rear brake pads worn one not and one still new?
- Winshield Repacement....Picture needed please
- help: is this part causing oil deposits on tb and intake plenum?
- Seat cover for a4 1.8T 98.5
- CC wiring diagram needed.
- Audi + VW Super Sale!!
- OEM Sport Muffler on SALE!!
- Just did timing belt, WP, and pulleys...
- I need to find someone that can tune a AEM stand alone
- Need Bose speakers for 01 A4
- Air conditioning
- Do you know if this guy is our forums?
- slave cylinder removal and installation (2.8)
- screaching sound at idle
- clutch pedal to the floor...
- my b5 quattro starts then stalls a few times before it will stay on
- How far into the hub should a front CV go?
- Who wants some free AxisMotorsport decals!?
- blower motor/relay/switch??
- AUX power source in boot/trunk
- help
- New Brake Pads
- Estimate to change the clutch 96 Audi A4 Quattro 2.8 V6 Manual
- OEM Coolant and Parts Needed
- Random Misfire
- New CC module worked until driving over
- ESP programming?
- One axle breaks (quattro), car won't move?
- Parking brake cables for '98 A4
- '01 A4 1.8T Q replacement rotors
- Buying a used Audi A4...
- '96 A4 brakes...
- Cracked Pleather seat
- Amazon car parts for B5. Pretty good pricing
- Weekend Mod thread? Me - lowering the B5 - possibly more if I have parts - thorough c
- Need help with the facelift headlights.
- MODS FOR MY B5
- speedometer works for about 10 miles then stops working until i shut the car off.
- Engine oil weight?
- Phone Jack in center console?
- Coolant question...
- Brake rotor removal trouble, rear
- That is about all I can take.
- I think it's time to sell/donate my car...
- Were can i find this Part. goes on tranny.
- Audi A4 Quattro
- 2.7t Boost?
- Car died - strange problem pls read
- Help! Car died last night
- WTB: 98.5 30V three coil pack and plug wires. Anyone have one available?
- 1996 Audi A4 Quattro!!!!!!
- Suspension Finished and Nice
- Loud squeak-
- HELP power lost between headlamp switch and fuses
- Anyone in Boston have Vag Com?
- B5 A4 1.8T (ATW) ECT Sensor P/N request
- Did you guys know that RIverside Parts is being shut down?
- coolant and oil mixing
- AEB Guru Needed...Boost Problem
- S4 shocks and springs on A4 (need a fast and definate answer please)
- 1996 A4 2.8 radio code?
- Question about door trim..
- Need advice on parts compability...
- What is this loose metal bar under front of my car?
- EPC warning indicator
- APR Commemorative Sale - June 22 – July 31
- Who else has done the MFS replacement? (Transmission Multi Function Switch)
- 1997 1.8t Auto transmission, reverse not working.
- Driver side front and rear parking lights dont work
- Engine idle/rev problems
- paging Nate... did you do your trans service yet?
- Timing belt tools - Bay Area California
- what do i have to do to run on the track
- 1996 A4 Quattro 6cyl - Oil temp gauge
- 2001 A4 QT 1.8 Coolant Sensor
- 98.5 A4 Converter - Which source would you advise?
- OIL TEMPERATURE PROBLEM!!
- So I finally grew a pair and got this:
- First post in a long time - not a happy one, possible blown turbo?
- Vag Cable Issues, any Help Appreciated!!!
- Timing belt
- can you remove the front lower control arms w/o...
- Brake Pedal soft and Brake sticks after heated
- starting problems
- 2004 ULTRASPORT 3.0Q -- LOWER PRICE!!!
- Quick Panasonic CD Changer Question for Audio Expert
- A/C Problems all over the place
- What clutch kit to buy?
- How to install front right lower door moulding
- Need help. Coolant expansion tank overflowing.
- Drain Oil?
- O2 Sensor confused?
- A4 - Transmission Issue - Please help!
- Suspension Job Woes
- Eibach vs. Vogtland springs
- Help! Oil pressure too high
- Central Locking
- ECU compatability
- Play in the drivetrain
- Will these fit??
- Exploded View of Tranny???
- Need some advice before I buy an Audi for the first time!!!!
- Any advice before I do my suspension?
- Need Help! Tons of DTC!
- N eed alignment recommendations for street
- ATP manifold - grrr
- Timing Belt Problem?
- Leaking oil form tranny.
- Will 97 CLP work on 99.5
- quote for coolant leak...
- Rear Differential and Axle Seal Question
- Who runs a test pipe??
- unstable idle after reconnect batt, despite doing TBA
- cooling problems
- Dashboard Model number location?
- pic of old turbo
- Sigh, my day went from bad to worse
- Tire Rims
- Performance parts?
- Rim sizes
- Air Conditioning & Over Heating Problem
- left engine mount - is the turbo side?
- 273k mi...pay for new transmission?
- Touch up question
- Clutch noise ( ticking or rubbing sound)
- Check Engine Light
- And the Hits Just Keep on Coming
- 22.1 (F118) A/C Refrigerant High Pressure Switch, static open. Where is it?
- Stupid question.... Which side is right?
- 1.8t not revving past 5k
- How much GOOP?
- Parting out an A4
- Problem starting
- Powder Coating Rim Question
- ABS Constantly turning on
- Bosch HID's won't work after storm
- Rear ABS Sensor Installation help
- WTB: B5 A4 rear drivshaft cv joint, Window Regulator, interior stuff and other random
- HELP!!! Front windows will not roll down...
- Can someone tell me whereabouts the drain is for the battery shelf area?
- Air conditioning fault codes...help!
- Help: Car Stalls After Pumping Gas
- dealer avant roof rack ?'s
- 1997 A4 2.8 air intake
- ECU compatibility '98 to '00
- CCT... again...
- Check Engine Light and code problem
- A/C Noise
- knocking noise in my wheels when I turn
- Oil light flashing.... What should I do?
- A/C Clutch / Sensor Issue
- Loss of boost issue
- A4 (B5) 1.8T Overheating Challenge
- Rotor removal question
- Nut question
- Help Lost power Steering!!
- Need Part Number
- Went for a late afternoon drive
- O2 sensor and code help please
- EMERGENCY TIMING BELT REPLACEMENT HELP PLEASE....
- Squeek in rear when taking off - source?
- Broken ABS Wheel Speed Sensor Wire
- Weatherstrip seal for the trunk?
- 2001 1.8t Cat Replacement
- Brake upgrade recommendation
- Front brace , Upper & Lower ?
- Speaker Recommendation
- alright i am sure this has been talked about /oil
- 96 a4 quattro a/c shuts off
- Time for some transmission service
- Changing wiper blades...Why is the passenger side windshield wiper curved?
- symptoms of failing coolant cap?
- Question on cleaning the belt path....
- NEW A4 member
- ot R.I.P. MASTER
- How can I opened headlight? -B5 A4
- please help i cant figure this out.
- Foiled by cheap aftermarket catalytic converter, suggestions?
- Exterior door trim kit
- Tie Rods Won't Come Out
- P0116 code and thermostat change
- What a month for Audi common probs
- Anyone know where the release tab is for the front passenger side turn signal?
- Market for a Dahlback chip....
- Rotor Replacement at 30K miles?
- Blinker relay
- Alarm system going off...
- Noise behind dash
- Startup Issues - Help!
- front bottom seat cover
- Flashing BRAKE light | Loss of braking assist
- Check engine light, checked the DTC codes, now what?
- slow car
- 1997 Audi a4 2.8 quattro Overheating problem
- In trouble here - No start after MAF cleaning
- question about which ICM i need
- Loose bolt on subframe need solution.
- ABS sensor install question.
- keep or sell
- Transmission - Major Leak
- New Wheels - what do you think?
- Using B6 17'' wheels on my B5
- update
- 01 1.8t sport tip
- New Treatment for Gout
- ABS + boost problem
- Looking for radio change
- What is this thing?
- Replacing front speakers
- B5 ipod MMI inteface AND phathoise at same time?
- ECM need replacement?
- Whats the best way to get to my front passenger side turn signal?
- How do you test a combi valve?
