View Full Version : A4 (B5 Platform) Discussion
- YAY!! Theft recovered, and car isnt too damanged. Help me figure our mods to replace!
- koni coilovers damper adjustment question
- Had rear wheel bearing replaced today, shop did a terrible job to say the least...
- When accerating, the car flattens out...
- How to test Secondary Air Injection pump with VAG?
- Questions about the bilsteins and vogtland i just got
- Caliper carrier torque?
- Car Stolen, damages not TOO bad....but I am looking for a CF hood. Any for sale pls?
- AC help please, I've tried lots of things
- Febi TRE Blowout
- Replace VC gaskets or not?
- CEL P0422
- 98 30V 2.8V6 Oil leaking at rear valve cover.
- Flange pics
- If its not one issue its another....Now having starting issues. Please help....
- 98 Audi A4 rear deck speaker ohms
- Foglight cable color
- I need help...
- I've got some problems. Codes, log and description inside...
- 1998 B5 1.8t question..
- Which 2.5" exhaust, Neuspeed or APR?
- transmission is leaking gear oil
- Simple rear pad wear??
- Engine Noise
- DTC 17748 problems??
- cant bet bolt to loosen on viscus fan even with using special tool
- "ABS + Brake" warning lights????
- debating whether 2 dynamat floorpanels
- Ecode tuning testpipe for sale - People still use testpipes these days?
- a4 brakes
- Rear view mirror fell off; anyone know how to put it back on?
- Headlights not working (read FAQ)
- Power steering leak
- A4 schematic
- Plugging the ATF hose
- APR chip installation
- Electrical problem, possibly a relay: A/C, fogs and radio won't power on
- What type of plastic are the B5 bumpers made from??
- Help!!! Under acceleration engine stutters and its getting worse!
- Just bought an Audi...couple questions
- Tuning Shop/Reputable Repair Shop Recomendation?
- B5 Aftermarket Pedal Set
- Coolant Leak
- ECU Relay Location ?? HELP
- 1997 A4 1.8 Engine starts/won't start
- Our cars values are dropping like flies....This is a concern because.......
- I just wanna say...
- Selling the A4 - Parting out some stuff, will this even sell? How much for car?
- transmisson help please give me feedback
- Thermostatic switch
- Help. Replacing rear rotors on 99 A4
- Exhaust leak
- Audi A4 B5 1996, Funny problem
- FYI - Fuel Filter be VERY CAREFUL with the lower banjo fitting fuel line!
- Help with Sunroof Fix
- AEB engine in ATW car?
- Traction Time
- If I never have to do another fuel filter on a B5, it will be too soon..
- AC Not Working!
- asap "Cam Tensioner Gaskets" and "Camshaft valley seals" question
- Whos going down to H20 this coming weekend?
- Where is the other end of wheel speed sensor harness?
- 96 A4 2.8 headlights
- S4 bumper with black lower pic request
- OT 02 GSX R750 stolen from Hooters lot in Union NJ
- Did anyone know how to take the climate control panel off?
- Anyone with a service manual help me out?
- Anyone have ABS module for sale
- Just installed Bailey Motorsport DV
- All Motor Question...
- Help please
- Recharge R134a AC
- 1.8t AEB bad?
- I'm hearing a swoosh noise from my rear suspension/shock.
- 3rd blown turbo in 2 months!
- Replacing Outside Drivers Mirror Glass
- Airbag control module not communicating with VAGCOM...
- Just but 1999 a4 1.8t and have problems...
- Is there any benefit to going with a larger diameter...
- NEED HELP BADLY!!!
- ABS sensor testing.
- For all the pro audi owmners help!
- Anyone have a CARFAX account to run a VIN for me please?
- Speaker Recommendations
- Looking for advice on how to "de-Bose" concert radio
- Electrolytic Rust Removal FTW
- Busted control arm.
- MAJOR electrical problem!!
- What parts do I need to for a Timing belt change?
- Anyone used the O34 Control Arm kit?
- Upgrading 1997 center concole.radio
- Please help - calling users with aftermarket head unit stereo
- AEB engine cyl 1 misfire
- Crankshaft Pulley Bolts
- Audi 99 v6/30v electronics gone koo koo bananas
- 99 A4 erratic idle and no power
- mirror question
- Problem with climatronic 22.1 (f118(
- A prospective owner lookin for a professional opinion
- ABS Light
- 99 A4 a/c not working....
- Error codes for 2001 1.8t sport quattro
- Anyone know this part?
- Snowflake not staying on
- Rear WHeel Bearing Sources
- Rolling idle with AC on
- What is the difference between ecu # 8d0-907-557-n and 8d0-907-557-p
- Crap, sunroof jammed in the open position
- Does this seem over-priced to you?
- Rear seat removal
- 2.8 30v need help w/ head install ....w/ pics
- HELP!!! Rumble/Growl coming from engine and exhaust, check engine light on
- Pictures of BBS CH or LM
- cracking and creaking noises from front end
- Manual Transmission Fluid Recommendations
- Boost with AC on - Sluggish under load.
- Wheel lock systems for Audi?
- is PES g2 supercharger a good option for my a4 b5 2.8 v6
- A4 not starting HELP!!!
- 99 A4 B5- rear bumper removal
- Climate Control Stopped Working
- Wanting to lower.. can't decide what suspension..
- ABS stops working
- first post and i already have a puzzle...
- Speedometer just stopped working...
- Turbo Inspection
- 1999 A4 turbo.....WHERES MY POWER????
- a4 quattro tire wearing fast
- 1999 CD changer
- Just got an S4
- O2 sensor troubleshooting
- Aftermarket HID question
- Outside Temp Sensor Location
- Thanks Silvia680 for the parts site....What gear oil shall I use?
- Radiator Swap, Need help!
- 1.8T exhaust gasket replacement
- GF said she saw two small plooms of blue ish smoke from the A4
- Newbie (though not new to Audis)
- Driver's side HID headlight not working.
- Chirping from driver side.
- braking problem
- Can't Read???!
- Lost Keys
- Motor Mount Comparison
- new guy with problems
- YES! My injectors and VCDS are here!
- RS4 wheels hyper black
- Extreme security approach
- Mirror caps
- Will the B6 sport 17 235 fit..
- Oil Spill Questoin
- Brake light on I.C. beeping upon start
- car stuck in park
- Odd blowing noise
- Whats the concensus on Manual Transmission Fluid to use these days?
- My new shoes
- Suspension & wheels
- :: ECS Tuning :: OEM Audi Parts Database Search - Now Live !!!
- What short shifter are you guys running?
- Does anyone know if there is a company that does control arms with poly bushings?
- Engine Code differences & Info? AUG?
- help locate part #s/names for electrical harness
- Crank position sensor
- Poll: Replace it or Keep it
- Hmm, looks like only modest gains were made on my injectors cleaning
- Help me diagnose an issue please
- How to isolate cause of suspension noise?
- Control Arm Question
- Anyone know the Trans code for an AEB 1.8t 5spd?
- Sigh, finally did it
- Rear diff fill plug part number?
- is there a market for CH box chips?
- Reverse is not ingaging
- It was a fun ride, but now its time to sell.
- How do you release Avant rear seat when the handle breaks?
- 95 A4 Console Help
- Found a steal
- I don't like the look of this Ruville rear wheel bearing
- Transmission Mount testing
- 98 A4 2.8 knocking on start up
- Has anyone had any luck with the russian website ABS module fix?
- newb back with clutch problems, slipping like a mo fo
- Wheel Offset question for 2000 A4 1.8t quattro
- How much are people paying for timing belt services?
- Jet Sound coming from my A4
- 1999 A4 help
- vibration on the steering wheel
- Looking for passenger headlamp
- :: ECS Tuning :: New Website Now LIVE !!!
- Cold wheel bearing fit.
- Engine clatter
- Spark Plug Replacement
- Darn Tranny making a whining noise like a power steering pump
- B5 with UrS4 Fuchs
- SC A4 or S4?
- Thanks to a fellow AW'er I was able to go out for some logging...
- Luck finding EVAP system leaks?
- Because my day wasn't already bad enough...
- LATCH kit arrived today
- OT: B5 A4 Wiki looks GREAT!! I like Joel's car at the top.
- Shifter Play Slop
- Car is running.. still boosting no more than 14 psi. doh!!
- Major transmission problems....
- Need help: terrible shudders at low rpm/idle (flashing CEL)
- oil pump-1997 A4 quattro V6 2.8
- Aftermarket Head Unit - 2001 A4 - Harness and Dashkit Problems - FYI
- Hmm, I can't seem to read that message at the top...
- Poll: If you had to chose one or the other...
- need help with strut bar and tranmission
- Piggy pipes on an A4 1.8T??
- OT: a little something around the corner from my house. F'ing sweet.
- SAI comes on when stopped at red light
- 3.0 v6 swap into a 97 A4
- Need Help!!
- Some progress..
- Cold start issues resolved!
- 26k posts NOW!
- OT: Lol this is for you Doug, Joel, Kris . . .
- Fuel injector cleaning services
- Bolt size for battery hold down....
- Chain tensioner Gasket ..
- mysterious oil leak still occuring!!!!
- New ABS Now Vac Com Won't Connect
- Anybody parting a B5 V6 in CT/RI/Eastern MA??
- How bad of an idea is it to...
- The A4 2.8L engine - any performance potential in this thing?? 1.8TQ vs 2.8Q??
- Is there a fuse for the MAF?
- We just uploaded 2200 items onto eBay and still have another 1800 to go – AW Gets 10%
- Need help (long), What would you do?
- Same Ignition switch/ load reduction relay problem with new ignition switch
- Brake Problem Want Opinion
- ABS engaging at low speed
- Retrofit Late Model A4 Seats in to B5?
- Facelift
- Only making 5lbs of boost????
- Question about clutch Pedal
- looking to buy a b5 a4
- after new battery aftermarket chip not working - 97 audi a4 1.8t
- Slightly used 3rd gear for sale.
- Radio Harness?
- Electric window problem
- Car won't start after refueling.
- Oil pump gasket leaking?
- For those who are about to have or have little ones, the car seat I have fits
- My CEL is on and im stuck at the GFs place...need help!
- BBA reman clusterpox repair review
- Custom wrench made. Check. Turbo in. Check. One more problem. Check.
- What to keep A4 2.8 or A8
- 2000 a4 A/C aux fan not working
- 2000 a4 oil temp
