- Anyone in Bay Area got a VAG thingy?
- Anyone know why I would have such inconsistent tire noise with brand new rubber? (x-post)
- Wheel question...
- Has anyone used the LLTek vinyl molding lower door trim with S4 sides?
- How do Audis compare to American cars? You guys call em Foreign or Import so you obviously wanna
- Driver driving debadged/clear side marker'd silver a4 on hutch/henry hudson getting road head...
- Can someone show me picture of a T28 on a 2K-
- How do you go about "corner balancing" a car with C/Os?
- SSR comps are on the car with 235s yokos.....looks good....
- Good post about different model K03's from ClubB5
- Looking at doing timing belt tensioner, Clair's 'new' price for the kit is the suck!
- how much is upgrade to s4 door trim?
- BOV just went... anyone that is running HKS SSQV...
- trouble starting again after stalling
- Oil/Temp warning going off after making left turns?
- Whats DBW?
- anyone here using the RS6 HID setup in their halogen ecodes?
- My odometer went out
- Free music.
- K26 will it bolt in?
- Boost problems....
- i started sanding my hood and fenders today...
- mobil 1 viscosity?
- Another Neuspeed 19MM Rear Sway Bar Question.....
- nicks on wheel....question
- do we get any discount from tirerack.com? there was "referral code" b4 order tires. thanks.
- Suspension Saturday...
- Half way through my Borla install. Random info....
- KO4 1.8T vs. PES SC 2.8..
- Question for anyone who has KONI Adjustable Shocks
- Quick Question on 19MM Neuspeed Rear Sway Bar
- how can I safely clean the sticky buttons on my console?
- Thermastat replacement $250???
- Hi guys doing timing Belt and other Maintenace Questions need some help!!
- southern connecticut is full of audis'......
- Oil/Temp? warning light going off...need help please
- is it still possible to get in on the K04 GB?
- Clutch / tranny differences between a 1.8T Quattro and a 1.8T FWD??...
- Trying to avoid the "new car bug" so, should I hit a Rieger RS4 Bumper -
- How do I mount this changer???
- Clean car pic, spare tire replacement, pick on BMW owners... haha
- Have a question about drives door latch....
- Car won't start... won't even crank
- Looking for independent Audi mechanic for engine replacement
- compatability with mix matching clutch and flywheel...
- Clean car pics
- Digital A4: Check your email
- Does APR EMCS work on a Stage 3 car?
- STFA: Did .aye four. get his ECS c/o kit installed yet?
- One of the rear speakers in the bose system is making
- replace timing belt at 60k or every 60k??
- question: requested vs. actual boost [EDITED]
- Very bored, I think I am going to put the car on ebay and see what it's worth...
- vdo gauge/non vdo gauge
- Headlights Out
- Mattig Bodykit
- Suspension question
- Info on Ignition Amplifier/ Power Output Stage (P/N)
- Cool Ideas for front Euro vanity plate???
- Moved to Germany...couple of questions for y'all.
- A4 door locks
- Pedal Installation ?
- Look Mom...tranny flush!!
- "Unlocking the Secrets within the Climate Control" Question
- anybody elses mintex pads disintegrate and fall off the plate there attached to ?
- quick, where can i find the paint code for a 99.5 bb???
- Just bought FMIC...I heard that this can create a CEL?
- Ok, so my car has been parked for *shutters* 6 months with one start up 3 months ago... what needs..
- 98 AEB- where is the MAP sensor (G71) ?? AKA Bar Pressure Sensor
- been to many concerts or festivals in your A4? Fun lovin criminals tonite
- want to buy oem sport suspension
- Rattling from front of engine '99 1.8T
- I'm off the the Petersen Automotive Museum....
- stock shifter bushing article??
- looking for someone to do PAINT WORK in the Tidewater Virginia area
- who needs a minivan/SUV/MPV
- Can I run KO4 w/ K03 programming until I can get new program?
- Horrible Engine Noise
- Surging at WOT
- what the heck is this stuff?
- apr 93 or giac x chip
- Leaking boost?
- Questions about rims...
- can someone please explain:
- idle question...
- humming noise from right rear corner
- best place to get extended car warranty??
- I love my borla....
- could a bad alignment cause vibrations at highway speeds even if the tires are balanced?
- Got rear-ended on the 10W today in Downtown LA.
- pop up lighter repair
- Just tried hooking up my Blitz TT to my 97 1.8T...
- SHIFT KNOB HELP FAST!!!!
- Temperature light went on..what does this mean?
- Have you guys ever wanted to put your car on ebay just to see what it would get?
- Adjustable Bilsteins With Stock Sport Springs Pic?
- Anyone with a 96-98 A4. Do you guys have this cover in the engine bay area?
- my back driver seat florr was covered in ICE..............HELP
- Who has info on good pully kits to add to a stgIII 1.8t??...
- anyone hear anything on when we are getting our
- fuse question... is the crusie control fuse socket supposed to have a 5amp fuse ?
- Any Home Appraisers here??
- Michelin Alpin Pilot snow tires on eBay 17/205/50
- Painting chrome on grills black
- halfway through timing belt change--found metal shards
- wheel lock trouble
- Will 2001 TT seats fit in my 98 a4 2.8 ?? TIA
- Need help finding shocks. Need good prices on good shocks, not 'tude.
- 1998 headlights?? 1.8T vs. 2.8?
- erebuni, type A front bumper install?
- Removal of center console
- N00b Q: ECS Sells oil drain plug and washer together...
- anyone use an Apexi Boost Controller?
- Whats the best way th descreen the MAF on a 2.8
- Clutch?
- garage wall ate my driver sideview mirror
- Does it mean anything that the springs on my koni c/o are green?
- Who is going to be at AMS Dyno Day on 28th.!
- APR V-Tune
- Anyone here interested in a GB on Greddy FMICs?
- Took me 5 hours to adjust my coilovers...
- WOOHOO...STG3 Successfully ordered!!! Will be in car end of month!!! (starts lookin for WRX's...)
- anyone have pics of a apr fmic installed???
- Help, car won't start! 2000 A41.8TQA. It will turn, just not fire. Coilpack? Something else?
- alignment
- Clutch and Flywheel question.
- Any updates on the GB on the rs4 reps (17)??
- Paging Jared from OH. Can you tell me if you receive the fog lights...Please email me.
- looking for euro hella horn...
- Best place to buy Rieger RS4 look?
- The alignment shop said my camber and caster are too far off to correct...does that mean I need new
- Buddy needs advice on a 1.8T
- anyone know the measurements for....
- Suspension clunking, missing bolts
- 17" RS4 Group buy is almost ready!
- DTC 16395 - Bank 1 Camshaft A (intake) retard setpoint not reached (over advanced)
- Need advise on 1996 A4
- brake pad wear-under warranty-dealer issue
- Bilstein parts number for a 1999.5 A4 1.8T QM
- ProDiag vs. VAG-COM?
- slight vibration at highway speeds...
- Look what the DHL man left me.....
- Won a handicapped street race today. Whooped on an Integra.
- How much can a dealer deal?
- removing resonator with stock exhaust
- Anyone got Stilauto 19's on their B5?
- 2000 1.8TQM GIAC vs. 1997 1.8TQM GIAC K04 = same???
- Need feedback on possibly selling my 99.5
- anyone have a decent sized "A! avant garde" logo?
- So I stopped by the VW dealer and checked out an R32 today
- Is there anyway to get the '97 black cloth-type seats more black? Like armorall for cloth?
- Achtuning 17" RS4 Wheel Group Buy UPDATE
- Splicing O2's.
- exhaust sound wavs...
- new body mod. think its possible to make.....
- Price aside, this is not that bad of a deal...
- A good place to buy a wiper relay?
- i cant find the s4 aluminum dash trim on clair. where can i get them?
- Installing springs
- H&R Race Springs... 1.8 vs 2.8
- I'm in the middle of installing my ECS Bilstein Coil Over Kit. Great so far..
- WTB some OEM audi projectors only.........
- Can someone link me to a site selling OEM S4 sides and trim. Couldn't find it on Clair.
- testing wiper realy
- lowering springs on stock shocks? bad idea?
- hi
- 8x17 versus 7x16 ... I like the 16s better! (long)
- Found a tear in my drivers' seat today. It's the black vinyl. Not happy. Howz best to fix this?
- How to haul a large dog (Mastiff) in the A4 w/o f-ing up the leather. Any tips/ideas? What do you
- Couple of Fixes Needed
- Another Radiator Hose Question: OEM or Car Quest/NAPA/AutoZone??
- Chip vs. SplitSec turbo boost controller??
- How much should I expect for a clutch install? 1.8T Quattro.
- S4 side skirts and door trim Group buy.
- Corroded alloys
- anyone have ASA AR1 wheels or FLIK artics on their TT's?- POST PICS!
- Brake upgrade
- Hey, could somebody pchop an RS4 kit onto my car
- Reminder: Central Jersey Rutgers University parking lot meet; weather looks great!
- A4 2.8 Sounds like a diesel in 1st & 2nd gears...
- Any opinions on the 99.5 A4 Quattro Neuspeed catback exhaust???..........
- 98.5 A4 1.8T 85K miles... 1 bar safe or go with .8?
- Is upgrading the rear brakes to S4s worth it, or should I just do better A4 rotors, pads & lines
- Softest Lowering Springs...
- Getting 2.8 Timing Belt Done this Week (72K Miles) Should I Replace......
- More info in DTC codes? I got a 15.7 yesterday & car cut off while driving.
- Timing belt replacement costs
- MY 2000 a4 quattro on some new rims
- Anyone know of a good repair shop in
- 1.8 Quattro Turbo Problems
- headlight problems
- where is the hazrard relay located at??? my blinker stays on, dealer said replace hazard relay. help
- RS4 kit (Riger look) group buy
- Question about difference with reiger v1 and v2
- I STFA can someone tell me what each package consisted of for MY 2000 A4's?
- installing xenons....
- Starting problem
- where can i buy replacement fuses?
- Is there anywhere to buy the greddy TT III?
- Snowboard trip- canceled
- pulled the trigger on a neuspeed 19mm sway bar
- bilstein shocks with stock sport springs
- WOOT!!!!!!!!!!!!! pullin the trigger on a few things tomorrow...
- PSA: Have you flushed your brake system lately?
- Poll:
- My coilover's stuck...I was trying to lower it and nope...
- Went to a last minute VWvortex meet in Union...mega BWW
- apr roll control springs - info???
- need spring recommendation
- Just got photoshop and I have a question...........
- or toyo proxes 4 for $114
- 225/40/18 Falken ZE-512 for $108...
- got rear ended today...
- Quick, help! How can you get the front ball joints apart without the special tool?
- ne1 have a driver door panel 4 sale?
- Good Denver Independent Audi Shop anyone?
- Installing Neuspeed Bilsteins: Some Questions
- Just got a 2001 A4! Some questions...
- Hey guys...
- why HIDs are better than halogen.
- AWE CF groupbuy update!
- UPS rocks....
- A4 only outputs RPM, speed(km/h), coolant (C) and TPS(%) to the ODBII interface?
- What is the best headunit that matches our interior red color? Model #'s and pics please!
- So the car is still in the shop =)
- AWE DTS anodized?
- Getting a V&S ss and trying to pick out a knob.
- I'm a wasteful person
- intake
- Ne1 have a Kamei Grill 4 sale?
- Good-bye my Precious A4
- Anyone have a Borla Exhaust and a Hi-Flow Cat- I have a question?
- AMS Short Shifter On Sale!
- Promblems with PES kit......What do I check??
- best place for s4 rear valence???? found one on clair parts for 119.95
- Anyone else with a Wife that...
- Paint question
- can i...
- Anyone know where I can buy 2000 style tail lights?.......
- ive done some searches about seat inserts but....
- i stfa but im still kinda confused on putting in Phillips Silvervision bulbs...
- Tanner Movie website still up?
- so my folks leave a message for me
- neuspeed 19mm rear sway bar for $210 shippied... ya or nay???
- Audio System Wiring Diagram
- Anyone know the name those plugs used to cover the license bracket holes...
- I'm happy...that is all!
- On a scale of 1-5 how hard is a boost guage install
- zimmerman rotors and EBC green pads
- two new pics from today's labor :)...
