- I need to do a solid works project for a cad class....
- Solaris and other 1/4 junkies... $100 for unlimited runs on 11/12
- whats the name of this part and where does the vacuum hose that...
- GRRRRR.,,, Right rear wheel bearing is making a nasty noise....
- Here's my quick review of the Stern Rear Diff Bushings...
- Does your 2.8 engine cover hit the underside of your hood insulation?
- Motive brake bleeder problem
- need help: power locks are broken but last time they id work my car was locked, i cant get to the
- Having my engine rebuilt. a few questions for you guys.
- Anyone know were to buy in-line check valves at a reasonable price, or an alternative?
- weird instrument cluster woes, any help appreciated PLEEASE
- How would these look on my car?
- A friends new project (caution Porsche content)
- Bose Speaker (2000 A4 2.8 Quattro Avant)
- Just saw that ASP site is up and going. Will they be doing much A4 stuff? Most of their..
- strange noise from brake
- I just replaced my inside driver's door handle - the one with the fragile spring.
- Well here is our spread from our visit to the Beer Yard today...
- Timing Belt Broken should i repair or sell?
- Last nights bulb discussion at Advance. Silverstar Ultra not always brighter
- Are these doable? valve cover gasket/power steering reservoir replacement
- how to find out if you need the steering strut or not for a 1996 A4's steering rack?
- Has anyone ever had a lot of noise coming from the fan pulley or clutch?....
- Sway bar bushing mod/upgrade(in process)...
- A4 Exhaust
- 1999 A4 1.8T up in flames
- LMAO -- Looked at a 2001 A4 1.8TQM
- Video indulgence for the day - R8 around the Ring
- Anyone know where I can get a 3 way brass vacuum fitting for my boost gauge?
- Question about location of giant HOW TO thread
- $33 for a 30v 2.8 throttle body gasket...is that some sort of sick joke?
- Whats the avg battery voltage range?
- are h-sport sway something i want to buy used
- Audi Wheels
- I have some changes coming this week:) Keep an eye out new mani, shaved lowers finally....
- So I wont be doing anything i planned this weekend FTMFL =( need suggestions PLZ look inside
- The wife and I are going to be in King of Prussia, PA tomorrow, I figured i'd swing by the Beeryard
- I am loving my revised Level Ten Valve Body! (more)
- NE1 else have issues with Motorola BT using "store" as a command when it rhymes with "four" argh!!!!
- swapping turbos this weekend and I'm looking for any good hints for the block coolant line
- TightT Email me please or get on AIM
- VAG-COM logging noob needs some help.
- Who has the link to that used A4 check list?
- anyone here need a valve cover gasket kit for a 2.8?
- CA Smog resetting codes - How long?
- 130K.
- hoping someone would know this answer...
- weren't all B5 avants quattro?!
- Anny suggestion for rebuilding a 1.8T AEB
- *Sigh*...what do you think? There are the "5x112" 17" FTDs. Rubber on Sat. Algmnt on Tues.
- Silverstreaking: I found a car for you
- pics of B6 sport wheels on a B5?
- battery dead overnight
- Carson@RiversideAudi has now seen/heard my car. =) What say yee??
- I need a hug.
- my how you've changed
- Paging silver streaking... i had the coolest dream
- Anyone have a close up pic of a 557P ECU chip?
- Problem with lights
- Wife's '98 A4 2.8 Avant needs new tires... Any suggestions?
- Weekend Mod Post:
- Looking for a good used k03s can anyone help?
- Quick Trivia....All Fliks are drilled for 5x100 & 5x112 correct?
- Error codes diagnose
- Paging Adam (TighTT)....got your license plate lights!
- Feeler post: might be parting out my mods
- Fix for G22 sensor problem??
- offset question - 99 audi A4 quatt.. 17 or 18" wheel
- A few pics after a cleaning today.....
- What's the most probable cause for engine knocking?
- Has anyone used a Walbro GSS341 or 342?
- independant fog mod help
- Help me identify this problem, picture included (2000 FWD A4)
- Vag-Com question: Is it a one computer or one subscriber program?
- Ahhh.......need some converting here
- What is this wheel?
- screw clamp instead of crimp ok?
- what a tard
- hahaha wtf PureMS having issues?
- air/fuel gauge
- Oil Change Confusion
- determing which o2 sensor or cat is bad (codes inside)
- Question about jacking the car up from the rear diff....
- Has anyone ordered from this ebay seller before? Looking to purchase front drivers ABS sensor.
- OEM vs. PureMS TB kit?
- I have a question
- 2000, 1.8T manuel.. What ecu??
- Rant : Maintenance!!!
- Question: If you were to choose any year B5 A4 to start off as a project car, what would it be?
- yay ... car is getting tinted on saturday...
- your vortex potd
- climate control issue staying hot?
- So has anyone done this sunroof mod & been successful?
- Does anyone know what year they made a change in the disign of the sunroofs?
- G89 Temperature Sensor - How to get to??
- Alright guys, poll for you a4 owners, what are your hobbies?
- 034 track density tranny mounts .. just a FYI
- anybody needs these???
- Project Car
- blog #eleventy: been driving around about 1 week now with the combi valve venting
- Can someone post a pic of the underside of a 2.8 Quattro with auto tansmission...
- Flex pipe, is it possible? 98 Audi A4 1.8T Quattro, Automatic, AEB
- G-05 coolant switch, I can buy wholesale from dealers which is my best source,
- Ug; I saw a community college student with half finished "gills" in his B5 front fenders.
- We'll be out of the office...
- senior quote help
- what kind of exhaust should I get?
- Finally finished the timing belt job I started on Friday. Had to wait for a bunch of new bolts
- Flashing "Brake" Light - What is it?
- Wassup guys...how's everyone doin?
- Fixed my vacuum leak...and now unleashed the hidden power...Maybe bad?
- New pics w/ new rims
- Ever wonder what happened when lighting hits your car?
- Thanks Pure Hatred, got the valve in the mail!
- Turbos back...
- Help! What could be causing oil build-up in the 034 PCV Valve...?
- Speed Pulse Wire for 2001A4 1.8
- Uhhh..whats up with Avalon's site? Im trying to order something and...
- VTB Esurance commercials forevAr!
- removing driver's power seat
- So how much do the plastic front undercarriage protector-thingy
- top of hatch(hash) marks is proper fill level correct?
- Suspension: R&R your sway bar links when putting in hsport f+r bars?
- Paging Carson....anything come in for me today???
- Can I get BKR7E's at autozone or pepboys?? They ask me for my car model...
- ABS module is that the same thing as ABS sensor on purems site?
- T3T4 TURBOS
- Borla CB $660 Shipped...
- (Mult) System too Lean - 17536 - P1128
- abs brakes
- 1996 a4 2.8 no reverse automatic transmission
- bank 1 efficiency down. What do I search for to trick the 02 system?
- Anyone here ever hear of "Hengst" Oil Filters?
- A4-1998 -Wheels
- Help! Major p/s rack replacement problem...
- Ok guys, pulled the plugs tonight...here's a pic...
- Update... kinda long
- Just to clarify, will a 2001 a4 sport suspension fit on a 99 a4?
- Anyone know what I am doing wrong when logging into 'classified' section. I input name correct, even
- Pedal goes to the floor.
- ABS and brake light coming on...
- Anyone have an unlimited carfax right now?
- Anyone have a silver S4 front bumper they want to get rid of
- CV boot torn. reputable place to get a rebuilt half shaft?
- also tring to figure out where egr temp ..
- GIAC doesn't sell individual chips for B5 anymore? bah
- Request: pinout from Bentley
- n00b question about suspension setup
- Kris Hansen - FAQ pics change locations?
- APR Motorsport to bid for 2008 Koni Challenge
- does anyone know where i can get a head for cheap
- Who's dat car on the Avalon MS website?
- 1 Day left for the Apikol Rear Diff Mount Introductory Sale...
- I started writing a little note for the new owner of my car
- I might have missed out on Doug's Stage 3 Avant but this looks like a good stgIII candidate
- Who needed one of the buttons off my Sym I radio? I heard from
- A4's suspension (KW V3) is being properly tuned today.....
- Anyone looking for a Sport package rear sway? I've got one in the classifeds I need to sell:
- I might be going to the dark side.
- Opinion request: STaSIS Street Sport or Vogtland coilovers?
- Anyone have an OEM passenger side turn signal bulb holder for the 1-piece headlight...
- *sigh* stalling, bucking, no flashing cel, but problems regardless.....-->
- Anyone in Maryland know this guy? trade gone bad...
- Front bumper lower valence.....
- alternator type..
- tech article not 100% correct...drain/fill tranny oil
- Is 40k about the life of rear diff seals? Leaking again ,did them yrs ago.
- Heater problem.
- GReddy Global Sport - G2S
- Well..it's that time of year..
- uggghh...it figures. Coldest night of the year and my alarm decides it wants to go goofy
- carson: how much are winter mats going for?
- New plugs. Any thoughts on the old ones?
- Stuffing a B5 S4 engine into a 98 A4Q Avant: nightmare or not too bad?
- Does anyone know where I can find a stock b5 sport suspension?
- 2.8 DIY timing belt, water pump, t-stat, cam and crank seals...Completed.
- Drivers side front brake with drag
- Replacing Timing belt, cam seals and other miscellaneous parts
- What is it?
- well...the DIY High Bias diff is in the car....
- Check out this pic from PassatWorld. 225 tire on a 10" wide rim:
- Does anyone have an extra 710N for sale?
- FYI- As of today STaSIS offers free ground shipping on all orders within the USA.
- Introduction
- alternator upper & lower bolt sizes i think i need to get a new one..
- Turbo boost controller questions (for use w/ gt28rs)...
- Is anyone w/ BT using a VES assembly? How happy are you?
- I have not seen too many, if any, other B5's with this wheel....
- My car hit a milestone Saturday.
- your 'zine POTD...
- Flik FTD does not clear brembos... fvck
- Cactus Green Metallic Paint Code
- Correct me if I'm wrong, bad ICM or coilpack=flashing CEL...bad vacuum leak=just a CEL...
- Only a few days left to take advantage of the Achtuning Achtoberfest sale!
- I know to get a new key recoded you have to take it to the dealer, but i found analt
- just saw this sig pic on another audi forum
- End of an era:
- *yawn* ... i get to file with small claims in a week ..
- Paging Carson: Do you have license plate lights (housings) for a 97 trunklid in stock??
- Strange problem last night, went to pull the car(97 1.8tQ) into the garage and it wouldn't start...
- Avalon Motorsports Online Order Special....
- Damnit, 5 yrs and NOW I have issues.....*sigh* halp ploz!
- Driveshaft & full size spare :)
- First post
- Rant: S4 wheels with snow tires. After speaking with a fellow AWer...
- Fellow AW'er coming to verify he wants the Avant today..... should I unplug something so it dies
- Incase anyone was up late last night wondering if my A4 is fater than a....
- Are there issues installing afermarket radio and frying the ECU?
- Does anyone have a parts diagram for a front brake caliper?
- Woohoo cold air !
- *Rant* Whats the point of paying for insurance, when they just screw you anyways?
- I think this is the earliest in the season I have ever seen a snoflake on my Trip Computer....
- 3rd gear pull VAG log and A/F log at 17psi *warning unnecessarylarge picture*
- question of curoisity -
- depo projectors. hit/skip? same light output as valeos?
- good places to buy B6 17" sport wheels?
- Happy 150k! =)
- Doing the VC gasket next weekend. i think i can see sludge looking down
- Clogged Sunroof Drain BT: I was trying to unclog my sunroof drains today (long)....
- Hmm...cant get either of my license plate lights to work....
- What are stock bumpers made of?
- Hit/Skip?
- Okay ,today car wouldn't start . Got it going tonight but....
- How do you brighten the xenon headlights?
- Belt Noise - No Power Steering and Battery Light On - 2001 A4 1.8TQ
- T for Turbo!!
- Has anyone installed this Xenon kit with Valeo e-codes?
- What every car needs.... more cold air...
- I cannot install this....
- what do you guys think stock airbox and filter are worth? I am looking for one and trying to figure
- guys ive been out of the game for a while - what would be an offer you would accept on Oettinger REs
- Part # request. The retaining clips for the heat exchanger hoses. One hose connects...
- 18" or 19" rims on a 98 a4 avant wagon?
- List of automotive superlatives - Lots of interesting info here:
- BitJockey: I want to give you money. She-Mail me.
- Quick question, will a 15" hubcentric wheel from a 97 A4 fit a 99 passat wagon?...
- Judging by the looks, is this spark plug still OK to use?
- help with b&m short shift install...
- The wife and I went out for a drive tonight to go explore Berks County, PA for a bit...
- just changed the spark plugs on the vehicle. It was the first time they had been changed by my guess
- Everyone keeps telling me to sell my car because of problems...what should i get a honda Hell No
- ac/heater fuse out instantly... what to check?
- I think I may trade my BBS's for these....call me crazy....
- Why are the ends of my spark plugs all sutted up.
- A little widebody upgrade...
- F'in A!! I dinged the oil pan on the A4 today.
- does anyone know if these wheels will clear mah brakes?
- I'm thinking of buying a B5 next spring. Input anyone?
- control arm replacement question???
- T3/T4 Setup
