- How/where do you measure fuel pressure? SFTA and couldn't find how. Plus other questions...
- Paging Mica, Mica1, Mica2, Mica3, Mica76392 - Pearl white 1999 A4 1.8t tip 70k miles $5,600..
- Opinion on replacement of CV boot
- Soooooooooooooooooo fcvking sexy. Me want. NOW.
- ABS on all the time...
- WJM, your package was sent out this morning via USPS...
- Looking for a trustworthy garage in Montreal?
- Just changed one of the A/C hoses and have a couple of questions:
- i dont want to sell my A4 to someone who won't appreciate it : (
- Intermittent 17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
- I hate Drive By Wire ! .... any one else ?
- Ideas on buying a 2000 ATW 1.8T? STFA/FAQ doesn't work for me
- I didn't learn the first time
- Blog #3: My A4 saw direct sunlight today for the first time in over a year
- evening ETKA pros
- Ran some Kero on idle and smoke came out the tail pipe - is that normal
- Thank you, whoever you are. Thank you for giving me teh caulk.
- i suck at searching. i cant find write up with pics on removing center console on 98 a4
- controll arms, are they the same in my1998 and 2001
- I've been searching for where to buy my o2 sensor.
- K04 owners: whats everyone's boost running at in this 50-60deg weather?
- The rivets on the Secondary air pump come loose - Bolt&Nuts size please?
- Going to be doing my brake job this weekend.....
- Never thought I would be asking this..but how much do you think my car is worth?
- These headlights look familiar (not the red and blue ones!)
- Update RE fried computer/poor running from 2 weeks ago, MAF not problem...
- Picture of my car I just saw posted on vortex...Feel free to caption
- Always wondered about clutches and race teams...
- Need help determining pin numbers on 121 pin ECU plug (B6)
- Pimps: VW parts numbers?
- Hey, trc009... need your help
- Which source would you trust to buy an alternator?
- does anybody know of a good place to get these eye lids
- Woot! A8 front brakes on, man that's a tight fit with 16" Swings!
- where can I get one of these?
- still cant find out this weird problem
- Thinking about custom fabing a B5 A4 bumper to my B3 90Q
- OK, cam caps are labeled 2-5. Do these go from front to back
- Remove key from fob?
- Test drove a new V6 Honda Accord..........automatic.......and
- thinking about going with a larger bumper cover to clear my FMIC better. sticking with OEM look, I'm
- Keep or Sell - '02 Passat Wagon vs. '01.5 A4
- what wheels are these?
- How difficult would it be to fit cruise control on my B5?
- So I did it. I bought the Borla exhaust system from PureMS
- Damn.....debaging was harder than I thought.........
- Need a source for switched power thats on during cranking.
- (braces for impact) vw passat p/ns for awm pcv: are they the same? . . .
- A4 1.8TQM gas mileage
- need new brakes: dealer or other (cheaper) option
- Turn Signal covers melting..? whats up with that
- Question - is it necessary to pull the front end to change out the Cam Adjuster Unit?
- Has anyone had a bouncing boost issue?
- Aero-Wiper Deal still going on?
- Having Weird Ignition Problems
- Which Brake sensor on 2001 Audi A4...Square vs. Round
- Exhaust break, How much should this cost me? TIA
- parts needed!
- Guess the problem - car dies at 110-120mph, front straight, Cal Speedway
- so, i finally settled on my car with the insurance company...
- Before some noob asks... *I expect one will* Deep Fryer oil is NOT an acceptable oil for the 1.8T
- Timing belt repleace in CT (connecticut)
- 17953 - Throttle Valve Controller: Malfunction
- Ok..........Who was it!!!!!
- You'd think casablanca white A4's were painted in gold.
- Well the cars back on the road...
- Anyone ever have this happen to a motor mount...
- Need help making a parts list / Part Number request
- encounter with a ricer... hehe :-D
- hood pins
- VVT tensioner.
- LOL. Autohausaz are some nice folks. Free shipping for orders $50 or more...
- Nate, what is this?
- Also need an exhaust. any suggestions/best fits...
- Need tranny mounts......Got some? '96 12v b5
- Pioneer AVIC-D3 Navi install write up now in tech section
- Alright, I've made up my mind. I'm going for the Borla exhaust. Getting it for ~$650 shipped.
- Brake pedal goes to the floor.
- Goodbye to the A4, hello to the R32
- yesterday i posted a small pic showing oil leak residue on the lower end of the dipstick. here is
- PSA - Camshaft Adjuster Unit (replacement) comes with the special tool 3366
- 1996 2.8 - tune up...what's involved
- hose from intake mani to bpv (awm) is it the same as the other vac lines, or its own p/n? i stfa
- woot! rs4 bumper and s4 sides on
- Name the leak....
- After a long time...
- Does VAG-COM throw any codes if the computer senses that the coolant pressure is low?
- Going to punch out a few .357" holes in my old Airbag Module when I get it out.
- Working DIY for Hazard Relay?
- can i plug my 1/0 gauge amplifier power cable under my dash like into a 12 relay?
- my fuse to my fog lights pop after i turn them on. I cant find ground wire under dash
- is it unnecessary to have a boost controller in audi?
- Potenza RE950's - 225/45-17's for ~$460 shipped. Hit or Skip?
- abs module won't communicate with vag com
- how much are my 18" RS4 reps worth?
- Poll: Should I pull the trigger and get the Borla exhaust system from PureMS?
- Anyone have a rear ABS sensor for my 99 avant? ABS control unit is throwing a code...
- so just wanted to say i fell in love with my 1.8t again after i put summer wheels back on...........
- Conflicting Error fault codes
- B5 S4 owner wanting to know if there are any tips or tricks to changing the rear 02 sensor on the
- March 31st and April 1st,,,, Audi Driver Event -Spring Mtn Raceway, Pahrump, Nevada
- door chime problem on 2001 a4.
- I am going back outside to put a fresh coat of wax on my car 1st time this year!
- have you guys heard about DTX clutches on ebay?
- ABS Control Module
- Quick question, how much vac line is needed for a 2.8 v6, thanks
- where is ground wire to fog lights? what doesit look like? pic?
- Paging Carson / GTIVR62801
- Ahhhh.....Plugs / Fuel Filter / Air Filter / Cabin Air Filter all done....Car is happy...
- Air bag, Centr Locks and anti-theft codes
- power steer... any juice will do?
- Axle Assembly - Opinions Wanted
- 2001 Quattro A4T 1.8
- BROCK IN BRACK
- PSA for those doing exhaust work...
- What is the OD and ID of the rear wheel bearing for a 96 quattro?
- When I start my car, I can hear the fuel pump and the fuel getting circulated back into the lines.
- Fogs Q...
- New to upgrading. Need help. A4 b5 platform, with the 12v 2.8
- strange airconditioner problem
- *sigh* More parts I have to order...
- Replacing Rear Brakes but...
- Could someone explain to me how the fan electronics work, and the wires under the frame rail
- Loose radiator fan
- Wow, I can't believe what difference new driveline mounts make
- guys with RS4 rep's, just looking for you take on the quality
- anyone here familiar with Chronopost
- Noise from behind serpentine belt
- two different braided hose OD: shouldnt they be the same?
- Sirius Sportster hardwire help
- ok i busted the flexpipe
- New Toys (wheels)
- confusion with DV
- Paging Brian@Avalon.
- aircon problem
- 2.8 30v Exhaust
- GTRS Eliminator fuel economy = not too shabby!
- Where do you get an alternator?
- 96 2.8 qm Diff oil changed
- Oil Change Walkthrough? With Pic hopefully???
- Popping on new stoptechs (x-post)
- k04 install question
- I recently bought a rebuilt K04
- most likely culprit? (oil leak)
- Flatbed.....
- audio clip of exhaust wannted (1.8t no cat 3' pipe)
- OT and probably repost... but fun...
- hit or skip? bbs ch with 235/40/18 from a b7 s4 for my b5 a4.
- audio question
- THE DEED IS DONE..... I am now very poor..... but will soon have the APR S3 I've always wanted!!
- Anyone have an extra stock nDBW ECU they could donate to my APR stage 3 fund?
- What the HELL is up with these Volvo C30 commercials!? Weird crap.
- Tire Trailer, part 2
- Is it difficult to add an OEM CD changer to a '01 A4 that originally doesn't have one?
- looking at used tires, I know not the BEST way to shop for tires. Most say 5/32 tread left,
- Source for rebuilt ABS module?
- Position & Phase questions for those with Infinity Basslink subs.
- Are these the correct pliers for a short shifter install?
- Has anyone here used Intrax coilovers?
- Listen
- Cheapest place for a full set of 4 coilpacks?
- I have a stock silver a4 i need to touch up front bumber, what paint code do i need?>>>
- Fvck yeah! Engine and transmission mounts DONE!
- Anyone have a '01 2.8q suspension lying around that they want to part with?
- What audi performance sites take paypal? I have $400 in my account...
- Help ! Mystery cut wire ?
- Has anyone every fitted a 235/40/18 8.5 et 32 on a B5 A4?
- im looking for a lowering kit any advice?
- Real quick. BOVs goes where DV is. T or F? Im not getting one im just curious. Thx
- BAHAHAHAH WW audizine is hilarious
- 96 a4 trunk....
- Popped my VagCom cherry tomato....Here's the result
- Homemade K03/K04 manifold to GT turbo adaptor *free* to a good home
- Why was that post deleted Kris?
- I need a set of tires : (
- Challenges with replacing 5spd Manual Tranny with 6spd Tranny?
- Hmmm. Something isn't right here.
- Big Problem Need Help
- Brake experts: How do I bleed air out from the slave cylinder?
- tire wear
- (no spoilers!) Touring/GT SPEED World Challenge series on today at 1:30, 2:30
- *Feeler post* not for sale, really........... PC-16 ECU..........
- poll: What kind of bike rack do you have?
- Power window pinout
- Brand new O2 sensor for under $40? Not a Bosch one but still ...
- Cam position sensor DTC question
- Some potentially helpful advice,
- If someone was building a stage 3 set-up with a true GTRS 5 bolt flange... what size TP/HFC would
- Will a 2001 A4 1.8q sports suspension fit on a 2001 2.8q?
- Wanting to get wheels for my A4. What to get 17" or 18"?
- Switch to Metric
- Anybody with a GTRS bolt-on kit? stock software? errm, APR software?
- Keyless entry question
- Update to my Giac X question (from a few days ago)
- Hey ModifiedA4...possible updates to CAPS???
- Think this'll clear an S4 bumper?
- How'd I do? ;-)
- Introducing StartupRacing Gran Turismo Suspension Kit
- Tire Trailer Build, part 1
- Too wet outside to work on the A4, so.....
- spare k03 anyone?
- Stoptech & H&R coilover installation
- tgtbt?
- FB: Block painted in apropriate color (black) forgot my DSLR so no piccies.
- Anyone with B5 A4/S4, measurements please!
- How much do A4 B5 Celebration wheels go for?
- this isnt a for sale post. i just need to know how much this stuff is worth
- who besides ecs sells stud conversion kits
- Stock Shift knob?
- Paging: SpeedyDTP
- So i was changing my spark plugs today and noticed a little bit of oil in there ...
- Sell?
- Whats a good price for 96 12v V6 ECU?
- I put on my Flik FTDs the other day and got the car washed today. I'm pleased with the look
- preliminary suspension diagnosis?
- Good deal/combo for front brakes?
- What the cheepest I can replace my breaks for? front and rear, all parts
- Collapsed upper rear wishbone....
- New navi from B7 into B5
- what is this in engine?
- just found this sweet a$$ lip for the trunk...
- ok still getting the lean code on my car after doing a clutch swap
- Yay for simple maintenance.. oil change done
- scraped under front bumber from a f'ing bump, how much does it cost to repaint?>>>>>
- Issue with my H&R coilovers...
- How much can I fit in my A4?
- Happy! (the saga is complete)
- Hit or Skip on Intrax C/O's for $600
- Anyone have a spare front grill lying around?
- Joey T to the Caucasian colored phone.
- Strange electrical anomaly after cruise control replacement....
- Looks like Castrol now claims the LT-71141 spec for their plain $3 Multi-Vehicle ATF.
- Time to get to the bottom of this. Part # request.
- Need help choosing wheels
- Just got my audi. will post pics later today, just have a few ?'s need help
- Update: Suspension noise from front right side
- borla fitment issues / rubbing
- Anyone selling a 2.8 engine?
- Has anyone ever modded these buttons? And any ideas for a new speaker cover? Pics:
- how much $ do you think i can get for my car(real world)
- I passed a SnapOn truck today that was at a body shop. all I can say is
- Couple of questions...Early 1999 AEB
- One day its quiet...
- Will 2000 A4 1 piece hid lights work in a 99 A4 non hid?
- Timing Belt Quote: Is It Worth It?
- getting a CLUNK/THUD sound when i go over bumps, coming from the rear, think it's the rear glass...
- Starter Wiring
- Would a "brake light switch" DTC throw my tiptronic off?!? (slipping)
- VW GIAC X work in an Audi? (i think i know this answer already)
- Question about an intermittent overboost problem, please help! DIT
