- Whoot, car feels great after some wknd maint...
- Cylinder 1 Misfire + Random Misfire
- 99.5 Avant radio install
- Does anyone know if they make a 8mm 1.00 pitch fitting with a barb for a vacuum line?
- Ok kids, it's been a while. I'm having a brain fart. What kind of HP does a walbro 255 support??
- Paging Mike at PUREMS -
- OT: Pricing for my father's BMW 325XI....
- Car will be eventually running soon...Downpipe almost done, oil and coolant lines done
- Few pictures (too sunny, not too great) of my A4.
- just added a new member to our family of Audis
- Happy Fathers Day to all you Dads out there
- So I'm at this bar last night with my friends and I get on the subject of 911 Turbos somehow
- Would bypassing the n75 with a mbc make me throw a CEL?
- Whew....gotta love me some motivation.....
- porsche caliper - are both sides interchangable?
- CEL/ Evap code, please help.
- Finito! 2nd TB complete....
- Will a gas treatment do any damage to car?
- Alloy Diverter Valve really worth $160?????
- Well, over 500mi. on her today, she ran strong and was perfectly behaved.
- Will I really notice a 5.5lbs increase at each corner? I just weighed my wheels
- how to remove drivers interior door handle?the door lock button is stuck to the handle
- Went to LACR today to see how the 1.8 trans felt vs the 2.8
- FB: Wiring my madness
- Help with Tip-tranny recoding
- Wow, slow day. So I come into work today and find this sitting on one of our shelfs...
- Input wanted....sorry for reposting
- damnit...1 line of dead pixels in my instrument cluster today. yet, when I started it up again,
- B5 Buying help
- Keyless program
- Annnnd WHY wont my pictures post....
- HRE Tire problem
- Getting the nut off the control arms... How do you keep the bolt from spinning?
- had a CEL come one went into autozone to get it cleared and see whats up
- Where did you buy your MAF?
- PROBLEM: Driving home from Chicago last night my check engine light went on and...
- Auto Trans Problem. Clutch E? How common is this?
- help unable to remove nut
- Jumpin Jackrabbits!! What is it??
- day 8, and the a4 is STILL in the shop...
- FB: woven or welded
- Dayum, it even gots a BOV. Yo Yo.
- Just auto-scanned and there is "Excessive Comm Errors problem" in address 08
- Am I missing anything here?
- anyone seen this video before... R10 build
- Ahhh ok how did I mess this one up? Slave cylinder exploded..parts help appreciated
- Hey Carson....
- I gotta tell ya Carson from Riverside Audi is da man !!!! Great prices and service !!! That's all
- im looking to redo a lot of the hoses in my car. im just curious where could i go to order some>
- how do you take the hooods grill out?
- im baaaaaack in the US.
- Hella Micro De's Halogen
- sound like a coil pack?.................
- Adjusting Bilstein Perch
- Replacement fuel pump question
- Where does this plug in to?
- Car being worked on.. inputs needed.
- Audi B5A4 1.8T Transmission Multifunction Switch Replacement Writeup
- *Shakes head* why why do I do these things... sometimes I don't think... OH, and combo post WMMT??
- Brake upgrade in the works a8 rotors with porsche calipers... need a little help
- want to buy 01' 1.8t , questions, need any advice ASAP on a Tip. w/51k for...
- Tiptronic question
- [L.A. GTG] Tuesday, June 19th @ The Stand in Encino (SFV) - Who's coming???
- Wanted: Bentley service inst. for alternator replacement...will pay! (99.5 A4 2.8 30V)
- Please Help! Alternator Swap On 99.5 B5 2.8
- Pricing Question: Input wanted
- Forza Motorsport 2 game giveaway, A.W.E. Tuning!
- Finally blew it...
- <flame suit on>Any reasonable way to mount C5 Corvette calipers on a B5?</flame suit on>
- Rust Underneath Car, How to Prevent/Stop Progression?
- 6500 repair bill just say no to dealers.
- Putting in new caliper - have a ndbw how do I turn off the brake sensor on VAG
- Should air pumps ever go bad? P0411 theory/practice? (searched)
- wow, borlas are expensive now
- Anyone know where to find instructions on the DIY tip shift knob mod...
- any clean avant pics?? TIA
- I need a pic of what the fire wall plenum should look like.
- So tempted to buy my friend's bike...i really need my car to be running
- Ideas on code P0455 which is sometimes fuel cap not tight or bad, I got a new one last yr.
- wing anyone?
- If the control arms on the car start going, what are the implications of it? (in non techy language)
- FB: Remove Replace Rewire Reconnect
- about to go for 3rd timing belt change , what is longest interval with new tensioner?...
- Update on starting problem
- Multifunction switch pwnge! Pictures, story, and tech write up to follow!
- searched but couldn't find anything.. turn signal connector?
- Carbon Fiber engine cover....w/ professionally painted rings (350Z Sunset Orange)
- Warning: Painted Calipers inside. And I finally made up some center caps which I think look pretty
- water pump gasket Q
- Paging Audi Junkie...Need Confirmation.
- I redid the brake pad sensor mod (trick) and still getting pad warning.. thoughts?
- What car would you buy?
- Car getting "floaty"
- Ctapp tune people - did he send you a chip or did you have to send your ecu in?
- Koni/Bilstein Shocks
- OT: VW Beetle maintence site? links needed from my B5 experts
- Hey Guys, need a little help with HVAC Blower/ Resistor
- Need to gain access to calipers, putting car on jack stands, best to do a side at time or front/rear
- 99.5 A4 2.8 AC Compressor Removal
- Need help with part #s
- question about the bumper brackets...could they be the reason why my bumper wont stay on?
- Camshaft tensioner oil seal
- If you disconnect a drive-shaft on a quattro car, can you pull it with a car dolly.
- something ain't right:
- Intermittent "air leak" and "lean on bank 2" codes after long highway drives.
- Interesting Problem - Advice needed, please
- CD Changer Q: for those with the 8-pin (pre-1999)
- looks like it is my n75... im sitin here pulling codes and that came up. which one should i go with?
- Car + Deer = sad audi owner
- Weird Climate Control Problem (1999.5 1.8Tqm)
- Well it's likely my B5 will be gone this weekend. Selling my only true love FTL!
- The Advice Hour
- well, it happened. engine go boom. what a crappy day
- Doug YGM YFF!
- Boost Leak Possibly?
- Decided to do my own downpipe and rest of the exhaust...
- Eliminator GT2871R Chip: Mika Tuned or Unitronics ?
- blog #6: Car back from fabrication
- looks like the n75 is bad... only boosting 5psi... which n75 to go with...
- Anybody have the CCT 3366 tool and is willing to loan it?
- water pump change 2001 A4 1.8T AWM engine
- airbag control module
- Hey Doug/Dung... have I got a deal for you!!!
- do coilovers settle over time?...
- Update on where my car stands:
- WooT!!!!! I am pleased to announce that I am the proud new owner of a gently used G2 SC!!!!
- PureMS new snub mount
- 99 1.8T quattro A4
- Anybody here?
- does ngk make a platinum equivalent to the bkr7e?
- Forge 007 dv...what color spring should I use?
- Joey T!
- What would a used manual 1.8t borla exhaust system sell for?
- My 1.8tq auto is programmed as a 1.8t manual HELP
- What size torx for removing MAF sensor?
- AWE Tuning BBQ/GTG is just a week away...Come out and join us
- Got my transmission MFS today as well as a couple of other goodies including another nice gift!
- Weird Noise when steering
- VAG-COM on windows mobile smartphone??
- Woke up to a nice flat front tire today in one of my extremely worn Kumho 712s
- APR R1 DV " mooing" sound
- There are chunks of plastic in my oil pan... Is that tensioner?
- Just did Control Arms but not TRE;s
- where can I order a Samco reducer hose online?
- GIAC V23 encryption board...anyone have a chip that would work on it.?-> more
- Carson@RiversideAudi: Got the package. Thanks for great service.
- 96 audi and ecodes....is there are a plug and play harness?
- *yawn* morning fellas.
- TRE bolt wont sit flush with knuckle
- Hey 4Rings........YGM
- Replaced lower oil pan gasket, now better evidence of oil leak (2.8 30v)
- Is 245/45/17 doable on 8" wide wheels for 25.5"F 25"R heights on my '01?
- Seating: compatable YES or NO - drivers manual from my 99.5 to - replace drivers electric 98..
- I've acquired two S4 cat-backs for free. One is OEM, the other is a 3" SS APR system
- Soft shudders when being pushed... Gear independent... Ick?
- Coolant?
- STFA - 2001 onyx center dash trim (around the hazard/foglight switches)part number?
- What should I replace while installing coils?
- Today was a good day. The OZ fairy found me with a deal I couldn't refuse.
- clutch pedal click after braking???
- Newly Chipped, GIAC... not what I expected?
- Transmission Problem???
- I start my tear down (another one) tomorrow afternoon... New clutch/custom exhaust/FMIC re-pipe...
- Wow.. STFA many times. 2001 1.8T fuel pump relay part number??
- DASH AUTO SHIFTER COVER WHERE TO BUY??
- PSA: Autohaus AZ has the L hose for 3$ a piece
- Would it reason that a n75 "K" would work the same as a "J" since the 20-40 ohm reading is the same?
- Finally fixed my positive deviation: culprit= L hose
- car stalling lately...weird
- Porsche caliper fitment
- CARSON!
- For Genuine Audi/VW parts,
- Anyone know where to get a replacement MAF?
- Driver side mirror replacement
- fun turbo sounds or more broken junk?
- KONI Sports in stock with FREE SHIPPING!
- Well, the Turbo Lady started singing to me yesterday.
- I'm pleased to announce that I am now able to offer dealer cost + 15% pricing to AW customers!
- V6 30v lower oil pan gasket, bought gasket today, it's ribbed... don't use sealant?
- Clutch pedal doesn't come back up
- What options do we have for a front mount oil cooler?
- Anyone need NGK BKR7Es. I had to buy 10 and only need 4.
- I love this car.......randomness.
- Need Help!
- Anyone figure out the keyless trunk release mod?...
- Audi A4 reliability - how does it truly compare?
- Need help with some codes guys...
- been on hiatus working for a couple weeks.. what have I missed? (besides "NEMISSSSIS!")
- 600 dollar turbo kit - some assemby required?
- Boost Factory SMIC - over 2 yrs on AW and Ive never seen anybody post about this.
- Tranny Work in Boston
- Is replacing the transmission multi function switch an easyish DIYer job?
- Pulled the airbag control module.....how do I check to see if it's getting power ?
- Paging all A/C Guru's
- Can the TB tensioner be reused?
- Anyone running an Inmotion Tip Chip? Or even an Inmotion tuned ECU for that matter...
- Paging Mr. Dungbeetle - Thank you for the package sir!
- Before, and after fuel line Carnage of the Viper. - WARNING - *Not for the faint of heart* - BWW
- A/C Problem
- Thoughts.... FTD...
- For some reason genuineaudiparts.com will not load in my Safari browser?
- Paging Bitjockey or anyone who's done a Power Steering cooler
- Rear (middle) seat belt stuck?
- Coil-over suggestions? (fixed redx, i think)
- She's always calling me
- Does the crank *pully* need to be aligned at TDC before I take it off?
- Stern A4 1.8T drivers side tranny mount....
- Plugs
- Should I trust OBDII connectors on ebay, what about software?
- Stuck putting the trans back in...shifter stabilizer bolt won't line up...Need some help
- To all persons that requested a parts quote from me over the weekend:
- What's a fair price to ask for a J31 GIAC chip? Just the chip, not the ECU.
- Anyone have a spare CH Ecu they would be willing to let go?
- Stock 98 1.8T QM: NGK BKR6Es still the plug of choice? if not, what then?
- Paging Kris: Gots two questions for you
- Mike @ PureMS. First off, thanks for the super fast delivery of my order. I'm still not used to
- can't find what noise this is
- 044 Bosch Motorsport fuel pump impressions.
- Nooooooooooo! Tried cleaning the MFS to no avail. Another $300 for this damn car...
- paging nate carson or qfrog! p/n needed!
- Anybody want a spare tire donut.
- NEMISSSSSSIS ... imawesome style :)
- Question
- Found my trasmission gear selection problem thanks to Carson (plus a little gift from DungBeetle)
- If the inner tie-rod ball joint is corroded, it'd cause groaning noises from the steering, right?
- P0411 on A4 208 AHA
- AC doesn't work, but clutch is engaged....Help
- Decisions decisions, $400 for Flik Justices(22lbs) or $1060 for OZ Ultraleggeras(16.7lbs)?
- Transmission fluid questions
- Doing lower oil pan gasket on 30v, alternative to OEM sealant? specific RTV?
- So I get my new tires mounted on the Flik's, the Vogtlands are all settled down...
- More Fuel System Problems- Getting real sick and tired of these
- I know you guys have seen this - but this is the first time you see what he ran over
- how many cells are in a techtonics cat converter for 1.8t a4???
- Guys, I really need help on this. For no apparent reason today, my car has lost reverse
- After 120,000 miles. My clutch is on the way out.
- A/C Problems. I need some help
- Paging... Audi Junkie to the oil soaked phone...
- Still overboosting.... WTF?
- blow off valves and intercoolers
- A little OT, but I wanted to show you this video.
- I know its a nono, but could someone do a carfax for me before this thread is deleted
- Ballast location?
- I just semi-fixed my tiptronic need a little help.
- Thanks to STaSIS for allowing me a few quick pics in the garage at Watkins Glen.
- Even though they are having trouble , I joined ACNA today.
- Clunking when going over a curb/speed bump. Control arm?
- bbs lm center cap question
- Vacuum line clamps.
- control arm pinch bolt battle gone bad...need help!!!
