- coolant reservoir is cracked!
- another N75 question
- swap interiors
- What's the best place to get a black mesh grill with no rings?
- Did a search..still dont know what oil to use
- Did anyone read in the 12v forum about the one AWer recently stealing from another AWer?
- No outside temp or gear indicator
- Would these wheels fit on the B5?
- Window regulator - I need a busted one
- Snow tire sizing. . .
- May the coolant temp sensor burn in he11 forever.
- Hey from a new A4 quattro owner
- Oil question
- You guys getting up to full operating temp in the winter??
- vote time for seats
- Clutch question
- So my engine is running nasty... i cant figure it out.
- trouble code 2.8 1998
- Secondary Air Pump Running Till Battery Dies
- should I buy my old B5 back from the guy I sold it to a year and a half ago?
- Check Oil Light
- Why am I only getting 200 miles/tank with my 2.8???
- Does anyone know what color this code is N5F / BG?
- Stuck Thermostat?
- need to top of my PS reservoir. but not sure if my shop has the right pentosin fluid
- Tie-rod replacement???
- Silly crappy German plastic... the A4 is now officially sunroof-less.
- Winter tires - How can I tell if I can replace one tire with a new one? Cut in sidewall :(
- RS2 caliper brackets..what are they used for in the B5?
- Techtonics Exhaust on 2.8?
- 1998 Driver's Side Tail Light
- What's the part called that connects the rod under the throttle to the rubber boot?
- Front Directional Issue
- Anyone have an ECU I could borrow for a few days(upsate NY)
- alternatives to www.vagcat.com if somebody has the etka software i need a transmisson# for reference
- Secondary Air and Exhaust
- Need Audi expert in O.C. SoCal & Help with 99.5 1.8TQ Tip K04 please
- How can these shop manual CD's be only $6? (ebay)
- my exhaust smells genuinely rotten
- Nate ,get this ...Akron/Cleveland weather tonight...possible rain/ice/sleet ...then ..
- Bad Gas Mileage here
- can the back cover of the 1-piece headlights be purchased separately from the housings?
- genesis injectors + unitronics + gtrs. 415cc or 430cc? AWM motor
- H/S paired at 500 bux
- Is That [Oil] Additive Really a Negative?
- Anything tricky about shift boot replacement?
- How can i get xenon lights?
- Does anybody know of any TDI tuning attempts in US? Any off the shelf kits available?
- Pagining A Few audiworld members (Dungbeetle/rallyvermont/kris hansen/phil (pac + qfrog)/
- Front speakers -- is there a "drop-in" component system out there?
- Replace your 'check valve'! CEL/hard starting cured
- Auto Dimming mirror replacement
- Maybe im searching for the wrong thing...but any chance of a center dash upgrade?
- car won't start after replacing central locking pump
- Does anyone have an AEB vac-line diagram? The one under my hood is gone :mad:
- 1.8T and quattro 5 speed in AW classifieds
- Hall sender problem A4
- A.W.E. Tuning's Holiday Sale Week Two Is In Full Swing
- Is my thermostat hiding under this part, or am I in the wrong place all together
- VWvortex is one crazy place.
- Anyone have an extra upper timing belt cover laying around?
- what happened to my transmission thread?
- Is my Bose Radio toast?
- I ordered a new thermostat due to my coolant temp not reading, and my oil temp being a low 175.. but
- Lollercoasters. "B7 Look body kit for B5!" This one isn't from LLTek...
- Unexplainable holes in the transmission?!?!
- Anyone try the Lud air intake?
- FB: Biggar Brakes... test fit.
- First trip to the body shop for any car I've owned...damn SUVs
- People in Davenport are not smart people
- ? about ecu's
- Anyone know if you can replace the little rubber boot on the hood latch handle?
- help quick please! car in for repair, need advice on transmission quote $$$
- Did I break something or fix something...
- anyone want to shine some light on this - it is 5lbs less then the oddessy
- Nice.
- Trade question 96 2.8qm for auto
- so here are the requested night shots . . .
- WWAWD
- Think it'll be totaled?
- My EPL Dyno Day Photos...
- Help finding part
- Opinion on used RS4 DTM replicas
- PSA: You can now view all your Blackstone reports online....
- any idea what this noise is?
- Would there be any interest out there for SPP (H7) bulbs?
- First time using VAG COM, need help analyzing result..
- removing a tip shifter
- Does anybody have a K03 or K03S for sale?
- Central Lock Pump - 99.5 B5
- Water Leak into Cabin BT: (long)
- 01 a4 ecu?
- Any clues where I can buy a Delta CC Radio
- sorry everyone haha i got halos :D
- Oil on spark plug boots?
- Just got an AVIC D2. Designing a custom background...
- Climate Control Problems
- Could the problem be the heater core?
- Anyone have a good pic of a pillar mounted boost gauge? If "good" is possible...
- Will 22mm-thick rotors fit the rear S4 caliper mod on a B5 A4 1.8TQ?
- Changing Headlight 99 A4
- Bearings and Brakes estimate
- How did your insurance company value your chip after total loss?
- A.W.E. Tuning Week Two of the Holiday Sale is rolling
- Back speakers
- Coolant temp sensor not working? Oil temp low? Part number check.
- any ideas what this noise could be?
- Considering rear S4 caliper upgrade. Will 22mm-thick rotors be bolt-on...?
- What do you suggest I do with this?
- I'm not sure I really like my city lights.
- i cant tighten up 1 bolt for ATP testpipe help please!!
- v6 and 1.8t wheel axles are not interchangeable correct?
- will wheel bearing 8do 598 625a work on a v6 quattro car?
- Where is the best place to source a new fender from (possibly already painted)?
- AC Clutch/pully
- Is there a Valve before the Heater core that directs Rad Fluid
- Mixing the new with the old... A4 parts in my 4000 :-P
- anyone know where to pick up a red christmas bow
- Paging Rallyvermont! I have a gift for you =) please click inside
- Boredom question: Can I take the steering wheel/airbag out of my 1997 12v A4 and drop it into
- just wanted to share... I had to laugh when I saw it.
- Heating system smells
- Cylinder Misfires
- Car just hit 70k miles. What else should I order for it?
- DIY brakes gone bad
- finally fixed the lights
- First time I have changed my screen name since it was created..
- "It's got cop tires, cop shocks, cop motor...."
- Best EBC bang for the buck?
- rally lights, finally some detailed shots
- Escort Passport 9500i or Valentine 1?
- Well lets have more fun on the snow topic: Post you Winter Wheel/Tire Setup:
- Oil Pressure Dummy light
- Porsche lovers: Buddy just got pictures from the Porsche G2G at Daytona developed
- So with such heated debate on "Snow" tires. Who here actually has lived in an area....
- Repairing e-code tabs.... They're not made of polyethylene or polypropylene, are they?
- XPOST - EPL Dyno Day Results:
- Question about stalling <long>:
- Stock Cat finally split (at least I think)
- Wow. Racist, much?
- Pretty good deal on this A4.
- Anyone need a thule B5 Sedan fit kit???
- Oil Q (and ya, i've been gone for a while)
- Brake upgrade gone slightly wrong....Brake Lines Don't Reach
- How can I temporarily break my power windows?
- Planning on doing a few things tonight...
- One for the experts. If ECU has exactly same Audi OEM # including letter, can it be good for...
- APR Stage 3 for 1998 ndbw AEB engine - Is the 280HP fig to the wheels or crank...?
- 215/60/16 snows rub at left rear. Can I drive it until it wears down?
- So I will be getting a SMIC, anyone use a fan?
- - Trying to set new wastegate actuator onto flapper arm ????? (28RS)--
- best place to get a new "shroud" that goes between the windshield and the hood?
- Vent Boost Install help please....
- German Touring Cars again on SPEED.
- Has someone ever tried to break the windows on our car
- Found a funny thing, someone put an A6 snub on my '00 A4
- How the fvck are people rolling these cars? I've read a few of these stories on AZ lately
- Do any of you see any problems running 195/65-15 snow tires instead of 205/60-15?
- Need help - buying a 98 A4 2.8 quatro
- Water looking stain
- curb weight comparison --> 1998 Avant 2.8 30V vs. 2000 2.8 Sedan - How close are they?
- I want to move to romania but not for their cars...........
- avic-d3
- Official WMMT: What are fellow AW'ers wrenching on this weekend?
- Rant: Crappy Ace wheels
- question about some used snow tires I just bought
- is the guy that put his car in the guardrail on mullholland dr. on here?
- off to NYC in a couple hours
- Unusually hard brake pedal...
- I just got S4 fogs for the front and I was messing around with the rears...Is
- Gone in 60 seconds = fail
- Audi Sport All Weather Floor Mats
- Which wire would i need to cut in order to eliminate my parking lights, but....
- Can someone tell me the name of a company that sells an oil pan shield?
- Misfiring cylinder & ticking engine noise
- A.W.E. Tuning Friday Happy Hour Special
- Can you identify this part?
- parts needed !! suspension
- Damn.....have to sell the Audi..
- Why would i not throw a code if i was misfiring?
- Anyone have the part # for the passenger side motor mount? Thanks
- Last Few Days Remaining In Week One Of The A.W.E. Tuning Holiday Sale
- Reminder: EPL Dyno Day TOMORROW! Hope to see you there!
- Audi Financial
- Signing Off Too
- Blew my block yesturday...looking for a AEB AT block for a 99 a4 1.8T quatto
- need help with 96 a4 2.8q 5 speed
- Should I feel bad??
- Signing Off
- Low brake pad warning light on, new rotors too?
- Anybody other than Milltek make an exhaust for the B5 A4Q V6 30V?
- Just got an interesting phone call from my R32 buddy
- Just for those who don't know, Joey T is a great guy. And Mica, the beast is lookin' good!
- You don't appreciate heat until not having it causes frost to form on the inside of your car.
- VAG-COM Fault Codes....need help understanding what is causing CEL:
- Does this log show a bad coolant sensor?
- ...about to pull the trigger on Vogtland Club Spec Springs....
- just pulled the trigger on bushing and linkage upgrades from JHM - someone make me feel better
- anyone have a rear silver (from a 2.8) bumper lyin around ??
- WATCH ME - this is what 10K of upgrade gets you these days
- Does anybody know where to get replacement bushings for the H-Sport sways?
- A4 96-01
- A4 purchase
- Anyone has a picture of SEIBON Carbon Fiber Front Lip on B5 A4?
- Got my first set of winter tires ordered from Tire Rack
- My 1st observation of WA vs. PA: Everyone here LOVES big chrome wheels.
- APR Holiday Sale Update! FSI Fuel Pump Performance Calibration Released!
- Hey Nate thanks for pointing me to the wintre tire package on tirerack, just ordered a set
- Post-snow car wash....was too lazy to do it myself, so I brought it to a handwash.
- VAG Codes pulled
- WOOT--just painted my garage in McLaren F1 team colors:-)
- Checking coolant temperature sensor
- SH1T!! Lunchtime CEL =( Any info/help would be GREATLY appreciated...
- How big does an air compressor need to be to run a decent impact wrech?
- A.W.E. Tuning Holiday Sale Week One will end...................
- ETKA gurues, need a part number
- what is an OEM non-sport suspension worth ?
- Sorry I have searched and about to give up cause can't find...
- Joey T: you have helped me before on this, hoping you have some insight now.
- Need Part: Center Armrest Lid
- Clutch replacement question: resurface fly-wheel?
- Black(?) B5 //S4, NH tag "BITURBO", 495N Sat. night - you here?
- Need part number again... subframe bolt
- Audi introduces it's R32
- Paging Carson....
- Alarm system problem. Help!
- Found some new problems...front suspension
- wheres this online Servay that APR is talking about? i cant find it to enter the raffle
- i need to use the stock jack in the e-kit because i am away from home
- While on the snow tire theme that seems to be here tonight...for the noobs
- On the topic of winter tires, how low do you let the tread get?
- hiccup/stutter getting worse!!! help!!! any ideas??
- part # request: nut, bolt, washers needed to connect rear sway bar link
- Nothing brings in December like cutting your own Christmas tree with TomRitt and NoNonsense :P
- help!!!!
- A crappy day gets worse, Chip or turbo problem?
- will rear struts (oem non-sport) from 99.5 work on 2001
- Still trying to figure out misfires
- What's your 15" winter tire of choice? I'm eyeing the Bridgestone Blizzak WS-60
- LOL at the "I have no traction in the snow with my crappy all seasons...
- Windsheild washer pump stoped working today, Grrrr!
- Fake brake pads made of kitty litter? According to Consumer Reports...
- Labree HFC Install (getting ready to anyway)
- What the hell...
- alright... how do you do it... secondary air injection pump removal
- sensor???
- Snow, tires, and ABS...
- Paging Wiinky
- 1996 A4 on slippery roads the back end wants to come around , Why??
- New Vendor Introduction:
