- Mobil 1 stopped making regular 15W-50 synthetic?
- x-post, who else carries Rear OEM Slotted Rotors (256x22) besides ECS & AWE?..........
- 2001 Audi A41.8T Quattro Blue for Sale 45K miles
- Greddy FATT question
- any suggestions for proper lemmiwinks settings for APR stage 3 + water injection?
- I shaved the inner door panel where the speaker resides
- small cooling problem
- To All Future/Current Audi Owners.
- Gone for now
- Valeo Headlight advice need some pictures.
- Which is more worth it: $5k on a 2.8 supercharger or trade for 1.8t or S4?
- anyone have a non-bose rear deck speaker amp that they would like to get rid of?
- is there a performance difference between the apr and purems snub mounts?
- there is no wet braking problem
- 2001 sports package wheels?
- Does anyone knows how to remove the erbuni bodykit????
- LOOK INSIDE..MANY OPINIONS WANTED..INTAKE
- Turbo upgrade
- I know my valve cover is leaking slightly, so would that explain the....
- It was a busy weekend for me...
- A '97 1.8T Ecu will work on a '99.5 right?
- anyone running a 3" exhaust
- Does anyon have a bad cat that is available...
- worn spot on steering wheel
- warranty coming to an end?
- Question about adjusting belts
- Ok guys, it's official, the car is being totaled...
- 02 sensors
- is WYSIWYG still around the forums..? Question about your grille
- finally a purchase has been made!! 01 a4 1st time audi owner
- Engine Rough at Idle, Vibrates when sitting at a light or in a parking garage
- Offset...
- Wheels
- How do I go about leveling my headlights? My night visibility is crap since I dropped.
- Center Caps...
- who has a stock 1.8t on this board an access to vagcom and would like to help out?
- Why does shopping for wheels suck so much
- Nobody here has adjusted the steering rack on the A4?
- Fog Lights...
- ive decided to do it....some info please.
- A4 starting problems
- First picture post and first sig!!!
- about how much is my stock 98.5 bose system worth?
- looking at getting a 96-00 a4 help me out!
- Tried the mega Puraltor L40316 Filter today
- does anybody kno wut kinda wheels these are?
- Cruise Control problem Linked to Clutch Sensor??
- The first evar meeting of the AW A4 Anti-Rice coalition was today.
- can anybody make me a sig?
- Anybody know if I can get a sign like this...
- 60 degrees today. Supposed to be in the high 50's to 60's all week...
- Happy Easter
- reminder to pls drive carefully...
- LCD screen for the climate control
- Are there any negative side effects to replacing my brake pads with sensorless ones?
- One last ICM Question (dielectric or thermal grease?)
- Differences between 99 and 98?
- is it ok to switch to summer wheels/tires yet?
- i got my new suspension on yesterdy now e brake light is flashing.any ideas.???
- For those of you who had the random cyl. misfire/No.2 cyl. misfire problem...
- Found this when I got out this morning.
- Stupid CEL...
- hey yall, wondering aboud the water temp guage....
- B6 Big Injector GiacFX independent dyno.
- Did some exploring today.......(long)
- Question: Tightening a loose steering rack...
- its nice to have a change of scenery for once in a while
- Check your motor mounts!
- transmission woes
- Does anyone have a 2 dual exhaust setup?... more
- ran the platinum for 500 miles and switched to coppers today... car runs nicer! thought i share
- pics of cars running different spacer setups?
- Hi, Rob Andrews, a question about your heat shield in the intake area..
- ok PES guys...what plugs should I be running??
- Just Finished the K04 Install
- Decarbonizing treatment
- Groaning sound from left front when I turn the wheel at low speeds...
- repost on SMALL pics...
- how can you tell if car is a SPORT
- A few new pics of the rims, this time with center caps installed
- cracked pcv hose/tube, 2001 2.8
- help for noobs
- Just sold my '05 S4 ....
- Bling'd out MTM A8 (sorry if its a repost)
- would these fit my 2001 a4 1.8tqms
- I got new wheels and the car is dropped. New bigger filter on the intake too. (BWW)
- Ok I have a decision to make about suspension? Help me decide please...
- Anyone have a used 1.8T catalytic converter they want to get rid of?
- looking for the cheapest place for springs and shocks...
- Where is that link to bash a dealer??
- Stripped Lug...Need Help!
- Question about wire colors for a delta stereo
- New quattro badge location
- not making boost
- How do you take off the automatic shifter cover? (searched)
- Quick quote: What's the cost to replace the front windshield?
- Just got tinted and debadged. Opinions wanted!
- sometimes the A4 makes no sense..re: remotes.
- 2-piece black E-code headlights?
- Really slow spool up problem...
- Hi, where can I get Ferodo pads?? Thanks.
- A8 wheels are finally back on...
- Is it a bad idea to chip my 1.8t at 97k?...
- intake, intake heat shield, and 20% tint.....
- xenon lights??
- Has anybody haver installed an S4 rotor and caliper on a A4 16" wheel?
- intake?
- front lower valence.. held in place by clips or screws?
- arrrg...diagnosing the squealing under boost...
- what EMCS programs did APR chip buyers purchase? worth it?
- anyone using TEINs coilover kit.. .....?
- Turbo surging problem
- stock shocks ..blisteins??
- Replacing Lower Door Molding For Dummies
- So my choices to raise my slammed front are grooving the shocks, or ECS coilover sleeves
- how to remove hood?
- Torque Sticks is having a %25 off sale on there torque sticks
- rear wheel bearing tech article mistake??
- anyone do silver rs4 mesh grill? hows it look?
- hey Cursh did you check out that cow running mad in cinci?
- Question about adjustable bypass valve
- Practical differences between control arm/tie rod kits? ECS vs PureMS?
- fk reputation and angeleye light quality? pic request
- Does anyone know the part number to the plastic tray that fits under the engine?
- clutch......what do i do now??....
- Bose replacement speakers
- which springs should i use ???
- Stock shift knob...
- ok deleting last thread anyone used this dash kit for their radio before?
- new jetta and a corolla.... what a coincidence
- Finally, the glue on my custom speaker brackets
- Poll: What Brake Pads are you currently using? How do you like them?
- those of you in urban areas, watch out
- POLL: does anyone like the indicator mirrors? found on mercedes C-class...
- kind of a poll...
- accident :(
- Seats.... I doubt I'll ever be totally content with any seat.... at least at this rate
- My car is too low!!!
- Searching the forums really does help...
- Transmission Problems?
- would a bad MAF cause random cylinder misfires?
- will a Ported Throttle Body benefit the 1.8T? i searched, no answers.
- Speaker install question
- Can someone give me the part# for a CV Boot kit for a 98.5 30vqm?
- Is it possible to Run H&R sports with Audi Sport shocks?
- D/S rear brake is heating up more than P/S...
- drop 2"/ springs???
- Guess what showed up at the door today...
- question for 4Žings
- anyone have their stock non-sport suspension sitting around?? my rear driver side spring is BROKEN!
- DRL and LLtek HID kit (canadian)
- 2 x Hankook Ventus HRII 245/40/18 for sale $200 CDN. Almost new.
- HORSEPOWER
- Changing brake pads and rotors
- So the new job is interesting...
- Stupid bolt!
- So my car needs $1300 in repairs..
- BMW SELL out - Help me Pick the Best A4!!
- Where can I get the Rob knob?
- Didnt this used to be the A4/B5 Forum? Now its more like "PIMP MY A4" WTF???
- update on GReddy FATT with speedometer function
- Winter mode is officially over. Here's a list with some pics of what I accomplished this winter...
- Whats with everyone posting pics for reads!? Has AW gone ADD???
- I'm having the biggest problem ever.
- New project! Lots of pics......
- 068 115 561 was the part # on them bigger oil filters right?
- 20's on a 98 A4quattro?
- How much are NEW Ign.Control Amplifiers worth? Seems pricing is all over...
- finally pulling the trigger on a full body kit next week. :)
- Car making a winding sound, most noticable when turning and gasing, what's wrong with it?........
- X-post: Refinished Sportecs
- the end of an era....
- Noob ass question about changing wheels...
- 98.5 A4 Avant 2.8L 30V AHA Tiptronic Broken timimg belt
- Congrats Chip!
- Coolant Leak
- autohaus az's response to the DV
- Kill Story -involves a prick in a mini Cooper S (BWW) read before judging.
- Will 245/45/17 fit without rubbing?
- I was thinking about putting LED bulbs in my Taillight/Brake light spot,
- Argh...........I hit 90,xxx miles this morning! Kinda scary. I put on 30,xxx in the last year.
- Leaving to germany in a couple of hours! My cuzzin has a bad ass 280sx up there and his buddies gots
- I have a sharp decrese in gas mileage, Any Idea what would cause that?
- Looking for a shop Near Philly
- Don't buy these Rims in Vancouver BC
- Grey alacantra/suede steering wheel?
- Soloracer.com..really fast shipping
- Do any of you A4 guys run mercedes wheels?
- has anyone put just the H&R Race ...(more)....
- Eibach Pro Kit for S4/A4 anybody interested before i put the springs on ebay ?
- Anyone know the AoA regional rep contact info for S.Eastern PA? TIA.
- Wheel weights spreadsheet says they're 17ish; dealer page says they're 22ish.. (bww)
- Anyone ever get stuttering when slowing to a stop?? help
- Paging Alex (Digi)...
- Serp. Belt Tensioner Replacement - Is it as easy as it looks?
- front sport seats are in
- Looking for used BBS Ch's 18"
- VAG-COM
- Diverter Valve...
- Car Keeps Dying (still)
- Shift display flickers from 5th-4th and back on highway.
- Control arm broke
- shop is asking 150CAN/wheel to fix my scratches bent and paint them black with an poliched lip, so
- At dealer today and really got a good look at new 2006 A4
- Correct setup for Forge BPV install....
- not a b5 a4 question but if you know the answer, i'll give the first person $5 nonetheless...
- Check out my new Sig, I am was really bored. now im going to bed. tell me if you guys like it
- Injector Question
- Squeaking
- who has laid carbon fiber?
- What do you guys think of this?
- My car is SCREAMING!!!!
- The new PS3 would look good in my car somewhere...
- I had the best looking car at the wedding
- Already posted in classifieds and people backed out on the deal so here's another try...
- 98 1.8T strange burning smell....
- Need the straight scoop on fueling a GT28RS w/ DBW... (m)...
- chrome tip on 2001 a4 exhaust
- Where is the cheapest place to get a OBDII cable?
- OK, looking at A8 brake upgrade....where can I get A8 rotors that are x-drilled?
- what all should i put in the bill of sale?
- I have a sharp decrease in gas mileage, any opinions as to why?
- Squeak and control arm RECALL
- autohausaz dropped my cart 2 days ago... well was trying to get a 710N and now its 35$ instead of 20
- f*#k you flu!
- Sport Cloth seats should go in tonight
- Throttle position sensor.
- got DTC's: 18010 + 18089 + 16806
- Diffrent tire sizes for front and rear???!!!
- New to me A4 and some questions
- Oil question
- zenetti rims
- I've always wanted this look of muffler on my car. Should i get it?
- Boston G2G saturday 2pm Xpost
- has anybody seen this yet? thoughts? neuspeed turbo inlet hose.
- 98.5 Quattro won't go into gear after heavy rain and puddle.
- Tint tomorrow- anyone have pics of 50% front, 35% the rest?
- WTK: cheapest place to purchase a front and rear O2 sensor
- suggestion....
- what should i offer for used TT carrier hangers?
- Newly Chipped Q - when you press on the gas hard then let off and feel a 'pop' is that the BPV?
- Blinking CEL, 16684, 16686, swapped coils, still cylinder 2 misfire, could it be anything other....
- CEL keeps coming on , Please help!
- I'm getting an RS4 bumper put on my 99 A4, where can I get a conversion fog light kit......
- car violently shakes, shudders when I step on the gas in 5th gear
- Can a dealer diag a plugged cat? Like measuring exhaust pressure before and after via O2 sensor
- my car is getting lowered tommrow....some ????s
- Might be selling my 99.5 CD changer. How much do they usually go for?
- How much do think this ECU will go for?
- New to AudiWorld
