- my foglight grill peice is gone now i need a new one. will an a4 02 fit?
- Seats
- Seats
- Clicking problem in 2000 1.8T
- Just got back from doing some scientific testing....
- is there a specific type of power steering fluid i should use??
- DIY heatshield is on
- T04E/K26 at 28psi video
- fun with seasons...
- Where to put boost gauge
- when you see the price for rotors.. are they for each or in pairs?
- Can't get rid of sunroof wind vibration noise - any help?
- RKA - You say the Porter Cable is "idiot proof" compared to a standard rotory polisher..
- the damn fuel sender is acting up again....
- Need ignition control module, any diff b/t Huco and Bosch?
- Well the first day of track time for my car is done.
- Best Place to buy
- How do you think these would look...
- Chip and redline Q?
- Sorry for asking this, but what is a VAG and what exactly does it do...
- Musty humid smell from A/C...
- Does anyone happen to know a source for a used center armrest?
- Will Stock 01 or 01.5 A4 Taillights fit on a 98.5 A4?
- Oh my GOD! Can it get any worse? :(
- is this worth it will it give me added hp?
- Nokian Tyres?
- Ok, I'll ask here- Middleton/Danvers MA., Black A4, Hood, black lights, lowered, rims, exhaust,etc
- Any AW's from Minnesota...?
- need to see pictures of flick tdr's in silver
- rear window mod
- Hmm...RS4 Replica Kit
- New VW/Audi model codes, from ClubB5...
- How do you bleed the coolant system on 2.8 12v
- ECU question... going from auto trans to manual
- Yet another boost question (EDIT)
- Most effective way to get your quarter mile time down?
- Is a 1 bar chip and N75J too much?
- Anyone got a spare set of stock rims and tires they want to 'rent'?
- this may be a dumb question but
- Air Conditioner Not working
- Anyone know if A4 wheels will fit a 1990 Audi 200 ?
- Does anyone have experience with Egauges.com
- is it possible to disconnect the driveshaft to make a quattro fwd?
- my right side headlight washer is clogged
- paging tech's...need help...possible leak?
- ko4 turbo in my 1.8t tiptronic
- O2 sensor cleaning
- P shop Request please. TYIA
- for you B5ers with Fuel Filter issues.
- How long does it take to change a Diverter Valve??
- My dad is looking for new Yokohama tires for his 911.
- golfing at red tail (devens, MA)
- When using a MBC w/o the n75...do I need to plug the bleed hole on the MBC?
- City light bulb question
- Now that we are on brake questions.................
- Question about PhatNoise intall in 98.5
- What is the difference between a brake disc and a Rotor?? Anything??
- 04 A4 1.8T CVT bhp mod possible?
- HVAC problem: MY2000 HVAC Wiring diagram urgently req.
- whats a stock "CH" ECU for a 2001 1.8T worth?
- should i run ate rotors or zimmerman? or brembo for replacment rotors?
- Need to replace front and rear pads...How much at dealership?? parts and labor??
- What type of grease/lube should I use on my sunroof tracks?
- Can anyone recommend some thick oil spray that I can use on my suspension bushings?
- boost gauge wiring, what terminal??
- side markers question
- Where can i get the little screws that hold the underpan on cheap? Dealer wants $8 each.
- o2 sensor question
- free 15hp woot!!!
- Smokin hot brakes
- A4 Long Term Ownership Prospects
- fuel injectors - duty cycle signal?
- really strange photo request:
- Well 96k and the original clutch is finally on it's way out...
- nothing like cleaning the MAF to make the idle a lil happier.
- Do these times sound right...?
- anyone replace a fog light switch?..mines gone 'round the bend
- Can someone get the part number for these parts for me??
- some TT questions
- Looking for a switch to replace one of the blanks in my '97 A4
- GIAC + N75J unasked question!!! (long)
- Code for concert serie
- I just added a fast 6.51sec Neuspeed Superk04 to the CAPS list. Seems like J31 has competition : P
- EDness. YGM
- For those that have done control arms, or suspension...
- EVO air intake
- APR exhaust and diverter valve.
- Send money order to canada for APR ECU? I can buy it for $300ish, what do you guys think?
- Radio Code (SAFE)
- Got this off Carpoint.com, just wondering if it is accurate...
- What do you guys think of ASA AR1 rims
- Well, Brrman's car is no more... pics of the destruction
- NEED to swap my test pipe for cat and tinted tails for oem tails ASAP
- what section in lowes has the plastic plugs to cover bumper holes?
- Great News Friends!!!!!!
- WTB Giac Chip
- How much stuff can I power off my 75X?
- I STFA, How much space do you get behind a s4 bumper to mount an IC?
- Looking to get a front mount intercooler. Opinions anyone?
- Guy ripping off Audi owners
- Heated mirrors another questions not answered in the tech...
- Anyone have PES's phone number? the website is down.
- ABS module, again....
- hey everyone here are pics of my almost finished car
- Dallas people: University Park or Boardwalk for out-of-warranty work.
- tow hitch instal finished, installed tie downs in the trunk too
- anyone selling a used v&s short shifter?
- If I remove the bottom shock bolt in order to remove my Sway bar link, I won't need a realignment
- How much should I expect to dish out in labor for..
- Random Power Steering Failure
- audi 96-99.5 trunk cover
- Anyone have a pic of BBS RZ's on their car?
- should i run oem spark plugs or something different? and when are you supopsed to change them?
- pics from Audi Club Sweden Summermeet
- What can I use to mount boost gauge into center vent?
- is it possible to make a set of silver painted rims into ones that have a polished lip?
- Help me find out what letter box i have
- when are you supposed to change your injectors?
- How do i take check the ABS light off with a VAG tool?? Any special procedure??
- Chip, ECU, and flash question?
- 30 valvers, where's your PCV valve located?
- Headlights don't work
- Does anyone know the difference between the B 000 600 A1 and B 000 700 A1 brake fluids?
- Sway Bar Link Removal HELP!!
- power steering out
- Why dosn't Audi make non-interferance engine's?
- Stage II Air Box Modifications for the A4 1.8T
- oil and oil filter question.....
- Better to part out or sale complete? 2000 A4 1.8T
- Does the A4 come with a battery cut-off?
- looking into putting in an Electic Fan to replace the Belt Driven Fan...
- Tail lights. anyone have wiring diagram? need to know what wire does what
- Front mount intercooler 02 B6
- What special tools do i need to change my 2000 Audi A4 spark plugs??
- 1.8T Spark plug recomendtions
- was at Audi Club Sweden Summermeet today
- Get my baby back today (a4). been in the shop for over a month!
- I am thinking of removing my OEM spoiler, any ideas on what a body shop would charge to fill the...
- look what I found....who was looking for these awhile ago...*door sills*
- Is the Tip Chip usually socketed in?
- where to buy N75J valve? are they available from a VW or Audi dealership?
- 12 second A4
- When the police in my town have nothing else better to do!!!
- Diverter Valve
- Intersting........................
- OEM spark plugs for AEB engine
- How many other B5 A4 1.8T owners have a clutch that slips easily
- Tie-Rods replaced at 50,000 miles
- STFA. Anyone have pics of the high plsh Flik Justice on the B5's?
- GOOD AFTERNOON BOYS!
- Pics of my new Audi...
- Cross Post....Pictorial of my Audi ownership so far...check out link
- Reminder: Avalon's M-3 lip spoiler group buy is almost over!!
- I think I have a bad wheel bearing, but which one?
- 1.8T Test Pipe GB
- Reminder: Long Island, NY Audi Meet/Drive/BBQ 8/1/04................
- A4 Tune up??
- With a Vag-com, K04, and FMIC
- Remove rear speaker cover
- Intermittant steering groan. Mechanic says lower control arms??
- Has anyone used the DieselGeek clutch? Got a review for me?
- A4 Lower Door Moldings tear too easiliy
- what do you guys recommend for a good street pad, under $100?
- anyone have a extra dipstick they want to sell, lol, dipstick.
- Who here has completely replaced the factory bose system?
- do stock RS 6 wheels fit on B5 A4?
- Some pics with my H&R Race springs installed
- ECM Fried - Need Help on New Chip
- Performance
- paging all those with ATP GT28 turbo kits
- buying keyless entry key off ebay. do i need it for an a4 or certain year?
- Dont have a Turbo Timer yet, When I let everything cool down What am I looking for
- Has anyone fit the newer Evo fmic in a stock bumper with fog lights?
- Two new problems that developed today...
- Turbo kit and exhaust
- Which Brakes???
- quick question: difference between N75 Valve and Race N75 Valve??? Thanks.
- A4 B5 vs B6? 1999.5 vs. 1999?
- wheels.
- Oh great audi gods that talk thru my puter, my new exhaust might offend you
- REMINDER: LA/OC folks... SCC Audi Techfest -- Saturday July 31st @ CEC in Century City
- My S4 skirts look crappy with stock door moldings!...
- Low Speed, Front End Thumping (suspension)
- anyone running a aftermarket smic? if so, why? just curious.
- oil in intake, oil oil everywhere, pcv?
- Quick ECU Question??
- What is the Subaru equivilent of Audi World?
- how driveable is a slipping clutch ?
- Tails question???
- Any way to have the instrument cluster lights stay on all thw time like in the S4
- spark plugs?? stock.. or aftermarket??
- vag-com
- Will a torn vac line to the intake manifold cause surging? I STFA and didnt find much of an answer,
- Thanks everyone for input on the "Audi or Acura?" post, I have decided...
- What does this light mean?
- Finally got Pictures of Brinsley onto my Comp.
- Obligatory "I just got chipped" post
- Tire Change Time!?
- Anyone have S4 spring/struts on A4? Do they use the same struts as stock A4 sport springs? Bad idea?
- Just bought my computer for carputer install
- Neuspeed Installed Today!!! (just another opinion thread)
- Ok, i need opinions. I can buy a M-box ecu off Ebay for 300, ecu and APR chip. Then sell my stock
- Does anyone have a GIAC chip to sell that will fit my 2000 Audi A4...
- Differences in oil drain plug size? ('97 1.8T engine vs. 98+)
- 1997 Audi A4 2.8 Quattro Bilstein Shocks
- Audi A4 99 or 99.5
- 1997 Audi A4 2.8 Neuspeed Sports Spring
- anyone know how big nipper's car is coming?
- having trouble registering at superchargedaudi.com
- Boost Gauge Advice Please
- anyone interested in new black all weather mats....
- Audi or Acura...?
- Vote for the new sig pic!
- Is anyone else as disapointed as me at this years 1.8T challenge???
- Anyone have the model code for a 2000 A4 1.8T FrontTrak manual; it begins 8D2... Thank you!
- Is there a tech article on DIY fender rolling? Can't find it.
- AC recharge
- 1/4 Mile database has migrated from Liam to me. Email me with your CAPS and 1/4 times...
- As a follow up to my post from yesterday about the mini cooper...
- What tie rod ends are you using?
- Please Help! I search, but need more info. Best MP3 CD Changer to use with stock Symphony system is?
- PhatNoise for $399.00
- Just drove this 89' around all afternoon. Good times.
- Here's an updated pic of my A4 after a couple mods
- ABS / CV Joints? (Did the search... anything additional?)
- 2000-1.8TQMSport and a fwe others...thanks!
- Is it just me or are more people buying B5 A4's?
- tools or mods??...
- 97 1.8tqm cold start / stall help!!
- Slight shudder accelerating from a stop through a turn
- can A4 Calipers from 2000 to fit 1998 A4
- How much to replace fuel filter?
- Maybe the ugliest a4 ever??????
- AW member looking for S4 Kits look inside ...
- Paging Nojoi...
- Ok, so i found out i have a P-box ecu. Can i use an M box with an APR chip?
- Are there specific types of radio/cd unit that will
- My car was just towed!!!
- Anyone got pics of !8" OZ Superturismos on their ride....or someone else's
- What do you guys use to get off the goop/foam left from wheel weights?
- Oil cooler GB...
- 3.0 liter or 1.8 turbo with chip??? Opinions??
- so it looks like ive sold my car (<crosses fingers> that he doesnt back out)
- Gas Pipe Problem?
- ****KK Meet tonight!!! 9pm @ Burbank******
- paging qfrog@work..... need 2 parts #s... thanks phil
- Kleen Wheels - WTF?
- System too lean
- Neuspeed Chip Question
- Buying Silver S4 Bumper with S4 Fogs & The Front Panel... Preferably Silver Please...
