- Rear wiper, any Avant-ees oot there? 180K on it's way.....
- Longevity (152,000 miles and counting)
- Which bulb style would I order if I got the HID's Lefko reviewed? I have S4 housings...
- Driver-side door lock issue
- Still getting CEL N75 intermittent even though I replaced valve with a new one...
- I Ain't A Player I just Crash Alot (for the B5 Crew)
- Ok dealer says the part i need is replaced with a substitute .......
- Bad turbo or broken boost line
- Anyone have a good fix for a broken lower mount on 1 piece housings?
- Weak heat, flushed heater core already
- Headlight washers aren't working, and there's a connector hanging down up front...
- electrical prob. please help.
- Block
- Ok ,Ok On a serious note, How exactly do you....
- So how many of you guys' ABS light goes out when its under 32 deg?
- Advice needed on MAF and pre-cat oxygen sensors
- Replacing Secondary Air Pump
- 1st gear problems, when cold
- when installing o2 sensors, it is recommended to grease the threads right? can I use lithium
- Milltek exhaust - is the sound clip on the stratmosphere website an accurate indication? more -
- Air leak on passenger side
- Think I could sell my old clutch?
- STFA? Early 99 1.8t head needed. What years will interchange, where to get one?
- audi a4 tdi new user advice plz
- HVAC blower fan/motor question
- Planning for spring already.... thinking about ordering coilovers at long last!!
- You know what's strange... i "think" i'll know the answer to a post
- uh oh... something wrong with the turbo?
- car slid on ice today and front driver's side wheel slammed into curb.. price estimates?
- nunya.... get on AIM if you have time/still awake.
- paging dennisa4
- Anyone know what is up with my outside mirror switch?
- What happened to my power
- What is it with classifieds listings (not necessarily AW) that say "make me an offer"?
- 97 A4 Heater problem!
- Which coolant/anti-freeze for the 30V V6?
- What to do when youre getting new tires the next day...
- Bumper Damage
- wish Audi put quick-connects on their fuel filters
- I was out in the snow the other day and my car does seem to understeer less since the new springs
- Thanks for you help and support guys! I probably couldn't have done the clutch job correctly if it
- problem with tranny/clutch
- quick wheel question regarding weights...
- Radio will not turn on
- has anyone gotten bosch universal 02 sensor part # 15738 to work
- Trunk light help
- WH00T OLD ACCOUNT BACK ! i can call nate a n00b again... ahh.. yes so refreshing
- Transmission linkage
- crap, in the middle of an oil change and there's oil spray all around the filter area
- HID Install and Full Review (pictures too)
- Need radio manual
- Steering column swap - from 97 to 98 and general removal questions
- Interior Upholstery Project Update: Completed for now...
- This will fit my car with some cutting right?
- silver b5 driver door forsale on ebay
- Can the door handle plastic trim be replaced w/o replacing entire door panel?
- Headlight Adaptor That Allows A Circular Male to Fit Into a Rectangular Female??
- ok last question today i promise!!! replacing tranny pan where do i get special filler tool!
- Anyone used this OBD software before .... Im thinking of getting it
- so went out for some high boosting fun :)
- think i found part number in forums. Anyone know if this is right. Thanks all!
- Just put in a grounding kit. Amazing new found power!
- F****ck!!!! what a night
- Low coolant warning...
- I just noticed... the FAQ did hit over 100K hits
- Since I ordered Labree HFC today...can I get a few quick reviews. Not much in archives.
- Cold and dry here in Joisey. Too bad I have Chevron Techron in my tank. My CAPS time says it matters
- First impressions of HID install
- chipped a4 1.8t is faster then stock 2.8L v6... true.. flase?
- South Bend OFE Stage 4 w/ SS pressure plate + 4250 RPM on the upswing = 4 wheel traction loss...
- bad gas mileage update / 02 sensor question
- Quick answer: True or false if you have a socketed ECU and have the stock chip in it
- Have a radiator next to my computer seat that is extraordinarily loud when it releases air.
- Help!! RossTech or VWTOOL Needed in Northern VA / DC / MD
- Funny how no one wants to hang out/do anything or you have "other" important things when you try to
- Dangerous Conditions lead to ...
- Well, the HID's are in... so far so good (kinda)
- Squeaking from front end...
- xpost from awma: whipple and an oil cooler
- Question for everyone on some Repairs????? How much to trust them.
- Anyone knows how to read or decipher parts VIN code range??
- Thermostat
- Did a cap run & MIL ?
- Another one bites the dust. More turbo carnage....
- A4 Bad rear...
- So what is a 2871R in a 28R compressor housing with less than 9K miles worth?
- Official WMMT: What is on the agenda this weekend?
- k04 rebuild....worth it to get the turbine housing ported and polished?
- Been suspended? Want your old account back? AudiWorld AMNESTY Announcement!! ---->
- No Gears / Transmission Problems?
- BJC the checks in the mail.....I will be rocking a FULL GT28rs by late March/April:)
- weird. I was driving along and thump - engine light - RPM drop. I immediatly pushed
- Help! Having trouble with the collar bolt.....
- I REALLY APPRECIATE THE HELP WITH THE CAT. THANKS!
- So just took the car for a drive.... question for ya'll.
- 16500 code after putting in new ECT sensor?????
- Well crap, conflicting info in the Bently, 2001 AWM, FW tq values, 60NM +90 or +180?
- I see you guys express displeasure about over-paying for parts... check this out
- looks like my valve body is getting overhauled
- Do you guys think 450whp is enough??
- Aargh! My headliners been out of the car and my dog not only walked on it but pissed a gallon!
- I have been trying to make my vdo gauge have a white lighting rather than red
- How do you prevent air pockets or get them out when changing your coolant?
- Kris Hansen...a question for you..
- Interesting read about Amsoil Oil vs. Mobile 1 vs. All others.....No more Mobile 1 for me!
- **Revo Technik welcomes Greff Motors of New Orleans LA to our Authorized dealer network
- Question about wiring on the blue 4-pin coolant temp sensor (G2/G62)
- Center Vent SPA/Zeitronix Install w/ Carbon
- Electrical Problem!!!!
- Tie Rod Tricks
- squeeling when i turn left...any ideas?
- Seat repair
- more manifold pics...
- If only our A4's were this easy... changing T-Belt and related on a TDI in the shop today...
- Got everything back together...almost
- Loose steering after new tires/alignment
- Best price for SCAT rods?? (AEB) (Paging Rally Vermont!)
- s4 seats on ebay, the guy says the seats are in "good condition"...
- Wastegate spring?
- Follow up to rattle/banging problem 97 A4 1.8TQA
- rear rotors for my a4
- 1 Fault Found: 17545
- Slotted rotors- problems with wet braking
- does anyone know if upping the octane on the J31 make a difference?
- 97' quattro 1.8t sport springs (Eibach OE Sport) > onto my 99.5 1.8T?
- climate control buttons: i stfa'd and tried both methods, but now .. (long but need advice)
- Ugh major water came through sun roof in carwash...
- Tranny swap on 99.5.....searching but has anyone done it?
- 1999.5 1.8t w/ AT.. what transmission do i have, and where can i buy parts
- Does this sound like the MAF needs to be replace?
- Ok, I took my car into my local mechanic a couple
- One of my spokes on my rims was cracked all the way through...
- $289...
- Can I limp my car 15 minutes home with a blinking CEL? (more)
- Which items are contributing to my handling feeling sloppy? Comparing what I had before to now..
- bassed-Prkway BURNER ygm
- How bad is it for your car if your wastegate is going/bad?
- Couple of q's during clutch install. Do I need to use copper grease on the release lever AND
- Does anyone have (4) used intake valves in near perfect condition? (Joey T: Unpimper?)
- So after a week, I finally got pictures of my new $3,000 non-Audi toy
- My standalone project
- Clunking noise after febi-bilstein front end?... sigh...
- Project 1 of 2 complete
- Im tired of searching...little help.
- It would appear the junkyard AWP engine sitting here has no pilot bearing.
- is there anyway to upgrade your quattro ?
- Audi technicians: this could be a unique opportunity
- Boost vs RPM Load, what are the draw backs? (LONG)
- paging Carson, help please!
- madan... stop sending me weird text messages!
- just got a set of euro headlights and trying to figure out the new wiring.
- i stfa'd and i forgot my bentley at a fellow AW'er: rear axle bolt torque on
- Will 2000 & 2001 drivers exterior door handle work on 99.5?
- Cold temp misfire issue...
- Stock spark plug part# ?
- strut problem
- Rear pad/rotor change... q?
- Because I know you love reading about it... 4000 turbo conversion update/xpost
- Transmission Tragedy....HELP!
- the stealer tries it again
- grinding sound from rear brakes for first 5 mins of driving
- Help! Auto tranny missing gears!
- transmission noise
- Paging Carson:
- UK member - audi dealer quoted at service ?1000 for cam belt change
- interchangeable parts...?
- Has anybody ever replaced their projectors with bi-xenons??
- Before I commit to the Febi kit,...did stfa, no exact info.
- just a pic
- Blown K04 from AWE with GIAC software, can i just drop in a new k04-15
- Wow......
- Where can I find this replacement bolt? *PIC*
- 7.3 Powerstroke < Audi in cold starts... damn -9*F upstate NY
- Need Help: Window Auto Down gets stuck
- finally cleaned the car up a bit...
- New Tweeters didnt fix bad front left tweeter - Is the amp bad?
- Phatbox owners, anyone try modding their hard drives for more space?
- OKay so at 70 mph and 20 psi one of my hoses let loose on me and holy crap I loose all power, pull
- New sound..Oh great...here is a description....
- Battery Suggestions?
- Dension Icelinks on eBay for cheap.
- E-Code (HID) lighting upgrade questions (from 2-piece '98.5 A4)
- Need some serious advice, In the middle of a timing belt changeover.
- Tubular Manifold Spyshots....
- Bently Factory Repair CD for sale.................
- FedEx is a bunch of pansies...
- Feel my pain....
- Paul_858 might have a point...and yes, there's some Audi content...
- B5 Shift Knob Suede Wraps For Sale...and feeler for b5 shift suede shift boots.
- Well the turbo is in and the car runs. A couple of questions though..
- What is the part number for the awe K04 kit is it a 15 or a 17?
- Toy 1 of 2 arrived (i want the other tho)
- Anyone tried using "paintscratch.com" products to touch up their A4.
- Best place to buy front and rear valances?
- Remote Key Programming/Ross-Tech
- oh boy! i got my injectors :)
- apr vs. giac? same chip? anyone goin big turbo and lookin to get sell either? ive got an extra ecu.
- A little teaser....
- Paging Jon 1.8T
- Windshield Glass... hmmm
- What would be a decent price for 4 BBS Motorsport wheels (edit)
- Anyone here soldered red LEDS onto their '00-'01 gauge cluster?
- Anybody have 2 front sport shocks they can part with?
- Question for Qfrog!! Please help!
- GTRS question..Does anyone know the size of the oil return studs, I managed to lose
- Cluster questions
- Anti-theft, Pt. 2...
- help on choosing engine mounts
- Got the final part to put everything back together....
- (UK member) recent service at dealership - cam belt change at 45K miles?
- Has anyone done time attack in an a4? Is there a list that lets you know where and when?
- 10deg F and max boost is 10psi...this is no fun.
- I dont know whats going on!!
- Forgive Me Father, For I Have Sinned (very long)
- Does the vent mounted AWE boost gauge come apart? Mine needs to be cleaned!
- What does eveyone think of this?
- Or a turbo rebuilt shop around LA.
- I need a K04 quick prefered rebuilt or new.
- Freaking noobs, this is getting old... The latest email I received.
- leaving my car for 4 months on Feb. 13 to go abroad...recommendations on how to leave her?
- Dyno comparisons. GIAC X, AMS, AMS Custom, Stock
- final ever photo post of my car ;) now that it's with its new owner BWW
- had a winter wakeup moment today
- Car still doesn't get up to temp...
- Does anyone know the part number for the valve cover screw? I have a AFC engine if that matters.
- A comment...
- unburned fuel smell and bad mileage
- Sludge?
- Calling for clarification. Did anyone see my post about needing non-Bose rear decklid speakers? chip
- Calling for Clarification, how to handle noobs?
- Calling for Clarification on WTF is going on.
- Calling for NO Clarification...Drivers seat repair
- Calling for clarification. Door speaker(s)
- Calling for clarification. Cam tensioner
- Calling for Clarification. Engine Mount(s)
- HuMMing Noise in Airbox - During Extreme cold
- Re-joining the audi family!!!!
- Can a small bubble in my Tint be fixed?
- Lowering Suggestions?
- Just a reminder .. D.V.A.G. Dyno Day at A.W.E. Tuning is coming, reserve your spot now
- Upsolute Chip??
- Anybody here familiar or use the SAFC unit?
- About to attempt the timing belt, Could use some advice...
- axhaust question
- Steering Wheel
- Sears is a trap, I never get out of there for under $100, I went in for a set of crows feet...
- Ok, since I haven't been on here in a bit, let me post the latest karma to my car;
- does audi cover rust?
- Headlight recall?
- Anti-theft...
