- Help needed asap
- HELP NEEDED AUX FAN ON/Running At All Times
- Outside air temperature signal
- Help please! 1999 A4 1.8t quattro, crazy electrical problems
- Substitute for flex pipe???
- [2006 a4] Wrong fuel grade, what do I do?
- B5 a4 upper dash removal
- Intermittent Fuel pump issues
- 2003 Audi Quattro A4 Allroad Revs but wont move!?!?!?
- Can someone help diagnose this noise while driving?
- :: ECS Tuning :: Timing Belt Kits + FREE Schwaben LED Pen Light! | B5 A4 1.8T
- Audi a4 v6 1999 leaking coolant fluid through drainage
- :: ECS Tuning :: Protect Your Pan! | ECS Stree Sheilds - $40 Off!
- :: ECS Tuning :: Breather Hose Service Kits | B5 A4 1.8T
- Automatic transmission fluid line route
- B5 Audi A4 Ring emblem Size
- MP3/USB/Bluetooth Adapter for Concert 1
- Possible bad turbo maybe? With video
- 98 A4 manual v6 does front drivetrain share fluid?
- Meet Audrey - 2000 Audi A4 (B5) 2.4 V6
- :: ECS Tuning :: Now Available! | HRE Wheel Collection
- Passenger side outer CV joint clunking?
- 2.8 start up problem! Help
- Concert head unit blown fuse and K line
- P0135 code but no CEL
- GTS Tuning
- Put something back together incorrectly
- Check Engine Light/ Clearing Code Question
- NOOB NEEDS HELP: EPC LIGHT, STALLING!
- Is the outer diameter of flex mesh pipe on the 1.8T engine 2.25?
- A4 V6 B5 2.8 Misfire
- :: ECS Tuning :: 034 Motorsport Collection For Your B5 A4
- BIRTHDAY SALE!
- 🔰 Meets 🇩🇪
- Starting mods
- Wanting a performance exhaust!
- 2001 AWM won't rev past 3k rpm and 25 mph
- :: ECS Tuning :: The One-Two Punch! ECS GEOMET® Rotors & Exact-Fit SS Brake Lines
- Clunking sound when brake pedal is released on passenger side...
- :: ECS Tuning :: ECS FSI Coil Pack Conversion Kits | B5 A4 1.8T
- 1998 A4 Airbag light, VAG-COM, VCDS-Lite failure
- Alternator Identification
- Bubbly, grinding feeling when accelerating. Normal?
- '98 2.8 no crank
- P103 MAF Circuit High Input - Only Under Boost
- Idle problems
- :: ECS Tuning :: NEW!! Stahlbus Oil Drain Valve Set | B5 A4 1.8T
- Unique '01 B5 A4 with one owner since day one (video)
- :: ECS Tuning :: Now Available!! Podi Gauges | B5 A4 1.8T
- Removing the turbo... How to access the underneath bolt on the cat side?
- Audi A4 1.8 petrol 1999 Fuel gauge
- :: ECS Tuning :: Save 15% On ECS Wheel Essentials | 7/6- 7/14 Only!
- B5 A4 Left Ecru Seat bottom ripped, recommends?
- Air conditioning fault
- 97 a4 rear differential
- Battery Discharge
- 2000 audi A4 quattro 1.8 T overheating
- 2000 A4 Quattro 2.8L HELP!!
- how much tq can the b5 5 speed handle?
- A4 1.8 1997 Immobilizer problem
- Issues in the Rain with shifting.
- Rear crossmeber questions
- :: ECS Tuning :: Ignition Service Solutions | Audi B5 A4 1.8T
- Auxiliary fan not working at all! Please help!!
- Engine overhaul - now starting problems - help please
- ac compressor removal on 1.8t
- Hello, new guy here, in need of advice
- :: ECS Tuning:: FREE SHIPPING ends 6/28 MIDNIGHT
- Summer Start MEGASALE!
- A4 B5 2.6 ABC - A/C fan not working
- Mods
- Headlights
- :: ECS Tuning :: Forge Motorsport Components | Audi B5 A4 1.8T
- Audi A4 B5 1.8 TQ Sunroof not working
- :: ECS Tuning :: Time Is Ticking!| Save Up To 15% On ECS Timing Belt Kits!
- FIX??? P1117 O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
- D, 1, 2, and 3 have the same functions on my automatic transmission
- :: ECS Tuning :: #SaveThePans | B5 A4 ECS Street Shield
- Help me pick a good turbo unit.
- :: ECS Tuning :: Performance Rear Differential Mount | Audi B5 A4
- Car dies in warm weather (97 A4 2.8 V6-12v)
- A4 Avant FWD Transmission Question
- :: ECS Tuning :: ECS Jack Pad Adapter Kit | Audi B5 A4
- Mass air flow sensor
- Electronic steering question
- 96 a4 A.c. compressor interchangeablity
- :: ECS Tuning :: Aero Wiper Conversion Kits | Audi B5 A4
- 1998 A4 Quattro 2.8L V6
- Random multiple misfire, bad cam gear
- NEED HELP. ABS AND WHEEL HUB ASSEMBLY
- 2001 A4 1.8t Quattro Avant AWM - whine follows RPM
- :: ECS Tuning :: Audi ECS Carbon Fiber Parts | Up to 25% Off!
- How to remove shifter trim on an '01 A4 B5
- Please Help **Audi A4 Quattro 1999 Sedan** Headlights/Blinkers Fail
- :: ECS Tuning :: Memorial Day Sale | Up to 25% Off RS Style Grilles & Alzor Wheels!
- rebuilding a 3.0
- Replacement radio for Delta
- 1998 audi a4 quattro idle problem
- 1999 A4 Avant 2.8 Owner's Manual
- :: ECS Tuning:: Summer Prep Sale Event! | Up to 30% off your favorite brands!
- FREE SHIPPING through Memorial Day!
- Less than 24 hours away from launch!
- Head unit problem.
- Oil leak help - 1996 2.6 V6 A4 B5
- Limp mode
- 1997 Audi A4 Quattro 2.8l Sohc Misfiring
- 2000 Audi a4 1.8T engine problems
- is this a warning...
- :: ECS Tuning :: P3Cars VIDI For Your Audi!
- Vacuum lines
- Over boosting, a waste gate problem or the whole turbo?
- :: ECS Tuning :: Valeo Clutch Kit/Single mass Flywheel Conversion | B5 A4 1.8T
- 2.5 tdi to 2.7 tdi
- B5 prop shaft compatability
- Complete Interior swap from 2000 a4 in 98 a4
- 2000 Audi A4 will not start
- :: ECS Tuning :: Assembled By ECS Oil Service Kit Sale - Save 10% | Audi B5 A4 1.8T
- rear axle removal
- :: ECS Tuning :: ECS RA4 240mm Clutch Conversion Kits | Audi B5 A4 1.8T
- AudiA4 1998 2,4l Automatic gearstick panel?
- WTB: b5 A4 Rubber Floor Mats
- Quick help wanted: Front control arms very early model split?
- AutoPreme Prices (2 Weeks Away from Launch!)
- AUDI A4 2001 problem
- :: ECS Tuning :: Audi B5 A4 1.8T ECS Vent Pod Boost Gauges & More!
- 1998 audi a4 1.8t quattro
- Audi B5 420-R DTM: The Build.
- :: ECS Tuning :: Bentley Service Manuals & Scan Tools | Audi B5 A4
- 2007 Audi A4 Quattro Ignition Switch Replacement
- 1998 a4 tdi power steering reservoir leak
- Is it worth the money? 2006 Audi A4
- :: ECS Tuning :: ST Suspensions Rebate Sale!
- Hub assembly
- Immobilizer blocked engine start
- Greetings from WI!
- FREE AutoPreme Floor Mats!?
- $12 A4
- Audi a4T 2007
- Track Monster yes or no?
- :: ECS Tuning:: Performance Sale Event | UP To 25% OFF!
- 1.8t Quattro Missing Nuts&Bolts
- How to Protect your Floor Mats (A Revolutionary Solution) - AutoPreme Update
- carbon fiber wrap
- how do I remove this trim?
- 1997 Audi B5
- Audi A4 TDI Sline
- :: ECS Tuning :: Front & Rear Wheel Bearings | Audi B5 A4 Quattro
- Tach and VCDS have different values
- 2.8 woes
- Is there a removable bulb for the airbag light?
- ***Don Nguyen | WannabeRacer.com | Vehicle Wrap - Tint - Plastidip - Custom Decals***
- Timing belt service + VC gaskets, half moon, tensioner gasket for $1300?
- Rim Sizes
- Oil on coolant reservoir. Another problem on my car -__-
- Has Somebody used the Vag-com VCDS 15.7.1 for A4?
- Door Locks
- pls any advice much appreciated
- :: ECS Tuning :: New Looks! | Fresh Wheel Options for 2016
- Coolant keeps going once every 3 weeks 2008 a4 tfsi se 1.8
- 2001 audi a4 transmission pan replacement
- :: ECS Tuning :: ECS 2.0T Coil Pack Conversion Kits | B5 A4 1.8T
- shifter play in 5th/reverse
- Replacing timing belt at the 1.8l ADR 5 valves engine
- Auto HVAC CODES! Please Help
- Door light, Windows and Sunroof don't work?
- Proper inner CV boot for rear axle?
- steering problems
- Headliner Removal/Thule overhead rack installation
- :: ECS Tuning :: Mesh Madness!! | Up To $50 Off 5 Days ONLY!
- Please help on my engine codes.
- A4 2.8 30v lights on rough running
- Audi a4 1.9 tdi wobbling sound
- Shifter issues
- FYI on K03
- What parts do I need to replace my PCV system?
- Code P-1340 persists with brand new CPS
- :: ECS Tuning :: Spring into power with Frankenturbo!
- 01 a4 b5 quattro...left front wheel clunking and shimmy
- Front Suspension pricing Q's
- Aftermarket stereo
- :: ECS Tuning :: Save Up To 30% On ECS Assembled Kits | Limited Time Only!
- :: ECS Tuning :: Save Up To 20% on Select B5 A4 Control Arms | Act NOW!
- :: ECS Tuning :: NEW!! ECS Coil Pack Harness Replacement Kit | Audi B5 A4 1.8T
- 2000 audi a4 b5 climate control problem
- Will B5.5 Passat OEM Roof Rack fit B5 Audi S4?
- ** GruvenParts.com SPC 81350 Adjustable Control Arms Sale !!
- b5 audi a4 need help!!! junk(part out first obviously) or fix
- 96 audi a4 clinate control issues
- Fuel Pump Relay Electrical
- 2001 A4 Reset ECU to re-train styles
- What a toilet!
- 2.8 throttle position sensor
- Need Help with various issues, big and small
- K line problem
- Proper torque sequence ?
- :: ECS Tuning :: Performance Drivetrain Mounts | Audi B5 A4 1.8T Quattro
- 2.8 quattro randomly wont start
- Headlight replacement
- coolant line replacement
- 1998 Audi a4 1.8t quattro Won't go in reverse or move in neutral even when pushed
- Serious Question
- screetch errrrrr zmmmm eeeeee (yup..)
- No Heat. Need help!
- B5 a4 united motorsports stage 3 tune "my experience"
- Odd Clutch Issues
- N91 solenoid replacement help
- 2000 A4 Q Rear Wheel Bearing Issues
- Fuel smell
- Cam Position Sensor
- :: ECS Tuning :: WeatherTech All Weather Floor Mats | Audi B5 A4
- Battery drain and doors
- Radio reception Syndrome
- :: ECS Tuning :: ECS Carbon Fiber Engine Cover | Audi B5 A4 1.8T
- Door locking and unlocking problems
- Swapping Audi A4 manual seats
- A4 B5 1.9 tdi quattro
- 2001 audi a4 Quattro crank no start I'll be up all night
- A4 Which oil to put in when history is vague
- Throttle Stuck Open/ New Audi
- B5 boost troubleshooting
- New guy here needs headlight washer caps
- :: ECS Tuning :: GEOMET® Coated Brake Rotors | Audi B5 A4
- A/c auto mode is not able turn off
- Motor whine without belts (AEB motor)
- :: ECS Tuning :: Assembled By ECS Oil Service Kits | Audi B5 A4 1.8T
- BOOST PROBLEM
- Tranny Problem :( please help
- :: ECS Tuning :: Single Mass Flywheel Clutch Kit | Audi B5 A4 1.8T
- Squeal Video - how to find problem?
- Severe Rear End Vibration/Failure
- Help finding some parts
- Sunroof won't seal
- 98 A4 Drivers Side Door Will Not Lock
- :: ECS Tuning :: 710N Diverter Valves | Audi B5 A4 1.8T
- Hello Audi World I have a question!
- :: ECS Tuning :: ECS Street Shield Aluminum Skid Plate | Audi B5 A4
- 5 speed transmission compatibility
- 99 A4 Avant. Tiptronic not working, magnets there
- Please Help - Audi A4 1.8T
- stereo help pleaseeeee
- steroids help pleaseeeee
- Am I missing turbo vacuum line?
- :: ECS Tuning :: Black Forest Industries Products | Audi B5 A4 1.8T
- Hello! New Audi Owner. Need Some Advice
- :: ECS Tuning :: B5 A4 ECS Carbon Fiber Mirror Caps
- 98 A4 2.8 -- Need advice
