View Full Version : A4 (B5 Platform) Discussion
- Dash temp readout at -58F
- 96 Audi A4
- car smokes out of the tailpipe after a turbo replacement
- A4 B5 quattro 2.8 v6 30v wont start
- car is harder to start the less fuel there is?
- Weird front end scraping sound at 60mph+
- B5 12v Radiator Hose Question (With Pics)
- Camber Adjustment in the Rear
- fault code 01176
- Decisions
- Center Differential Fluid Change Questions.
- Wheel size?
- Used parts sources?
- 98 2.8 30v no start, no compression
- No start after 3 months without running. Bad G28 sensor?
- Reverse trouble
- Seeking Knowledge on the 2001 A4 3.0 Manual 6 Engine
- Rough idle then dies 12v 2.8
- Replace MAF Sensor just because?
- 96 a4 2.8
- OEM exhaust
- Wiring diagrams
- Aftermarket coolant certified for Audi use?
- When to let go?
- Help!!! Slave cylinder install
- '96 A4 with concert 1 tape head unit Bluetooth mod
- Your thoughts on these refurbished wheels?
- No Keys
- Help me figure out.
- two black wires, but where do they connect??
- Disposal cost or value for 2001 A4
- Dumbest thing i've ever done to my 2.5tdi
- Audi A4 B5 1.8 Acceleration Problems
- Wheel compatibility with 2015 S3 rims
- Head Lights/Dash lights
- AU: 2000 A4 1.8T Quattro Project
- Refurbish switch trim?
- No communication
- Recommendations for replacement for Standard suspension?
- What is this button?
- Which units have VIN programmed?
- good book for 1998 A4?
- B5 A4 problems
- New guy with questions
- Tune up ECM to 1.8 to 1.8T?
- Camshaft Timing Solenoid
- My Venture into B5 Ownership - New to Me '97 12v 5MT Quattro
- Audi a4 b5 1.8t
- Change the whole wiring harness with ALL components from another car
- Were is the remote sensor located?
- A4 1.8t intake
- NO: An idiot accidently put 24V start help in my A4 B5 Quattro - Change whole system?
- AC blower problem
- Need Help: Window motor
- B5 1.8T IDLE issue Camshaft Positon Sensor or Coilpack wiring?
- UK: Audi A4 1.9 tdi avant 115: lost immobiliser
- A4 b5 1.8t
- Upgrading to LCD Cluster from non-lcd in 99 A4 1.8T
- Purchased a 2001 a4 2.8L for 500$ (LCD question)
- Valve hit pistons and on one cylinder it went cracked the piston should I replace it?
- Does sirius XM come on a 2019 premium?
- Loose Starter Connection?
- A5 b5 1.8t
- A4 popping noise from exhaust when starting???
- Not shifting past reverse
- Dead battery, car locked
- Difference between BPW and BRE engines
- 65535 airbag code
- HUGE hole in tube under manifold
- SSR AUTOBODY ♖ | SoCal's #1 Source for Quality European Collision Repair!
- 2000 audi a4 2.8 automatic limp mode HELP!!
- ABS light on, code 18014 and no response from ABS controller
- Possible A4 Quattro purchase
- 2000 audi a4 quattro
- V94 Central Control Module, Where Can I get one?
- A4 T2.0 2006
- Brake light blinks at me but fluid level is fine
- audi s4 bumper glassfiber
- Clutch pedal feels sticky
- 2001.5 Audi A4 Avant - wiper stalk replacement/compatibility
- A4 B5 1.8T cooling system bleeding procedure?
- 3.0 N/A
- 2005 A4 1.8t Cabriolet rear pass. regulator fix
- A4 B5 -98 crank no start
- Timing Over-Retarded; Camshaft position wrong
- 2007 A4 2.0 Loss of power, hard start
- Turbo-kit for A4 1.8T, TT, Golf GTI, Jetta really compatible?
- 01 Audi A4 slips out of 5th on the highway at high throttle
- Gas gauge won't go above 3/4 full
- CEL P0171 and P0455
- 04 audi 4 convertible
- Concert 1 to Concert 2
- Crazy speed+rev readings
- Upgrading b5 audi 1.8t
- Restoring my B5 A4 1.8T. Some suggestions.
- CEL, ABS, SRS, and brake light problems.
- Stay away from audistream2air Bluetooth Adapter
- How many miles can you expect a 2004 A4 to last?
- Audi a4 2003
- Just bought an '01 A4. What do I need to know?
- Need help Audi A4 B5 rear suspension issue.
- Why does sunroof reverse direction while closing?
- A4 01j gearbox
- Brake Lifhts stay on when headlights are on
- Headliner Fabric ADHESIVE
- Help with 1999.5 A4 Avant Q value
- Identify piece
- Audi A4 2012 window trims HELP!
- Can I swap my Audi B5 2.8 V6 with the B5 S4 2.7tt with our problems?
- What's an 01 A4 with 201k and needing an oil pump worth?
- Please help
- WTB B5 S4 in very good condiion
- 2000 1.8 starting/running problem
- 1998 Avant
- Why does ABS Wheel Speed Sensor contact Reluctor Ring?
- Inner Door Seal Sagging - part# and repair?
- Audi A4 B5 oil pan baffle
- A4B5 sedan seats
- Engine swap
- A4 B5 Avant Sport
- Some issues
- Issues after a transmission flush
- Sigh. It's time to say goodbye to my dear friend
- front passenger window green clips
- Can I use any lighter in the cigarette lighter holder ?
- 2008 a4 b5 2.7t swap
- Smoke coming from catalytic converter
- 2000 A4 Avant 1.8t WHEELS/TIRES
- TCU and ECU up for grabs. Both good working order
- Configuring A4 B5 transmission with LAUNCH CRP 123X car scan tool
- Hazard light issue when start up
- Dropping the oil pan without lifting the engine? (2001 A4 1.8t)
- Problem with starting my car
- 240,000 Mile Automatic Quattro 1.8t
- Vagcom
- clutch flywheel, need help!!!
- Need help with my A4
- 2005 12 / A4 2.0T FSI Avant
- 1.8T Automatic
- 99 a4 2.8 not charging
- A4 2.6 1997 High idle
- JOM Sport vs OE-Sport (1BE) suspension?
- Wiring nightmare.
- getAudiparts.com | Black Friday/Cyber Monday FREE SHIPPING + Promo Code!!!
- LV: Car dies after 2 seconds
- A4 / B5 aftermarket backup reverse camera recommendations?
- rpm change after cold start
- Goes into reverse but not drive.
- 2008 A4 Quattro indicator shows my left park light is out.
- Concert radio problem red glow on display
- Aeb intake on Bea motor, injectors?
- 1998 AEB, cranks, no start, can't connect to ECU
- Cornering G-force sensor / alarm driving me crazy! Disable?
- Rust and moisture in trunk
- Slow acceleration issue..
- https://www.pactofsupplement.com/viga-plus-fr/
- Interior lighting problem
- 17x7.5j ET45 with 225/45R17 on 97' A4 b5
- Audi a4 1.8l -96 central lock pump work sometimes
- How to replace control arm bushings myself?
- Weird Transmission Issue
- No crank...damaged ignition cylinder?
- 1.8t starter or clutch switch bad
- Fuel Pump, interchangable?
- Car AC keeps turning on by itself
- Rear door lock pin too deep
- 08 Audi A4 S line
- Car starting problems
- Front Suspension Problem
- OBD2 does not connect to ecu
- 2000 A4 Quattro Avant 1.8T NO SPARK AT ALL
- First time doing a Timing Belt (2.8 30v)
- Slave Cylinder Keeps Failing At the Hard line Coupling! Need Help!
- A4 2.8 oil filter attachment
- Draining old petrol Audi A4 B5 2.4 V6
- First car
- Help finding MAF
- Problems with weak acceleration/Feels like no boost
- 2.7biturbo coilpacks for 1.8t? Also A6 C5 seats for B5?
- General Advice going into a B5
- Aftermarket Central locking system
- B5 Rain Tray
- Whole car respray
- need some tips after k04 upgrade
- Unidentified Battery Drain on '99 A4 2.8L
- 1996 audi a4 autmatic shift linkage location
- Door lock problems - Need help
- '98 A4 Quattro Avant
- Overwhelmed immobilizer.
- ABS Problems
- Just aqquired my first Audi, looking for a little advice
- No crank. 1997 Audi A4 Avant 1.8
- Car starts but if left for about a minute in the on position it won't
- 2.8 30v Low RPM and stutters, driving hard fixes it though?
- Clunking in right rear of 99 A4
- Audi A4 - car staggers on take off
- Cam chain tensioner failure stripped teeth. 98 2.8 30v
- Neep help
- Need advice: crankshaft sensor motor failure
- What is a good buyers guide and how is reliability after 200k?
- 2.8 overheating quandary
- Engine swap question
- part name ?
- Rear shocks use fully threaded bolt?
- A4 B5 avant 1999 single din to double din conversion
- Turbo problem? Lack of power. Help me out
- Need help.
- Why is the LCD dispaly in my instrument cluster so dim?
- Pls help
- Audi B5 A4 1996 OBD PROBLEM
- I’m Interested (pls read)
- power window motor? smoke from driver's door
- Reverse Light switches-On momentarily
- LV: instrument cluster for simulator games
- Sunroof "swap"
- Cluster stepper motors
- No start, no ecu connection after jump & battery replacement.
- PT: Avaria, alguem pode ajudar?
- Non turbo oil cooler?
- Windshield Wiper Issues: HELP! HELP!
- 2.0L TFSI knock at startup
- Wheel Fitment
- Coolant leak
- 1998 audi a4 quattro 1.8t 5 speed trans issue
- Replaced serpentine belt now car seems to misfire/start by itself?
- UK: AUDI A4 1997 knackered?
- Help a4 Quattro 2005 new slave cylinder and new fluid aren't compatible
- Major misfire problems
- 2001 Audi a4 exhaust question
- $50 off ECS Engine Street Shields + Free Shipping
- HID burnt out - replacement doesn't work
- 1998 Audi No Spark
- Starter problem, no crank, no click, new starter
- DIY: A4 B5 bluetooth phone, bluetooth audio, and USB power
- having problems with the car idle 1.8TQ
- 97 A4 NEED HELP RESET GAUGE NEEDLES
- Broken hood release cable, additional trouble
- AC Problem - Climate control wont go into "AUTO" or start AC
- Selling Car?
- Engine turned off while I was on freeway and now won’t turn over
- 1998 2.8 Buy?
- Leaking Coolant
- 2.8 30v Vacuum Leak at oil filler, new gaskets wont seal the leak.
- Start/High Rev problem
- 2012 AUDI A4 OIL CONSUMPTION HELP
- rpm fluctuation
- Can someone please tell me what goes here
- B5 Transmission problems
- Very strange engine noises when idling
