- Where is the transmission mounted to the car?
- need part numer for
- Part number needed for the rubber coated window guide....
- 1 down, 49 to go...
- Real or PSed, still very funny
- $250- to replace shocks and springs on a 1999 Audi a4 1.8T quattro is this a fair price?
- Cup holder Mod on 96 B5
- I need a coil pack, I can get one for $60, but somone recomended changing all 4
- Does $90 to press in a rear wheel bearing sound a bit much?
- Will the W8 belly pan work on a '96 w/2.8 and FWD? conflicting....
- RaceTec FMIC vs. TyrolSport SMIC
- all front quattro ABS sensors created equal?
- "Hi I'm Rally, two weeks AW sober"... what have I missed?
- Anyone have a cheap, working K03 w/ decent miles? My buddy is looking for one...
- Figured I'd share the good news... 4000 turbo project..... IS RUNNING!
- :( just went to dealership to buy wheel bearing... fvck 136$.. oh well
- Bwah, take a guess how much stealer wanted for one front wheel bearing? (just the part)
- Is there any market for ported 1.8t heads? My buddy does porting & asked me...
- More great customer service <NOT!> from Mike Hoppen of JHM
- How often should you lube a billet DV?
- Hey guys...can I purchase the power steering fluid from a vw dealership for a 99.5 1.8TQM?
- ETKA owning guys, is the power steering pump for the 96 V6 same as the 97.
- UPDATE: Shop Ownage - Part III - The Conclusion
- Part Number For Torque Converter
- I know these posts come up every now and again, but i think it's time for another one
- WHO LET THE DAWGS OUT?! HOO HOO HOOO
- ABS - Now what?
- Where can i get a new screen for the middle of my dash and how hard a swap is it?
- getting new tip tranny...whats tht zf transmissions?
- Where do I put the EGT probe for my VDO pyrometer?
- Brake pad from autohauz got 3 choices, ate, mintex, padgid?
- miles ...to replace spark plugs? what gap for 99.5 V6 2.8
- doors does not lock
- Where does your oil temp sit at on your 2.8 during freeway speeds?
- Can someone recommend a decent yet affordable racing seat?
- Front End Clunk - Need Help
- Thanks for all the help guys. The 99 avant lives!
- lights out in passenger footwell
- Are NGK Iridium spark plugs worth the money?
- Weird Ticking noise....
- In a 1/4 mile race, do you think I would have this guy until about the end of 2nd gear?
- Footwell light no workie, but "dome" light works fine
- have you guys ever seen that movie of the young kid starting the red saleen mustang?(audi content!)
- Paging Bitjockey...
- oil leak after TB and other maintnence.....
- 2001 A4 2.8 Transmission problem?
- Just a little A4 "how you like them apples"...
- Cant budge the o2. Little advice please.
- Some idiot tried to break into my car, blew the right rear window in his/her face and ran....
- Guess I'm not replacing the PCV valve & plastic hard breather pipe without taking the mani off
- well, i only got 50% of the way through the tranny mount install...
- Thinkin of switching to B5 1.8t...
- What size is the stock non-sport front swaybar?
- Finished replacing my LR wheel bearing today.....
- Uneven brake pad wear... 1mm avg thickness on the right hand side vs.
- Should I keep my blown K04 just for a replacement part.
- 2001 coolant lines metal (from airbox area towards glovebox) twist black knob right.
- 235/40/17 ok on 17x8 wheel w/o rubbing? Heights are 25.5F/25.0R
- Need help
- No way to program FOB w/ one key ... ?
- wierd door lock problem, only drivers door unlocks and locks?
- collant flange is leaking on my 1.8t
- Imnotawesome: YGM.
- #1000
- VVME HID kit flickering bad after stopping for short periods
- Engine shut down while doing 50mph on highway....not sure why, here's the scenario:
- HELP!!
- 1996 Volvo 850
- anti lock break problem
- ABS Speed Sensor opinion requested (xPost)
- Do B6 floor mats fit in a B5?
- TT or R32
- Installed the Labree shotgun testpipe
- Anyone know the weight of ASA AR-1 18"x8.5"?
- Repair or refurbish key fob possible?
- CNC? What would YOU do?
- Could a bad O2 sensor be to blame for surging boost?
- "Sludge" in my 1999 1.8t, continued.
- Addco rear sway bar. anyone know anything about them?! 3/4" diameter solid bar.
- Awe A pillar VDO Boost Gauge quest
- Does anyone have tt carrier they want to part with?
- Auto Rx what thichkness of dino oil should i use for the clean.
- 007 A4 Intake Manifold
- Tire Suggestions
- navigation unit in a b5?
- PW'ing.. daytime pics of vogtlands ...
- One thing I have never understood is how an A6 or other car with auto-leveling HID's is aware when..
- E-code (HID) lighting upgrade question (from 2-piece '98.5 A4)
- Looking at a couple of A4's and ...
- ModifiedA4, did you put an AEB intake mani on your ATW?
- Woo hoo, new motor mounts feel great! (question inside)
- I might go to look at a B5 that won't start tomorrow. It cranks but won't turn over....
- Rim repair shop in MI
- Welp, there goes the front wheel bearing after I curbed it earlier this wk...
- 2001 S4 ~45,000 Miles
- Does anyone have a write up to change inner cv boot on front? Thanks
- Can I put these wheels on yet?!
- Saturday AM Vacuum replacement
- Every time I think of getting rid of the Audi I just can't seem to do it...
- Turn Signal Flasher?
- i want to get a fun 2door beater car
- mixed messages from STF. Can Koni's be adjusted on the car (compressed) or is it 100% required that
- Need help with strut decision...
- BBS RK 17's...
- ABS light
- Bangs head on desk...and starts to look into megasquirt
- any Avant-ees?. Wiring search providied no results
- stupid question.....if you had to guess the weight of a 1.8T block w/crank...how much???
- Did I blow up my ECU
- Does anyone have superleggera gt - I am thinking about 18s.
- Like new S4 AVANT Suspension on ebay
- My vogtland coilover review/install/pics
- How to replace batteries in keyfob (I searched)...
- Lurker
- Blower (K04) question
- Two mods I've put off for a long time...and a question about aiming headlights
- Front driver side Koni is blown, I am not original owner am I SOL?!
- I have searched. where is antenna amplifier located. time for sparks,gap?
- how do you take the hazard switch apart without breaking off the led's attached to the red lid part?
- oh yeah, friday night modding...just urethane filled my transmission mounts.
- JE custom pistons & Pauter Rods group buy by Avalon Motorsports has started...
- K04 - should i get a boost controler?
- Turbo Inlet pipe on egay hit or miss?
- i searched... but, is there a pdf. version of the original Audi manual?
- My driver seat is burning my a**!
- Consumer Reports Cars for 2007 issue came today
- Misfires...
- Turbo Question
- I want to buy a powdercoater. Every part on my car is so corroded and rusty : /
- Loud squeal coming from front of car when i cold start
- Are these good prices on parts?
- Longest thread ever about "missing b00st"???
- Air Injection Valve/Pump
- ABT-tuned Audi RS6 Crash (ripped the car in half)
- :: ECS Tuning :: Wastegate Actuator Assembly - Now Available !!!
- Has anyone tried blauparts motor mounts?
- Relay roller. Help a 1.8t n00b, please.
- OK, current best place to buy a K04?
- Defective S4 Motor Mounts
- goes out to rent spring compressor* IT'S TIME!
- OK ... still have an issue in the rain. Loss of power, rough idle/acceleration, sharp clunking....
- My new windshield.... I think i've made up my mind... But I'm not sure
- Anyone ever sand blasted a valve cover to get a cleaner look? Plus...
- interval to replace fuel filter ?? garage says $240
- Just ordered my Tax return toys.
- Looking for an odd part, pop-up phone mount for the armest...
- ok, finished TB and just took it for a 10 mile drive. Runs perfect, temp is dead center...
- Anyone thinking about de-modding a 97/98 2.8Q?
- k04_j31 dyno results on dyno dynmatics dyno...
- So i have a case of M1 10w30
- Cost to go from 240 to 280 HP on a tip ... is it worth it?
- Is it a bad idea to buy a 1.8 with a broken TB and the associated problems?
- coolant bleed screw - AWM 1.8 (2001) - not under accordian piece near battery??
- Fan Clucth Problem (short)?
- Pre-buy concern, please help a newbie
- Reason for Fan Breaking?
- Diesel in North America. What is the problem?
- audi a4 head gasket repair
- How Can I diagnose this problem - Wheel Bearing Bad?
- so it's looks like the A4 is now my winter beater.. (flamesuit on for my new summer ride)
- WATER DAMAGED A4 PROBLEM SOLVED!!
- PES Supercharger 2001 A4 2.8
- Manual boost controller...
- Hey guys....long time no see. This is NOT a for sale thread...just a feeler-->
- Sludge. Dropping the pan. Worth the effort?
- RIP Hazard Switch.... Where to get new one? 8d0941509h
- hey opened my door handle from the inside in cold weather and something snapped still works flimsy
- Russian Audi Parts website with pics like b3ntl3y
- Searching for rims... i guess i'll remain paitent
- ok, is less than one tooth acceptable on a TB? I cannot for the life of me get everything
- How does this theory sound for my clutch noise I am having... Need expert opinion!!
- A8 V8 4.0tdi grrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrrrrrr
- question about my gtrs with mika...
- Anyone have a pick of the door lock remote prior to the flip keys?
- Petrol VS Diesel
- Still getting two codes...
- Windshield Wiper/Washer Problem
- Mocking me. Just mocking me...
- Ahhh I KNEW i shoulda had a coil pack in my trunk!
- tip transmission upgrades other than the chip????
- ebay fraud, any help greatly appreciated, watch out for fake emails from sellers
- Timing belt - 1.8 AWM engine - cannot get belt on... any suggestions?
- Has anyone ever run a .82 exhaust A/R??
- I've been thinking of either getting an R32 and ditching the A4
- Check Engine Light
- wierd *ping* noise
- Little help please.?
- Got Snow!??
- Fudge, nailed a curb this am on ice for the first time...
- Is there a specific bed-in procedure for Axxis Ultimates?
- Stock Stereo Specs for 2001 A4 1.8T
- cqlight 6500k or VVME 6000k FTW???????
- what did you pay for timing belt replacement?
- I give up. I'm going to have to take my car in. Clicking/tweeting continues.
- How hard is it to replace a rear lighbulb? I hope it's easier than the fog lights(Canada's DRL)
- Is replacing a rear wheel bearing on an A4 the same as a S4?
- a4 b5
- Might need a brake job soon....
- Car turns 10 years on the 10th this month and its gone through...
- 99 1.8t AEB A4Q Possible vacuum leak, cold and warm start issues
- anyone know what a transmission replacement cost on a 98 a4?
- Buying a TB kit from pureMS got some questions thou??
- Have anyone heard of this problem on Audi.
- This will probably get deleted, but it's funny
- K ordered VVM headlights
- Has anyone purchased a 710N recently? if so, anyone find it for <$37.95?
- What type of problems would cause a car not to start and not throw any warning lights i.e. CEL
- Any good sources to have my BBS RGR's painted or powder coated black?
- Is there an easy way to get the airbag light to turn off?
- for shame...
- ECS Tunning Question
- K04 install quest
- Is there article thread that talks about changing rotors and show actual pictures?
- Replacing vacuum hoses & suction pump
- Man i was worried. turns out it was nothing
- Front brake disc's
- So at what speed does a rear wing actually start generating enough downforce to be useful...?
- Cheapest place for coolant sensor?
- For the one or two old-timers here who care... my big-ol International truck is running again! Video
- Car does not start sometimes.
- Need urgent help, flashing CEL . . .
- Oil change: should I use Seafoam first?
- 2 quick questions...
- As anybody ever put those alu/chrome S4 door sills on their A4? Is it pretty straightforward?
- Original MIM Sportec Owners....(RKA, Alex, etx)
- what the hell is this noise?
- Someone HELP please! Name that sound!! Major help needed...
- Woot, just registered for the NEQ's WG1, this time its in April!
- 2001 VW Golf TDI, 116K, auto... What's a good price?
- Who's upgraded from stock to A8 rotors/TT carriers....then to the PureMS Stage 2 Boxster calipers
- question on mirror covers
- You folks seen this? Nice information although it applies to transverse manifolds
- Price for S4 license plate cover
- Paging Mike@pureMS (or anyone who may know): BBS LM center cap question...
- NOW the fun begins...... twin turbo goodness.......... mmmmmmm...... semi OT :
- Anyone have a carfax acct? Could you please run...
- Pshop experts: Could someone please color match my wheels?
- OEM M3 lip spoilers now available at Avalon Motorsports..
- Anyone here a member of BIRA?
- Have been researching welders for a while...
- 5th gear notchiness
- Center armrest covering material question.....
- What could this noise be?
- where is the best deal for OBD cable for vag-com (USB)
- Transmission Problems..searched here is what i have. any ideas ?
- who has had 18" anthracite OZ SL crack?
- Chip Herr Returns To STaSIS Motorsports for 2007 Season
- help.. want to buy an a4 in the $7000 range..
- Exhaust came loose - any thoughts?
