- Update on my little car fire this weekend
- Okay bishes, back from the Bahamas... what did I miss???
- coolant system draining and bleeding
- is 950 a good price for a TB and water pump change (and all other belts)??
- Where can I buy sunfoof tracks, stealer wants 1187.23 NO WAY!!!
- Complete the following. . . In the trunk of my Audi, you will find:
- Those who havent seen The Transporter 2 yet.. skip on seeing the movie it sucks!
- Gas price does had some good effect: less traffic....
- DIY maintenance - service book and VAG advice, please
- TURBO UPGRADE Audi A4 1.8T QUATTRO
- Should I wait for a cel to replace my O2 sensors?
- High Idle - Steady CEL
- with the gas price rise are you stations pay before you pump now too?
- CEL came on while driving normally but when hood was poped the turbo was glowing HELP!...
- Where can I find a replacement instrument cluster?... pretty sure I'll need one
- New shoes and sunglasses...what do you guys think?
- anyone see the quote in this add? too funny
- How do I convert ACC format to MP3 for PhatBox?
- Bolt size for battery hold down clip on 2000 A41.8TQM ATW??
- Ferodo D2500 impressions after mild track day.
- Autodimming Mirrors turned on this weekend during the day...
- X post from 12v forum... need a lil help finding why my car electric fans aren't turning on
- ETKA request, fuel filter 97 1.8T FWD model
- Who's got the best deal on the C5, A6 rotors for the rear upgrade?
- Anyone here have a chance to weigh a Flik Justice in a 19in?
- OT? Anyone ever have/know of/driven a *cough* BMW 318Ti (trunk impaired) coupe?
- Who needs a new background image?
- Need part number/price. QFrog?
- Anyone have any wheel spacers they want rid of? Preferably 3 - 15mm.
- Replacing External Mirror glass? Just pull?
- Which remote battery do i need?
- I've put over 1750 miles on my car this month...
- Heater not real hot.
- So, my steering rack is missing a boot clamp.....
- Tie-rod check
- Is there an inspection hole for the clutch somewhere?
- Will 215/55VR16 tires work on my OE 5 Spoke 00' 2.8l Rims?
- What weight of synthetic oil does everybody use for the 1.8T?
- I need a pic of the VDO oil pressure sender installed & where do I go through the firewall?
- Anyone have 19in OZ superleggeras?
- Need help figuring this out...
- AutoSpeed Performance TSB Group Buy Update - Quite Popular!
- Doing the control arms and noticed my motor mounts are leaking. any need to do an alignment after
- assistance required with my xenon lights...
- does anyone have a vag around eastern long island?
- Vag-Com Codes Now Problems
- xpost from AWMA forum: today's mod session
- Buffalo/Rochester/Nearby crew: Looking for a 97-99.5 B5 A4 1.8TQ
- something is wrong with my car....
- clutch question
- ABS Issue
- life w/ phatbox & freshlymixed > life with satellite radio.
- My Labor Day project... (BWW)
- Heh...
- Please can i get a walk through on how to take off my 1.8t oil pan while its on the car!
- only 24 more inches of red stripe to go!
- If brake wear sensor will not shut off after, taping wires together ...
- wats a good bov for my 1.8T a4??? and are they hard to install?
- Since I didn't get a lot of feedback yesterday about my leaking fuel filter I'll post again today.
- Anyone know how tough the OEM or Replica RS4 rims are?...
- Put the W8 belly pan on
- VAG code read help
- went to change my oil today and came across...
- I am victorious..
- Brake wear sensor question ...
- Fronttrak with Tiptronic question
- Metric grade 10.9 bolts and locking nuts?
- Help me diagnose this A4 DTC - '96 A4 2.8 5 speed
- Part Number request for rear defrost switch ('97) and cost of it
- so I've been taking it real slow with this heater core and I finally...
- Can someone with photoshop help me create a simple sig?
- I finally bought a Euro plate. I like the Stasis vinyl, so I might move it over to the sides
- I knoe that BOVS are bad, but can I hook up a hose where it vents to push air back into teh turboe?
- can i get a walk through on how to take off my 1.8t oil pan while its on the car!
- So I think I screwed up my key/remote
- cost for repl timing belt and water pump
- any tips on getting the front ABS sensors out?
- Any ideas on how to de-ghettoize this boost gauge install?
- AWE Euro Headlights
- I think I am getting a rotten egg smell from my car.
- Are the b5 and b5 headlight lenses the same size?
- is the BF Goodrich g-Force Sport in 225/45/17 any good?
- Tough Choice, need AW input!
- wats the cheapest way i can get my 1.8t a4 to beat my buddys 98 328
- will a hks ssbv mess up my 1.8T a4... or is there any other bov that i can run safely
- I'm thinking of re-badging my car
- i know this is random but...
- Quattro Transmission Rebuild?
- Tiptronic Loose shifter repair
- HELP! My car stinks! Literally!
- how important is an anti sway bar? .......
- just got back from saratoga (JoeyT's)
- Am I the only person who likes white wheels?
- Transporter 2 - - Audi is coming up!
- b5 a4 vs e36
- Harsh Start
- Tie rod ends, OEM vs Meyle
- Maximum wheel size that will fit.
- Part number request:
- Can I connect the e-brake line of a Greddy TT to the clutch swith instead?
- Ok Photoshop guys, new sig please.
- looking to buy a '99 1.8T- need advice on potential issues
- If I pull fuse #7 and disable my ABS module. . .
- Some quick help... PLEASE :0
- Anyone have a used Tiptronic shift module from a 98 0r 99 A4 that they want to get rid of?
- Audi owners in Germany are trying to get into the Guinness Book for the biggest group drive
- A4 Leaking Power Steering Fluid (Hydraulic)
- cant decide (updated new pic) with old post
- I dont remember if this is allowed or not, but am i allowed to post anything to sell?
- Price check on my Audi please
- New pics from a drive to the mountain this weekend.
- As you can se there are two wires that I dont know where they belong "brown and purple"
- My AIR-BAG light is ON!!!...??????
- Tein Coilovers, Timing Belt, Oil Cooler/oil change..Eurocode Tuning.(Longish)
- Fog Light Mod 96 A4
- 96 - 01 Coil Springs??
- 2 blown speakers...worth changing myself? or something for a pro?
- Can someone help to fix an ECU chip's checksum? I can email you the OEM and the chipped file.
- leaking fuel... right rear tire anyone with experience chime in.
- Why the ABS not under recall?
- been away from the b5 forum a bit....any groupbuys going on?
- Springs ??? My car is TOO LOW!
- two different monting positions for the lower rear control arms?
- Got Purems snub mount.....True or False
- A sunny day in the UK with some beer and a bottle of meguires :)
- ZING! , that was a good one....ATP hits at APR without throwing names around!!
- looking to get a new car?
- replace broken driver's side speaker panel
- Car won't start after short trip ('98 1'8Tqm)
- My Newest mod finaly finished
- Just when you thought the bowl of rice was small
- Ignition troubles
- steering/combination switch stuck
- cant decide
- Anyone in Indy with a Vag-com that could help me out quick?
- What is the meaning of round sign with mpg written in it?
- WTB: Unmodded A4
- I'm in the middle of replacing all the control arms. The new upper arm has a slight curve instead
- Parts list for 2.8 water pump and timing belt repl
- (Edit) ok, current score - Aaron 1/2 Audi 1/2
- Ok, where to get my timing belt changed in Southeast CT? Any recommendations?
- quick question: any North Dakota residents here?
- NE1 know the size of the socket head bolts holding the rear brake carriers?
- nice cleanup ghostrider
- XPOST Need help from anyone with a big Turbo kit...
- Anyone here do a Dalhback crate engine???
- Tossing the K&N in the garbage...
- Is there anything else I need to install milltek exhaust?
- My EPC light came on 3 times today and the last time the check engine light came with it.
- cheap downpipe?
- Well, the guys at the local Audio place couldn't get my radio out..
- power steering and rack problems
- Well, I'm finishing up the EVO and getting ready for the next project.
- Paging JoeyT. . .
- who is going to H2O?
- having real trouble removing the radio..
- I found that I can use the SS brake lines I bought for the stock calipers w/ Boxster calipers...
- Finished clearmask 3m Aeroguard kit...
- economy track wheel setup I was thinking: 17" flik Lex (18 lbs.) and toyo t1r
- breyton spirits and ace allure wheels
- How do you know when to change the timing belt?
- Word to the wise: Be really careful when doing the DIY smoked taillights from the tech section
- Looking for a pn for clutch pedal pivot bushing. The plastic bushing.
- Anyone try the PBR metal masters?
- Feel free to flame!!!!! Just some pics of my car the way it sits now.
- common problem?
- what are my chances of a cheap shop press from Harbor Freight working for front wheell bearings?
- does this pump look shot?
- will a flywheel from a 2003 passat 1.8t work in my 2001 a4 1.8t?
- Stranded - headlights will not turn on. PLEASE HELP
- Warning & Advise Re: ABS Failure
- stupid radio removal question..
- Anyone Selling a Brilliant Yellow, Silver, or Black A4 2.8 Quattro 5 Speed in CA?
- for those who have ordered from clairparts...
- would you guys agree that shocks should come before exhaust---->
- What should I do to the engine next? 2001 1.8t Quattro
- Clunk from tranny...
- aright guys, need everyones input...
- Strange Tire Wear on 17 inch 225 tires
- OMG, this A4 rawks on gas mileage!!1111one!!
- 300mi... and I probably have 30-50mi remaining in the tank
- someone just told me my front diff was shot...
- Shvt. Bye bye RF CV boot. Looks like its going to be a messy weekend.
- AutosportWerks Installs...
- changing steering wheel
- Rear wheel bearing replacement question (pressing cylinder ideas needed).
- euro stretched tire look, why is it bad for suspension? uneven tire wear? 17x9.5 w/215/40/17
- cylender 2 misfire...
- starting the heater core tomorrow.. some questions
- Whats the most expensive single upgrade/maintenance you've done?
- mysterious grant....way OT
- Two updated outer tie-rod ends from my dealer (no bolts), $106 out the door, - should I?
- brakes are acting wierd...
- Anyone going to see The Transporter 2 tonight?
- DTM Wheel/Tire Package Group Buy! (18s for $1350 & 19s for $1650!)
- how can I add a 20gallon seccondary fuel tank to my Avant?
- and away she goes!
- has anyoned tried this before/ did it work?
- Planning replacing stock clutch. good idea to change tranny mounts as well?
- Scratches
- Windshield Upper Gasket
- BSK Thunder stealing: Weekend Mod plans?
- Whats a good electric impact wrench for changing wheels, say for track use.
- Just wanted to thank everybody. Car is back on the road with a new Timing Belt.
- GT2X with PES T28 chip...
- Paging Q-frog .... Can you find any info about the roof rack rubber booties? Thanks!
- Has anyone used ATF mixed with dino oil to flush an engine?
- anothersilver: your roof rack part number
- So I think i officialy amputated my lead foot....
- Some advice needed for a friend with a 1.8T A6
- Ignition sticking
- Anybody got a stock ECU they want to get rid of? Or trade for my APR nDBW box?
- A4 1.8 Turbo Quattro Boost problems??
- Experience with HopUp Racing
- exhaust shop troubles..
- so i went to ask a few questions at the muffler shop.....
- still have the check engine light on, i have no clue what the hell is wrong?????
- what would you guys say is too much boost for an automatic?
- drive on a tire with damaged sidewall
- Whachagonnamodthisweekend? Head start for me: NGK BKUR6ET + Stratmosphere HB DV = monstrous power
- Quick check, 2001 1.8t engine code is AWM????
- REMINDER: BROOKLYN MEET TOMORROW
- ----> EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help)
- what happens if u bypass the n75 and connect the hose form the wastegate to the turbo intake housing
- Some Pics Of My Avant
- I've STFA, but still ask; any good alternatives to the pricey Ice Link ipod Adapter?
- Finally!! my travels have found me the BG source/warehouse!!
- Oil weight recommendation in SoCal.
- question...dealer is replacing engine under warranty
- What FPR with GIAC P-16 file
- For those of you living in one state with plates/license in another...
- OMG..... too much music to listen to with my phatbox now
- Stealership quoted me $2500 dollars for Clutch, flywheel, timing belt, and radiator...
- Paging Qfrog ... were you able to find any info about the roof rack rubber booties?
- RS4 DTM's
- how much would....
- Question about TB and intake hose connected to it. . .
- Boston Fish Pier GTG - Wednesday September 14
- How much should it cost to replace a headgasket on a 97 12v?
- Where do people buy Pagid, Ferodo, and Porterfield Pads?
- How much should it cost for the dealer to replace the valve cover gasket?
- Does anybody know where the vac lines are on the vw 2.0 engine?
- GAIC chip?
- You guys seen this vid? Stage3 A4 Vs. Stage3 S4..
- Help... low fluid: Power steering line leak vs. bad rack (details inside + picutres)
- 17" wheels, big brakes?
- What's the engine code on a 2000 A4 1.8T Quattro 5spd?
- quick oil question...
- is there a place that sells a kit to fix the foglight tabs/brackets??
