- Repainting lowers
- Remote Fob from 1st VW parts.com
- When replacing the inner CV boot is it possible to do it without a press?
- OK small things that need to get done (losing boost / cell troubles)
- Help!! What does this noise sound like to you??
- I'll be damned... he has one..
- I wonder, is anyone here selling their A4?
- If I needed an AWP short block,
- Will a non-autodimming rear view mirror fit my 00 A4?
- Mistake using all-seasons in winter for first time in 6 years...
- Is there a brake disc wear light in a 99.5 A4 2.8L
- I've searched & searched now need help - P1545 code preventing TBA
- Issues with Pure snubmount
- a few problems! signal lights, engine light
- Poll(e): Will we ever see a dyno of the SC'd 12v/ has it already blown up?
- ATF Fluid Temp
- I can't STAND how my car lifts one rear wheel up and spins when i pull into a driveway.
- raceshopper.com rotors? Rears @$22 each... anyone buy from them?
- Say goodbye to the ricer.....
- where's winter? I'm still on summer rubber. I want some snow!
- What makes the turn signals automatically return?
- 96 12v V6 A4 Performance options? And don't tell my Motor Swap, I know! LOL...
- Note for future reference: S4 seats arent that hard at all to throw in an A4!! (1.8T)
- Is an S4 muffler the best choice for my purposes? If so, where can i find one?
- What do I REALLY need for a clutch replacement?
- Airbag Light Chime???
- Idle Problems
- Tire question, a little OT . . .
- ATP Findings on my Fuel Pump
- Where is fuel cut on the stock nDBW ECU? 10psi? And does it just kill the injectors? Or spark?
- When harassing noobs gets old...
- Quick question on repairing headlight combo switch
- DTC P-Code system (good for troublesshooting vag codes?)
- BSK auf Arbeit 2005-04-02 09:30:19 (97463 views)
- I spent 20 mins on the phone with wiseco today (frogblog)
- My Wednesday night:
- Nice weather leads me to believe i have an exhaust leak...
- So I stripped the rear diff fill plug....
- Never sell anything on audizine.
- Audi Announces Record U.S. Sales During 2006....
- Exhaust manifold is off. Piece of cake. Is it safe to run sandpaper over the gasket surface on...
- New vacuum line from intake to 710 valve, car seems faster.
- Day 2 of Interior Upholstery Project...
- anyone need a new southbend ofe clutch pressure plate kit?
- For those curious how I attached the Hella fogs to my bumper....
- Does anyone have an HVAC blower fan they would like to sell?
- What weight capacity jack/jack stands do you own?
- Ugly A4 of the day award goes to ...
- Any difference between front and rear Boxster 986 calipers?
- Warranty Company is only giving .5 hours to remove ABS Module and Audi tech says they need more.
- Does anyone have the Ekta diagram for the stock DTS-like bar?
- water temp in not-so-cold weather
- Strange rattle/banging when starting in first gear 97 A4 1.8TQ Automatic
- Black wheel search...
- Anyone have any interest in a center vent (Opal Gray color)?
- Anyone got a picture of the clips that hold the radio in place and where they are located?
- Anyone in need of a AEB head?
- Day-crew repost...need some help
- Spotted this on New Year's when I was visiting my fiancee'
- Can someone post an ETKA diagram/#s please...
- Ahh, another small around of parts ordered...
- intake? 1.8T
- chipped MTM P box on ebay
- Steering Column U Joint....does it exist?
- What to do before CPO is up?
- did cursh change his name?
- Cruise control not working...
- APR Holiday Sale Ends Today!
- Hella Micro De daylight pictures and up close...
- Got GIAC'ed
- Got It ! successfully removed dropped item from center vent
- Anyone know where I cant find Split CV boots for my 99.5 2.8L V6 30V FWD.
- Considering buying some items from APR's site...
- audi 105k could it hold doing a little somethin somethin to it?
- Neat: Audi's new luxury cars engineered on Linux
- Does anyone have Tom Ritts contact info?
- Jan. 1st no emmisions testing in my county. Anyone ever take a broom handle to clean out their cat.
- looking for some new fuel injectors...
- Finally got my car VAG'd...help me out:) Where should I start?
- anyone ever heard of these guys?
- Misfire Cyl. 2 Detected...
- how can i tell if my radiator is still good??
- Can't find a replacement speedo cluster with trip computer, anyone have good parts info...
- Where is Lower radiator hose on 2.8 A4 Q
- Insufficient Catalyst
- window moldings bubbling
- 468 miles down...I'm beginning to do some 1/2 throttle runs up to 3rd in stock mode...
- borla is too loud, thinking about an s4 muffler
- May go to DARK Side ,the Jetta & Passats deals killed by CARFAX ,found BMW...
- I am so excited I went out and snagged some pics to show the new lamps...
- How do you remove the posts in the seats for the headrests? and i found why my heated seat wasnt wo
- 2007 is kicking off with a bang...
- anyone know if your camshaft position actuator was going out would it..
- Sooo what engine is in a 2002 Poonetta?
- yay or nay headlights
- Wet Driver's Carpet
- Flooded battery compartment - now won't start
- Anyone got the specs for a 99.5 audi a4 2.8l 30v V6 Stock. like max speed and max hp output
- Lost my radio code...dealer dosn't have it...what to do?
- Day 1 of Interior Upholstery Project and a question...
- Anyone put in a B6 expansion tank? Think im gonna.....
- How can i check the fuel trim on my car?
- My Clutch is slipping after 118k...
- anyone have an idea of how many hours an independent shop should charge for CA's and TRE's..?
- Chipping
- all weather airbox mod...part 4 of my intake mods.
- cupped tires vs. wheel bearing: easy way to tell the difference?
- Central locking problems....can some help?
- Carbonio intake owners: What to use to clean foam filter?
- Chrome mIrror Caps
- Smoked Headlights and Tailights
- Cross post about MTM II SW...
- paging cursh: question about one of your previous posts
- TIP will not engage.
- New wheels for summer.... 17" DTM RS4 replicas from achtuning... what do you think?
- My New Years resolution.....
- :: ECS Tuning :: Annual Holiday Sale Ends Tonight @ Midnight !!!
- Everyone here at AWE Tuning wishes all of you a Happy and Healthy New Year!
- Start the new year right with a clean widebody
- Anyone ever successfully fish anything out of the center air vent?
- Was the similarity pure accidental
- I wonder...
- FOLLOW UP....... Just got car back today... Need help!! ..... FOLLOW UP
- Rotors... replace?
- Turbo Exhaust pipe blown off
- De-carbonization?
- It's back - Gas tank leak
- Located the leak
- Clutch gone bad ...
- OK, here's an update and a question...
- How many ATW owners are running a testpipe nowadays?!
- saw a white a4 with euro front tag and (maybe) s4 bumper....
- 333.2 miles down....157.8 miles to go....
- Price check -- 8d0907558m (nDBW) ecu with APR 91oct program...How much is it worth?
- Test Pipe Installation
- Anyone put sub in rear deck or rear armrest space? Pics?
- Do I have HID Headlights?
- visiting from the UrS4 forum with a question....
- which relay is for the fog lights? tech article is wrong year...
- Pic of new $649 V-Maxx Coilover Kit...
- Does anyone remember?
- just found this vid, not an audi.
- this is interesting...
- Happy New Year B5 forum!!!
- Anyone near New Haven CT, want to help me fix my car????
- Fuel pump kill switch. Realy needed or not?
- Replacing the stock throttle body to a new bigger
- Valet lost the door unlocker part of the remote. Can I get any remote so long as the numbers match
- 211 miles down......289 to go....
- somethings wrong with my temp gauge...
- Anyone have an extra stock Opal center vent?
- The 'dreaded' tiptronic trans!
- Engine running below normal running temperture.
- Parting out AEB engine
- Thanks to everyone.....
- Ok just double checking (oil filter content) Big kahuna vs the world
- 034 snub mount with bracket question?
- can anyone help me find the thread dealing with APR software reverting / resetting to stock? (more)
- I've STA, but can't find a link to a complete parts list.
- Excessive Cranking... Plugs? MAF? Fuel Filter?
- 2000 1.8TQ Tip 87K for $6000, clean, all stock with no service records Yes/No?
- Why me? Why? yet another costly repair (yay)
- requestion: do any online parts suppliers sell a driverside rear wheelbearing and hub as one unit?
- VEGAS BABY!!!
- last day to post -- who will be the top 5 posters this year?
- Survival of the fittest/best prepared
- Motodyne?
- Can I check my engine codes?
- Advice on K03/K04
- Secondary Air Pump
- A certain Edwin's A4 seems to have made reader ride in eurotuner this month.
- Yippers - Looks like hasenpfeffer needed you....
- Couple of Winter Mode Pics with the new dslr...
- Airbag BT: Are there any well known issues that cause the airbag light to trigger, esp for the
- Zeitronix and RPM input???
- Yeah, I'm new...
- I need injectors for a 96 A4 2.8... Any idea where I can get them cheap???
- Cost estimate for B5 windshield replacement
- The Clutch is in!
- VAG codes
- Going to seafoam...
- Loss of brake pressure?
- 96k mile valvetrain 30v.
- whats the large diesel oil filter you can use in a pinch?
- Cant decide about a sway. Little help.
- Most annoying install yet.
- Temp Gauge has mind of its own, help!
- After hours of waiting at Meineke, I finally got my APR exhaust installed. Sounds good
- Fix problem on Audi A4 1,6 -98 AHL. Speed sensor G28
- Cross-post from allroad board - Charleston, SC GTG...
- as I was leaving from bar, I started car and after a few minutes of warming up it died
- Need a repair shop in LA.
- 99.5 2.8---urgent quick question.........
- Audio n00B: Need help wiring the metra kit 70-1787 to the factory '01 Symphony Bose harness...
- Difference between an A4 and Passat AEB engine head
- Oh, boy......Tein SS vs. Pss9 coilovers.............
- Problems with 97 a4
- Aluminum BBK brackets are cracking, what are the steel alternatives?
- Feck it just happened so quick...
- So turns out that my Bailey DV gave out today during my spirited run with a friend through the area
- woot for wifi at panera!
- X-Post from Wheels and Tires discussion about lugbolt size...
- Pumping sound at back of car, could it be fuel pump?
- ahhh its good to be me(question inside)
- where could i get my car to pass inspection with tinted windows in the north jersey area
- It's official. My A4 is no longer *my* A4. *sniff**tear* (BWW)
- High pressure whine near passenger's rear tire/gas cap?
- Pics from Essen Motorshow in Germany
- Don't miss out!!.........FREE UPS shipping from AWE Tuning
- With 3 days left on my CPO....
- Just in time for the weekend: Boost leak! Only making 5psi =(
- Red engine temp light beeping
- Lower door molding strips on A4 - suggested adhesives ?
- Anyone use this Used Parts place?
- Vibration at 70mph
- Upgrading intake, IC etc piping is it worth it? 2 questions inside, thanks.
- fvck it.. i'm ordering a dts...
- Positive Buyer Feedback
- AHHHHH.... new stg3 clutchmaster kit slipping 30 days after install...
- M3 lip spoiler stolen =(
- correct me if im wrong. A8 front upgrade will not fit behind 15'' stockers?
- should i use silicone on a new lower oilpan gasket?
- Any common reason that an engine would start running a lean gas mixture? 97 2.8 qm
- FREE UPS shipping from AWE Tuning......time is running out!
- 1999 A4 1.8T Cruise Control Module...Anyone know the part number(s) that will work on this model?
- Help! Something draining battery
- Does S4 suspension fit on A4
- Stock Quattro Avant (Tdi) (UK)
- Recommendations for Performance Chipping
- 6MT transplant B5 A4 1.8t
- front pipe broken after cat - what are my options?
- The 2871R is on the way (more)...
- HURRY!!! buy 1 ($19.99) get 1 free of valeo ultimate wiper blades
- Mandeep, got the package YFF!!
- Pumping sound? Air compressor?
- Pumping Sound .
- I got my tires swapped onto the 4.2 Sport Wheels, and the GF gave me my christmas present today . .
- STaSIS Motorsports Signs Daytona 24 Hour Champion for 2007 SPEED World Challenge Touring Car
- Engine might be dead...help if you can AW:) *hey whoever remembers me**
- Help.....car won't start
- Paging IAmAwesome... got a call from work saying that your package arrived!
- One wheel spinning in snow
- Long to do list request audi specialist reference
- Also, what kind of inspection is needed for a sawy install...
- Listen up n00bs! This is why you always, ALWAYS double check your work on the car
- Good idea or bad idea? Fogs
- Broken front spring - how difficult to replace?
- KMD Tuning/Dahlback Programming: Definately NOT RIGHT
- Freaking A!!! I think my Alternator just went out on me!
- Any help appreciated
