- s4 h&r coilovers FTMFW!!!! I love them
- Just sold my car
- Need a part...can anybody help?
- k srsly my car is being weird... and joeyT i don't think it's an intake leak
- My whore let me down... Fuel Pump content...
- I had a nightmare where i was driving a stock 1.8t chicktronic
- Larger throttle body...
- Will a B6 a4 k03 sport fit a b5 without changing any parts?
- Coolant leak, what's it?
- I really need to sell my car.
- Out of curiousity, for those of you who have considered getting a B5 S4....
- BNIB: APR Boost gauge!! Yay!
- does anyone know where i could get s4 parts?
- part no. request: engine speed sensor for awm motor
- 1.8 ticking noise FOUND! WTB k03/k03 sport (used)
- So now I have no boost at all. Has anyone had this code before 17963.
- 2.8 30V coolant bleed question...stripped bleeder screw....
- anyone have a new front 02 sensor they want to part with =)
- Been awhile since we've had an update on that building being erected in AL.
- Should have the DIY 4:1 center diff in the car Monday....stay tuned...
- im in my garage with vag on... what can i log/check to figure out my issue?
- NEED HELP! Flashing check engine light...
- is there still a market for oem lower black door moldings?
- K04 install hardware questions: What size are the exhaust nuts? 8, 10 or 12mm? Also...
- Paging Ray Khan to the bat-phone ploz.-->
- Is there any Heavy Duty Input Shaft for 2.8 Tranny ?
- Anyone here heard of a Borg Wagner e05 turbo?...
- Ipod-Itrip question..
- 2 Koni B5 A4 Q Coilover kits left at $900 shipped from Achtuning!
- I'm at the point in the TB change where the crank pulley must come off. I took the 4 allen bolts out
- Bittersweet: Just received a deposit on the Avant..... happy/sad day.
- v v The Picture below reminds me of something (Temp guage)
- I should have turned the flash off, but I was on the NJ Turnpike at the time...
- Kudos to Kris Hansen, again, for his heater core tech writeup
- Help: Preparing to go gt28rs soon, checking on list of musts...
- Anyone have the Blitzsafe iPod adapter? Where did you mount the box?
- Does anyone know where I can get a "consolidated" chip for a gt28RS on 93 gas...?
- Opinions: Tecnaut Autobody in Elizabeth, NJ?
- front seat guide replacement on a manual leatherette 1.8tq
- The turbo gods called again...
- Is this possible? or an explanation
- So your car is fast. What are your 0-60 times?
- Had a massive boost leak on the GTI. Check out this slick forge DV made for the 2.0t...
- hey Mandeep... looks as if your N75 didn't stop my bouncing boost issue :(
- A8 wheels will they fit? i bet they are heavy . . .
- Apikol mount install....
- QUICK QUESTION
- Mr. Sprague you're one of the bestest:) Thanks for the badges n sorry the wg wasn't the right one!
- Local paper 1999 Silver Audi A4 Avant quattro 177k miles.. $1,800 - can I get an Amen
- anyone know what nut is on the engine mounts? size?
- Final HFC Question
- Blackstone oil report: would it indicate sludge?
- OK, if removing the center makes a 2.8 too loud what's a decent alternative...
- where to get MAF cleaner?
- Blowout pricing on TRE's and control arms!
- Dash Removal
- Block.
- What's the best place to get a stock new or rebuilt ECU?
- What would be the biggest rotors to fit our stock B5 1.8t rear calipers?
- Check out this amazing new bodykit!
- looks alone. which of these two wheels would you rather have?
- After market alarm wiring
- Damnit!!!! why are my manual tranny drain and fill bolts DIFFERENT?
- Does a B5 Passat use the same stock injectors as a B5 A4?
- So... Kinetic wants a 20% restock fee for the K04....anyone need one?
- Anyone know how to fix a weak battery in 5 mins?
- So the car is acting up again...VAG-COM scan inside..
- Headlight Problem: Referencing the JoeyT repair. Can I buy a new plastic contact slider? more...
- Anyone have a 3 bar FPR or adj. FPR to sell? My friend needs one.
- So... my car is in the classifieds at a little lower price. So sad - I hope my friend wants it:
- Speaker sizes?
- ive been messing around the secondary air system and noticed a potential performance issue with it.
- Started listing parts off of car.....
- From off topic - but it's really ON topic here: Interesting tid-bit on fuel tanks--->
- Holy crap, has anyone seen the Woot of the night?
- Dave 'n Doug: YGSM comin' your way!
- Need some help with the codes...
- BT BT ( Big Turbo Brain Trust ) Or WTF was I thinking?
- anyone use schaeffer oils? recommendations for moly trans & dif, 9000motor oil
- Fixed all the pics in the FAQ for the strut bar tips/tricks post.
- Timing Belt Job
- Blow off valve in 98 1.8 Quattro
- VR6 TB on the 1.8t
- So..........well......... if i wanted to sell the Avant pretty quick what would be a good price?
- Please help with some boost issues..
- Two Milltek 2.8 catback exhausts on clearance at Achtuning, $849
- lemmiwinks question...
- help! coilover install.. how to get front shock over lower control A arm?
- Anyone know how much a new steering rack would be for a 96 12v? TIA
- San Diego area GTG Monday, 11/5 @ 7pm
- Compatible ECU B5
- LaBree or Techtonics HFC w/ stock exhaust? Do I need a reducer to fit the stock exhaust?
- HEY MICA!!!
- wait a sec.. if silver got his package today.. that means APR got their package today
- I can never remember...Are negative #'s in Block 32 rich or lean?
- Typical Peak MAF on a GIAC chipped 2000 A4 1.8T?
- With this I'll be on my fourth Throttle Body so far...
- 99 a4 quattro engine swap?
- CV Joint Replacement
- Yes/No? Leaning yes =)...
- Anyone have a JL stealth box they want to part with?? Bassed...do you still have yours??
- Anyone parting w/ a 93 octane mtm stage 3 chip for manual ndbw w/ k04?
- Just to twist the knife.... my RS4 grill arrived today....maybe it will fit my truck *pulls trigger*
- Thanks. I'll try it out later tonight.
- What triggers fuel cut on nDBW's?
- Clutch Upgrade
- Anyone have a good pic of the underside of an A4 2.8 Q?
- ETKA pimps:
- Car insurance question...
- reuse rubber lower oem spring seat, or get a large washer? coilovers
- anyone in irvine want to help with a coilover install today?
- Poll: S4 or A6 either with 6 speed 2.7T or just get another 1.8T A4?
- HELP!!! anyone need parts from an 98 A4 Quattro 1.8T 5 speed? Before they total it!
- must... resist.. urge.. to..
- Here's one for everyone, fog light mod has mind of its own?
- Anyone know of any tire deals going on right now online? ALSO...
- Looks like my immobilizer is dead... any help?
- does anyone know stock ride height fender to the ground? sport or non-sport.
- Stolen Xenon Headlights
- Brake question
- Paging Nate,found out one of the 3.0 parts I bought is an A8 part
- Are there codes to identify the interior colors?
- CRITICAL......
- Car Starting Problem
- What the heck is this and do I need to hang on to it?
- Anybody have feedback about GRD tuning in Chicago?
- steering pump (i think) is driving me nuts..
- HELP!!!
- Score! There was a class action settlement with the dealership I bought my A4 from
- WTB - KO3 Sport Turbo
- Went and checked out a "land Rover only speciality shop" today..... I am teh glutton for punishment!
- Chip for '01 w/o upgrading exhaust...?
- Symphony in dash CD player gunked up
- Can anyone give me a hand w/ a part #.... 8d0201991d...?
- bahhaah dealership officially knows about my car...
- Well im still getting misfires after replacing the plugs.
- Can anybody help
- wowe! let it never be said imawesome isn't tactful!also paging silverstreakin
- New DTCs with new ECU: 18021 & 16985.
- Is this a transmission leak or something better?
- has any DBW guys replaced their injector inserts?
- P-Flow intake
- Is there a point to get a C16 or 110 leaded tune
- Hey TUMBO..you need to make a movie like THIS! >...
- Coolant flange leaking after replacement
- anyone looking for 18s with summers? REs have always been a fav of mine for a classic B5 look
- New Website Launched....
- Help ordering paint
- Leaky door lock actuator. It whistles when I lock the doors..
- anyone have the vvme ebay link?
- Help: Passenger footwell and red door light stopped working
- GDMFS... NO ONE has bentley manuals in paperback form.
- Last call for Boston Area Fall Finish GTG tonight!!!
- What is the size of the main crank bolt on a 2001 2.8 24mm or 19mm 12pt?
- Well.. ping city.. low pre boost RPM and high RPM ping at near WOT.
- A movie about my AUDI A4
- Paging All AW Masters.
- iPod Integration for 98 A4 wagon
- New 2000 A4 1.8T suggestions
- Got the LC-1 and DB guage all in. Calibrate it hop in and go for a spin only to.....
- what makes tire look like this - does it mean it needs lotion it looks dry
- Replacement part # for 4D0 905 351 ICM
- Brake pad question
- Check out this A3.
- What would be bad about using nitromethane in a methanol injection setup?
- Slight rattle from suspension???
- 2001 A4 Lim. Quattro 1.8t
- So.......I think I want a Saturn Sky Redline.
- Making Progress... Slowly but surely
- random part number of the day: door lock cyl lube: G052778A2
- Is anyone running an oil-cooled only turbo (other than GT25)?
- UPS paid me a visit while I was gone...
- stereo fitament?
- whats the login for partsvoice.com that was posted by carson?(i believe)
- Monster Mats for pre-facelift B5s?
- overboosting, wastegate? fuel regulator?
- Testpipe Installation on AEB
- Repost: Question about wheel spacers?
- I don't think I want to de-mod the Avant - think someone will want a 1.8TQM Stg 3 Avant for a good $
- Well i just installed my MTM chipped ECU and I'm misfiring like crazy on cyl 1 &3
- Will e-bay vag cable work with ross-tech software?
- can you say sludge?
- check out my response in this AZ poll.
- Looking for "transmission FLANGE"
- how many litres for power steering system ?
- HUGE props to 034 Motorsports!!
- Im getting flashed a lot..but not titties =). am i supposed to reangle HIDs down when installed??
- YAY.. my car is getting vinyl! should be done tomorrow.. pics to come =)
- has anyone modified their front doors to accomodate 6.5" speakers? pics please
- fuel mileage question!!please help
- Changing my plugs and found white powder around coil packs.. what is this?
- interesting tidbit...regarding flow of stock panel filter
- Im looking at getting a wide body for my sex machine but didnt want it with my
- Turbo Boost.....HELP
- Pole: Best place to purchase a VDO boost gauge?
- got my car back from the shop.....
- any reason why the throttle body cant be rotated 90deg?
- New Headlamps
- Barn time: If yer interested...
- Another HFC Question (Regarding stock 1.8T Exhaust)
- We have any good Audio guys here?
- First Drive =) (longish)
- :: ECS Tuning Launches Dynamic LIVE Inventory System !!! ::
- Are my inner tie-rods fubared? I have a new clunking noise when I turn the wheel back and forth
- Installed Stern rear diff mounts/JE short shifter/034 motor/tranny mounts this Wend
- weekend mod summary...
- Used A4 for my Son
- EV12 style injectors????
- HAHA whos seen the new lexus commercial?
- Is factory exhaust on 1.8T
- So my front driver's side axle appears to be borked following that incorrect-lugnut debacle
- zomg! ----> this post has pictures!
- Need help seriously, Missfire Cylinder 3...
- steering pump noise???
- Has anyone used o2 sensors by Ceradex?
- Plummenting A4 value: results so far for my "for sale" A4.
- Washed up, in and out today.. it was about due
- Tiptronic Chip question..
- Guess what.......
- Poll: Should I shave my rear door handles?
- so now to look into tires... the tire is chose but the size isn't for 17x8.5 wheels
- 370miles, 82 mph avg, 27.4mpg, one tank of gas each way.
- upper control arm grease.....
- Just got back from the VW/Audi Show & Go at Englishtown. Didn't get as many runs...
- Question on 4-wire oxygen sensor heater circuit resistance
- whats the best sounding exaust i could get for a 2.8?
- Where's QFrog been?
- Why are SSRs so damn expensive? Tirerack sold them for like $300. Now they are $600?
- aaaahhhhhhh....oil change, air filter, seafoam, new plugs.
- Milltek exhusting "stretching?"
- What to do with stock exhaust....
- Cheapest High-Flow Cat?
- xpost starter repacement help
- I heard someone makes a box that fits in our car?
- F#CK DEER!!!
- sunroof tool - 1997 A4 quattro
- Anyone seen this before?
- PES G2 n00b QUESTION
- Need some help/suggestions: am running rich at idle
- x-post fix for your instrument cluster
- Has anyone had their timing belt break before. . .
- Neuspeed .8 bar chip FTL
- high beam bulb wattage
- easy to swap a b6 or b7 steering wheel into our cars?
- New toys
- Bassed when are you heading up this way to Unitronics?
- HFC=Techtonics or Labree??...(going to be used w/Borla cat back)
- Does anyone have an extra 557p ecu they dont need? I checked classifieds and didnt see one.
- update and Silverstreakin, myself and another local buddy went out for a cruise....
- No forward or reverse in 97 A4 1.8t?
