- "Weekend Project": Oil Filter and under-car inspection
- Anyone with H&R\Bilsten sport having trouble going thru automatic car wash?
- Help setting 1996 12v readiness!
- Well guys...since I no longer have a pelican.....------------->
- i haz!
- Paging Nononsenseikcal Axisisisis Joe: I have a need for some stuff ------->
- *rally was here*
- Those of you w/ Boxster calipers and A8 rotors... question within...
- Oil in my coolant. A4 1.8 Non Turbo
- looking for the part number for the a/c condensor for 2001 1.8t....
- Euromesh wheels on clearance at Achtuning, $899-set!
- Vibration in the front of car when accelerating . . .
- Exhaust is falling apart
- Interesting gas find...
- Coolant flush
- Anyone have an extra rear diff mount laying around?
- Vogtland Springs on Sale! V6 FWD
- 1.8 thermostat
- Rear Suspension Question
- Is this timing belt estimate as bad as I think?
- tried out my camera mount on the A4 / made a quickie movie.
- The Power Steering Resevoir location?
- Knock sensor readings during a redline test
- i think i nailed down what the rattle is, which coincided with my exhaust install.
- O2 sensor questions
- lowering suspension
- Any wild and crazy suspension deals at Waterfest? I need new shocks and springs
- The A4 may be getting up there in age but at least the KM's are going by slowly!!
- Well guys, the A4 is officially no longer mine. I signed the Title over to the New owner today...
- Anyone who has trouble with windows not opening
- need a car cover
- Can the K04 installation kit from ECS be used to install a K03? ALSO---
- T Minus 5 days, 16 hours, 8 minutes
- Bish is running and the drive train is like butter. PA TP and stop and go.....
- This board is really gonna suck when vB rolls in.
- Replace radiator/coolant fan, ATF drain and refill, RS4 grills, and a few photos. Re-post.
- Can someone provide me w/ porsche boxster pads part #?
- ww!! (skip to end... last 15 seconds)... okay who owns the car?
- Grinding and high squeel when I step on the clutch
- Amsoil?
- Vagcom
- Passenger mirror kicked off - new or used? (more...)
- short shifter choices
- Does anyone have the resistance values of an IAT sensor at non operating temps?
- rough idle, mechanic is busy...CRAP
- *Prayer to ETKA gods* PN request inside...
- would a k03 from an AEB work on an AWM?
- Have vogtland/koni and love the ride but want to raise my car up an inch or so. options?
- Vacation Fuel Milage Report
- Off topic, 2009 GT-R photos. Wouldn't mind owning one, they are not too pricey when you take
- actually....Saw a sweet looking late model B5 Avant on 287 north too...silver...
- Baby Blue (not pelican) B5 with chrome wheels spotted yesterday...
- Mike Hood - who can you talk to on the CF stuff that was made for you?
- So.....apparently this.............
- So..........apparently this.........
- A little moment in time.....
- Passenger side headlight ground wire
- What spark plugs should I be using on a stock 99 A4 1.8T
- '01 w/ 80k - TRE seem to be shot - getting a awful noise when turning
- Flogged my (recently chipped) A4 through Deal's Gap Saturday and got the CEL...
- Should I be worried having the body shop fit my aerocatch hood pins? cutting carbon fiber
- wanted; Console shifter cover for 01 A4 Camel Color 5 speed
- Which is the proper filter for my car?
- part number question....
- Thank god the VB conversion is a hoax......
- Battery Light and Other Symptoms Question
- Finished up TB cleanup today...one minor problem
- P0707 Tranny DTC trouble.
- What I bought to replace the B5
- After installing a new pre cat oxygen sensor, the car sounds funny. Exhaust tone is louder and comi
- I'm becoming increasingly frustrated with Audi's parts swapping during summer/fall '97.
- Speaking of new forum formats, I like the new classifieds on Audizine. No bumping.
- FREE 17 inch Avus rims anyone?
- Anyone selling a B5?
- oil to use
- A4 Automatic Transmission_DaveInSaltLake
- transponder in key
- What color is that?
- Rear Window Switches Illuminate?
- Electrical Ground & Alternator "Big 3" upgrade
- They should have let this ad campaign run longer...freakin' hilarious
- so selling used motormounts a new thing now?
- Is the 2002+ wideband o2 the same for the 2001?
- Software needed to swap K03 to K03 Sport?
- ABS Pressure Warning Switch location
- PSA: Change your fuel filter! NOW!
- In middle of TB job , bottom viscous fan bolt seized ...any removal secrets?
- I have to replace my control arms very soon.
- New (to me) seats
- Stereo crossovers: Any thoughts on a nice place to put them?
- Missing OBD connector
- I'm about to do double din conversion on my 98.5. Question inside...
- im off to saw up my old exhaust and bring it to the town dump. </goodtimes>
- VAGKRAFT 2.0 - Sunday August 17th - Powerade Centre - Canada's largest Audi/VW Show!
- 174,000 miles out of front control arms...
- Anyone have a K03 or K03S for sale?
- I have never had a coil fail. Thinking when it would happen, and then it did... LOL!
- control arms
- Seats . . .
- HID question....is it safe to say this is a bad ballast?
- what size long bolts do I need to put the front carrier in service position?
- Cheapest place to get S4 tie-rod ends?
- wow b6 ---> b7 rs4 conversion
- starting the car
- no start... cam position sensor circuit malfuntion
- Woo hoo! Got my car back today :-)
- My seat goes back and forth a lot. Its sloppy. Do you think a seat bushing kit
- Should be a fun weekend....
- is weatherstripping a DIY task?
- Mr. Hansen to the LY9B Courtesy Phone please....
- Kawf.......Kawf.......
- How hard is it to replace the right rear speed sensor on 96 A4Q? TIA.
- Rear shelf speaker size 97 sedan?
- FOB Key Question - How do you remove the key?
- Misfires, shuttering, wrx sounding sputters....flashing cel. uh oh?
- Xpost: Caption contest...
- ABS Controller - Anyone attempt DIY rebuild?
- We looked at that '99.5 Avant I posted earlier; Pulled these codes/some pics. Worth the time or $$?
- Are the catalytic converters the same in the 30v as the 12v?
- Engine Speed Sensor reading
- My set of stock 15" wheels are on ebay and the auction is over in 13hours im trying to get $150.00
- Speedometer problem, any ideas?
- Help with my transmission/driveshaft/driveline
- Where is the speedometer sensor on a tiptronic?
- Paging Kenny Dremel:
- Flex pipe part number help
- Mintex Red Box mystery
- Replacing my Central Locking Pump
- Racetec
- anyone have pics of a b5 with dark grey or dolphin grey paint?
- Somewhat on current topic: Engrish skills not required for RS4 ownership.....
- Since my full race downpipe came thought I would throw up some current pictures
- Is it possible to switch the signal stalk and the light stalk?
- Wheel offset.
- Going to help a buddy go look at a Silver '99 1.8T, MT, quattro Avant. We thought it was
- Looking for rear driver door window motor
- 1999 A4 1.8TQ manual: Instructions for replacing the Ignition Control Module?
- APR Waterfest Sale! - Ecodetuning.com
- Clutch replacement questions
- zomg I just talked to THEE! tom Ritt!!!!!!!
- Testpipe/HFC CEL: 17544 - Too Rich
- Anyone have a stock AEB injector kicking around?
- Couple Lock/Window Issues
- OZ Ultraleggeras in 18" or 19"?? Opinions?
- Replacing my ignition switch this weekend. Anything I need to know?
- 96 12v a4 oil temp gauge intermittent and oil check light has come on..
- Part number of a non-return valve that sits on top of the airbox slightly toward the right side
- whining in the back right of the car
- 1996 A4 Cluster Bulbs?
- testpipes that look like the stock cat
- Happy Ending - was stuck in Poconos last week (Sal saves the day)
- San Diego GTG set for later this month
- mmmmm casavant....
- whats in the box?
- Need help with sisters car.....
- Is my MAF going? (Log Included, High Res)
- Anyone using vw parts in their car?
- "Weekend Project": Coolant Temp Sensor and Vacuum hoses
- who is not filling 91 Octane gas?
- stupid Q, my car is year 2000, 1.8t, does it mean its 150 hp?
- flywheel question...
- which o2 sensor is the front and which is the rear?
- Will Stoptechs with 332 mm rotors have enough clearance to mount under 17" OZ Ultraleggeras?
- Hot wax treatment.....
- for you that track and have adjustable control arms, how much front camber?
- So I fixed my right rear door, but now the window doesn't work...
- BMW build underway
- Trading in B5 2.8Q for B8
- Gunk Motor Flush BT: Why does it say not recommended for turbo engines
- i might cut out of work early :)
- Having problems with raising Vogtland coilovers.
- Clutch replacement pics and adivce
- ohhh yeah, my new wheels are "out for delivery"...i feel like a kid at xmas.
- Is anyone running 19" RS4 DTM on B5? If so, are there any rubbing issues?
- rear deck speakers
- driver side door protection strip
- Switchblade/FOB Key Battery?
- Can I use Mobil Delvac 1300 Super 15W-40 Diesel oil for my V6 30V? Drive in Texas, Short trips.
- New Member
- my ross-tech cable is for sale in the classfieds
- Waterfest sale pricing in effect at Achtuning!
- Cost Thoughts...
- help! I drowned my keyfob.
- Out from the Hospital+Aw's new format= I can not catch a break!!
- for everyone - checked my tires they are made in 07
- Mercedes To Phase Out Gasoline By 2015
- quick steering question: If I turn the wheel with the car off and it still makes noise, it cant be
- What kind of front end links do people use?
- 96 audi a4 front bumper and bumper support
- While looking at the 1.8t AWM today with 52K miles on it
- doh. T-belt in my old car apparently snapped after 40k miles
- causes of engine failure in a 1.8t?
- RE: STFA: Loud hissing and suction noise under WOT...fvcking h3ll
- Anything else to log to troubleshoot slow caps times?
- Just got back from a week in Beijing... Audi has invaded!
- Any experience with BFGoodrich g-Force Super Sport A/S tires?
- Stupid Q, but may have the answer to my slow caps times... What gear do you run it in?
- Ok before I dig into this problem I am having, some white smoke after idling comes out exhaust
- Full Oil Change Kits Now Available!
- How can I know my car is a 150 or 170 HP?
- Ok noob ?. What is the filter behind engine (1.8 AEB) close to firewall for? What does it do?
- Picked my car up from ASP : GT28rs Kit installed
- Paging: Pac1085........ still have a Holset H1C for parts?
- any input on the "ebay" dvd repair manual vs the Bentley
- Who is debadged except for rings on the trunk? Pics?
- Insurance Question>
- CTS and Burning Smell?
- CPO B7 2.0TQM vs. low mileage B5 S4. Discuss. will xpost to B5S4
- GTRS late spool issue, hit 10psi at 4000RPM and 20psi at 5500RPM
- 1998 A4 Quattro oil pan
- Give me some options re: quick release bumper fasteners...
- a semi-ecological car wash....
- ok.. get ready for it.. full field sobriety #2 in less than one year.. guh.
- Anyone know how wide of a tire can fit on a 4.5" wide wheel?
- If anyone's considering the jump to the new B8, it's a great car...
- Does Bentley have directions for one-piece headlights?
- radiator bt: is replacing the radiator on an 04 passat the same as doing the job on our cars?
- Damn... I was having a heart attack this morning when AudiWorld went down...
- Hmmmmm what is this......
- Decided on the stage 2 cluch from awe...anything else i should replace while its all apart?
- Saturday somewhere in Ohio
- Engine build number infinity w00t!
- Need a Rt. rear caliper, cheapest place to get one?
- shop wants 1600 to change clutch on a fwd 1.8t
- 2 lights on in dash
- The what is my car worth thread.
- ...and we're back?
- changing the left rear abs sensor and appears to be too big....
- Noticed some deposit build up on my intake valves with cylinder #3 being the worst
- PSA: Do NOT evar buy an Optimal (Optimol?) brand wheel bearing!! 3 down in under a year.
- Engine Rebuild Update: Engine Out of the Car
- Does anyone have a copy of that fill capacity table?
- Has anyone registered for Waterfest, either exhibition or show car? I just got my packet in the mail
- Brake Issue! When I come to a stop the last two seconds before...
- Xenon conversion...hit/skip?
- Replacing Temperature Regulator Flap Motor
- Got my VAG! Here is the readout!
- Redline tested my MAF, could anything else be the cause of bad reading?
- How can I test bump?
- How can I test starter?
- Re: "the new V6 in the S4 will be turbocharged. - JAFO"
- *Bump* oh wait
- How many people would be interested in meeting up to drive Skyline Drive in Virginia?
- Had airbag module fixed by BBA-Reman. Installed and still have airbag light.
- Anyone have a sport suspension or
- Waiting for ryan to post up "I GOT MY CAR!"-------------------------------------->
- Fiber image hood shock question (big pic)
- Mystery Warning Light
- When replacing FPR, you dont have to take off the fuel rail do you? I was thinking just pull it off?
- Interesting sound on my AEB GTRS while accelerating under vacuum.
