- So I'm looking at the new BMW 135i and it weighs as much as my Quattro 2.8 ?!?
- How long to change just one side seal on rear diff with car on stands?
- upgrade suggestions
- Blew fire out ma rear..
- Bored with work and wondering about a few gremlins you guys might be able to help me with...
- Update on my old A4's transmission woes:
- cleaned ICV today. wow what a difference! It wouldnt idle at all before i did it...
- big thanks to Carson, package arrived on time and packaged very well!
- ODB communication fails
- Fvck, Audi has THE worst license plate light design
- seems gimmicky... what's the chance of accuracy?
- installing a KO4 turbo, do you need anything else other than what is in the ECS package?
- Just finished the RSQ mod...
- How much pad is left when the brake indicator comes on the dash? Visual inspection
- Stock ecu...What's it worth?
- A.W.E. Tuning Vent Boost Gauge Kits Are In Stock and Ready to Ship!
- has anyone changed their rear diff center seal?
- new wheels to me..
- Thought I would share some updated pictures
- installing cv joint bolts
- Need help with brake installation
- Help with P0352 fault code please, archive search found nothing.
- question time - how much more power can i get out of the gt28rs elim
- replaced concert radio..the screen says SAFE, and...
- Another, "What am I worth post"...
- drivers side front diff seal, anyone know how to replace it
- driveshaft...ujoints? troublesome??
- Lol @ local exhaust shop.
- How hard is it to change the clutch on a b5 1.8t 01.5???
- Speedometer noise question.
- Smog Check Disaster
- anyone have a picture of the back of symphony hu?
- electrics
- Need help with O2 sensor
- anyone have stock fuel lines wasting space?
- Bose Amp problem...(drivers side shelf speaker connection)
- '00 Audi A4 Avant Quattro 1.8t Trans multifunction and Other ?'s
- Any ideas on how to plug a bung for wideband when not in use?
- Help with vac-line diagram. Is this the correct version for a 2001 AWM engine?
- Mint 2001 Black 1.8t manual if anyone is interested (Burlington VT)
- Help me clean my garage.......Left over parts from the A4
- Thinking of going with this BBK... think it will fit?
- 1999 A4 Quattro - Window Motor
- Opinions on Kumho Ecsta SPT?
- block---
- My hubshark has paid for itself already...
- Interior Door Handle - Needs a spring?
- Paging Avant Owners: What exhaust are you running and how's the drone at crusing speeds?
- Rns retrofit
- What do you think?
- Yay! My rear spring broke!
- Woot.... just put on my RS4 reps with Kumho ASX tires on last night
- Is there a better SUMMER tire than the ContiSportContact2 I'm running?
- Spotted Santorin B5 A4, NC plate "APR STG3" (or similar), dark wheels - anyone know who's car?
- ebay concert radio
- Radio flashes between Phone and radio station.....any suggestions?
- B5 RNS-E DVD Retrofit
- Detailed pictures from the crash..
- Alignment
- Cant find tech article for Air Filter Change
- apparently some bad news about my old A4... some trans problems
- Door locks and Keyless entry IN-OP 99 A4
- Replacing Audi 1996 2.8 with 2000 S4 2.7 biturbo
- Help on tightening the front strut mount for Audi A4 00 Avant!!!!
- What are celebrations worth now days?
- new bumper acquired...paging JoeyT
- Sport weather matts........NOT happy with them!!*Calling 4 Carson*
- Editted pending resolution hopefully.
- Getting a jump on the weather today
- Just returned from Germany...
- Opinions please on alternative front plate placement:
- Wheel fell off on freeway....Updated with pics-
- Follow up to my Concert restore project, HU is not working now, long...
- Mr. mom for my bolts that you said can be picked up at porche dealer
- Heh.. funny story involving insurance quote
- Mr Mom, please email me Re: drivers side door panel.
- Rear Wheel Bearings - $400 @ Quattrohaus for both sides parts and labor. I think I should take it...
- 17" S4 wheels on Stock '01 A4?
- how much should it cost for a body shop to repaint/refinish a rear bumper with 20+ nicks/scratches?
- how to refinish stock 17" rims? how much should it cost per wheel if shop does it?
- what is a good place to get a license place holder kit.... my rear is only held on by a couple
- CTS vs Thermostat
- Interesting (Ice Link)
- can't sleep question: if i get a meth/water inject would i need to get a new tune or can i just
- Oil level light on after 3500 miles.... What would cause that kind of oil loss?
- very light smoke from both sides of 2.8L engine when running
- thanks for all the help yesterday with the brake problems - here is an update
- mmart6545... we miss you.
- Test Fitting new track shoes..... Rodger hope the new shoes here quiet you down now:)
- How to bleed slave clutch cylinder.
- Anyone interested in trading a 91 GIAC or APR ECU for my 93 APR ECU?
- Was getting tired of hot air in the intake
- Alright, I swapped the Blizzak LM-22's over to my BFG KDW2's....It better not freaking snow!
- I have sport susp. now. I want to go lower without losing the ride.....
- Where can I get cheap parts!?
- XENON Ballast bad?
- Blown K03...advice needed!
- Radiator Fan Control Unit
- Remove rear Spearer Grille 2000 A4 ??
- So I got a little bored, and I am looking for everyone's opinion...
- While I was changing the air filter, I accidentally broke "evap frequency valve"
- anyone in irvine have a big 1.8t oil filter i could have? i will replace it or give you $
- Don't know how many of you are Christian folk, but Happy Easter to you all!!
- weird Ac fault
- Insurance? OEM parts?
- Happy Easter
- Getting ready to order/replace radiator, have a quick question though.
- Iginition Coil Problem
- 00 A4 1.8T secondary air incorrect flow detected
- were can i get vag-com tool
- super sad brake day =(
- !!! Need some Help, Starter Wont Turn, but... !!!
- OK so I did the A8 front brake conversion yesterday...
- My Gas Guage is Possessed
- I know there is a write up on a clutch swap on a 1.8t but...
- DHY trans code is for...?
- Feeling hot around the lower right leg while driving the 96B5A4
- Is an '99 Avant rear bumper interchangable with sedan? Or are they different?
- Anyone got a link to a TA or know how to replace the rear view mirror (auto dim one)?
- Cleaning/refurbishing leatherette interior?
- What can cause P103 to come up please help
- Had a wheel come off on the freeway.....
- chipping my A4
- Does anyone have a tutorial to remove the upper cat?
- Carson: can I get a price check on the turbo oil supply line. ATW code '00 A4 1.8tqm. Thanks
- Can someone show/tell me where the turbo oil supply line hooks up to the block?
- I wonder what a chip would do to the new 911 GT2.
- Anyone have their stock springs they dont need?
- 1996 A4 TDI 110 - Intermittent loss of turbo
- THERMOSTAT CHANGE 2001 1.8T
- so a guy at the dealership told me my differentials were seaping.
- ECT SENSOR 2001 1.8T
- 1.8 Turbo Pinging
- Whatever happened to the firewall cracking issue?
- help
- Ok... so I am going to drive from NY->FL (forget the train)... the question is>
- My A4 is such a tease. Best I could get out of her tonight was a 14.034@97.78MPH
- transmission doesnt like to shift while cold and when I get up on
- Alright so im talking to the ajuster tomorow about the car. Its deffinetly totaled.
- Changed timing belt...
- How can you determine if the valve seals are bad?
- Need opinions on compression and leak down test results on an '01 1.8T -->
- Early spring cleaning. (What's in your engine bay thread)...
- Gawd Damn Tragedy...........
- Question about changing lower front door speakers...
- Passenger side mirror
- My car
- Any 2001s running HFCs with no CELs? What fouler/build are you using?
- Photoshoped 3 Wheel Options: Which do you prefer?
- Anybody used Neuspeed Sport Springs with Bilstein Shocks and how is the ride?
- Haven't had any luck in the Wheel/tire forum, have a question regarding alignment...
- Is there a walk through for re&re of center trip comp display?
- So anyone have that AWM bottom-end (auto) I guess I may need....?
- help with one-piece clear corner mod!
- Wheel Bearing Noise BT:
- Purrddyy
- what are symptoms of a bad caliper
- Can the early B5 center inst cluster display be turned off 100%?
- Paging Carson.....you working today?? If so...how can I get in touch with you?
- aftermarket headlights with halos
- AWM engine noise (take 3)
- Paint guys...
- h/s pads
- Does anyone need a set of TRE's? I got these with my control arm kit but had already upgraded them.
- One confused CPP TRE, and one stuck TRE... Some questions. (Big pic warning)
- Nice or rice, Euro licence plate for the front...
- PSA - A4 LLTek Stress Bar.....
- Reasons why my car is running rich, GO!
- VagCom: "No response from controller" (address 35: central locks)
- Who had the white sedan at Jenness Beach, NH? Plate read PRA4SRF.
- question for you A4 guys, what plugs should my friend be running in his B5 A4
- How long should it take a shop to install each of the following PLEASE HELP thanks!
- Inner tire wear on one tire. (stock suspension). Pls help.
- URGENT: cv boot clamp
- So whats the cheapest place for me to get a h7 hid kit? is VVME still the best choice? Links?
- how many gallons do you usually fill up?
- Poor doggy! Good thing my A4s rear windows don't go all the way down.
- funny story about e85...
- class action
- Does anyone know if this keyless remote will work for my '01?
- Any suggestion on grills
- P/Ns and pricing for vinyl door trim? All 4 needed. I'm backseating the 1.8T's bodywork
- Dumb suspension question. Can I run S4 struts with A4 sport springs on a 1.8TQ?
- Could worn UCAs contribute to instability at highway speeds?
- CEL Flashing, Need some help.
- Front end squeeks
- does anyone have a front pair of black cloth door cards
- I'm guessing alignment.
- bumper issues
- Speedomoter issues...
- do the audi a6 luggage racks fit the b5?
- looks a little worse than my car did, but would be the same amount of work
- Anyone need a carfax report?
- Bout with a wrx last night
- intakes ideas/questions
- Drool!! this thing would be the perfect track day toy. I sure wish I had the cash.
- 10% ethanol everywhere?
- Air fuel ratio gauge help
- Lots of vibration when i come off the gas....(long)
- brake rotor woe - and buying suggestions
- what makes these worth what they are?
- you know...
- Paging SFexBOY (and anyone that knows the fix)
- Anybody have any spare center caps for the 16" 7-spoke "Swing" wheels?
- Power windows went down during a new windshield install, but . . . .
- where do I find steering knuckle for my 99 A4
- Driveline Slop/Thud
- Anyone in upstate NY/pa/surrounding area have an extra S4 bumper?
- click, drag and release....
- Ordered some maintenance items
- Questions regarding clutch kits from Valeo
- Weird running problem...
- Replace Front Wheel Bearings
- Flickering instrument panel lights
- ECU remap
- SPA + Bullseye make a gorgeous pairing.....
- off to Cleveland for two weeks maybe I'll see some C-Town AW'ers on the road?
- Speaker problem.. maybe.. maybe not
- 2 cycle oil in gas... update...
- God damn it, guys. I wonder why alot of people still do this...
- for those of you who did the A8 rotor upgrade, what else do I need?
- Here is a reason not to own an Audi
- Brake pad wear sensors are only 99.5 and > right?. I think thats what I got from STFA
- I think it's safe to say I made it through my only winter... On summers none the less!
- Trade in or sell privately?
- carbon fiber drive shaft on 1996 A4's
- If anyone's looking for a used flywheel, I have one (2.8L)
- Few more new cars pics (for those that requested).....BWW (56K go smoke a cigar)
- Two questions: Does anyone *else* have a stock set of sport springs
- AWM engine noise - round 2!
- should this be on my car?
- Can somebody double check a part number for me 038 903 018 FX
- Im getting an "itch" wanna chime in?
- Those who are running Hawk HP Plus pads at the track, are they decent?
- Vibration/Driveshaft/Clutch
- Mass Air Flow Sensor
- Looking for Audi 1996+ got questions
- Possible new owner with a few questions
- Old timer here with request for a couple pages from Bentley or equiv. manual
- what's it worth post?
- wheel spacers on a daily driver 96 a4q
- Apikol Rear Diff Mount now offering New Upgraded Bushings...
- oil filters...DIE BOSCH DIE!
- Drove a B5S4 yesterday for the first time...impressions...
- dts on ebay
- Tech article for replacing the drive shaft?
- Anyone have a wiring schematic for a 2000 A4 Cd Changer/Radio...(more)
- Hello AW, from Munich.
- GT3071R-WG ATP Turbo
