View Full Version : A4 (B5 Platform) Discussion
- Transmission Whine?
- Front/Mid/Rear Diff Transmission Flush?
- 99 audi a4 limp mode
- I need help with my 97 audi a4 aeb 1.8t
- Window/Sunroof operation fails
- A4 2001 v6 coolant hose
- Need some help vacuum diagram
- Driveshaft center support bearing
- Best Spark Plug (Ignition) Wires?
- Car Alarm keeps going off
- 1999 A4 art project
- B5 Poly Control Arm Upgrades!
- Air bag wiring connection on DRIVERS SEAT
- past 375K with 1998 Audi A4 1.8T
- 1999 A4 won't start after throttle body replacement
- 96 A4Q 2.8 Running Super rich, no power.
- ATTENTION To All engineering staff please report immediately need back up!
- 01 audi b5 1.8t awm being a ****ty car
- 1.9 tdi won't start after prolonged cranking
- 1996 audi a4 shifter button stuck in
- coolant temp sensor
- O2 sensor 2 replacement help
- Difference Standard and HD suspension
- New tires -- recommendations?
- C.A.R.B.-compliant catalytic converters?
- 1998 2.8 Fuel tank Heat shield: ideas or source??
- 96 A4 2.8l 12 valve 5 speed.
- Secondary air pump:1999.5 2.8L
- 04 A4 V6 flooding at cold start up
- Radio just stopped working
- A5 b5 saloon water leak
- [FS] Audi A4 Bentley Service Manual 1996-2001
- Temperature gauge drops
- 98 Audi A4 Quatro No reverse
- Instrument cluster beeping but no display
- I need help with 2000 audi a4 b5 avant
- changing rear shocks/springs 2001 b5
- RDS & TP buttons not clearing Safe Mode
- A4 B5 1.9TDI PD
- Which Audi is considered the best handling ever?
- I need help
- Fml Audi gang probs
- Suggestions where to buy shocks
- Old B5 needs some help, won't start
- Car starts but wont stay running, need help
- 1997 12v 2.8 camshaft seal leak
- Front Diff (auto) driver side flange seal replace - looking for tips/clarification
- 2000 A4 2.8 AT limp mode diagnosis
- Audi A4 B5 Automatic transmission problems
- Still getting P0411
- 99 A4 Starter connection 15a vs. 50 ?
- What is that ???
- 1.8t sputters at WOT
- 2001 audi a4 1.8t no start
- Mystery 2-pin Connector
- 1999 Audi A4 beeps 3 times consecutively after starting. No warning lights on dash.
- 2001 A4 Avant
- Getting my new project running
- Headlight Connections
- Melted engine cover
- Noob question on K04 install
- UK: Hello, I need help. What is this pipe called, please?
- Electric Windows not working
- throwout bearing after replacement?
- New here and new project 1999 A4 Quattro
- 99 audi a4 Quattro 1.8t
- Audi a4
- Pressure plate and fly wheel
- speedometer and cluster
- Injector grounded out need help plz
- New or used engine
- Aftermarket Cruise Control?
- Correction to my previous post
- Noisy A4 quattro differential
- Brand new Audi owner HELP PLEASE
- Damage to water pump after drained coolant
- 98 aeb 1.8t wont crank after i pulled engine to replace clutch
- 1997 A4 1.8T FWD: Car feels loose on rough road - Even After Front suspension change
- 2001 audi a4 1.8t rodknock on start up
- 99.5 audi a4 1.8t quattro engine dies after starting
- Oil pipe
- third brake light stays on while driving
- Clutch Not Fully Returning
- 1997 key fob replacement
- 2001 a4 quattro manual cranks no start
- Replacing bose with aftermarket radio - specific odd question
- High beam flickering
- Engine stall when breaks epc light turns on after stall
- Intake manifold vacuum line
- Scrapping advice
- DOA Audi for $500... Loosing my mind.
- Life expectancy of fuel pump
- b5 audi a4 wont stay running? 18010
- Audi part out
- A4 1.6 1999 facelift
- Help with engine code
- 2001 Audi unicorn?
- 99 A4 B5 motor mount replacement
- P1300
- INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
- Def on instrument cluster
- 2008 A4 Avant TDi - Window Relay location
- Brake pads warning light
- **** 17963 Boost pressure control : Upper Limit Exceeded???
- getAudiparts.com | Black Friday - Cyber Monday: Lower Pricing + FREE Shipping!!!
- Knocking Noise While Braking
- I want to modify my 2001 but i don't know where to start
- 1998 A4 B5 trip odometer resets randomly
- 2.8 30V Still running rich after replacing common problem spots
- Under 2800 rpm car lean/misfire under boost
- Automatic headlight range control defective
- Daily driver coilover recommendations in 2018
- Misfiring
- how long do sports suspensions last
- 1998 A4 B5 Tiptronic fluid capacity - fill procedure weirdness
- Putting 2.8 auto trans in 1.8T auto, will parts match up?
- Does anyone have a rear subframe for sale or that they would sell?
- Goes in gear but doesn't move.
- Can an ECU be reprogrammed with a standard VAGcom cable?
- Heater core swap reinstall leftover nuts?
- interior dash wood molding
- Bubbling from expansion tank!
- Audi A4 B5 8D Instrument cluster warning lights blinking/lit and no RPM
- FWD Gearbox - close ratio questions
- Bought an Aquarel Green Metallic B5 A4
- Brake Caliper heat shield
- Odd wiper behavior
- steering lock issue
- 96’ Quattro A4 Broken piece in timing belt cover
- ICM delete kit
- Heater Core Explosion
- 05 a4 1.8t helppppp
- Coolant temp just past the middle line (90° Celsius) normal?
- 1998 A4 B5 2.8L 30V Oil Pressure
- B5 A4 slack with gear lever when in gear
- 2001 Audi A4 Brake behavior
- Accidentally broke cluster clock LCD while disassembling cluster
- Control arm bolt/ fuel line in the way HELP!
- What Is This Red "R" On The Trunk
- ESP/Traction Control/ABS light on after ECU swap
- What is this sound in my engine bay ?
- Cam chain question late AWM 1.8t
- audi a4 fuel pump housing
- Transmission problem. Need help!
- Camber Plate
- Water Pump seized
- State Refferee
- Coolant Temperature Sensor
- 98 A4 2.8 Crank but not start. Have VCDS
- Rear lights
- 97 A4 2.8 wont go into park or move
- getAudiparts.com | Genuine Audi Collection Key Rings!
- Catch can install?
- 1998 Audi A4 Quattro 1.8t AEB
- 07 a4 2.0 t
- B5 INJECTION RELAY
- Check engine and air bag light on!
- Popping Sound
- Need Parts - B5 Eibach Rear Springs
- 2011 A4 manual stumble during when engine at lower rpms during acceleration
- Boost Questiono
- 99 audi a4 1.8t quattro NO POWER STEERING
- PLEASE HELP! Can’t get into trunk
- Trunk doesn’t open half the time?
- A4 B5 Auto Gearbox issue from Newbie!
- Audi A4 B5 1.8t Quattro Front Power Window Issue.
- Found Oil Around Spark PLUGS ???
- 1999 A4 sat for a while
- newbie tech question
- 2004 Audi A4 1.8 Quattro Avant Blower Motor not getting power
- Audi A4 B5 2.8L 5spd Speedometer not working
- 1995 Cabriolet crank but not start
- Possible vacuum leak?
- central locking problem a4 b5 quattro
- 99 1.8t sputtering, idle, problem MAF?
- Wheel help
- rough idle
- Water Coolant Consumption High
- ARP Performance Fasteners 10% off! FLASH SALE
- I have an Audi A4 B5 2000 1.9Tdi, The speedometer (instrument) does not show me the t
- 1998 a4 quattro tcm wiring diagram??
- 1998 Audi A4 B5 Radio lights up but doesn’t work
- Engine and SAI Diagrams - A4 B5 SAI Port location?
- Rotiform IND-T How's looking on A4 B5???
- code P1136
- 97 audi a4 2.6 wont start cold.starts fine once warm.
- possible to increase hp on an A4?
- Transmission Troubles, Again..
- FLASH SALE! Street Shield Skid Plates 15% off + FREE SHIPPING
- Audi A4. Pickup issue and does not climb hill roads.
- SALE GSP Replacement Parts | up to 15% off | Wheel Bearings, Axles, Loaded Struts
- New Product Launch Blue, red or clean bright white FOOTWELL LEDs for all AUDI Models!
- Should I buy this A4 B5 2.8L Quattro?
- Crashing sound when in reverse
- Flash SALE! Cooling Refresh! | #dontoverheat
- Erroneous indications on dash
- ABS error message
- Intermittent low beam headlight notification
- Turbo Upgrade time
- Help diagnosing
- 98 A4 odd interior ?
- A4 2016 FWD to quattro
- Turn signal doesn't turn off after turning
- how to get new safe code for AUZ2Z3B1032428 thanks
- Heated Windshield Washer Nozzles are garbage, is there a non heated replacement?
- AC works but no cold air
- TIRE SIZE
- BLOWER MOTOR
- Audi A4 Avant b5 1.8 non turbo starting problem
- 07 a4 humming
- PCM RELAY ONLY GETTING 5 VOLTS INSTEAD OF 12
- Need help with indactors
- Oil Consumption Repair - Issues Post Repair?
- A4 B5 2.8 ticking sound above intake box
- Outside Fish smell 2016 A6 drivers front tire area
- return flow pump
- A4 Turbo replacement
- Flash SALE! Solo-Werks Coilovers 10% off + Free Shipping
- Need window regulator fastener assistance!
- adjustment screw in headliner
- coil swap... throwing codes... need ground
- Key Cutting
- recent ratteling noise and vibration
- 1998 Audi a4
- free wheels & tires Denver
- 2000 Audi A4 bottom seat cover
- B5 LED display change
- B6 ZF AWD Steering Rack Compatible w/ 96 A4 Quattro?
- 2013 Audi TT stuck in park, check engine light on
- Oil change effect
- First Aid Kit
- Audi A4 B5 2001 2.8 Fuse #34 & ECM Problems
- Need an upper management contact
- Got a free 1995 Audi A4 B5 platform; asking for advice to see if it's serviceable
- There is no oil temp gauge
- B6 V6 Steering rack into B5 V6
- i am looking for the shark fin antenna cover for 2013 audi a5. I broke the cover off
- Audi A4 timing chain and turbo
- genuine Audi parts ON SALE!!!
- 2002 audi TTdoormproblems
- 2003 A4 Quattro power steering
- ***WannabeRacer.com | Norcal/Bay Area Vinyl Wrapping Tour - July 30th - Aug 3rd 2018*
- 2000 Avant A4 Manual Lock Replacement?
- Rims
- A4 2006 1.8 Turbo B.F.B Engine
- the whistling car
- 2009 Audi A4 Quattro 2.0 transmission hex socket
- Rear caliper piston compression direction
