- One thing about Q7 stolen if it's true.
- Security
- 1997 A4 2.8 + strange rear noise *Please Help*
- Paging: audisscott
- pilot sports + quattro + snow = manageable... great snow fun in victoria today !
- boehm - Please remove your post from the FAQ
- Immobilizer failiur to protect
- How much vacuum line to cover everything under the hood?
- Anyone install a APR BLUE SNUB on a TIP and have vibrations
- My roommate was nice enough to loan me his car while mine is down.....
- 2001, manual, 1.8T exhaust recomendations??
- AWE Tuning hosting Dyno Day GTG for DVAG
- My car seems to wander a bit on the highway...kinda like if it was really windy out
- Torn outer CV Boot, how many labor hours to replace?
- couple of quick quesiton on a 2000 A4 with 98.5k miles and some reminiscing
- nead a part number, thanks in advance
- Need some advice.... control arms are getting replaced
- Bose Rear Speaker
- ATP High flow manifold people, free turbo to manifold bolts to a good home.
- Why is the ground all wet?
- Compact spare wheel to give away FREE
- so after changing the battery yesterday, i now have new but similar problems...
- PSA: PureMS's SS Boxster brake lines are no longer nylon coated.
- B5 A4 AWE Tuning Brake Packages
- Axel Installation?
- heated seat works then it doesn't then it does........
- Damn coilpack prices go up or something, one aeb coilpack is 64 bucks
- Guys it does exist...
- Paging GTIVR62801 - Cat Efficiency Codes
- ETKA pimps, I need a few part numbers for a 96 A4Q, search revealed very little.
- rear wheel bearing
- 2000 A4 - Broken Timing Belt - Any Ideas - Possibly for Sale
- ok another BRAKE question
- M1 Racing 0w30 -- damn, before I could even find it while using up Motul 5w40, it was discontinued.
- Diagnosing vibration at high speeds
- Whirring Hollow sound from wheels at slow speed...
- doing the timing belt/etc tomorrow
- Time to get the car smogged.... and detailed buyer's financing came through =D
- Poortex:
- HOLY RAPAGE!! 1st GEAR is $350 for JUST the gear!!
- I got the Bentley manual and cant seem to find the cam position actuator
- can someone explain to me the fluttering sound from the DV?
- updated logs, blocks 117 and 119
- Electronic buzzing? (TB Adaptation-like) coming from rear
- Bentley manual BT: is the letter/number combo on the bottom right the part # in question?
- A4(B5) Power Steering Flush
- wow... take a look at this electrical nightmare...
- Radio Went to Hell.. What should i do ?
- MAF Voltage 99 AEB
- FEELER: is there any interest in these parts??
- anyone out there with a bmw 2002?
- Is changeing your coolant as simple as drain the old and fill with the new?
- can someone please tell me the part number for stock transmission fluid for a 2001.5 a4 1.8 5-speed?
- I've run out of ideas, my 91oct ndbw K04 peaks at 15psi and surges all over the place at low rpms
- Is it better to buy your fluids from your local Napa or buy them online and pay for shipping?
- Whoa! I just noticed 1stvwparts.com no longer does Audi parts. That blows
- tires, is anyone running 255/40r17
- im thinking ahead to my next step for fueling...i want to get away from the 5bar fpr
- Tips on diagnosing cylinder misfire on 2.8 30V
- CV boot replacement
- Low Maf readings??
- What is the average cost of getting total control arms upper and lower replaced if i have the parts
- How important is this piece and can I buy a new one?
- APR 93 vs. GIAC
- an injector sheet i have lists the flow in (g/min)...whats the conversion to (cc/min)?
- Where should i have my valentine wired?
- Non-APR BT gents who's still running a SAP(Secondary Air Pump)?
- Getting Chipped
- Leaking coolant BT: coolant coming out (fast drip) from hose coming from behind engine block..
- Simple How To For Axel Installation
- scent flavored tires anyone?!
- New Flash - Automaker sued for animal cruelty
- MUAHAHAHAHAHAHA... the audi may finally be sold..
- marker light replacement 99.5
- Tire Rack's Valeo wiper blades - thumbs up
- anyone have a passenger side mirror laying around? Silver maybe
- What is the Avg Cost of getting a time belt change if you have your own parts?
- S4 Xenon one piece lights on 2001 A4 will they fit and are they a plug and play setup?
- so i go to start my car yesterday and get nothing.. no juice whatsoever.. tried to jump it...
- is the stock boost at a regular load 8-10? or is that going up a hill? i searched and..
- -->: Hella Micro DE
- X-Post from Mid-Atlantic about suspension damage cause by massive pothole
- Does Hartmann Wheels sell the rims in packages???
- ok gurus...here are some datalogs...can you figure out what is going on
- w00t! Brown dropped off more goodies today!
- A4 tiptronic transmission slipping
- Can anyone tell me if this plug looks fouled?
- need help: 99 2.8Q rattling noise at idle that does not go away
- Has anyone used studs instead of bolts on the ATP high flow manifold?
- BWW: The beast is coming alive....... way OT, but those who are following my truck project at all:
- Is anyone looking to get an A4? (feeler not 4 sale)
- s4 front brakes on a 97 a4? will/can it work?
- A4 suspension upgrade question
- 97 Audi A4 Quattro 2.8L Motor Oil
- For those that knew Bing, he has passed on now.
- For the rear seats which look do you prefer...I'm on the fence 1 or 2
- paging Chicktronic (or anyone else with a DEFI HUD gauge)
- paint colour
- break pads and rotors
- Getting a code for EVAP SYSTEM SMALL LEAK! Bought new gas cap and still comes on cold weather only!
- 2001 1.8t chirp?
- anyone selling all weather floor mats for 97 a4?
- 12v timing belt question (paging qfrog!)
- How to recode washer fluid warning so it doesn't show.. (incase you want to know)
- :: ECS Tuning :: 1.8T Ignition Solutions
- MAF
- 99.5 Headling Aiming
- Cold weather - wipers don't work
- Hey guys, I'm interested in getting into the auto industy. Does anyone have any ideas how to do so?
- I didnt know the posting stats are out!
- My latest powdercoating project:
- Anyone thinking of trading in their 2000/2001 B5, <80K miles, looking for one for less
- Anyone try a Walker 02 sensor?
- my A4 wont start
- Airbag Light in Cold Weather
- Questions about upgrading to HID lights
- looking for ETKA diagram 103-90 and the full pn/name listing for 133-27 ...
- I really like my A4, but as customer support from Audi really blows.
- 98 2.8q Manual Fuel Filter
- 96 2.8q manual diferential fluid change
- About to start rebuilding, need good sources for parts
- Since I'm a moron, could anybody put together me a timing belt & associated parts.
- fuel filter replacement
- 16805 and 16815 - catalyst effiency CEL on a 2000 A4. I think I remember...
- anyone have a used but working alternator? car wouldn't start today, then my friend wrecked...
- Last time I'll post this... PROMISE.. MADAN GET IN TOUCH WITH ME ! (RANT)
- My new status here merited a sig refresh...
- is the Camshaft Position Actuator the same as Cam Chain Tensioner
- rear wheel bearing replacement on 2.8 quattro
- Simple oil change gone wrong
- w00t! 5th place in B5 A4 PWOTY!
- front end stiffness
- wh00t !
- Exhaust Question
- Congrats to Nate for taking post whore stats in B5 A4!
- paging,modifieda4...how did you caps run/test go with the airbox mod?
- anyone know where to find out the specs on stock audi rims for example
- can u take the lower contols arms off a 1997 A4 without removing everything please help
- Besides AWE, ECS, ACHTuning, anywhere else to get a set of hal ecode headlights?
- Only took me about 5 hours, but I finally got the RaceTec FMIC in. A few snags, but nothing big
- repost for today's crew
- Interior Upholstery Project Update: slight bww
- Big car update
- Fianlly did auto timer....few questions????
- Finally got some pics of all 4 cars together when I was in CA over Xmas.
- Can't get my pilot bearing out!! Any suggestions?
- about to swap exhausts with a buddy of mine-any suggestions?
- w00t! I am in the February issue of Road & Track
- P0171...culprit
- Sunroof from hell!!
- What is the torque spec for the rear flange center bolt?
- Anyone on this this Forum from Hawaii Island of Oahu?
- Quattro Nole: Nice to meet you tonight.
- information center on dash is starting to crap out
- Door handle (inside) went pop
- Roof rackage II
- Roof Rackage, base carrier, slide-on bolt "thingie"
- car not starting sometimes
- Secondary air pump wont turn off someone please help.....
- CONSOLE - HELP -_2001.5_b5_a4_1.8TQMS_
- oil leak
- whistle from the top vent
- Offroad photos, put the latest mod to good use... MBWW
- Anyone need some stuff for their car ??
- Wh00t !
- Stupid newb question (no, really)...
- Happy New Year to F-ing ME!! Part II
- 10 mpg - holy smokes
- Happy New Year to F-ing ME!!!
- Got a little coolant leak at the oil coolant return hose
- What is the safest way to clean the interior bell housing after an input seal blows? Brake cleaner?
- Bought my daughter some rice today ,no kraut on menu.
- 2.8 vs S4 connecting rods, same or different?
- how do you change the front turn signal?
- Suggestions for what to do since I removed the front plate?
- Wet Driver's Carpet: SOLUTION
- 99.5 Concert radio clips broken
- G1 & G2
- Anyone know how much roughly it would cost to get a k03 rebuilt to a k04?
- Last suspension post...
- Help Please, Big time Front end problems
- January 6th in NJ?
- Need some help on troubleshooting problem
- Oil FAQ didnt answer this question...10W-30 ok for winter?
- Could someone please tell me the engine code for the 99.5 2.8L 30v V6 A4.
- Brackets to fit B5 A4 Brembo BBK on B5 S4?
- Downpipe removal question
- 225/50 vs 205/55 - Kris Hansen?
- Meineke came through. They didn't cut anything on my exhaust, just expanded the inlets...
- What is a good place to get a short shifter but still not spend alot of money(100+)?99.52.8L30v
- What about doing the front shocks and springs when...
- Sub-enclosure question
- Engine Stall and Low Speeds
- gl 4, gl 5, gl 4/5, redline, motul, royal, mt90, etc., etc. that's what i've gotten from searching.
- New CA's/TRE's..still getting a lot of wheel noise over sharp edges..Ideas?
- if my CA'S are covered by my warranty ... can i still provide the parts?
- How much do new tranny mounts going to cut down on driveline slack?
- neighbor had his car stolen the other night, and I'm stuck parking outside while I'm visiting my dad
- No wonder my exhaust tips stick out so far. The pipes are obviously either too long or...
- Paging Yippers. Got the FMIC, thanks man.....
- eh, latest CAPS time isnt too impressive...6.4 secs.
- 01 a4 vacuume hose leak...
- car is now driveable !
- fuel filter wasn't as bad as some say
- Anyone looking for a stock ECM M Box?
- New Wheels Spray Side Of Car
- So, I take it I am screwed if my flywheel even has the SMALLEST of cracks right? Taking donations!!
- xpost: old school audi ripping it up with some all-wheel drifting
- So my K03 is shot from sitting for 1 year+, whats my cheapest option for replacement?
- So nobody knows how fuel cut works on the nDBW cars?
- 99 brake front brake rotor replacement question.
- Weekend mod thread?
- Turbo Questions
- umm.. did any of you take my "body" section out of my bentley?
- Xpost: B5A4 with twin-turbo V8 engine
- instrument cluster problem
- anyone know (or selling) of a place where i can just buy a single driver side e-code headlight?
- Ignition swtich recall?
- 96 2.8 quattro manual Fuel Filter Question
- TBA with VAG-COM: should engine be warm or cold?...
- where is the hazard relay located??
- Paging Clayton from CTS turbo
- trouble code 118 coolant tempture
- pulled the trigger today, one step closer to getting her running again
- is SPP the only place to get a 50w 4300k HID kit for Valeo halogen ecodes? what's the current best
- Left rear knuckle needed.
- Compression test results...anyone up?
- Headlamp replacement - 1998 halogens to HID. Is LLTek's option a good solution?
- Headlight Bulb Replacement Problem.
- NGK BKR6E vs. BKR6ES Performance differences?
- ? about how to do a compression test...please help:)
- Want to find a '98-00 1.8T Tip for my GF (what to look out for?)
- Got the exhaust manifold back on and I still hear an exhaust leak. This is fvcking absurd
- Alternator issues....
- Welp, I chipped her last night...MTM
- my symphony + iceLink woes
- Issue with head unit
- Im buying the Meyle CA kit from purems....
- is there any way to adjust how far it takes for the turn signal to auto return?
- Supercharged 12v update:
- P0300 code? Misfire
- Why do i always get this fault
- "Creak" sound from the steering wheel
- HVAC Blower Fan
- Ebay Vag Tool
- Exhaust TSB issue... What am I supposed to do now?
- your vortex POTD (post of the day)
- Should you be able to blow through both ends of the puck valve on the TIP or do I need a new one?!
- X-Post from the Mid Atlantic Forum: AWE's GT28R kit.
- Chaing the rear main seal during clutch install, what all in involved...
