View Full Version : A4 (B5 Platform) Discussion
- Audi A4 B5 GT30R Snow drift
- One piece wiring harness..
- Been a while.. How is everyone?
- VMR | Wheels - Moving Sale!
- very hard to use,
- catch cans
- A/C Compressor Clutch/ need help/
- Has anybody installed a fron end cover bra?
- Question bout a shot turbo on my A4
- keyless entry broken any one know quick Fix?
- Amp location
- 98 A4 audible warning beebs
- need turbo rebuilt, help me find somewhere to do it!!
- Amazed what people think of my A4
- 99 a4 quattro hard restart after fueling
- Interesting Brake Light problem
- help and advice please
- What are these lights?
- Oil leak back driver side of 2.8L 1998 Avant?
- Tell me about your tires
- Tune up!
- anyone live in san diegoish
- can any 1 help me please
- p1128 confusion
- B5 Avant Bose Amp location?
- 96 A4 Auto Tranny help needed!
- 98 A4 Strut Bar
- will this rub?
- 96 A4 Immobilizer
- Headlight Washer Cap - Driver's Side
- Lower timing cover shredded!!!
- Shaved engine bay - B5 A4 2.8L 30V
- Avant owners: easy fix for broken cargo cover "hooks"?
- shave/fiberglass over lower rear bumber exhaust hole
- New to the A4s
- DTC 16684 and 16688 coil packs? HELP!
- What is "normal" performance for 99 A4 quattro 2.8L
- Turbo problems
- New here with a dying car
- MAF sensor HELP PLEASE!
- audi A4 short shifter
- VMR Wheels | V709 Multi Spoke
- Back n' blue!
- Prestone Anti-Freeze?
- Interior Light "TIMER"
- Question on Codes and Erasing Them
- how many filters?
- CEL and codes P1296 & P0116
- powersteering pump
- Misfire in #4 Cylinder
- a few issues with 97 A4 Auto 2.6 v6 A4
- Quick Advice for a college audi drive.
- Belt Mess turned Belt tragedy!
- 2.8L engine rebuild questions
- 2.8L30V Chip flashing help
- Need help With Vag Com Trouble codes
- Exhuast on 2.8L, question
- 1997 A4 2.8 Running like garbage
- best HID upgrade? too many choices
- I piece headlight conversion wiring!!!!!!!!!!!help!!!!!!
- Help an idiot with Dash Lights
- BBS LM Replica's
- cost of auto dimming day/night mirrors
- IMMO trouble after dash out
- self dimming day/night mirror
- 01 A4 Fuel Trim Code 17536
- New Here. About to buy a late 90s A4. what to look for?
- 3rd Brake Light Bulb Replacement
- How can i hook up an ipod touch to my audi?
- E-Code (HID) lighting upgrade questions (from 2-piece '96 A4)
- Climate Controle led's/bulbs
- Side view mirror glass replacement
- Steeering Wheel Looseness
- hard start still :( and power door locks wont work
- longer lug studs?
- Self-dimming day/ night outside mirrors
- Best prices on 5w-40 oil and filters
- Need Headlights
- looking for vid from old ATCC or BTCC with A4Q
- Cheaper Pentosin CHF 11S Power Steering Fluid Alternative
- anyone know of any mods for a 96 b5 w/12v ???
- The A4 quit on me today!
- New Here
- wondering about guage readings
- Looking for a Quattro with a blown motor
- Low cold start idle
- Heater Inop, Only Cold Air Blows HVAC
- Inner CV joint to transmission bolt size? 8mm or 10mm? Torque Specs?
- question for Kris or anyone who knows 2.8L
- How much for Coolant Temp sensor?
- quick link for a headlight switch?
- Need one old style O.Z. Superturismo wheel
- HITONE64
- cam plug
- no speedometer, no rpm no gas and no engine temp
- Dashboard light repair, help!!!
- How much hp and torque gains can I expect (2.8L) Major Project!
- help with after market headers for 2.8L 30v
- loose steering and clunking noise...
- Make my exhaust stealthy
- VMR Wheels | V710 18" and 19"
- 2piece - 1 piece headlight conversion!!!!!!!!!!!
- Audi is finally making a new B5! 2013my
- Greetings from an A4 Noob
- RS4 kit on A4 question
- 96 A4 Dash Light Warning Lights Configuration
- Bulb out warning won't go away (searched)
- Timing issues? HELP PLEASE
- I cant figure out where this sound is coming from!
- tiptronic recommendation
- 1997 A4 Avant TDi..Faulty heater..Blows NO air
- gas tank gurgle
- Very little to no heat after waterpump/tb job.
- headlight switch big issue
- Help, only reverse and second gear!
- Audi 2.8 rebuild and rev question with giac etc
- Coolant Temp Sensor
- Door interior handle latch spring
- air bag module help.
- Heater core pipe cracked: how to fix?
- Block Heaters ?
- need help asap, my DD is down
- HELP--Small Block of Wood Fell Beyond Throttle Body Into ????
- Stern Drivetrain Mounts all in stock!
- Central Locking nightmares
- Headlights wont come on
- Major Oil Leak!
- Replacing doors on 98-99 models
- which airbag module to get
- H&R/BILSTEIN
- Left front differential bearing
- 2.8 Timing belt scraping block-side guard?
- VMR | Wheels - V708 RS4 Style Wheel
- Hit it or Quit it?
- Old Coolant Temp Sensor
- Audi SUSPENSION question! HELP!!
- Problem under acceleration
- loud noise-exhaust leak? help me diagnose
- Quick Mirror Question..
- 1999 A4 HID conversion
- 1999 a4 starting up problems
- Blown turbo, sludge or blown head gasket?
- 96 a4 Brake light problem
- Anyone have an extra headlight washer cover in Silver?
- Aluminum Skid Plates
- Beating the sh*t out of the auto to manual swap dead horse...
- Headlight Washer and/or Cap?
- Front Left Brake Caliper "Boinging"?
- A4 2.8l Exhaust
- Need part # and advice on fixing metal coolant hardline leak
- would this turbo plug leak coolant or oil?
- Maintenance Times
- belly pan/ noise reducer
- Weird factory alarm problem Truck Unlockcing when set off????
- Where to buy catalyst? [2000/A4/Quattro/v6/2.8]
- HELP ! brake light flashing abs light on , not the module problem !
- 1999 A4 Quattro 2.8 Overheating Question
- Front Valance (spoiler) Mounting Hardware
- 2001 A4 1.8T Quattro PCV valve location?
- Can I move the car with the bumper removed?
- Rear door latch won't latch
- All PDF's involving the B5.
- New B5 S4
- Coolant pouring out......
- DIY: B5 A4 - Ignition Switch Replacement
- 2000 diff/rear shaft seals
- Replacing slipping clutch and 90K service suggestion
- got it running again, still misfireing or feels like that
- Where te buy OEM parts - crush washers, etc.?
- 2000 1.8 TQM Slight shudder when started
- Buying New Suspension, anyone selling/advice?
- DOES ANY1 NO HOW TO FIT BOOST GAUGE TO A4 1.9TDI 1997
- Starting when Cold
- performance .........help!
- Grind/Rattle from under gear shift at 4k-5k, especially when cold.
- New Radio
- HOW TO FIT BOOST GAUGE AUDI A4 TDI 97 MODEL
- How to disconnect wires/cables/tubes to remove hood?
- Why doesn't P0705 show on regular scanner? MFS
- Cam Chain Tensioner Causes Engine Failure?
- 99 1.8 Oil Leak HELP...
- Door sag remedy?
- Valeo Headlight Assembly??
- Immobilizer Wiring Diagram needed URGENTLY
- 01 1.8t oil pan
- Need help diagnosing misfire. 00 2.8q
- Can a LW flywheel make a car loose boost?
- shortshifters
- where to get new seprentine belt tensioner
- Attn: ECS TUNING in Norton
- rear brake bolts - need part numbers please
- Tranny Slip
- '96 Trip Meter/window convienience Resets after sitting for several hours
- help! turbo break in period?
- Bad outer front tire wear
- rear wiper
- Audi snow sculpture...
- HID Burning the Ignition Coil?
- does anybody recognize this part?
- headlamp washer stuck
- Brother's 99 A4 1.8T quattro fueling issues
- 2002 A4 2l Engine: Coolant in Cylinder and Heater problems
- Alignment Shops near Detroit
- 96 A4 2.6 No Injector Pulse
- Audi tool 3212 for loan/rent in Boston area?
- Need help mounting rear door speaker grilles on '96 A4
- Coil pack 1997 Audi a4 2.8
- whats this?
- what does this hose do?
- radiator fan bolt reverse thread?
- A4 B5 AWM - Engine Noise with VIDEO
- Belt split in half...Now I have a rattling noise
- Coolant T gauge issues?
- Bumper adjustment
- Window rolls down but not back up
- Buying a Chip, any advice?
- Shopping for an A4...
- vacuum line diagram
- turbo install probs
- 1996 A4, 12 Valve. Shut car off and now won't start. Cranks and no start.
- Best Oil Filters Article
- Auto Tranny fluid change
- Rant
- Fuel supply line flare nut connection to fuel rail
- NEED HELP. INSTALLED NEW CLUTCH LOST BOOST
- concert radio reset help - broken display, need # of sec. to hold in
- Ecode HID and HID kit retrofit ballast
- Part number help
- 99 a4 1.8t broken timing belt
- Emissions failure 1.8T
- Bumper is falling off, HELP!!!
- Need help transmission lines
- 1999 a4 1.8t
- Got a "New" one... a few Q....
- FS: autodimming mirror
- Braking Problem
- Locked out need help!!
- 99 A4 Smoking Real Bad..HELP!!
- Please beggin for help with ect
- Battery Died and then we jumped it and now the stereo wont turn on???
- CV Axle Wedged In - Help!
- P0411 - Audi A4 Avant Quattro 1998
- Turbo kit and supporting mods for 11 second 1/4mile?
- Failed smog check due to aftermarket stereo and check engine light
- New Info on Oil Light Flashing Problem - It's NOT the pump! Now what?
- Society for the Prevention of Teenage Clutch Abuse
- starts and dies cel flashing
- Quick Question about Cam Seals
- General Wondering.......
