- Quiz: Find the problem with this car - Camshaft adjuster/position DTC (Despaired) (Long)
- Hardwire help
- Hit a milestone on the A4 tonight: 175k while out doing some last minute shopping.
- Zero Fault Codes, but engine studdering... Any Ideas?
- Wats everyone hoping for christmas...
- anyone in Los Angeles want to help me with a turbo timer install? (i have lots of booze)
- Engine Code In Trunk = APU, Engine Code On Block = AEB... What's Up?
- Clutch Engagement Change
- If I change water pump but NOT the timing belt tensioner, will I run into problems?...
- Happy Holidays and Merry Christmas!
- BSK...
- 16" to 17" or 18" without lowering on an '01 1.8T Sport Package
- APR Stage 3+ installation notes and initial impressions (really really long)
- n00b electrical question...
- What is the little L-shaped hose, that runs under the coolant expansion tank?
- Just Dave is Dead!
- shift rod size and thread count
- Replacement MAF for 01.5 1.8T (UPDATED)
- what kind of bolts should I buy for 17x8 Borbet Type T wheels?
- Heat still not working after flushing the heater core
- Overheating problem -- updated.
- Time for a W8 belly pan. I thought I actually damaged the oil pan for a minute there
- WTF is wrong with my speedo
- Audi iPod Adapter in stock
- Here are my fault Codes
- wow that got owned quick..
- I want to take a moment to say thank you.
- what are the pressure sensors in our cars good for???? thanks
- where do i get an alternator for a 2.8 a4? besides the stealership
- Did your v&s ss come with instructions?
- ipod adapter is available now.
- Christmas Weekend Modding and Maintenance Thread... well, Merry Christmas Thread this Weekend
- B6 owners can blow me.
- CEL and umm yeah not so good....
- Need help. Wifey's 1.8t Passat has the "STOP oil pressure light"
- A8 brake upgrades, just the rotors or more involved??? What to buy?
- 96 A4 Aux Radiator Fan - 4 pin ?
- POLL: Which engine ref and ECU ref. n? are you running with your B5 1.8TQuattro?
- Happy Christmas to everyone...
- Repost for morning crowd. New RS4 bumper help?
- just installed boost gauge and have ZERO boost. peak is 10 in/hg vaccum
- just found a button between driver door and passenger door on the column. what is this button 4?thnx
- saw this on my way home from work yesterday
- still having electrical problems after switching out relay #893/603...
- RS4 bumper back from Body shop! Woot! Help?
- Anyone direct me to a list of things to look out for when buying...
- loose tie rod ends @ 55k miles (already replace at 14k under recall)...
- battery exist hose
- Need an opinion on transmission issue
- UUC SS...what's the deal?
- The final Stage 3+ raffle has been won!
- Some dirty A4 pics....to show the new mirrors.
- Will a DP from an 05 A4 fit my 00 A4? tx
- Need help with running battery exit hose.
- Rubber seal on windshield?
- a good place to install the k04 kit in southern california
- airbox mod shows some gain
- For an outer cv joint on a 98.5 1.8tqm it goes...concave washer, plastic cone, and then c clip
- Anyone know what city & state TighTT (T28'd A4) is from? I'm trying to figure out shipping.
- OT: This looks terrible. My cousin had the same thing happen to his Audi coupe.
- Suspension.
- Ordering parts from dealer... which one is the fastest in Bay Area?
- Anyone have pics of the Seidl Tuning widebody RS4 kit?
- how to remove old adhesive left behind from removed wheel weights?
- woot woot ups came today
- PSA if you use 1SourceAutoWarranty.com, First Assured Warranty Corporation and WarranteeWise, Inc.
- 1995 Audi A4 - Audi Upgrade - Help!
- interesting situation... I thought my waterpump went
- Where to get Brake Caliper Rebuild Kits F/R? Any Recommendations?
- Michelin Pilot Sport A/S
- Overheating woes -- bad head gasket?
- Is any of you guys running a 8D0 907 559 E ECU box?
- Where can I buy either oem brake lines or stainless with fast shipping?
- saw fun with dick and jane ... and at one point hes in a garage with a bunch of cars ...
- for non audi hands free kit... can symphony stereo be tuned to mute for incoming calls?
- Which Fuse do i pull to turn off my ABS
- After about 2 hours of work my driver suspension looks like this...Brake line question inside
- Update on my heating problem:
- its alive
- Recommended paint shops in New York
- "qfrog" Parts Question: Can I get a replacement "end cap" for my Avants Cargo Cover?
- for everybody who helped me last night, heres how the JB Weld cured
- xpost from audio forum: new wires or not?
- Clutch/flywheel removal tools
- Friends 97 A4 has lost an engine. I'm trying to help him out, looking for rebuilt or used engines.
- Slipping Clutch Question
- Heater not hot....
- has anyone ever tried to put a stock ECU in a stage 3 A4?
- Does anyone know how much closer to the ground a stock S4 front is vs a stock 96 A4?
- Who has a PhatNoise and what do you think of it? My parents said they would buy me one for....
- So who has the stage III+ installed....thoughts, reports back?
- POLL - Anyone purchase APR Stage 3 or 3+ during holiday sale? Might pull trigger today!
- is there really an '01.5 ? or just '01 ?
- WARNING: possible noob question: Audi parts from a VW dealer ?
- Its my birthday YFFs
- i love this photo
- help -> lost some screws
- Just a random thought.
- Ignition switch problems ?...
- Ac Compressor engaging w/snowflake?
- CODE 49..... WHAT ARE YOU?
- Paging Kris Hansen: YGM.
- Replace DV to 710n
- Been driving with a spare for 60 miles or so.
- Oil in intake hose???
- jbrentd, here is a better view to help you decide on those wheels...
- MadanB-I just tapped the manifold for 10mm studs....this looks ALOT safer-->
- Just had t-belt changed...now the heat isn't very hot???
- i don't suppose anyone has a front license plate holder they'd like to give me?
- How much is the c/d pillar cover?
- hesitation under WOT
- Joining the club - A4 quattro wagon 2.8L
- Should I be alright using 1 stock 205/55/16 for a spare with the rest being 225/40/18 w/ quattro?
- glove box problem..
- expost poll: B5 s4 or GT28rs
- Does anyone make a full exhaust for the 30V 2.8, including the cats?
- CV Joint question
- need help finding metallic grinding sound coming from around radiator
- Help with possible oil leak would be appreciated. More inside...
- Well knowing my luck something is going to mess up my control arm install
- found some ecodes on ebay for $219 new..
- Are these legit ecodes?
- Broken Timing Belt, STFA'd, few questions.
- Does you car leak like a sieve????
- How many inches of ice on a pond do you think you need before you can drive on it?
- Coolant level doesn't reach 90 degress
- please no flamage...but i broke the nipple off the intake manny where the vac line connects
- WooT to Ebay......now to see if they even fit.
- Help- where to find exhaust flex joint??
- Seat squeeking! =/
- i want to upgrade to a little heavier oil weight, currently using 0w-40 mobile 1
- where do you run the line through the firewalls for a boost gauge install?
- 2 questions, what is #24 in pic and what numbers are the vac lines?
- Sound very similar to an old Printer (fax machine) comming from behind the drivers side light at idl
- I'm going to grab a shortshifter on ebay, but would rather buy from an AWer...
- Headlights don't work (already tried to repair switch)
- yay for me....
- xenon Headlight question.....inside
- got the grill but...
- Climate Control Codes for 99.5 WTF?
- People with Tiptronic transmissions may want to read this...
- Misfire Problem, Just got it VAG-ed, Codes inside.......
- Last week of the AWE Tuning Holiday Sale!
- how much "new" windshield gonna cost me ?
- Anyone want a cracked S4-RS4 bumper?
- how much would u spend on a..... READ ON
- Hands free car kit auto mute... is it doable on the non-bose stereo?
- type of gas
- Omari Boost Gauge...
- differences between auto and tiptronic
- So, my laptop's harddrive went bye-bye...got a new one. Anyone know the procedure for getting VAG..
- Trying to remove the exhaust, are there any tricks to getting the downpipe free of the cat?
- Will the newer Bose Concert from TT's (CD insert) be able to replace an older Concert (Cassette)?
- how do i install velocity stacks in a cone air filter?....
- Is N-034-790-7 the pinch bolt and N-102-861-02 the nut?
- anyone on here in or around the Lynnwood Washington area. If so please email me. I found an A4
- Headlights blinking.
- well back to canada for holidays.. = much less posting :) .. see you in the new year yff's
- was just browsing through the classifieds and was curious about hybrid K04's...
- Dyno day in the SE on the 7th. Doing a few pulls in the current configs...
- could ticking from my engine be the coilpacks?
- 99.5 and up On Board Diagnostic Codes
- about to post random shiet just to get the blood flowing in here, doing a 12v timing belt tonight...
- HELP! Temp Sensor Confussion
- About to do timing belt. Anyone in NY metro area have cam bar / pully puller?
- Just got done with my timing belt and.....
- haha 10$ m3 led type mirrors on washdc CL
- how much could i honestly get for my car now?....
- Sooo, for only 15 more bucks, I can..
- What is involved in a cat back install with a downpipe? I have seen the tech articles on b5 fwd and.
- If i could get these for like 250-300 would you say thats a deal?
- dang, someone bid my isocom interface for vagcom to 130$ they gotta be kidding me
- How do you check if your Ignition Amplifier is bad?
- A friend is thinking about getting a 2001 Passat 1.8TM (avant?) @144K....
- Anyone have a Vagcom in CT(Preferrably fairfield county area)
- Any A4'ers in Las Vegas know any good detailers??
- any replacements for e-brake handle? alcantara? or CF?
- Misfire problem, getting it VAG-ed tomorrow, What should I do?......
- Anyone have a phone # for TomRitt or mAd1(gt2871r)? Please email me... gracias!
- temperature gage weirdness
- Anyone ever have their rear brake pads wear out faster than the fronts? EBC Greens, FWIW.
- Throttle Body Alignment for 99.5 A4 2.8 Auto
- what should I buy from the stealership...they just sent me a $25 gift cert...
- changed my N75 today and.....
- recode ECU from fronttrak to quattro?
- Wanted to buy Transmission Mounts :) j/k Question for Mike @ PureMS..
- found this pretty cool site, this guy developed a board from which you can control the FIS display..
- What docking station for Ipod is a hit?
- Well fellas...
- Need part numbers and possible dealer pricing, qfrog??
- how hard is the install on a hands free kit?
- Happy Holidays from AMS...Click here to ...
- Did Neuspeed update their part #'s??
- in order to help me and others for the battery addition to the FAQ. I need some help
- need pic or diagram
- Anyone running a SPP boost gauge setup?
- If I do the airbag resistor "fix" will the light go off?
- I just can't seem to win...
- Any common known problems relating to misfires?
- Tapping Rears For Amp Install HELP!
- Whats wrong with my brakes?
- ok...how about "for rent" posts?
- hmm can we give stuff away? technically not a for sale post...
- paging njskier
- BSK & Modified A4- I updated the B5 FAQ Link.
- I have, for sale, one
- Where have you guys got clamp pliers? i can only find them on ebay
- Opinions please...
- Boost Gauge...
- Paging DGmodel
- How do I locate/disconnect my MAF?
- Will B5.5 Passat wipers bolt-on to B5 A4?
- Just a friendly reminder from your friendly AW staff: For sale, want to buy, and for trade posts...
- 2000 A4 B5 Battery Replacement and Battery Fitment FAQ (Updated 24 Jan 06)
- Anyone use additives from ECS like this one inside??
- what sparkplugs are people using with PC-16 file and gap?
- just got my boost gauge delivered. needle not zero'ed out perfectly
- *Edit* Where did the 01.5's start at in the VIN sequence number?
- 2 Days left to win an APR Stg 3!!! Call APR for details.
- got chipmunk sounding noise......
- Anyone put OEM heated seats in a car that didn't have heated seats?
- Is there any way to tell if a car has been chipped?
- What do you guys think about this deal?
- i am looking for a center cap
- pretty complete integrated boost gauge writeup on passatworld i found...
- Guys with Boxster brake calipers -- which brake lines do you use?
- Metallic clattering sound
- Need recommendation on boost gauges (not vent, etc.)
- Want to buy: Tiptronic Transmission Pan
- Xpost to a more active forum... Lighting up a boost gauge outside a car...
- Quick pics as promised to RayKhan this afternoon...
- SCANNER INSTALL ---Im trying to Remove my ashtray looking for advice... STFA
- I need a stock ECU: 4B0 906 018 CH
- Aftermarket Warranty after factory warranty is used up?
- Friday is going to feel like Christmas...Control arm kit will be here, also an upgraded tranny mount
- K04 sale @ AWE...is the bump from an X chip to a K04 worth $1199
- So I was on the highway for a few miles, stopped at a light and I hear some ricey junk as I take off
- double din faceplate for a carputer LCD
- woot! PureMS stress bar installed...
- Any 2000 1.8T A4 guys need an unmolested ECU??
- this thing is supposed to be a coolant temp sensor and what are these broken hoses?
- with all this sludge talk.... what should I do?
- lets play a little game i like to call....name that problem.
- pnwed.. trying to leave the jail the car wouldnt crank and start.... lights go dim
- P0102 + ABS + ESP
- new intake, check engine light
- Madan-- please pick up the white courtesy phone!
- Is 16X6.5 ok to run? Looking at Unique Steel Rims on Discounttire
- Thermostat replacement A4 1.8 TQM
- IS Coils
