- need exhaust diagrams & info
- What are all weather mats worth?
- blower box remove
- hook up my ipod?
- Winter mode: Phase 1. (and some interior shots)
- best shocks for stock sport springs with possible future upgrade to aftermarket sport springs
- building your own series resistor for aux fan?
- After a new radiator and a subsequent coolant flush, I was expecting to see cooler oil temps
- dumb question......
- Stock DTS / stress bar / cross support Question...
- Insurance claim question
- To solve my leaky turbo woes, I think I'm just gonna rebuild my K03 Sport. Anyone done so before?
- Help!!! power steering flush
- Looking for a new headunit for my wife' double din Bose system
- Obligatory car cleaning today....
- What kind of intercoolers are people running under OE RS4 front bumpers?
- I posted a couple weeks past about a problem with the clutch...more>>>
- is it hard to install a front mount intercooler?
- Car was paint balled last night WTF people suck..
- 99 A4 electronic issues: Please help!!
- mmmmm vvme 6000k HIDs
- Cheap AEB O2 Sensors?
- has anyone try using 2 diverter valve?
- Fair Price for 2000 Stage 3 A4 with 112K miles?
- Been out straight working the last week or so.. what have I missed?
- E-code Turn Signal Question
- So installing new coil packs and...
- B5S4 vs. B5A4 - which would you make into a DD, and which into a track car?
- Weekend work on hault.....
- chronic limp mode
- Anyone on the board ever attempt to install one of these? Did yours come with instructions?
- My central locking pump stopped working....how do I open fuel filler door?
- Does anyone near Philly have a Bentley that I could borrow for a few days?
- I had this thought last night and a friend of mine brought up tonight, too. What are the odds that..
- 1998 radio plug and play for 1997?
- Heh heh: What do you call a Skoda at the top of a hill?
- so does anyone have a boost gauge that actually matches the interior lighting?
- Residue build up on ignition coils
- WHATEVA I DO WHAT I WANT
- Where can I buy just the bushings and brackets for front H-sport sway bar?
- Ok...don't bite my head off. I have a quick VW related question.
- Can someone tell me what this hose does?
- SIII+ help: I finally had all of my problems fixed
- brake pads dragging after tire rotation...
- I'm going to cover my shifter surround with black Alcantara/Ultrasuede...what
- difficult to diagnose brake issue
- Leaks (please help)
- ross tech key usb vag com cable in the classifieds. or email me if interested.
- Im going to say this wasn't my car... (but it was)... any diagnosis?
- Plugs/Coil packs..
- Is '99 2.8 5V engine AKA 061110?
- Any vendors open on sat that carry metal rear sway links? My right one is completely broken, bar rub
- Audi or german repair shops in Charlotte, NC area?
- Battery well filled with water. Causes passenger side flooding. Found TWO drain holes.
- Leaking hydraulic fluid??
- AZ potd...
- Finally after months of annoying dash warning lights.....I can breathe.
- Looking for a (8D9 953 503D 01C) 97 avant wiper switch with computer
- where can I get the rebuilt parts?
- ACNA in northern Ohio?
- Having a really tough time finding what socket size I need to remove sway bar. Boss bringing tools
- Hi, can anyone tell me where this plastic plug goes?
- Oh no! Coolant in the cylinder!
- I just can't put into words how disappointed I am tonight. 14.281@95.99MPH
- is this the crankshaft position sensor?
- Approx how many miles does your car take to hit full coolant temp on a cold start?
- Dipstick tube breaking on older 1.8 T's?
- Question about skill level / experience -
- help me deicide what to do with my car.. pseudo-feeler post
- Anyone have a quick guide or photo to the color-coding of 98.5 A4 lighting wiring?
- BTW, Silverstreakin', one of our cars apparently made RedlineTV...
- Does anyone have any pictures of where the vacuum hose is? Or can someone get one please??
- more codes after a new chip - does this mean my ecu is KABOOM and need a new one
- Help me diagnose front suspension problem
- Which brand/type of PS Fluid can I buy at Autozone?
- FMIC necessary with K04/Hammer on AWM cars?
- cruise control doesn't work, and there's no spot in the fuse box to insert the fuse!!!!
- Paging phil2.0 can you take some pictures as you install your head unit i might follow
- Not a bad looking car for $54k....
- no heat .. possible core problem , advice please
- Paging A400. Who is Peter Link? Where can I contact him?
- Where can I get just the MTM-k04 chip? Is Hoppen the only dealer?
- Anyone happens to know injector size and make to match K04 on AEB engine?
- What color caliper paint would match dark blue paintjob?
- A few problems.....
- Hub Shark versus harborfreight wheel bearing R&R tool
- Strange Noise
- I broke something while fixing something (typical)
- Looking for info on this clutch / flywheel kit
- Oil on plugs? Bad gasket?Any advice appreciated!
- Are the engine mounts the same P/N on a '99.5 A4 1.8TQMS?
- Can someone tell me what the symptoms would be if there's a break in the combi valve hose
- Since my car will be parked mostly all winter, should I get one of those battery disconnect switches
- Just bought my suspension for my E30.
- Tie Rod problem?
- Does anyone have an extra Non fouler, Long drilled or non drilled they can spare? one more Q..
- Kris Hansen: Did you ever get to try the 2 cycle oil?
- Hello Gent's, quick question...
- Does this sound like a CV/ axle issue?
- Anyone in need of stainless steel braided brake lines?
- which tranny does the 12v have? 5speed manual
- Poll: At what mileage did you require a new clutch?
- Photoshop anyone?
- Anyone know if the Hotchkis sway kit is different from an A4 to an S4??
- Just did VC job but need togo back in . Should i buy another gasket?
- Trivial Question. Im STFA now but in case someone knows....(Clutch Q)
- If you buy a chip that requires soddering onto the ECU..
- Some wee little changes....
- Need pointer on where to get mtm chip for k04. Also, which injectors is this tune for?
- European Mirror Glasses...
- Can you disconnect the speed gauge on an O1? Or blow the fuse or calibrate it using VAG?
- 1 piece headlight outer rubber gasket
- Mounting front 6.5" speakers
- Tomorrow's weather looks good for Englishtown, NJ. Last Friday of the season...
- Audi B5 A4 reliability (and response to last time I posted)
- Yo Avalon....whats the scoop?
- In-op / Intermittent ventilation fan . . .
- Can't believe that I have to post about this BS again, but...
- Someone help, looking for link to right angle non foulers...
- Occasional starting problem - 99.5 A4 1.8T
- Rear Caliper... tiny whole in dust boot...replace seal and boot....
- hard starting,.. exhaust cloud... stink... 30v 2.8
- New Turbo Time
- gauge lights dim/rpms move while rolling my windows up at idle
- 97 A4 1.8TQM 155K whining noise from tranny/stick under load
- TEASER: V-Maxx Quattro Coilovers, container arrives soon...
- Anyone have good lead on 00 or 01 A4 1.8t 5speed within 200 miles of cincy. Little brother is lookin
- Follow up.... Clarion FB275BT (black)
- Ok folks, my Palm M100 is in the classifieds waiting for you to buy it....
- Paging Mandeep...
- I think mounts are culprit: Sometimes if I try to shift into 1st (at stop) it does not go all the
- need help with upgrding 97 a4 tail light to 01 a4
- Help finding Oettinger style lip spoiler? And don't let wife drive the car!
- replace crankshaft position sensor (078-906-433-A) or vehicle speed sensor (012-409-191-D) for P0322
- Can anyone point me to a "non-fouler" write-up?
- Does the AHA engine have a WOT switch?...
- Quick Question (Sort of STFA but theres just way to much) Y or N question...
- Is BitJockey still alive?
- Does the Labree HFC need a reducer or any extras to fit stock downpipe...?
- Would it be easier or harder to replace the engine mounts during a clutch job?
- Anyone install OEM heated seats in a non-heated car? Searched for a hour with nothing? Part Numbers?
- EPL Dyno Day Dec 8th : Spots are filling up fast!!! - 2 Spots left.
- Where did you get your Milltek HFCs?
- Help, car slow to start...(more inside)
- car randomly stalls. recently replaced engine speed sensor.
- Fender replacement.....
- OT: SKIERS & RIDERS: TGR Ski Movie Tour THIS week - NY/CT/Boston
- Modified....back to the post on thread sealer for the injector seats
- Carson... could I get some input?
- what a night for lights... front fogs and rear fog needed, snow flake, butt warmer on #2 and a CEL!
- My second Greddy FATT died.... Along with my battery... D.mn that thing is
- Thanks APR !!! Got mah DV back... put it in...
- I took some tint off my windows tonight and it came right off in one peice...
- My headliner is coming down bad...What do you guys suggest I do?
- Dealer wants ~$250 for front passenger speaker woofer. so where else do i look?
- Jerking
- i may have missed it being posted here, but I found the 034 practice Vid from Laguna
- Carfax acct anyone? Now im pushin it haha
- B5 Tiptronic Transmission Filter Change and Flush write-up
- Drivetrain issues, thinking slave cylinder... opinions would be much appreciated.
- My idle problems - first ram error
- Anyone know where I can get a rear bumper remanufacture for cheap in atlanta area?
- Hey guys. I need some help. I screwed up a CAM tensioner gasket job. Got fault code 16727
- :Old school guys: : Stripped my thermos. housing thread, Cant helicoil it....... Help!
- What spring/strut compressors are AWer's using out there?Thanks...
- So I did an inspection on my car today and wrote up a list of everything I could find/think of
- Amusing test drive story...
- What else should I do with timing belt and water pump
- VVME order - how long did it take for you to get your HID conversion
- having the ram error and the tuner wants to send me another chip
- suspension rattle/clunk questions.
- Powder coating rear caliper housings?
- Has anyone ordered any of the slotted/drilled rotors of eBay?
- Secondary Air Pump Hose Part
- Where is the best deal to replace my A8 brake rotors???
- So, just to be sure... starter/alternator from an AEB in an ATW. Yay or nay?
- Pro Clip no longer sells the radio mount?
- Le Mans series from monza on speed
- symptoms which your car may have and you diagnose a sh!tload and other sh!t happens
- those with ice-link, is there a way to scroll through the ipod without pulling it out?
- I got an APR chipped ECU that I just pulled from my car (99.5 A4 1.8TQM)...
- Who wants to trade stock 16" wheels (5 spokes for 10)
- Finally converting some raw materials into some new mods...
- Stratmosphere - Hyperboost in stock and ready to ship!
- what was the first year that audi offered the sport suspensin in these cars?
- Turn signals and hazards both died at once - relay?
- Just did timing belt, water pumps, tensioner + 60k service for $1,100 - fair price or rip off??
- Anyone use LuK clutch parts on their A4?
- will a passenger side mirrow from a 2001 fit on a 97
- 4.0l 6 cyl....low oil pressure. Diagnosis, is it the sender, gauge, or actually low oil press?
- Looking for a pic of a giac socket chip on an AEB ecu.
- Car knocks when it is worm but not when its cold....
- ANyone use ATE (Auto & Truck Electronics) for ABS rebuild? Lifetime Warrenty- $150
- Does anyone here know anyone or have experience with installing a B6 cluster into a B5 A4?
- Paging GVee...I found silver mirrors at the junkyard today.
- Will a 2.8 fit in audi a4 1.8t?
- Paging Nate or someone who knows part #'s
- 034Motorsport Time Attack VR6T A4 sweeps Redline's modified class at Laguna this weekend!
- dumped 99 a4 BOUGHT 90 audi 200 but it takes a long time to kick over when sitting...wuts wrong?
- Just incase he hasn't received enough praise already... Brian @ avalon = an amazing person to deal
- Does anybody besides APR make this gauge pod?
- How do you bump a thread here?
- : :X Post and Small problem (WG Actuator) : :
- Gas milage ~24MPG Highway?!
- What year locking remotes can we use with a 2000 model car? Any of the newer ones work?
- So what are you eliminator-turbo users using for an air intake?
- Temp gauge oddity...
- APR software changes
- My babys new home fo the winter!
- Hey guys, I just set up a new email address for suggestions and comments
- Need help: Is a 2002 B6 1.8T Engine and maual Tranny fit in a 1999.5 B5 ?
- 99.5 Auto A4 wont go into Park......
- 1997 A4 12V6 Throttle Q:
- Is there a trick to getting the coolant temp sensor to seat properly?
- Looking to install off-the-shelf GT28RS. What "piping" elements do I need...?
- So it's taking longer to get to operating temps since the installation of S4 bumper...
- Tantrumwerks Phone Number?
- Pre-emptive repair on sun visor 'rollers'
- My sunroof is making a lot of wind noise at speed, so it might be time for a new seal (?)
- Son of an onion. Best place to buy a starter and alternator?
- Oil Light came on and started yelling at me. Pulled over, engine sounds fine, and oil level is
- Anybody between Amsterdam, NY and Utica, NY (off I-90) that can help me out??
- Rough idle, restarted problem gone
- part number for an N75F???
- If I de-sauder(sp) a giac socket chip from a 8DO 907 558 M ECU, does it put it back to stock.
- Power Steering Pump Replacement - Bleeding problems
- Double checking - 2001 1.8T Passats were ATW and used standard K03, correct?
- Too cheap? <edited with some responses>
- New radio time...
- Old link I have on my favorites.
- Been sick all week so today i decided to install some HID's
- anyone have these?
- super bad idle - car dies now white smoke is comming out =( - wth is up
- What is a normal range of MAF readings for a chipped 1.8T (AWM w/ stock K03)?
- Need some quick help please. Trying to get the CAM tensioner off of a 1.8T
- Audi S4 (B5) 2000 - 2002 coilovers fit my A4 2001.5?
- I assume our cars have a low brake pad warning? What is it?
- check out my cool codes
- NO AM reception at all
- FB: wasted spark & batch injection
- Anyone have old tail lights lying around?
- Is a manual trans from a 96' 2.8 the same as a 98' 2.8?
- Will all know about the "pour sand in the intake to clean/port polish"
- has anyone try the water fuel? water4gas.com
- Anyone know where video of audi vs bmw AWD is? The one where they put the rear tires on rollers and
- I'm loving the block heater on the Golf. Now I'm considering it for my Audi and found the factory
- Coolant emergency
- Another satisfied ModuleMaster customer ---->
- My new wall o' fenders
- Do B5 and/or B6 OEM Audi S4 wheels fit on a B5 Audi A4?
