- woud you have a mech. check car before you buy???
- i also got a speeding ticket tonight...
- Well how gay is that? I got a speeding ticket tonight.... (details inside)
- That was fast.
- Washed out Brake fluid from under master cylander...
- I am looking for a good 97-98 A4......
- Turbo Timers
- Noob who just bought a 99.5 1.8T FWD
- They say this is for european cars only, is it possible to somehow fit it on a north american car?
- Fuel for GIAC chip
- What side skirts are these?
- Q about injectors and 01
- Help! My Spedo is possessed!!!
- up to 80 sigs
- Diverter Valves
- Brilliant red w/ CLEARCOAT?
- Chip...I'll admit I was wrong...
- PhatBox
- What kind of glue/double sided tape should I use to install this CF lip?
- Problem....
- Shocks for sale???
- Brake pads
- new boost gauge, and some questions...
- need some advice....
- i am teh racecar driver now
- "98A4 1.8QTIP Owners manual
- Awww f#%king hell!
- Light Weight CH alternative?
- Andy Sprague grills arrived today. Pictures and details inside.
- Some pics from SoCal vs. NorCal
- To all that talk SH*% about those less knowledgable than themselves!!!!
- so I'm going home to NY this weekend to visit my girlfriend
- Anyone have a4/s4 pics with axis spiders. Idea after seeing the car below with supermesh = HOT
- mass air-flow sensor problem?
- Let's play "Name that supension noise" !
- X-Post: Lltech strutbar questions
- Ran some asian dude in a Black A4 this weekend
- Weight of OEM 8-spoke 15x7 wheel? Not in tech section.
- new wheels on
- Anyone running Flik Justice wheels or have any pics?
- Does anyone here has the Neuspeed Sport springs with Bilstein (grooved). Height issue...
- HELP- A4 Wheel (offset / width) question
- Looking for Dark Blue '00-'01 A4 1.8T Quattro !!
- Run with couple cars..
- Cat back means....
- So I was thinking of buying just one eye-brow...
- OK, pic for yesterday's post. Did u get it? :-)))
- Hissing from air conditioning after I turn my car off. Any ideas?
- Can anyone help me out?
- Just found these shots of my car.....
- CHIPSTAR, I noticed in your pp that you have a pioneer cd changer, and an alpine HU...
- Any good Audi shops in Concord, Ca?
- Some jerk opened his door to far and hit mine.
- Someone please answer, emergency...
- post pics of your widebody A4!! need to gather some ideas for widebody project
- Anyone have a pic of Flik Lex wheels?
- Ok who has a Stock CH ECU???
- Been gone for a while...BWW
- If sport wheels are 'Swing', and S4 wheels are 'Avus', what are the OEM 5-spoke 16" wheels called?
- forge 007 on the way, install standard/reversed and why?
- Looks (sounds) as though one my wheel bearings is shot at 37k
- who here is in wilmington, nc? saw a silver b5, rs4 kit, wheels, cf hood, wing
- ATTN: JHam_CT....YGM...
- hey notjcs: did you ever solve the noise with your Stoptechs??
- What would you get....
- Reasonable-Audi Mechanic near Jackson, NJ (Wanted)
- Can anyone help me track down a passenger side rear door, painted santorin blue?
- Supension Done
- Anyone have instructions for putting an A4 into the "service position" with the nose extended
- Where can i find a leightweight steel flywheel and a performance clutch?
- Regrets on my tinting
- Hey Chipstar, did you ever find out what was rubbing at slow speeds
- Look what came today!!!
- What do you guys consider a good deal for the labor on a 1.8t timing belt job?
- Which wire is the antenna wire on the 1997 central locking system box in the trunk?
- Where is the cruise control actuator on a 1997 1.8? I've heard this may be why my CC doesn't work..
- Does this come with....
- Curiosity Question: Would a tank full of Sunoco GT100 help in passing emmissions testing?
- Is anyone running RS4 replica rims?
- Does anybody have any window tint suggestions?
- Can someone please email me the bentley cd?
- will S4 DTS fit on an A4? both are manuals and quattro...
- Sportec US distributor?
- Fuel Injector cleaner
- Did you sign up today for Lime Rock,CT track day in June?
- Looking for Cat....
- need sunroof replacement procedure guide
- Much thanks to josh for taking this picture of my car at the event!
- Who was it that found a good source for good quality M3 Lips on E-Bay?
- 1998 a4
- finally fixed boost guage, how to prevent kinks in vacuum hose?
- question about E-codes
- collar bolt removal
- immobilizer
- Pics of my car at the euromeet.. (probably some of the last pics of my car) :(
- Paging iamMatt...
- any recommendations on places to get wheel bearings replaced in central jersey?
- european headlights!!!!
- Is the plastic belly pan necessary? Mine's falling apart on my 2.8 30v and wanted to know if I
- Clutch Installation
- need help! tiptronic problem..kinda serious
- TURBO THAT WILL PROPEL YOUR A4 1.8T 8 SEC.
- wow...anyone need some bling?
- Catalyst Bank one-operation too less, what's this mean?
- clutch questions
- very bad light bulb comparison
- S4 Rims
- What type of oil should I run during this time of year in NorCal?
- Anyone have any pics of the 18" swing wheels on an A4
- 30v thermostat
- A few hundred random 1/4 mile times. Interesting to see what some stock cars can do.
- with KO4 upgrade turbo and EIP high flow cylinder head what should I be lookin at for HP?
- Anyone know of a new 20AE GTi on a lot? or somone selling private?
- Need new wheel bearing, shops to do hub at same time???
- Automatic transmission problem, gear does not release
- New turbo for under 1500? any ideas?
- Anyone know a place in the Hartford, CT area that could polish the exterior of my intake manifold??
- good Audi shops in RI??? anyone?
- Drag Day - May 21st - Lebanon Valley Dragway (New England/NY), sign up info...
- intermittent misfire...
- Avant owners with tint...
- New Sig.
- A4 - Windsheild Wiper Relay
- Anyone know what years of Passat 1.8T are Non-DBW?
- Massive Radar Trap!!!!
- How does the RSQ turn?
- Anyone know MtnA4? I really need to know how he did this. (email address not showing up)
- Recaro update.......
- Anyone have comments on Mini Motors in Madison NJ?
- My 2 A's
- Need help. Would someone in Central NJ be willing to VAG my Car.
- How can i make my car do a 10 sec 1/4
- * * * * Mod Raffle 3 sponsored by AWE Tuning has begun!!!!!!! * * * *
- Forgive me if this is a repost: Socal/Norcal petition
- boost gauge pod review xpost
- Need Some Help
- Climate Control Problem on a 2001
- Really weird starting problem...
- Midwest Question
- cars running again... (long)
- Gotta do a new turbo.. whats a good deal?
- anyone have a pic of a silver car with BBS rx on it?
- best after market performance dealer?
- Damn. I just can't get enough of...
- paint is chipped, what grit sandpaper do i use?
- SOCAL VS NORCAL PICS! bww..more inside
- uhm, wtf? pls help
- stolen jetta recovered....
- who makes the 18 inch s4 wheels?
- whats the first cosmetic mod i should do?
- need some new parts. what to do?
- Hey Chip,were you out driving in the snow?
- Does anyone have a set of leather seats (Preferably black) that would fit a 97 Sedan?
- What did you do with the rusty staff of the...
- First speeding ticket in CT
- Airbag light 1998.5 a4 a.18t
- What can i run with this set up...
- this board is great and it sucks at the same time
- Radio display help
- HELP powersteering fluid?
- HELP 18' wheel set up. what did you guys use?
- anyone running the N76 racing valve?
- Bad ATP Turbo Experience
- anybody here from virginia know a good traffic lawyer?
- anybody have a spare shift knob they don't need?
- engine light?
- How to make a mountain out of a mole hill 101: ARM1 A/F meter Install
- How damaging is a chip to a stock engine?
- high temp plexiglass
- paging andysprague...
- 'Airbag' logo piece needed
- Stupid Exhaust System Question
- bigger maf? possible? stupid? opinions
- Problem w/ fellow Audi World A4 goer...
- I think a piece of a bridge fell in my car
- considering an A4 1.8t for
- '98 A4 Avant Stereo Question
- What new wheels should I get? Recommendations...I have RS4 wheels but looking for...
- stolen!
- anyone found hardend gears for the manual??
- BMC Airbox
- How do I get the front ABS sensor through the bearing housing (doing front wheel bearing)?
- Water pump leaking after timing belt changed
- For those with Rieger bumpers....(install Q's)
- AudiSpinz are you out there
- any1 have the neuspeed chip?
- Manual or Auto? What do you guys think? here what i think.
- Magna Flow exhaust
- Going w/forge 007 dv, where can i get one in PA
- Vibrating 1 Piece Headlights
- Exhaust and Control Arm Questions Please Help?
- A transmission is so heavy, unbelievable.need to start making em out of carbon fiber or something ;)
- hey quattrofrog... what exacly do you do at the dealership?
- car broken into last night...
- S4 2000 radio dash kit
- Turbo back exhaust
- HOW MUCH would you PAY for this??? help please!!!
- Timing belt changed, battery was disconneted, TBA required?
- 1,8t k03 users, favorite Diverter Valve?
- getting new spark plugs. thinking of the NGK BKR7E...
- S4 rotors on A4 1.8t?
- OBX? yay or nay?
- Please help me with my HID Problem
- Relocating oil line, wtf? bull****?
- AUDI HEADLIGHT WASHER ASSEMBLY
- Stereo is finally done (BWW)
- Norcal vs Socal Pics....
- anyone know how to get the t-28 manifold bolts tight on the top what tool do i need?
- happy easter fellas
- anyone know anything about AST suspension - there's nothing in the archives
- So i think i might be buying a new car (more)...
- Would you buy this pimp A4
- ko23 turbo upgrade
- Before and After Pictures
- APR Boost Gauge - With or Without Vacuum?
- does anyone know where I can get a bolt like this in the pic
- speaker sizes for 2000 a4 quattro
- happy easter to all that celebrate it; hope none of you get beat by VW Rabbits @ a traffic light!
- Question Regarding Diverter Valves
- Photoshp request for these rims PLEASE!
- Squeeky Front suspension
- Cleaning The Headliner Made Easy & Inexpensive
- stage 1 brake upgrade...
- H&R Sport Springs vs. Eibach Prokit Springs
- What do people keep PSI set at in their 17's?...just curious.
- so, started priming my m3 type lip spoiler. got some painting questions.
- cheap ways to boost horsepower on the 2.8 30v?
- Headlight washer
- EVO FMIC...what's the pipe size(ID)? TIA
- We got a Passat TDI now, where is my A4 TDI?
- Can a T3 super 60 turbo be put on an A4 1.8....also what other mods would be needed?
- Where can I find this cheap?
- WHO WANTS TO WEIGH THEIR CARS??
- Odd Suspension Question
- Rear Seatback Removal
- Questions regarding bleeding brakes using the Motiv Power Bleeder, already read various FAQs...
- Really ignorant question: what are the best places to put a jack stand under on all four corners...
- mmmmmmm 17x8.5 BBS CHs on ebay (5x112)
- This forum f**king blows these days.
- Hey chipstar, can you tell me about how you installed your rs4 bumper. I just got mine today and i
- Need help with a brake wear sensor light
- there is now one less silver modded 99.5 a4 on the roads....
- Does anybody have pics of two piece projectors on their car. The only ones I could find in the...
- Scary and weird HELP!
- QUATTROFROG question
- Search but info sucks.Anyone with Upsolute or GIAC on 2.8 30V?
- Another Exhaust Tip Question
- Spring Orientation Question
- Install a sub after amp installation
- anyone interested in buying 2000 2.8Q in the toronto area?
