- Just an update since I am home checking where to get CA's... Big Turbo goodness -->
- 99 A4 installing 2000 S4 one-peice headlights
- damn it... the inner tie rod end needs to be replaced too..
- East coast place to get Febi or Lemfo... CA's? I tried Adirondack they sell "Optimol"???
- Been posted before, but I dont know if the video was... Michelin airless tire...Tweel...
- Is there a Passat PN for 8D1-837-019-A-1EJ (Drivers side inside door lever, onyx)?
- How to make $40 real quick?
- [REMINDER] TONIGHT, TUE April 17th -- GTG @ The Stand in Encino (SFV) 7pm
- Well car is no longer in my possession :(
- Hey Everyone can you help out...
- whining noise coming from somewhere in the area near cylinder 4 runner of the intake manifold
- I changed my fuel filter yesterday after 116K miles....
- REPOST: Stg4 SB OFE clutch is in... a quick pre-break in review...
- airbag codes help pls
- Save $154.00 on AWE Tuning Stage 2 Clutch Kits!!!!!
- K04 guys: Ever gone from a crushed 4-bar FPR to a Bosch Motorsport 5-bar FPR?
- After pressure testing my intake and seeing how the OEM compressor inlet hose balloons out...
- Yay! My suspension is on its way! It's a good day! And I am rhyming so much I must be....
- Who's got a catus green B5 with BBS CH rims - pics?
- ECU softcoding (kinda longish)
- aftermarket bumber for a European make Audi whats the real difficulty besides getting one???
- Im in the market for a high quality, 4 post lift. Anyone have any thought or recommendations?
- Poll: Seeing as my motor is almost out of the car..........
- So want to buy a jack, what do you guys recomend???
- BWAHAHAA!!! "When stealing a car is 'legal'" (Audi content)
- Front suspension/steering rattle
- K04 Euro-Spec?
- Upcoming project
- Happy birthday to me and the gf
- ok, who's the guy that lives in Amherst, NY with 3 audi's in his driveway?
- Shock absorbers yesterday. Worst wrenching ever...
- clicking noise
- Thinking I'm going to use 3M paint care products this year on my car. Anyone have a recommendation
- Folks sometimes say our cars have hamsters in them... Well this one couldn't run fast enough...
- WJM and others... need info on load reduction relay
- Faulty instrument cluster in 2000 A4.
- AWE stage 2 clutch impressions
- ughhh....new 4 inch tear along the stitching of the drivers seat....
- 2000 1.8t: The reservoir in the very front of the engine bay on the drivers side is power steering?
- Someone start a candle for those kids at VT. Hope nobody around here was directly effected.
- lower door trim clips, 8D0 853 909B, how many of these f'ers do i need?
- a little pricing comparison...oil temp/level sensor
- APR BBQ SALE THIS WEEK ONLY !
- PROBLEMS WIRING CONCERT II CD PLYER IN A 96 AUDI A4 PLEASE HELP!!
- Anyone feel strongly about replacing this TOB sleeve?
- Dropped the trans + worn AWE stage II clutch (pics inside)
- Any one with a 28rs or higher run down an RS4 Yet, Curious how a BT a4 would do.
- A milestone for the A4 today...
- just ordered a crapload of constant torque clamps....DIE BOOST LEAK!
- SB stg4 clutch is in with UR fly. and, the fly bolts are NOT the same length as stock.
- APR Stage 3 instal blog #2: Clean, nekid and...... painted! ;)
- Can I trust that these are the real deal?
- Does 12 hrs for install on both front wheel bearings and new suspension sound about right?
- figured I'd toss out an update on my 4000 project for those who are interested...
- If I were to get a V1 where should I mount it?
- Need Maf help (wiring problem?)
- Cross country trip
- need help id'ing a noise in the rear
- Auto-RX blog #1
- torque/power is fine to 1500 then nothing
- Quatro rear suspension droop
- Gave the 'ol girl some much needed love this weekend...
- Video Of My Control Arm Test
- all done with this... night time pics FTL... i'll try and get some in the day
- Pics of my new dash kit installed (Metra kit modded)
- w00t! its alive its alive!!!
- opinions: k04 giac software
- Who wants to play name that noise?!
- Y or N. PB Blaster or the like on o2?
- (STFA/FAQ..) Can someone lay out the "tuning limitations" on the '01 1.8Ts for me?
- CC fix in the FAQ (pictures dont work anymore)
- Once again... anyone want to "share" a CA full kit? I did this with a few others before --->
- Need Advice on HID Kits
- Malfunction Indicator Light (MIL) On
- Timing belts?
- ok haveing some big issues need help....
- Can somebody point me to a precat O2 sensor replacement writeup?
- Question? If i lower my car 2 inches will it rub.
- Tire Pressure for 1996 A4
- Since it's slow, everyone post up pics of their Key Fobs.. mine = coolest
- Anyone got a picture of the engine block under the intake manifold?
- Finally got my bumper off after being reminded how it latches onto the sides. Boost leak city
- Do I need "Pulley puller - for removing pulleys" to do TB or it just for Cam seals? for 99.5 2.8V6
- Rant on Stratmosphere and Milltek...
- Does anyone sell new pistons for the front caliper?
- Woot....I've got an economy car now (29.4 MPG)
- Man, I really wish I had a urinal in the garage.
- Speaking of T28's..if I had a PES T28, PES manifold, PES TIP, as well as NDBW 93 AND race software..
- Diesel Mix-Up
- PES T28 Turbo rebuild?
- yesterday i was going to fix a SAIP hose i broke...
- Weekend maintainence completed: Front wheel bearings
- what sized spacers needed for stock swings?
- Tie Rod End Boot Ripped on One Side
- waistegate
- oil out the BOV
- Took my turbo out today for a rebuild but found...
- Today was the day the control arms went on...
- Awsome. Tip tranny is slipping in reverse......
- So I have a problem and need some help, regarding the rear stabilizer bar bolt.
- did some research on my suspension creaking and found out you can lube the control arms>>>
- Streets of Legend movie: B5 A4
- APR Stage 3 instal blog #1: Tear down.............. LONG LONG LONG........
- Power loss at high speed and high RPM
- AWE Clutch and Flywheel Clatter
- K03/K04 Turbo failure: Wastegate actuator melting...
- swaybar links (free to good home) if u pick up
- Trunk BT : Caught a plastic bag in the latch while trying to close the trunk, now it won't connect
- check engine light, and 17536 code...
- Tire Trailer = Finished.
- Anyone tried these Halo(angel eyes) projectors one piece??
- TRE, CA, wheel bearing, or something else? Rattling in front suspension..
- A bit of entertainment for the forum. After all it's the wekend.
- Is there such a thing as QUIET brake pads with good initial bite?
- Less understeer with OEM Sport sways29/16mm or H&R32/17mm?
- bose speakers
- Is this normal? CA's look to be essentially the same.. but.. minor difference
- Late night stupid humor.....
- Part # Request: I need the P/N for the "Low Beam Headlight Relay" - 1998.5 A4 Avant 2.8L
- APR BBQ sale starts Monday April 16th at Achtuning.com!
- Blowdryer for the A4..
- Got my PC16 flashed ECU back this morning, so I installed it after lunch and started logging
- Guys... Need instant help.. on the side of the road with an issue
- Time to play everyone's favorite game: What's it worth?
- Tires cause vibration at highway speed (bad tires)...the question is:
- WHY IS EVERYONE DOING THIS TODAY??
- APT downpipe question...
- Changing radator.
- why does it seem like etka and vagcat don't show anything for awm?
- STEERING NOISE??
- Has anyone ever made a plutonium exhaust?
- vag com
- P/N request: gas cap for 2000 A4 1.8T (ATW)
- REMOVING EXTERIOR REVIEW MIRRORS...ANYONE HAD EXPERIENCE WITH THIS?
- Has anyone on here every done a Titanium exhaust?? I think Im going to.
- Track wheel for a black car?
- Revo Technik welcomes German Speed Merchants of Wilmington NC to our authorized dealer network
- How necessary are the special tools for
- Correded Exhaust tips
- who's silver A4 with avust B5 s4 wheels is sitting on the side of 202S in West Chester Pa?
- Save $120.00 on Borla for B5 A4 at AWE Tuning!!
- Mixing power steering fluid...
- What do you guys think of this as a custom plate for the A4 I'm getting?
- would shocks/springs from my '98 1.8t fit a '99 1.8t avant?
- '99 A4 2.8 Battery Replacement
- Help removing middle door molding.
- Steering problem
- 1996 A4 rough idle when cold
- 1999 A4 1.8t Oxygen Sensor problem ??
- Paging Rob (Rosati) - Your parts came in.
- Mid-Week Maintenance: Replaced transmission mounts...
- Small leak at the gasket before the catalytic converter.
- paging 77' 911: a comment...
- Paging qfrog Ti20 to the allroad forum..Post for Mr. qfrog Ti20
- I year after install (approx 30k mi) and LaBree HFC throwing constant CEL
- clima codes for audi A4 avant 2004
- 98 Avant - how weird... pull the door handle on the inside, and the electronic trunk pops!
- Helloooo B5 A4 forum... I just picked up a 98 A4 2.8 5spd -needs a ton of work!
- Anyone in LA area help set cam timming properly for cash?
- How do i tell if my AC isnt working because of AC compresor being shot or no frion??
- Aaaarrrgh......Now both of my washer pumps don't work.
- wheel spacer question... any downside?
- Clutch needing replacement... symptoms + replacement solutions
- Nice boost gauge.
- Reflections on a suspension install
- OK, every-so-often it's nice to deal with a great company...
- Real quick...please. I need some reassurance. I also hope to forget Quattro someday soon...
- Paging "Rosati" and "Iamsofrickinawesomeithurtsmymanluv" you both have PKG's in teh Mail. ;)
- One of my customers 2.8 30V's wouldn't start for them today, finally did. They brought it over:
- Headlight Help...
- Help!! Tie rod end question.
- ran block 032
- nunya-- ever trace down why you kept losing ATP turbos? I think my GTRS is dying.
- Paging Jprice, Nate...and others.....in reference to previous post about VAG Cables...
- Car won't start - I sure hope it's just the battery
- Damn it. I'm sick of this. I'm going to change my home address to where I work
- pixels.. When its cold they are perfect, when hot not so good...
- This can't be true... can it?
- Caption Contest...
- I might be buying an audi A4 tonight...please read!
- do light weight pulleys really make a difference?? if so what
- Need/want your opinions ...
- The "Engine Check" on my wife's car is on. Any Idea?
- thank you sir may I have another
- Took delivery of our third VAG product last night...
- Paging Audi Junkie, or any other filter smart people.
- fuel problem, changed plugs, old ones were black
- At some point somebody had mentioned very cheap rotors and pads...
- Damage of my car as it stands today. my poor car.
- The insanity continues.....
- Will this work on a B5?
- Anybody replaced their vac check valves with non-Audi ones? Like universal ones, etc.?
- sounds like the fan clutch is getting loud.....again
- Paging Nunya - You're running Addco 19mm rear sway w/o reinf. links, right? How's it holding up?
- Melange Beige owners, pictures please! (STFA)
- 710N DV ramblings
- Yanking on the e-brake gives makes the rear-end slide out to the right...
- Where can i find iamawesome's exhaust clip? thanks
- Day 2 A4 vs. MACK truck reconstruction
- So I'm elbows deep into this engine swap
- Just purchased a 98 A4 1.8T new to the B5 community but not on the AudiWorld board
- crack in Headlight washer pump - don't want to replace it - how to fix "Volcano"
- clutch chatter
- Ebay short-shifter failures? Post your horror stories please, if you have any
- What are these wheels called. and does anyone else have these on their B5???
- Rims and lower door molding
- Biggest DIY yet (for me, sad). CA kit will be here early next week...*Paging Nate*
- FB: progress... matte black is my bag baby.
- Has anyone put Delrin or Polyurethane bushings into their front control arms?
- Insulating or shielding the airbox - 2000 A4 2.8
- I love Rosati.
- Knocking/Tapping noise while letting off throtle in 1st and 2nd gear.. help please :/
- Someone here was looking for a nice B5 yesterday, I saw this....
- ICV - resistance is @12 Do I need a new one
- What is the theory/technique behind subframe alignment to "equalize" camber
- Who has a painted carbon fiber hood?
- would a missing end prong on a GIAC chip cause car not to start?
- Climate Control Problem...NEED HELP
- 18" superleggera's race silver
- And the day just keeps getting better! (sideskirts/door mouldings i won on ebay)
- That's it...I'm done being nice
- Whats the wierdest to thing ever hit your car on the road?
- rant... the $600 alignment.
- Leaky Creaky 1998 B5 Avant 2.8q
- What's required to put B5 S4 seats in an A4 1.8T...
- still have fuel problem, and ready to give up on the car :(
- Ovalized holes in Neuspeed rear anti-sway bar.
- Would you recommend HSports sway bars for my daily driver?
- How the hell does this happen? (and pics of my Ginzo Snub mount)
- any one selling a b5? I'm looking for a 1.8tqm...
- Milestone for 96 A4
- HID Problem! help
- any one know for certain where the oil temp sender is for ATW (not AEB).
- A couple questions about brakes, and taillights, ect.
- Planning on going with J31 K04. Opinion on my current clutch?
- Options for downpipe replacement or repair...
- Look what happened to my Borla!
- Is the part # "8D0 145 156F" for96 A4Q auto 2.8L P/S Pump?. TIA..
- Paging "WJM" couple questions inside re: Water to air charge coolers.....
- I know why A6 Xenons need recode after lowering, but why do A4 stock Xenons NOT need recoding?
- Oil pouring our of car?!?
- vinyl repair kits.. are there any good ones you'd recommend?
- front right tire noise
- Anyone have a spare front plate holder for a B5 anywhere?
- took my vacuum pump out again meanwhile, it's shattered. how to hook me up with a refurb or used one
- Prepping Car for Storage?
- A4 HU Instrument Cluster Light Burned out
- 1.8t vs 6 cylinder reliability
- It just so happens that I need to rebuild
- Stock clutch adequate for a stage I chip?
