- 2.8 V6 12 Valve, makes strange loud HUMMMMM when i start the car, seems to go away after about .....
- Whats up with the Jackstands...
- how come a coilpack costs 50$ at the dealer and ecs sells 4 of them for 82$?
- RaceTec Gen III FMIC
- Control arm help!
- help please!!!
- For those who replaced their clutch and kept the OEM flywheel...
- Noisy lifters are beginning to rattle on acceleration....
- Eibach springs and Bilstein shocks
- Anyone selling a stage III kit?
- Clunking question Help Please (more inside)
- Anyone have an S4 lower rear valance they want to sell?
- Leaking Valve
- Okay what broke this time (Clicking noise dependent with speed)
- searched threads....How do i know if my alternator is a Valeo or Bosch. 97 A4 QM 12v 2.8 v6
- part number request..
- wheel bearing
- LLTEK Cross Tower Bar (Strut brace) questions...
- Good Deal or Not??
- please identify this foglamp trim piece
- Too nice to not wash the car. Then had to squeeze it into the garage slight BWW
- wheels
- Where is the cheapest N75 valve you can get? *new
- Oil pan/gasket part numbers
- Do you have a 2001 w/ the GIAC-X/APR/Any chip in the Orange County/San Diego/LA area??
- WoOT. just go the title to the car today per mail.
- Mmmmm.......now I'm hungry!
- went to dealership for boost leak problem--NO HELP!!!! HELP ME!!! repost for monday crowd
- My CA smog update...
- How can I determine if my ballast died from moisture or H20 damage for my headlights?
- Well, it looks like its clutch time...
- Where to buy turbos? Dealer wants $900!
- Use Aftermarket CD Changer
- Vermonters...if you have a moment please check out the new england regional forum.
- paging....GTIVR62801... carson.... please come to the LC3Y phone
- got gunk?
- anyone ever buy any BBR sports line stuff? the website dosent work....
- bad outside temp reading... making climate control react incorrectly
- Thermostat location
- Anybody tried EBC Yellowstuff pads? Will be occasionally tracked.
- what a pain. called the vw dealer which is way closer than the audi dealer and they are out of coils
- Recommendation for good Audi mechanic in Livermore area?
- Oil Pan threads stripped!!!!
- Engine Diagram for 1.8T
- noob question
- Do I have to put front end in service carrier position to replace alternator on 1.8T?
- got new spark plugs and swapped coilpacks from cyl 1 and 4 and the misfire travelled with it
- Cluster Bulbs 1996 A4 Quattro
- gO sIRIUS!
- 1997 Audi A4 , 2.8, Catalytic Converter Failed.
- Does someone have the coil pack part number for a 99 1.8t? thanks
- Searched, not much info, carbon M3 lip spoiler.....
- what is the value of a 2001.5 a4 1.8T avant?
- Just bought near-new neuspeed race springs on ebay for $150 in the box. Shock suggestions?
- Repost?
- bully clutch kit on a b5 anyone heard of or have ?
- great weather for a car wash.. (pics)
- About to buy a 1998 A4 2.8 Avant - need opinion
- My new subwoofer setup. Turns out Cursh is good for something ;)
- My A4 dribbles...
- Burnt throttle body?
- Anyone fixed trip computer MPG readout w/o replacing the instrument cluster?
- Who sells a decent control arm kit?
- 1998 A4 1.8t - rear stock shocks - does anyone have??
- Jeez...talk about stealership...just called audi of wallingford....
- Wheel Bearing Change BT....can you get the hub out without a press?
- Recommended brake pads
- ODB-II code 1296 - What does it mean?
- w00t, electrical cleaner spray fixed the cruise control!
- Rotors
- Anyone have a badgeless FK grill?
- tyler smith are you there???
- Wiring 2000 S4 Projectors (DOT USDM), into my 96
- About to join the ranks of parents
- Does a 99' 2.8Q 5spd have a trans-oil cooler ?
- picked up the '98 this weekend, i had no idea how big of a difference the K04 makes....
- any owners from Richmond,VA?
- next question(s) about my misfire...
- What's the consensus on 2001's: go ahead and KO4 or stay with Xchip
- Will Bilstein sport shocks and springs from an S4 fit my A4? Is it ideal?? RKA, Kris, anyone help..
- Does anyone know what exhaust Flexpipe size i need for 96 12v...i have a leak..thx
- 99 1.8T FWD - Correct Tire Size for 18 X 8.5 ET35 Wheels. Searched but still can't make decision....
- Does anyone have Delta CC unit they want to get rid of?
- so I have a miss fire and suspect the ingintion modual...
- bearing or rotor - sound from rear end (insert joke)
- Repost: Where are the heater core inlet/outlet pipes on the 30v?
- Floor mat questions....
- H-sport group buy
- Looking at Flik Wasps on edgeracing.com Tire suggestions?
- tip paddle shifters in a 97 a4?
- 1997 Audi 1.8T oil problem
- do you guys use gumout injector cleaner? i just used it (high mileage). is it good?
- What are the torque specs for the front swaybar clamps?
- so i vag'd the car and found the error: misfire on cyl 4. also played with lemmiwinks and log'd stuf
- This should just be some good knowledge...
- Did STFA - need good pic of RS4 grill on silver - close-up. TIA. :-)
- ok people trying to get the glue from the tinted windows off but how do i scrape the glue off
- How can I get this to fit on my US Spec A4?
- Rear Humming noise / Steering noise...HELP!!!
- bling?
- cauge cluster/instrument cluster
- new pictures (bww)
- 19" RS4 GB from Achtuning.com, APR Stage III+, FMIC, CF hood/trunk lid, snub mount,
- What do you think about mixing gear oil from red line and royal purple??
- Are all sport suspension years the same, shocks and springs since my neih
- Headlight moisture issues...
- Score, 2 slightly used 15 inch rims for 25 bux
- a good buy?...
- Paging Mr.Alex...Mr.AngryAlex to the red courtesy phone pls...
- Took some pictures tonight, BWW
- Help with my Motor mount install.......
- 1997 A4 Clear Corners..............
- replace airbag seat with recaro airbag seat?!!!!
- Where are the heater core inlet/outlet pipes on the 30v?
- FYI...
- 1997 vs 1998 differences?
- Separating wheel bearing housing and cv joint - replacing outer CV boot
- auto-x today, xpost
- Why do people do that for a gas cap!!??
- touch up paint for 8 spoke 15 inch rims
- [60,000 mile]- things-to-do list.
- wind noise/speaker rattle questions
- Need help!
- pics just for the hell of it
- Just to inform everyone about my Power steering Woes!! This morning
- What would be the most inexpensive big brake mod?
- Has anyone upgraded their dash lights with the 2.0 Watt set?
- Dmak's old A4 is for sale again
- how do i test if there is a boost leak?
- Squeaky noise that stops when i push econ button.. HELP
- Follow up on my Family car outting with a friends supra last night...
- best suspension upgrade?
- Brake "Upgrade"
- Possibly Trading to a local for a MKII GTI in great condition.
- No Audi dealer within 100+ miles !
- [surging]- possible solutions listed, but where should I start?
- 17963 - Charge pressure maximum limit exceeded
- Anyone know the torque specs, when installing motor mounts?
- Dripping Washer Fluid--From the bottom of the Reservoir
- argh blower fan prob
- I'm going to be changing out my rear diff and Tranny fluids with redline next weekend..
- cheapest place to buy a full set of new bilstein shocks?
- 2.8 vs 1.8t
- Just searched over on VW Vortex about upgraded head studs etc-->
- Removing the Glove Box on a 96 A4...
- push down reverse - What model year did this stop? Thanks
- Looking for: Stock Front Springs for '96 A4
- xpost... cheapest place to purchase Falken AZENIS ST115
- Do these look like 18 or 19 inch bbs ch's? Do you think 19's look 2 big in ch's? Or are they a small
- I cant find my wheels for sale anywhere.
- Refilling tranny fluid
- Re-Post: Buzzing Boost Gauge Problem
- how easy is it to mess up the front differential?
- another battery light question
- can someone look up a part # for me?
- Bad milage, unburned fuel smell
- will the lower fog lights grilles from a B6 fit an B5. Thanks.
- Ecodes - Turn Signal (White Bulb or Orange Bulb) what size is that. Tks.
- Ecode install....Anyone have issues with the turn signal wiring.........
- After washing the car today, found another DEEP rock chip in the hood.................
- how much are the bira boxster caliper brackets?
- So, me and the family car decided to go out with the Supra tonight, looky what we found...
- S4 sideskirts price?
- Anyone else get their S4 motor mounts yet? Mine came in today...
- sorry late post, can someone give me height dimension of the inside of the trunk?
- I'm looking at a 2001 1.8t....what does it mean when it has the red t on the 1.8t badge?
- I have a '96 2.8 fwd...I'm possibly purchasing a 2001 1.8t Quattro...Is there anyway to transfer
- Oil, noises and headaches. heeeeeelp
- Had a couple runs with an SRT4 tonight and it was dead even
- what's the difference b/t a 2002 center console and a 2000?
- Silver A4 just on Berlin Turnpike u here. Was the one in the Jetta
- threw a blinking cel today on my way back from work
- changed oil. now rough shifting.
- Cincinnati and their fantabulous roads claimed another one of my wheels.
- Turbo Rattling - Wastegate - No Boost
- Pics of my ride on 19's and H&R c/o
- Sneak peak at cam chain tensioner fix.
- Speedo dropped to zero
- Weather broke 40deg today,...It was time to de-salt the car
- Lower FRONT Control Arm Zerk pictures...
- Latest Mods.
- Front brake upgrade
- Check out my dooley a4
- Stupid question, oil change without replacing filter is 3.2 quarts
- for last nights crew: i tried the sunroof closed and open thing and noticed the draft of air
- I saw the coolest thing today...
- a4 radio says 'safe'
- I'm trying to find the pic of a green audi ...front stance with lip spoiler and lowered...
- INTRAX Springs
- PSA: Pentosin Power Steering Fluid at Strauss Auto
- 1999 1.8T FWD - Grooved Bilsteins from ECS are only fronts. Where can I have the rears grooved. Tks.
- do high performance clutches wear out quicker than a stock?
- fuel injector problems
- symphony swap
- Searching is great. Now I don't want to buy the Neuspeed lower tie bar
- looking to buy rs4 grill... please dont say search
- How many of you think Audi's are unknown to most Americans? [story inside]
- w00t...celebrating one year with my Stg3 kit-->
- Boost Gauge Buzzing Question
- Installing a manual boost controller need help
- ADR Version 2 with tires still fit
- New Grill, what do you guys think?
- TIre pressure for the 18" wheel club with 225 tires. What's everyone running? TIA
- Will a DV from our cars fit a 5000?
- 1.8t 577p ecu wiring diagram Haltech
- Why PES t28?
- Need help/advice on ABS / CV boot and front axle
- Going back to europe in April..any good stops suggested?
- Did a ccompression test...all seems good?.........
- CEL on!!! someone help
- Questions about clock and roof-window!
- what a great way to start work: listening to a shooting that just happened in northern va
- Radio locked out in SAFE mode... (X-post)
- got a new control arm, problem became worst
- A couple of wheel questions and opinions needed PLEASE:
- Strongly considering a 2005 Acura TSX 6-Speed with Navigation as my next car...
- Can I remove my Symphony HU with only two keys?
- ... PureMS does as promised
- how do i put clear corners in an a 97 A4?
- Will tinting my car degrade the fm/am/gps reception? (non metallic tint)
- Getting H/R Sports. Should I get Grooved or UnGrooved Bilsteins to match. 99 1.8T FWD. Thanks.
- Trying to remove my headlights. How do you take out the bottom bolt? Did a search, nothin...
- So I'm leaving my intership yesterday...
- Oil change question (searched)
- Keyless Entry Remote Problem
- Vibration/shudder problems.
- Rieger Rear Window Spoiler...Fiberglass?
- High Res A4 Wallpaper
- Anyone see ATP's latest release??? (GT28rs matted to stock manifold?)
- Re: my CF trunk post.
- Monroe CT Tint groub buy...
- How do I check to see if my 99 is a 99.5?
- anyone besides APR sell CF trunks?
- volcano black a4's with rs4 bodykit....lets see some pics!!!!
- Cant find V&S ss, ive tried searching all over the net and cant find one, anybody have links?
- Smoked Tail Lights Illegal?
- Okay, I finally decided. Getting the Brabus Monoblock VI look-alikes....
- Body-shop question...
- About to clean engine sensors with CRC electronic cleaner.....
- Help please!!!
- WOOT!!! I'm in the Sheriff's department!!!!
- ice>link arrived today...
- APR Stage 3 dyno results
- Is Q-frog around? or does anyone know the part # for S4 grill, and aproximate price?
- Is the 99 muffler/exhaust the same as the 99.5
- anyone have some used front brake pads they wanna send me?
- Trip computer
- do you let your car warm up?
- One more question about the road trip i posted earlier today.
