- Clutch Suggestions for a 01 1.8T A4?
- This is not good at all.....
- pshop wheel request on red B5 TIA!
- new sig or old?
- Are there any aftermarket rear sway bar endlinks beside the CPP ones?
- ARC1 installation
- just glanced over the clutch replacement tech article...
- CEL on
- If i remove my left rear shock and reinstall it, will i need a alignment ?
- anyway to vag the radio so it doesnt turn itself off with the ignition?
- is it possible to smoke side marker (diy) pre 99.5
- Tire question for 18's and 19's
- Sig V1 i have too many good ideas
- Dash kits
- Would my car be considered total loss?
- As I was checking my suspension today... (edit)
- paging chipstar....
- A few questions about brakes
- Quick body shop question...
- Exhaust Lifetime?
- How much is this 97 A4 worth?
- Considering an A4, need some help
- PA request wheel on Red (B5)
- S4 grill on, modding done for the year... and why I am broke
- Vacuum hose problem-engine now knocks when cold
- is the trip computer's mpg calculation still valid after k04'ing?
- anyway to keep my boost to redline???
- mmmm.....salty!
- What does everyone do for a living..
- about to order reiger rs4 frt. $ v1 sides for 750.00 shipped
- difference between "original audi" and "oem non-original" wheel??
- WTK: what to expect with my audi 2k 1.8t 5spd. quattro w/ 40k
- Anyone know of a local shop in LA area where I can get the 14x1.5 tap to fix my hub threads?
- scam??
- Tiptronic problem
- Wet carpet behind driver only what is going on? (more)
- DON'T FORGET TO SET YOUR CLOCKS BACK!!!!
- i've seen it all now
- NE1 know what the 3 place female plug is, that exits the loom under the pwr steering reservior with
- I cant find the APR stage 3 install hints page...can someone help (or offer some hints)?
- Kinda funny....watch out for your cigarette lighter....
- is this old news? everybody seen this? instructor crashes student car
- Performance Review: Data logs and testing of the Phenolic Spacer...
- Spark Plug Question
- lol you guys need to see this...
- OK, turbo is in! Woot! Everything is working but I have a few questions....
- what do you think of this pic as a base for my sig?
- Secondary Air Injection and O2 sensor codes?? Causes?
- how many of these do you see on a daily-basis?
- new article created: FPR install
- Timing Belt replaced now having problems
- Climate Control Display
- Winter rims are finally on
- tranny fluid change interval.... anybody knows?
- Winter mode now activated...
- Stage three problems resolved.
- Check Engine Light - Code P1128 - "Bank1 Lean" - HELP
- 01 a4T quatro- need a good mechanic in brroklyn ny that is open right now. anyone know someone good?
- Anyone know part number for stock 1.8t diverter valve???
- Will this adapter work for my t-28?
- Accident questions.
- So my winter wheel bolts disappeared sometime over the summer- what size are they?
- Does a GIAC chip have their name or logo on it?
- Leaking Window Seal
- Exhaust Problem
- CEL on. Could it be...
- Hey what do you think about Unitronic chip ???
- Concern about engine not warming up to operating temperature
- i can get a 97 v6 a4 for ok price, how much you think you can make parting one out?
- Anybody adjust clutch grab point by fooling with
- Help! (Read Fault Codes on 99+ Audi in Boston Area)
- do regular carparts (Pep Buys, Strauss, Etc.) carry Blitz Wax? I need to get some......
- My A4 1.8T loss its power. What is the problems?
- A couple of questions...
- kudos to awe for turning around my k04 chip fast. thanks!
- dunno, i think a chopped audi is cool :)
- fitting murcielago door handle on A4?
- Knock sound in front end when I take off.......
- is deflating ya 4 wheels for security like stealing cookies from the cookie jar?
- how do you guys clean your mouse wheel? *squeak squeak stick stick squeak*
- Who is running an Under Drive Pulley & Have you had any problems?
- wanted: cheap/free junk single piece headlight to drill big hole in.
- Shaved handles -- More!!!
- Where can I buy?
- Shaved door handles, anybody toyed with the idea or accomplished this project?
- privat kraftwerk
- what does the instrument cluster show when you replace the radio?
- Can someone explain diff between stock a4 1.8t DV and TT DV (75N something)
- HELP!!! Turbo install help needed.
- Getting car from CT ---> California(San Francisco)
- I cant wait to install this new rear seat
- 1996 A4 Radio Code
- Headlight question
- Seekings answers and opinions. (bww)
- 99.5 OEM HID conversion
- Anybody with clutch replacment pix and procedures 2.8Q?
- Can you run a 8 pin from the Concert Stereo?
- Finally..an engine without oil leaks!!!! 2.8 30V 1998Q
- changed my oil to mobil 0W40 and larger oil filter today..
- jsut did home depot clutch stop install, it kicks ass, much faster shifting
- Latest chapter in the story of my winter wheels (BWW)
- Just came across a few of these on ebay....
- Timing Belt
- Heater core Leaks?
- Control arm hits my wheel. Please Help.
- part # request...
- 20% left on my brakes with 3 weeks left on my warranty - beautiful.
- Does the CEL that goes with a test pipe rob a little power? It felt like it pulled a tad more before
- IAT Sensor location???(1996, 2.8)
- 1997 A4 Center Arm Rest
- Post from S4 board.. Someone tried stealing My S4 Lastnight
- should you change your pads if you install new rotors?
- Haven't posted in a long time, need some opinions
- new sig... ;)
- 01-a4-qt --my check engine light has been on for about a week now.
- Comments on APR exhaust for 98' A4 1.8t
- Spec stage 2 or 3 clutch for APR stage 3 car??
- SAFE- I have the code but its getting past the SAFE
- anyone know what the proper temp thrmostat for my 1997 A41.8T is?
- Trunk Leak
- Report on the noon news about more Troopers being added-
- ATTN: Tom Kliem, send me an email if you see this!
- Poll: Please Help!! I'm lloking at getting a new suspension. I have a FWD sport right now and I
- AWE pedal cover fitment = crap
- any events in SOCAL soon? LA area would be nice...
- in case anyone wanted to see my TThuper car....
- Anyone know where I can get some of those kewl neon under lights?
- opinions requested, im thinking about doing a front lip, sides and rear...
- Considering a roof spoiler for my A4
- Concert instal help in 98' A4 with Delta CC currently installed
- Looking for purchase advice & general info
- Check out what was in front of me the other day......
- in normal driving my oil temp never goes above 175 or so.....normal?
- The money pit takes a little more of my beer money.
- buzzing sound on the rear part of my b5 2.8.
- Looking for aftermarket rims for 96 A4q
- shocks settings
- pics from carbonio install...
- I need to replace the tail seal where it exits the trans and connects to the drive shaft (more)
- Some one have contact info for Renn Art?
- why doesn't my cruise control work?
- anyone know where i can find a cap the same size as teh brake fluid reservoir? im making my own
- ALUMINUM DASK FOR MY 1999.5 B5
- is 130mph the limiter on our cars
- I have a bunch of stock parts from my car I am looking to sell but have no idea what to set prices..
- About how much would a s4 bumper installed on my a4 cost at the dealer?
- Where should I go find the M3 lip spoiler for my B5? Is local BMW dealer the best place?
- off clubb5...carbon fiber belly pans...
- Anyone have any good screen savers? TIA
- does canada get tdi A4s?
- Slight click or clunk noise on initial braking......
- REVO Software Opinions?
- city light bulb question
- maybe I'm the only one... but I'm kinda amused by the 1.8T oil light and sludge
- Switching from US to metric
- Moaning noise coming from the steering column
- NOOB Experience (long)
- Wheel fitment help needed fast!
- with the larger oil filter... how many qt of oil do i have to put in?
- STaSIS questions ? Give us a call !!
- on the home depot clutch stop install how long does the bolt need to be?
- New A4 owner with some questions
- What are the signs of incorect timing? I had my timming belt replaced
- AMS 5-speed Short Shifter new lower price + $50.00 store credit offer!
- (A4) S4 suspension on a 2001 A4 1.8TQ non-sport? (B5)
- Does a DBW 1.8t have an EGR Valve? MY2001 to be exact
- Tire replacement question?
- How much could a RS4 sell for in the U.S.? Is the B6 version out yet?
- More about headlight washer, need help...
- so ... anyone wanna sell em their unmodded A4 ? :-)
- Who here has a silver B5 and goes to Fitzone on the circle?!?!
- HKS SSQV or GReddy TypeS?
- Headlights go off when I put the right-turn signal on
- blast form the past...wetteraur k04 kit...
- Should I leave the trim on the RS4 grill silver or paint it red or black? (pic)
- My car sometimes "hiccups" and the engine almost dies, then it catches. Sometimes it just dies.
- Dyno day/Audi GTG at Yarrowsport in Providence RI.
- Who uses Redline Tranny Fluid? Opinions? Problems?
- New pics with latest wheels, from last night's KK
- Why is it so hard to find a Greddy III Turbo Timer and what are good alternatives??
- Impromptu GTG @ Houlihan's in Weehawken, NJ tonight
- Has anyone installed the new Samco Tubo Inlet Hose? Impressions?
- hmmm... me likey
- Thoughts on AWE pedals anyone?
- Wheel & tire's slow today.. OEM wheel question
- What is the best OZ wheel for A4 with sport package?
- Is a ko4-23 a direct bolton to the the stock manifold and cat
- SYED, I want your Flik's!!!
- question about belt....
- Help with VAG_COM code.... What is 17766 cyl. 2 ignition circuit: open circuit?...and...
- Why all the Quattro for sale here in SoCal are TIP? I have not found one Q with Manual yet.
- looking for a 3 inch maf housing
- Wiring kit info please
- anyone have a diagram of how to build a pressure tester for the 1.8t?
- Phil, can I get a part number?
- qfrog, or anyone, my CEL light burned out I believe....
- Eddie from SouthBend...
- 152,XXX miles and my first coil pack went........who would have thought
- car trouble.
- In Search of: Front Valence 1998 A4 (Black plastic)
- If you guys were going to buy B5 OEM one-piece headlights
- will the B6 sidemarker fit the B5?
- Ahh HA!
- knocking sound... oil?
- Paging NOJOI, did you figure out what the code was from the carbonio?
- oil sludge
- When you guys talk about "the track," who is referring to a road course and who means a drag strip?
- Anyone in North Jersey area have the VAG tool I can use??
- Trading my silver Projektzwo sideskirts...anyone have some sides they want to trade?
- Tint for a silver A4? What to get?
- b5 n0ob question...
- planning to change plugs, what do you guys recommend?
- OMG we were kidding about this..... so i thought
- APR front mount Comments?
- Boost problems (non-chipped and spiking at 17lbs!)
- anyone tried the yellow tint for their fogs?
- new best time at the track
- I was expecting that to be deleted....
- Cant we all just get along? hahah
- Xpost to Audio: Aux Input for Symphony Deck
- LLtek Intake + GIAC Chip Good Idea?
- tires
- anyone know where i can get and ABS Speed Sensor?
- black a4 tints, rims, shaved, smoked taillights.. danbury ct area.. SHOW URSELF!!!
- Hey..guys...we're being disrespected on the B6 forum..WTF-->
- bought another audi 01, 1.8T frontrack tip for my wife...
- short version of my car trouble..
- Best Suspension?
- open to anyone in the area,,,Fort Wayne,IN Audi Meet and Drive on Halloween, sunday
- Passenger Side Mirror
- quick someone do a rain dance they can't win!!!
- New Audi front end, circa 1963
- Anyone missing these?
- FINALLY got my S4 rear seats
- GO SOX!!!!
- You gonna let those B6 guys talk smack??
- So I finally drove a WRX yesterday. Didn't feel any faster than my car. Whats the deal?
- city light question
- CEL Codes
- Bumper Dent Fix - Help Please!
- if i beat stock 2.8 A4s (quattro manual) should i have a problem with a 2001 jetta VR6 auto?
- This is just a feeler / inquiry post (bww)
- do you know what audi recomends for tire pressure for my 16'' with 205-55
- The lengths a man gotta go to get these damn wheels to fit
- unsolved mystery..noise, any help? (kinda long)
- Quick! time for some fun on the B6 forum!!!
- Fall washing for the 1.8......
- brother doesnt want an audi..... : - (
- 993 Porsche Calipers vs Porsche Boxster Calipers
