View Full Version : A4 (B5 Platform) Discussion
- Control Arm Bushings
- Wiring in Pioneer Deck to Delta BOSE system.
- Anyone for power steering pumps?
- control arms
- WANTED! Turbo for 99 A4 1.8T
- help stuck in neutral
- rear diff oil change?
- engine won't start
- need help obd port not working
- Temperature Gauge says its -58 degrees? WTF
- Backfiring pulled 8 codes!!!
- Fuel Filter Replacement Issue
- will this ipod adapter work with a bose systen?
- Coolant leaking from hole behind pully.
- My project for the next months
- Bose "subwoofer" amp, XO'd or full range?
- Question regarding Vacuum hoses/lines.
- AIM MXL PISTA install in an Audi A4 B5 - help!
- A/C problem
- B5 camber Issues
- Couple problems come up
- Engine Floods in On-Position
- Interesting noise from my '96 A4Q engine, need to remove plastic cover BUT how?....
- no start issues on '96 A4 2.8L
- Heavy missing/hesitation under very small and very large load/rough idle
- Camshaft alignment and compression test
- coilovers on my 96Q
- Brake Light Warning Problem
- :: ECS Tuning :: 3M Di-Noc Carbon Fiber Wrap Now Available for LESS
- Needs tires, but clears the ST's with tons of room and runs flush with the fender
- audi camber issues
- How to change the Clutch?
- Coolant drain points in 2.8V6-12V block????
- code p1545 help
- '96 A4 v6 starting problem - should CKP have tranny fluid on it?
- "Fan" noise (?) when car is off draining battery over night
- Audi A4 2.8 transmission problem
- '01 Rear Wheel Bearing - Circle Clips?
- Access to the boot
- Carwash broke off my antenna.. shark fin?
- What yrs of Steering columns can be swapped....
- Swap out a 1999 audi a4 steering?
- Vag-com to remove brake wear indicator light
- can I drive with a broken rear coil spring?
- New Clutch, Southbend Stage 2 A4 2.8
- elyte
- Lights! (I want to drive at night too!!!!)
- fuel Economy
- Hoepad
- Inconsistent Starting
- Cyl 4 & 5 misfires
- Fuel Venting problems
- Airbag light question.
- No power to fuel pump
- painting front grill?
- A4 Automatic Transmission Range Sensor: Low Input Code
- Possible head gasket failure!
- Bentley instructions for replacing and adjusting wiper motor?
- Alarm doesn't work....Vag
- Run Away or Run and Grab It?
- p0455
- Oil Gauge
- A/C Condenser Fan Not Working!
- $1000 bet
- K-Seal, Innostop, Headgasket problems
- going round corner and traction control kicks in at slow speed!!?
- OIL
- rear o2 sensor delete
- Audi to climb peaks without a driver?
- radio removal troubles!!!HELP PLEASE!!!
- 2001 S4 Springs on a 2001 A4 1.8T
- Electrical Question?
- My wife put oil in the coolant tank
- fuel system cleaning
- Rear spring cracked
- Sunroof motor available?
- B5 A4
- Lamborghini Gallardo wheels on the A4.. coming soon.
- Seat swap
- Rattling noise from front tire pls help!
- Clutch or Slave Cylinder
- control arm kit and suspension
- X-post: Anyone with a ball joint separator in DC area?
- Need
- Anyone have the Thermal R&D CL Exhaust System?
- universal O2 sensor wires
- Mounting fire extinguisher in B5 A4
- rear wheel bearing dilemma !!!
- Radio on Safe?
- Whats wrong?
- 2DIN upgrade
- Climate Control Panel
- Highway RPMs?
- Soon to be owner...
- Power window noise
- Power Steering Fluid
- loud noise from engine that starts when sitting at street light
- Anyone have parts for a 2 din upgrade?
- Replace coils as a set????
- Can I run wire through the AC unit grommet?
- Turn Signal and wipers not working
- Looking to buy an Audi, need advice
- my car seems to being consuming fuel at an alarming rate! also... other things...
- charcoal cannister
- "Readiness" and VAG-COM Question.
- Battery Self Destructed
- Front Inner CV sticking problem
- failed tbelt tensioner
- 2000 a4 climate control shutdown
- 150,000 mile oil change
- noise from trunk area
- Intermittent oil temp guage
- Key-fob Separating
- Weird clunking and revving
- V-Checker Scanner Pro
- Anyone put a rear spoiler on their 99.5 A4
- Overheating help!!!
- Inside door release has gone 'floppy'.
- New member, transmission question
- heater problem?
- key & navi from a 03' b7 a4 for a 96' b5 a4?
- Speedometer Off by 2mph - VAG sensor G196
- Speedometer Off by 2mph - VAG senor G196
- wont idle on start up
- Summer tires and rims on! Finally.
- what size are inner cv joint to tranny bolts .
- which control arm sqeaks
- What is this? (2.8L V6)
- **HELP!!!**: p1260 p1136 p0134
- 2001 intermittent oil light
- NO fuel and no ignition, WTF?
- ok, Iam officiay lost now.
- Tire Size on Quattro
- VAG-COM scanner
- A damn shame
- Combination Switch or Ignition Switch
- t-belt tensoiner failing,
- Which maintenance parts to buy? (Oil filter, air filter, etc.)
- Speed control doesn't work
- Interior lights not working
- CAN bus loop help
- A4 Rear Coilovers
- water in back seat, alarm missfire, now no start
- HELP-My door won't open on my '00 Passat
- Need help with upperl control arm replacement
- 01 to 97 sport cloth seat
- Revo Technik Spring Sale Marth 27th - April 11th 2010
- rear door panel replacement
- looking for bushing reviews
- Left suspension vibration
- best b5 lowering spring
- First time buyer... A4 or S4 (already STFA)
- Broke bolt in cylinder head!
- 2001 audi a4 windows/sunroof/power locks wont work need answers please
- Is there a way to tell when my timing belt was replaced?
- How do I know if my clutch is bad?
- Super low mileage, Help..
- 2000 a4 quattro, orrrr, 2001 VW passat
- 1999 Audi A4 for sale
- Please help: Windows went "KA-CHUNK"
- Huge problem, need help.
- Pictures of my 1.8T and a few questions
- How to install an aftermarket radio without a wiring harness
- How to Clear False Errors on Driver Information Display
- Innovation? Putting a cup holder in place of the dash ashtray
- o2 sensors
- Failed Inspection P0134 P1408 P1504 P0401
- Problem with Turbo
- Power Steering Issue
- (1.8T) 5 wire pre-cat O2 sensor $52 at Advance Auto Parts!
- 2001 A4 $3,500
- service warning light-turnoff
- swap heater core and only luke warm air
- Recently bought 2001 A4 question on fuel economy
- engine sputtering
- B5 timing belt writeup?
- Horn doesn't honk when doors are locked - fuses?
- How do you Reset the Oil Change Service Flashing OIL code?
- Memoscan Problem
- Just Got 1997 A4 2.7 Quattro - Daily Driver
- 1998 A4: Want to add one piece headlights.....
- Engine code AHA vs ATQ - swap
- 01 A4 ashtray
- Anyone have a 1996, 1997, early 1998 blown 5sp transmission?
- I need to source a Center Differential and rear cap. Know anyone/anyplace?
- Brake Rotors wearing on outer edge only
- 8D0 907 557 P ECU
- Rattle off power, clutch engaged, most distinct from 4k-2k rpm
- Need radio wiring help with 2000 A4
- S4 HELP!!!
- Recently Purchased A4
- Door handle removal?
- How to adjust 12V timing
- 2.8 v6 30 noise, not power steerin pump
- new winter shoes
- Engine swap
- ::ECS Tuning:: Quick Sale - Warning Triangles and Cargo Nets - 72% - 92% OFF
- 2000 audi a4 1.8l headlight bulb replacement, will these work?
- after market speakers with bose wiring harness?
- transmission problem and engine mount
- heater core problem
- a couple of questions.....im ready to get a new a clutch....im going with sachs, but
- Heater core change, Remove dash help
- Transmission Weirdness
- Buying - 1997 Audi A4 1.8T
- VMR Updated Wheel Inventory!
- Right Rear Tie Bar or as a shop called it Ladder Arm
- Boost Issues
- Brake wear indicator light (O) Help!
- Marbles rattling around?
- 96 A4 2.8 FWD not quattro-noisy front end
- Yet Another 96 A4 2.8L EGR Problem
- vibration followed by check engine light
- Central locking funtions
- Advice..oil overfill, ignition coils, o2 sensor
- Ring Job
- Will a maf out of a 2000 a4 1.8t work with a 1999 a4 1.8t? Are they both the same?
- same problem.....no speedometer and my fuel gauge acting like a boost meter....i
- Vag com help
- Pulled seat and reinstalled. Now F/B slider lever only locks if I lean back
- automatic or manual??
- where to buy oil dipstick
- abs/brake light
- It wants to shift at 5200 not 6200 RPM
- Water leak... already STFA, but not finding it.
- x-post... Pics & info needed
- 5 Auto Maintenance Procedures You Don't Need
- Oxygen sensor replacement advice
- 2.8 30v noise
- Need coilpack cleaning advice...
- ::ECS Tuning:: A4 FWD APR Turbo-Back Exhaust - 17% OFF - Limited Quantities
- motor swap
- Master cylinder reservoir
- GEARBOX CODE HELP HELP
- Probably buying an A4
- (B5) Audi 1.8T/2.8 Tuning (Turbocharging etc.)
- tail light need help
- 1996 Audi A4 1st gear problems HELP
- VAG-COM
- Hole worn in valve cover......
- Transmission service...to change or not to change that is the question?
- Timing Belt Change - also cam sprocket seal and crank pulley seal?
- Please help :( (Transmission probs) 97 1.8tq
- 97 A4 1.8 - Headlights do not come on?1?
- Transmission Needs
- Help me diagnost my 5 speed transmission problem
- Where to buy some 17" RS4 reps these days?
- VMR | Wheels - V718 Mesh *Photos Updated*
- Favorite DC Area Garages???
