View Full Version : A4 (B5 Platform) Discussion
- b5 help plz! 1.8trouble
- Water on rear passenger floor
- audi 95/96 500 SE
- Difference between 1.8l and 1.8t
- A3
- Bubbling expansion tank
- K04 Upgrade for 01 B5
- Electrical issue killed starter and all windows?
- 2.5 v6 tdi fuel pump
- Headlight washer
- High Rev when car is hot
- my new B5
- Brakes wont bleed, no fluid to 2 corners please help!!
- Central locking
- Audi b5 1996
- 2002 audi a8
- a4 backseats windows switch locked!
- Some wires, idk what is that :(
- New car, to me at least.
- right octane fuel use
- Oil leak from where?
- No stereo power, no climate control power, oil thermal sensor error.
- 2010 Audi A4 Radio
- Won't start after intake gasket change
- wiper does not stop audi A4 quotro 2001
- 1996 A4 B5 Rear Window Defroster stopped working
- b5 a4 grounds
- 2011 Audi A4 Quattro 1.8T High engine oil consumption
- 1999 Audi A4 2.8 Quattro 5 speed p1545 17953 codes?!
- 1998 audi a4 quattro 2.8L 30V.. noise trouble
- 1996 A4 5hp19dcs fwd troubleshooting
- What seats will fit my B5?
- instrument cluster
- Audi B5 1.8T shut down, wont start
- S-line has Plastic on rear wheel wells?
- vacuum line(s)
- Spring grinding sound
- AEB Engine, GIAC Tune, Green Giant, Fuel Pressure?
- blower moto not coming on Audi A6 2008.
- HUB AND WHEEL BEARING SIZES
- Transmission problems with Audi A4 2003
- Sagging headliner - does stapling hold? Other options?
- ******need help*****
- 2012 Audi A4
- Audi A4 B5 1999 2.4 engine AC Fan problem?
- Unitronics Stage 2+ AWM w/ KO4
- Audi A4 1996 not starting
- 1998 A4 Delta CC cassette Radio
- audi a8 laser headlight wiring diagram
- Exhaust??
- IAC connected issue !?
- 1999 1.8T fan clutch needs replaced
- code p0011
- 2009 A4 avant sunroof won't close
- advice please
- Audi A4 (B5) Avant, year 2000 (facelift).
- Replaced engine. Now runs rough and all camshaft sensors are throwing codes
- no power to climate control
- 2.8 30v auto- accesories have power, but it wont turn over
- what is
- altitude (barometric) sensor
- 1995 A4 Immobiliser issues - Scrap?
- Motor swap issues
- RWD gearbox for an B5 2.4L audi engine?
- 99 audi a4 quattro
- 98 1.8TQ owners - can anyone post the following Instruments/Adaption channel values
- manifold gasket
- Colour achatgrau/agat grey
- 1997 A4 OBD wiring diagram
- '01 B5 1.8T Stuttering and violently shaking under acceleration
- Computer very often resetting itself randomly
- Temperature issue
- 1997 audi a4 quattro 2.8 acceleration problems. Loss of power
- What part is this? 2000 Audi A4 1.8
- Effect of a Slipping Clutch
- windows and roof not working.
- DIY melted switch clean headlights
- 1999 A4 Avant Quattro Front end Weirdness
- 98 a4 Quattro 5spd. Plenty of issues I need advice on. You know audis...
- 2006 A3 2.0T Central locking not working
- Help: Computer randomly resetting all the time
- 1999 2.8L A4 coolant overflowing
- Terrible Sluggish acceleration
- New owner... wish me luck
- whining sound from front diif
- 2.8L 30 Valve Cam Chain Tensioners
- Audi A4 b7 Oil pressure
- hesitation, bucking at slow start up speeds...
- Catalytic Converters, O2 sensors 2002 A4 Quattro 3.0 6 cylinder
- Need help I have 2 questions
- Transmission gear exposed
- Fuel Leak at Rail
- power steering pump making noise
- Looked at A4 2.8, advice please.
- concerned
- Are Audi's really as expensive to operate as everyone tells me?
- headlight switch
- Did I make a mistake buying this car?1998 audi a4 2.8 Quattro
- Alignment
- Can anyone help with AAN swap ?
- AAN swap need help !
- 1999 a4 1.9 tdi cruise control retrofit tutorial/parts list required
- Stripped these two bolts, what can I do now?
- Wiper& washer not working
- locked torque converter
- 2.4 b5 quattro wagon ecu/box troubles
- Pressure or vacuum
- Do You have a pic or image of the A/C HIGH PRESSURE SENSOR location on a 2008 A4 2L ?
- Electrical issues
- Can anyone help identify if this is a bleeder on my radiator/location of leak?
- Any idea what this sensor is??
- Audi Quattro alarm
- A B5 Is What I Now Drive
- ECT SENSOR ON AUDI Q7 4.2TDI LOCATION
- Looking for someone to answer my question
- Bluetooth
- B5 Audi 1.8t AWM Overheating, please help
- Throttle Body Harness
- Help cel on after timing belt but car runs perfect
- Rear Differential Cross Member removal....
- Injector Wires: AEB Engine
- a4 sunroof shade slid back into roof
- 2008 Audi A4 Car won't start
- Henry Moore
- NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
- Breather Vacuum Hose Check Valve???
- cheap battery?
- No start condition...Please help!
- Intake issues (MAF, fuel trim, etc - P1141, P1127, P1129)
- 1996 - Damaged door seals?
- G 109 sensor, where?
- Wipers are in off position but still cycling
- Meyle brake pads and disc
- Can someone help me find the part code ?
- where should I ask that?
- 1.8T & 2.4V6 piston dimensions
- Car dies while running like fuel cuts off.
- Wierd Problem with Tranny
- B5 A4 Oil pressure and temp issues
- Mr Vytas
- Oil Light STILL on After Engine Swap
- CHECK OIL ALERT
- 97 Audi A4 2.8 Quattro only starts in neutral
- How to tell if I snapped a cv joint on rear axle
- 2001 audi a4 1.8t --new alternator&battery, experiencing intermittent charge issue
- 1999 A4 S-Line timing belt replacement
- need help please
- Car won't rev high a loss of power
- Tachometer giving bad readings
- Clutch/Transmission Inconsistency
- Engine wiring loom
- excessive Oil in the intercooler
- Climate control issue
- New car
- 98.5 A4 Avant B5 2.8 _ Alternator Replacement PLS Help
- Buy one that needs a little love they said.....
- Audi a4 seat swap! or airbag bypass help!!
- Just want some info
- Check Engine/coolant sensor
- body plug difference between 1.8 and 2.8?
- Swapping a 2.8 with a 1.8 please help!
- Stigan Turbos: any reviews.
- B5 steering rack help please
- 1998 Audi A4 2.8 Quattro Help
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - January 1st - 7th, 2017***
- 2003 Audi A4 FWD,cvt transmision P1773
- 99 Audi A4 B5 Pushing All Power Steering Fluid Out of Reservoir
- Windshield Wipers
- New Koni Sport shocks in front. Sitting too high
- Thermostat stuck in open position, A4 1998 V6 2,4 165hk automatic
- a4 b5 2.8 12v v6 non start
- New car and new to Audi World
- Should I Buy This A4 Avant?
- Having fun with my A4 today
- Coolant Leaking
- Blue fluid link
- b5 wiring diagram
- A4 B5 1998 1.6 owners manual?
- Computer doesn't turn off
- 1999 A4 new transmitter programming
- Overboosting problem
- !AUDI ONLINE PARTS WINTER RAFFLE!
- 99 1.8t avant:What to expect
- 99 A4 1.8T Electrical Problems
- 1997 A4 2.8 REAR BRAKE CALIPER COMPRESSION HELP
- b5 need help
- 1996 2.8l won't start on first crank.
- WHAT DO YOU WANT TO SEE FROM A PARTS DEALER?
- Remote Key supported?
- clicking/popping noise in left rear tire not cv shaft
- ANY INFO OR ADVICE ABOUT AUDI A4 B5 quattro
- Dipstick broke in half
- Flash to pass not working
- Cluster problem
- Coming Home/Leaving Home lights
- Miss fire problem
- ATW Engine No Start. Has Fuel, Has Spark.
- Hose Clamp Sizes?
- Comfort control module
- TCM issues
- gas paddle stuck
- 5th gear & reverse gear lock
- Need help reprogramming swapped cluster
- Gauge Cluster swap question
- Audi A4, 2003, o/s headlight not working
- Concert Radio requiring code?
- OZ Superturismo WRC
- A4 2.8 starting issues
- 2001 A4 Audi Quattro Rear passenger window
- First Post, Bear With
- No reverse after cleaning NSS
- 1st gear stretch AT 1996 a4 quattro
- Coil pack Adapter wiring.... need the colours
- :: GruvenParts.com Performance Parts for Audi !
- Need your expertise, back in the game.
- 2000 a4 b5 1.8t quattro wont start after trans swap
- Cam Lock Tool
- misfire question
- so many questions??????
- Lighting questions...
- 1999 a4 b5 TDI, multiple issues.
- Help PLEASE
- 1.9TDi 81kW turning key - starter not engaging
- 1.8t vs 3.0 ?
- How to recover your steering wheel
- Weird noise
- 98 A4 2.8
- A4 Quattro 1.8 T not starting/ running right
- shaking car and misfires
- S4 vs A4 probs.
- Engine making roaring noise when pressing on gas
- TT 225 engine with an A4 longitudinal FWD trans
- Red Oil Pressure Light
- Manual Locked up drive train ...?
- diagnostic-port and cut wires
- !NEW AUDIWORLD EXCLUSIVE PROMO!
- Hello, looking for some advice
- A4 1.8TQ Low Oil Pressure
- I need help please
- 1999 2.8 Hibiscus
- Problems
- Engine won't turn over
- Engine Light Just Came On
- Any help
- Double Din Android System for B5
- Changing your chrome gearshift trim
- A slight shudder
- :: ECS Tuning :: Stay In Control! | Vaico Replacement Upper Control Arms
- Coolant Leak
- Help needed asap
