- CEL: Pulled P1604 Internal Control Module Driver Error
- How is the CV joint from Deutsche Parts USA on Ebay? It is cheap. How is its quality?
- Can I replace this vac hose?
- Help with Brake Change
- Time to replace TREs =)
- FREEEEEEEEEE stuff................
- Ok to use OEM sport springs from MY2K with my S4 shocks?
- Temperature issue.
- 17956, all valves replaced (calling Audi masters)
- "Windshield Wiper Fluid Low" warning light
- Are V6 and 4 cyl cam sensors the same?
- Finally suspension
- Washington snow (big pic)
- 034 clutch kit owners: How did you break it in?
- 99 A4 2.8qm needs new clutch... worth the $?
- Engine Code help 96 2.8L qm
- MAF and Transmission problems.. !
- Calling ModifiedA4: Was it you that did the S4 oil cooler upgrade?
- Front end overhaul....
- Any value in a catalyst for B5 1.8T?
- Truth in Engineering... this is the add they should haveplayed at the superbowl...
- DungBeetle..RE: fuel filter washers
- Paging: Dave in salt lake..
- Quick part # request , thanks. Anyone have ETKA handy? steering rack 1997 1.8TQ
- attention!!! i have court tomorrow and need your help. has anyone had a speedo read the wrong mph?!!
- Oil filter 068-115-561-B vs J
- Page Carson@Riverside Audi? How much is the outter CV joint on right front (passenger) A4 2.8 M 99.5
- Timing Belt and floor mats. . .
- ABS sensor ring on the outter CV joint is broken. Could i replace the ring only?
- about to order Ocap control arms and a timing belt kit from Blau.. any reason I shouldn't?
- is anyone nice enough to give me the quantities and P/N of the interior bulbs?
- FREE SHIPPING on all Stratmosphere products
- Im sure many of you have seen the new Audi R8 Superbowl Commerc. AMAZING!
- Alright guys, please assist in this PCV BS once and for all...
- OMG! <post from another forum>
- brought the car in after the toe...
- Bioethanol questions - Do you get E85 or E100 in your filling stations?
- oil dipstick tube broke. pull off old one and push on new one? nothing tricky, just snaps on right?
- How much!! ??
- addiction to this forum...
- 1996 A4 car will not start
- HAH...
- sfta about some codes and getting confused................
- How do-able is a clutch replacement on my car? (Details inside...)
- R8, right before ,super bowl
- A cookie for anyone that can give me the correct part number....
- So my car that hasn't been running for 2 years has no spark, ideas?
- Oil Pressure Light ON when engine is at normal temp
- Recent Clutch work
- Normal heater operation...
- Lost 1996 key
- passenger seat headrest button popped out?
- Coolant Temperature / Bad Milage
- delta head unit replacement without bose speakers
- engine cover?
- Bouncing idle question
- in process of buying 98.5 A4...
- Thanks for the support gents.......Come on seriously this is rediculous!
- Problem with the Turbo, A4 1.8T 98,
- Need new front pads - suggestions?
- Whats the difference between 1.8 and 2.8 manual trans?
- Can anyone help me verify that this is the part I need... (part # inside)
- Found the cause of the horrible gas smell...
- Gas Smell in car after gas fill-up
- Converting timing belt to timing chain
- Some new mods completed, finally have most of the engine bay sorted...
- Chased after my old A4 today
- i love this picture (large pic warning)
- Anyone have a Mk 1 Toyota MR2 for track duty ?
- Anyone have these rear sport cloth seats for an avant? ** If so, I WTB!!!
- I love it...
- Burning rubber smell left rear wheelwell
- had car inspected, car was on front jacks and he made my front wheels spin only...
- Best place to buy braided brake lines? cheap?
- alright yesterday my volt meter read 11 and today it reads 0
- So i think my tranni is going bad. opinions please
- AZ warning-->Paul/Boostfactory aka "killa" is a feckin a$$hole and everyone should BOYCOTT them
- 'flaps!
- "Son of a nutcracker!"......
- intermittent hard starting. have searched...
- Pole: 87 octane gas now.... or 93 octane gas purchased in May of '07?
- A sign of neglect
- Heater Problems
- Oil Cooler failure to cause water in the oil and no lubrication?
- NAMOTORSPORTS | Thule Roof Racks and Accessories Now Available
- Help me out with this question...
- Audi A4 heater blues...
- German Touring Cars, Barcelona, Noon- Speed Channel
- wanted; Console shifter cover for 01 A4 Camel Color
- holy crap I am so freaking jealous. 382hp/332lb-ft
- Can there be air in the cooling system if both the input & output tubes going to the heater are
- had to get towed, and dont no whats wrong??
- Just before, I was preparing for my brake hose replacement tomorrow and checking all the nuts
- iirc a member here made "unpimp ze auto" stickers, are you making any more of them?
- Avant Owners: Have any suggestions for a Dog Barrier?
- roof rack fairing?
- 2001 A4 1.8T Engine Pressure Light/ Sludge Questions
- Replacing injector seals & clips.....
- Replacing Delta Reciever on 97 A4..
- SPA's US site is live now.
- This sounds OT, but it's kinda not. I don't get Amazon. I bought a urethane trans mount...
- slider pin - is it connected to the caliper or carrier?
- Heater not working after timing belt change....
- Anyone know a good body shop in central ohio and where u get the carbon fiber shifter surround?
- wheel bolts are dumb... who has studs and where did you get them?
- aww...my battery is dead I just replaced it like 6 months ago too
- Update on exterior door handle not working: It thawed out (more)
- How could I reassemble my front inner CV joint? (put steel balls back in)
- Is there a way to get rid of those damn lower door modlings for good??
- Has anyone here had an experience they could share with me on Meyle ABS sensors?
- ooh la la... stage 3 S4 on ebay
- power locks, p-windows, dome light fubar-ed?
- Anyone got a spare cam sensor laying around???
- Thermostat
- I must say, I feel especially good about my car right now. Been looking at A4's with a friend for 4
- PN request......
- Can anyone translate this? 1998 A4 1.8tQ MTM ECU
- anyone familiar with this car?
- I had to trick ETKA into showing me my PCV setup... =\
- 97 A4 1.8t power relay for the ECU location?
- So the GF got a CEL on her car today (plymouth) just wondering if I can hook up the ole' VAG and
- Photo of my A4 in the snow, WA is pretty crazy now.
- Engine's Not starting! HELP PLZ~!
- What will those crazy Germans think of next?
- Ok so after multiple manifold issues I have found the manifold many have been looking for.......
- Look who just got himself banned from the forum AGAIN!
- 2.8 exhaust flex joints
- Ah the joy of an old car... Found out a few interesting things about our A4 tonight...
- Slipping TRANSMISSION JESUS
- New one on me....car towed in today after going off road last night.
- Anyone know where i can get a Belly Pan???
- How do I fix this?
- PSA - if you're ever in Charleston WV and you need your Audi fixed go see Scott at Sprots Car Clinic
- how would this sound on my a4?
- I need to get a set of wheels and track rubber for next years autocross events
- Wheel bearing noise
- has APR ever offered more than just one level of programming for their non-DBW chips?
- aprA4STAGE3: any updates on your exterior door handle? Same thing happened to me...
- After getting some time to drive normally with the Boost Machine and Stern diff parts...
- Anyone have a set of grey leatherette front seats?? I WTB...
- I know some of you guys dont technically visit awot, but if you have the time, I'd apprecieate some
- hey Bassed, tell me who did the 2.0t swap!!!!!!!!!!
- Recurrent Phatnoise issue and thoughts/questions.
- Water leak in 02 b5 s4
- New FOBs for old audis?
- Hotchkis Sways in stock!
- Workshop Manual Needed for Audi A4 1996 V6 2.6
- three things.
- Hartmann Wheels Blem Sale (part 2, prices and descriptions) *Update 3*
- Will S4 Brakes clear a 16'' rim?
- Just unpacked my Brialle battery. It's tiny!
- 77'911: My 30V is different.. wtf? My hose just goes across...
- 1998 A4 1.8tQ MTM ECM
- White/ Smoke Follow Up Pics
- unstable fuel guage any tsb's for this
- paging Carson:
- Oil Leaks - Should they be fixed ASAP?
- Stage 3 APR For Sale--Price Reduced to $9999--$10k in mods!
- B5 A4 reliability
- Thanks Carson!
- Anyone have Santorin door side moldings they want to get rid off?
- 96 A4Q will not move !
- 215/55/18 are these too big to run on an a4?
- Follow Up : Bike vs A8 suit....
- Wanted Manifold w K03 for 98 A4
- noise from 99 oem radio. Is it a problem of radio or speaker?
- starting.... how's your widebody coming?
- Wtf.... Do the B8 A4's come in 1.8TFSI ? Not 2.0TFSI? I must be clueless...[edit]
- new here and first new problem to greet me
- Wow - there is a sick ass parts car in the classifieds for cheap . . .
- Weather poll ...who is expecting quattro weather?
- fyi: chevron techron fuel system cleaner is free AR at Peb Boys
- OT: Completely OT: For the old timers and those of you who I miss here.... you know who you are. ;-)
- A4 went into the audio shop for a new system.....
- Are there supposed to be 2 wrenches to adjust Koni Coilovers?
- Is the concert Bose system similar to or the same thing as the Symphony Bose system?
- Testpipe CEL
- so while my car is down and out for a couple weeks while waiting for rotors I'm going to refinish my
- Where in the world is the oil pressure sender located?
- RS4 Grill
- Hartmann Wheels Blem Sale (part 1)
- Quick question, are there seperate fuses for the left and right headlight on a 97A4? My...
- Climate Control help requested
- Anyone have 380cc injectors for sale? I thought i saw some in the clasifieds gone now.
- How do you check the transmission fluid on an automatic tranny?
- Not a close call.
- Close call
- Airbag light issues....more inside
- God Bless, Stoptech.......
- Lost cause post: anyone in socal with a BONE STOCK 98-99.5 A4?
- Auto trans Guys: If Trans isnt shifting/acting up which sensor can it be?
- ROFLMAO
- is this 034 Downpipe with 034 Header a test pipe mated to a downpipe?
- Speaking of ignition... think it's worth replacing 200k mile old coil pack connectors (boots)?
- Just placed my clutch order from 034.... 240mm kit and tranny mounts :)
- off another forum: ICM delete for AEB
- TSW Wheel and Package special at Achtuning, 18s and 19s available for a limited time
- x post about my rusty trunk lid, any thoughts about rust coverage? its an 01
- Left window open in rain, leather soaked, now hard/stiff
- Another Exhaust Question...but i did search!!!
- What would happen if you chained a modded Avant to a Dodge Ram 2500?
- Left Brake Light Misbehaving
- HELP: Ticking sound and now misfires (REPOST)
- Will a 2001 TT block fit my 99 A4? I can reuse my AEB head.
- It's official the B5 will drain a battery in the span of two days.
- Replacing the ABS Control Module
- Jiffy Lube scam - may be a repost.
- Boost still flutters at WOT with KO4,PC-16
- Anyone have a VAG in or around Northern DE? Need some help with codes and some overall advice on the
- My A4 in the classifieds... have a look.
- replacement parts...
- Coolant leak from the top of the expansion tank
- anyone heard of Great Atlantic Warranty?
- Update I think im gonna go with GIAC but quik question regarding fuel....2.0GT35 help please
- how many of you guys leave off your oil pan plastic cover?
- Thinking of getting the 034 cat-less 3" downpipe and moving the cat away from the turbo.
- Budget minded summers?
- eibach springs that lower a 1.8t 1.5 inches .. work on a 2.8 and just lower it more???
- Wipers won't work...Blinkers won't work...heater doesn't work...
- uh ohhhh, friend just got a 08' ford focus, who do u thinks gonna win off the line?
- Oil sludge warranty is what? on a A4 1.8t 2001
- For artemm, a 30v engine pic.....
- I have a knack for dodging bullets that I shoot at myself... or I have bad aim
- Need some advice. I have k04 turbo right now and I need to get software for it...
- anyone (I know PureHatred probably does) have a stock front brake set up laying around?
- az warning: not something i would do
- old guys.. does the name Vortrag ring any bells?
- Bumper Grills
- White Smoke
- Pure Hatred, YGM. And...
- Coolant temperature gauge problem
- Trans is shifting poor ---- change the fluid?
- My A4
- service reminder interval.
- NE1 got this part? (headlight switch repair) Mine has melted too far to save?
- oil changing
- I know it's not very interesting, but I thought I might get more attention form the morning crowd...
- Couple of shots of suspension and modded iPhone
- Asked already on S forums but wanted to see what you thought... Hit or skip?
- How much should I pay a shop to change a front wheel bearing?
- Help with remote door locks
- life expectancy of (oem)shocks on Avant q sports (no mods) suspension?
- Rough stages of Zune and Navigation install
- swapped ecu box, from 557 P to 559 C, idle dips down to 500 RPM then back up to 750 RPM
- name that oil leak...part beneath where the oil filter sits
- Can anyone have give me the part number for a 2001A4 shifter rod (fork??) and the main seal?
- Anyone know a good place that can repair rims in north jersey?
- ECU swap: 8D0-907-557-N to a 8D0-907-557-P that is chipped...
- GT4 driving sim almost back together
