View Full Version : A4 (B5 Platform) Discussion
- 01 Missfire issue 1.8t
- 96 quattro a4 engine idle trouble help please
- Rear Brake Clicking noise when e-brakes engaged
- indicator faulty on B5 A4
- plugs full of oil and not starting on first turn
- misfire, wiring, & throttle body
- How a failed clutch release bearing look like?
- Differential Service
- Issue with my HID's
- Which One of These Wires Operates the Starter Solenoid?
- Winshield Wipers not Working - Help with Wiring For Wiper motor testing
- Hayne Vs Chilton
- Lighting
- Dear Chinese power steering pump maker: Go burn in hell.
- Anyone else have an injector go bad?
- :: ECS Tuning :: B5 A4/S4 Schwaben Floor Mats!!
- 1st Service as Audi Owner
- Running Rich
- 1997 2.8 12v water pump.
- Car wont start after replacing head gasket
- Having trouble cleaning your wheels? Not anymore - Wheel Woolies are here
- Gasket Diy
- Looking for OE Sport Springs for my '98 1.8T Quattro
- ~~~ Car Lost 90% of Power while driving! - Help...
- Help can anyone identify this fuse?
- Will my fender from 99.5 fit 98? please need help fast.
- 1.8t turbo boost issue
- Gearbox oil in coolant
- 2.8 AHA rear coolant pipe leak
- Coolant Leak from the tank
- considering a 2000 A4 1.8t avant wagon, but not sure
- PureMS - KONI Coilovers on Sale!
- brake master cylinder rebuild?
- 1999 2.8 timing belt change instructions
- Handling, looks and quality. The H&R A4 Catalog, from AWE Tuning
- 2000 A4 conversion?Need Suggestions
- 00 1.8T stalls occasionally on acceleration??
- 1999 A4 auto not shifting correctly?
- HELPPPPPP. Oil Pressure
- So push-starting a car...
- A4 Ownership Data
- B5 seat guide repair kit (201 A4)
- Central Locking Issue
- Q about oil pump & pan sealant
- Android Pandora double-din head units?
- ABS code 1203 after cluster center display rebuild
- Coolant Pipe
- Bad battery, bad alternator or bad luck?
- Fuel Filter, P0441, P0455, Etc
- Rough idle, cracked hose/pump
- miss fire cylinder 2
- Back window stuck down and air bag light on
- The BBS A4 Catalog, from AWE Tuning
- audi a4 b5 1.8l x 20 v --- work on cylinder head pics
- audi a4 b5 1.8 Head cylinder rebuilding still in process
- Cluster gauge needles not moving and cruise stopped working, etc
- The original answer to Drivetrain slop, from AWE Tuning
- power questions
- 98 A4 v6 - AC Quit
- Operation "New AC Compressor" is a success...
- HID Xenon Headlights
- handbrake light flashing on b5 audi 1.8T
- Chipped ecu question
- New starter grinding flywheel?
- '98 A4 B5 K03 - Wastegate and Central Locking(?)
- 2000 A4 1.8T Parasitic Drain, New Battery, 2.7 amps
- Waterfest 18 Special Starts Now - Get your detailing gear before the big day!
- Timing belt, VCG, and PCV hose jobs coming up - need tool help
- Installed new electric radiator cooling fan
- Help removing Climatronic?
- P0103, P1141, P1857 and stuck in limp mode
- Front end is sitting low. Help please.
- Corners, be afraid: The Bilstein Catalog, from AWE Tuning
- motor flush
- car alarm issues
- No power steering
- HELP!!! Airbag removal passenger side.
- computer problem??
- a6 springs on B5 a4 - for posterity's sake
- '96 A4 2.8 problem
- :: ECS Tuning :: B5 A4 1.8T APR Sale!!
- Coolant flange leak?
- Smoke in cabin
- ST Coilovers adjusting?
- 1999 2.8 transmission just failed
- Boost Loss / Turbo Flutter
- Who wants to swap their gray headliner and associated parts for a black S4 one???
- Coolant leak towards back of passenger side
- audi a4 b5 wont start up ?
- Please help identifying this plastic tube. 2001 2.8 30v quattro
- speedo/tach issues
- 2000 Audi A4 Quattro Solenoid replacement?
- Engine Hard to Start after Refueling
- 98 A4, No Compressor Cycling, No Blower Motor?
- My first Audi - An ongoing project
- A/C Leak Questioning the size of O-ring
- .:Eurocode Tuning:. APR Summer Sale!!! July 1st thru Aug 3th
- Cylinder #3
- Stolen 1M CCTV
- oil problems, need help 500mi per qt
- Antenna Booster Module
- New to Audi's lotsa Q's!!
- 1999 A4 2.8 tranny problem
- July 4th Special @ Detailer's Domain
- be riped off on leather interior
- 1998 Automatic transmission hard shifting
- What should i look for?
- Need help identifying this hose
- Engine cut out - now won't start????
- Rear right side door latch problem
- Audi A4 1996 Window Regulator Clip Replacement
- Head gasket?
- Hard cold start - Already changed coolant sensor... no difference. Help a new member?
- Weird p0411 issue... components work, but pump wont turn on in morning. Help a new gu
- :: ECS Tuning :: B5 A4 Manual Transmission Service Kits!!
- Problem when testing panel jaeger
- B5 s4 side skirts
- Audi a4 b5 1.8l 2.0v please help
- New Sponsor Introduction
- wtb polydrive head bolt tool in las Vegas
- 98 A4 2.8 Avant - 5.3 ABS Module or speed sensor?
- 99 audi a4 2.8 p1626 check engine light advice please
- Exhaust size? - 2001 1.8t
- 98 A4 1.8t misfire cyl 2, coil is good ????
- good vacuum port on the 2.8
- Turn signals,wipers and climate control not working c...help
- Im looking for a serpertine belt diagram
- 2.8 Exhaust Question
- My old '96 12V pulled 30 MPG
- The South Bend Silent Design catalog, by AWE Tuning.
- My center console, 2000 Black interior
- Electric fan,was noisy,running whole time,
- The benefits of stability, from AWE Tuning
- AC help PLZ its hot as hell out!!
- California Car! Cat Replacement / Smog Advice
- Aftermarket exhaust
- 2.8 Avant chiming and temp issue
- NIB 2.8 audi flywheel for sale
- What's Shokan's reputation?
- :: ECS Tuning :: B5 A4 1.8T Carbon Engine Covers!!
- Part # needed not in ETKA
- Doing TB on 1.8 for first time
- Further proof you need the tools to set timing.
- 97 audi a4 auto delaware for sale 800
- Changed Accessory Belts , now chirping
- Electrical Issues
- 00 1.8 massive oil consumption, rings or valve seals
- :: ECS Tuning :: B5 A4 1.8T MANN Filters!!
- Wheel bearing replacement
- 99 won't crank, ignition inhibitor switch?
- Lower rear control arm & E brake cable
- 99' Preventive maintenance
- 97 A4 no spark
- Misfire at full throttle?
- Problems starting 1996 A4 2.6
- AC problems
- A4 2.8 Idle 500-550 rpm, stalling, exhaust smell
- These are the brakes: The Stoptech B5 A4 Catalogue from AWE Tuning.
- audi a4 2.8 p1626 p1392 check engine codes
- how do you test the fuel pressure regulator
- Headlight/high beam wiring
- idle at 1400rpm
- car won't start wtf !
- Invalid VIN?
- Strange Problem...PLEASE HELP ME
- How Screwed Am I?
- Coil Pack connectors
- New audi owner need help
- What hose is this? (pic)
- Missfire :(
- 98 A4 1.8t B5 - Won't start, Can't pull codes, No communication
- Yes, Yes you can use different trans codes
- 98 a4 quattro
- air bag light after new battery
- Control arms
- Climate Control buttons not working
- somewhat-loud turbo hissing with clutch engaged
- 1999 A4 Sline Lower exterior door trim
- Climatronic weird noise?
- My $300 '00 Audi A4 1.8t
- White smoke comi out of exhast ???ng
- need help clearing code
- Expansion tank leak problems?
- Buy 4 Get 2 Free - Sonax Full Effect Wheel Cleaner!
- v6 tdi violent vibration after long load
- lower control arm bolt
- Black plastic lower door trim peeling off. 1997 A4
- 1997 Audi A4 Tranny Question
- Please help tcu ??
- Gurgling coming from coolant lines
- any one has dropped the oil pan before? need help please....
- Misfires on cyl 3 - 1.8T AEB
- Help w/ Replacement bulb for aftermarket Hella HID Xenon Kit? W/ Pics!!
- 2000 A4 Quattro 1.8T Gas Smell / Starting Problems
- 1999.5 body panels Compatibility
- Help with B5 A4 1.8t Quattro DTC
- 1999 can't work a/c
- Wheel bearing, static sound?
- Help finding part number, pic attached
- External FM radio antenna advice?
- 1996 AC not working
- 1996 Remote for door locks
- 00792 AC pressure switch F129
- :: ECS Tuning :: B5 A4 GEOMET OE Big Brake Kits!!
- Knocking noise and oil burning smell .... Display on screen beeping but I can't see..
- The Bilstein Suspension Catalog, from AWE Tuning
- do all parts or one
- Roaming idle only while moving???
- What is the best air filter for B5 1.8T?
- Quality Seat Cover?
- Changed my mind about 12V timing belt tension
- Changing Drivetrain Fluids
- brake problems
- 2001 1.8t Gas milage problem
- Need help with Cam sensor
- timing belt adjustment
- bleeding the hydraulic throw out bearing?
- Possibly coming back to the family via a new (to me) B5 A4 2.8 - some questions
- quick question about the radiator fan
- The BBS Catalog, from AWE Tuning
- possibly stupid driveshaft/transmission question
- Fuel Filter Replacement on Jack Stands
- Going to pull a trans., what tools? (slightly urgent)
- central locking pump leaking ?
- Wouldn't start - til I removed the gas cap
- Throttle body very dirty...
- Large evap lines... cut/missing?
- Frankenturbo?
- Finally getting to the A4 trans, questions
- 2000 Audi A4 2.8 V6 Questions
- Part throttle stumble.. Baffled...
- GIAC chip swap
- Any good diagnostic tools for audi a4?
- Just got her back from an overhaul . . .
- Avant rear door on a saloon
- clutch slave question
- Tiptronic clunking and banging
- Won't turn over after sitting for 6 weeks
- 2000 Audi Q4 2.8 V6 Questions
- Lowest dust front pads?
- Click when I push the brakes(just replace rf axel)
- Quattro with issues
- :: ECS Tuning :: B5 A4 1.8T Crankcase Breather Hose Refresh Kits!!
- B5 rear diff tail piece seal change
- Clicking/rattling/knocking noise when clutch is pushed down
- Audi A4 B5 signal relay
- :: ECS Tuning :: B5 Lower Door Moldings - Back In Stock!!
- what to also do while servicing timing belt
- VCDS won't has error while trying to do TBA..
